# CGI Studio Community Edition
This books provides an overview of the Community Edition and highlights the differences between the CGI Studio Editions.
# Overview
The **Community Edition** is our newly introduced and freely available Candera CGI Studio version for makers, enthusiasts and curious developers. The package includes the same set of features as our Professional Edition (see <span style="color:rgb(230,126,35);">[here](https://doc3161en.candera.eu/books/cgi-studio-editions/page/candera-cgi-studio-editions-comparison-table)),</span> but does not require a license for Scene Composer.
This edition is for private usage only and cannot be used for commercial purposes. Via registration at our <span style="color:rgb(230,126,35);">[Community Forum](https://community.candera.eu/)</span>, each user has access to three free target licenses, enabling the usage of up to three target devices without restrictions (no watermark, no runtime limitation).
The Community Edition was introduced with CGI Studio Version 3.16 and will be maintained along with our other CGI Studio versions.
For details about the CGI Studio versions, go to this page: <span style="color:rgb(230,126,35);">[CGI Studio Editions](https://doc3161en.candera.eu/books/cgi-studio-editions)</span>
This edition initially supports Raspberry Pi 4 and 5 only. Further hardware support will be added in later releases.
<p class="callout info">Some of the bundled samples are designed for the Enterprise Edition of CGI Studio and contain a not compatible data binding definition. In that case the sample would not run on the target. Please have a look at the Pollen Infoscreen sample, as it is specifically designed for the Community Edition.</p>
# How to obtain your License?
To run your solutions as assets on hardware, a valid **hardware license** is required. Without this license, system limitations such as watermarks and runtime restrictions will apply.
Before activating your hardware, ensure that the system is correctly set up according to the <span style="color:rgb(230,126,35);">[**Target Setup Guide**](https://doc3161en.candera.eu/books/target-setup-for-community-edition-raspberry-pi/page/target-setup-and-first-steps)</span>, up to the section **“Activate License”**.
**Steps to Obtain Your License File:**
- Visit the [<span style="color:rgb(230,126,35);">Candera Community Forum</span>](https://community.candera.eu/).
- Sign up to the Candera Community Forum. You will receive a system notification granting access to **three license vouchers**.
    <div drawio-diagram="9134"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-08/drawing-7-1785739964.png" alt="drawing-7-1785739964.png"/></div>
- Open the notification. It will contain the following message:
    <div drawio-diagram="9167"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-08/drawing-7-1786689590.png" alt="drawing-7-1786689590.png"/></div>
- Before obtaining your license, you must retrieve the **Device ID** of your RaspberryPi device. Ensure that the <span style="color:rgb(230,126,35);">[Candera Debian package](https://doc3161en.candera.eu/link/1405#bkmrk-install-deb-package-)</span> is installed on the device before performing this step.
    /opt/candera/bin/Player
     You should see the the Device ID in the console log: <div drawio-diagram="9136"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-08/drawing-7-1785740020.png" alt="drawing-7-1785740020.png"/></div>
- For a voucher, select the corresponding activation link (e.g., **“Activate target device with Voucher 1”**).
    You will be redirected to the activation page.
    <div drawio-diagram="9137"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-08/drawing-7-1785740043.png" alt="drawing-7-1785740043.png"/></div>
- After submitting the Device ID and completing the voucher activation process, you will receive an email containing your **hardware license file (.lic)**.
- Copy the license file to the same directory as the Player on the target device.
    /opt/candera/bin/License.lic
    <p class="callout info">Moving the license file to a different location prevents the license from being activated on the target.
    If the license file is not named **License.lic**, please rename it. CGI Studio is now activated on your target device.</p>
    <p class="callout warning">If you don't have permission to copy the license file, grant it by running *sudo chmod* 777 */opt/candera/bin* on the device.</p>
Please continue with our <span style="color:rgb(230,126,35);">[Target Setup Guide](https://doc3161en.candera.eu/link/1405#bkmrk-page-title)</span> to run your first assets on the target and familiarize yourself with CGI Studio.
# Python-based Data Binding
The Player Connector Library is a simple library written in Python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (<span style="color:rgb(230,126,35);">[Variant](http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_variant.html)</span>) through Python scripting.
### Player Connector Library Package
The main functionality of the library is contained in two files, **`CanderaAppConnector.py`** <sup>\[1\]</sup> and `<strong>BindingSourceEnum.py</strong>` <sup>\[2\]</sup>. These files contain three classes.
- `CanderaAppConnector`: This is the main class to be used to play assets and interact with them using data binding
- `BindingSourceEnum`: A Python enum generated by the build pipeline that contains the enum keys to be used when setting and getting data binding items. The keys underlay the nomenclature "SOURCE&lt;*sourceIndex&gt;*ITEM&lt;i*temIndex&gt;"*. Source - and item index start at one and go to ten, as we currently have ten predefined binding sources and ten items per source.
- `Logger`: Logger class that my be used to generate logs with compliant format and logging levels
The sources and types listed above are contained in a file system Python package that can be installed with pip.
```bash
<p class="callout info">It is suggested to install the library to a virtual environment and not to the global Python installation. For an exemplary usage refer to the <span style="color:rgb(230,126,35);">[Blood Pressure Sample](https://doc3161en.candera.eu/books/cgi-studio-community-edition/page/blood-pressure-sample "Blood Pressure Sample")</span> documentation and source code.</p>
\[1\]: */bin/CommunityEdition/Python/CanderaAppConnector/CanderaAppConnector.py*
\[2\]: */bin/CommunityEdition/Python/Generated/BindingSourceEnum.py*
#### Workflow
1. Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
2. Initializing the library with the asset binary
3. Optionally register data binding callbacks
4. Continuously calling step to invoke the render loop and internal message delivery
5. Interact with data bindings. Note that internally, changes to the data bindings are reflected on the view when step is called
6. Shutdown library and gracefully exit program
#### Documentation
#### Constructor
<table id="bkmrk-parameters-binarypat" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
1. `<strong>BinaryLibraryPath</strong>`: Absolute or relative path to the Player Connector Library binary
</td></tr></tbody></table>
#### Init
Initializes the player with the provided asset path. Expects an absolute or relative path to the asset binary as parameter. Must be called before every other method. Returns a bool value whether the operation was successful.
<table id="bkmrk-parameters-assetpath" style="border-collapse:collapse;width:100%;height:99.8281px;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr style="height:70.0312px;"><td style="height:70.0312px;">Parameters</td><td style="height:70.0312px;">
1. `<strong>AssetPath</strong>`: Absolute or relative path to the asset binary
</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Returns</td><td style="height:29.7969px;">The bool value</td></tr></tbody></table>
#### Step
Invokes the internal message processing and render loop execution. Needs to be called continuously. Databinding updates are reflected internally during the invocation of this method. Returns a bool value whether the operation was successful.
<table id="bkmrk-parameters-none-retu" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>None</td></tr><tr><td>Returns</td><td>The bool value</td></tr></tbody></table>
#### SetIntValue
<table id="bkmrk-parameters-bindingso" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
1. `<strong>BindingSourceItem</strong>`: Enum that specifies the binding source item. Enum is defined in *Generated/BindingSourceEnum.py*
2. `<strong>Value</strong>`: The integer value
#### SetBoolValue
<table id="bkmrk-parameters-bindingso-1" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
2. `<strong>Value</strong>`: The bool value
#### SetStringValue
<table id="bkmrk-parameters-bindingso-2" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
2. `<strong>Value</strong>`: The string
#### SetFloatValue
<table id="bkmrk-parameters-bindingso-3" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
2. `<strong>Value</strong>`: The float value
#### GetIntValue
<table id="bkmrk-parameters-bindingso-4" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
</td></tr><tr><td>Returns</td><td>The integer value</td></tr></tbody></table>
#### GetBoolValue
<table id="bkmrk-parameters-bindingso-5" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
#### GetStringValue
<table id="bkmrk-parameters-bindingso-6" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
</td></tr><tr><td>Returns</td><td>The string</td></tr></tbody></table>
#### GetFloatValue
<table id="bkmrk-parameters-bindingso-7" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
</td></tr><tr><td>Returns</td><td>The float value</td></tr></tbody></table>
#### RegisterCallback
<table id="bkmrk-parameters-callbackf" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>
1. **`CallbackFn`**: Callable type with two parameters
#### ShutDown
<table id="bkmrk-parameters-none-retu-1" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:50%;"></col><col style="width:50%;"></col></colgroup><tbody><tr><td>Parameters</td><td>None</td></tr><tr><td>Returns</td><td>The bool value</td></tr></tbody></table>
# Predefined Data Bindings
The CGI Studio Community Edition comes with a predefined set of data bindings. This set consists of ten data binding sources with ten data binding items each. They are all of type <span style="color:rgb(230,126,35);">[FeatStd::Variant](http://dev.doc.cgistudio.at/APILINK/class_feat_std_1_1_variant.html)</span> and can be bound to any bindable property in the scene composer with <span style="color:rgb(230,126,35);">[standard data binding](https://doc3161en.candera.eu/link/1178#bkmrk-3.-scene-composer-%E3%81%AB%E3%82%88)</span>. The data binding sources are prefixed with *PredefinedBindingSource*\[n\] and the items of each source is prefixed with *Item*\[n\].
To select and use the predefined set of data bindings follow the steps in the image below
1. Click on the chain icon near a bindable property in the properties panel.
2. Select a predefined binding item from the list in the modal window that follows the nomenclature described above.
<div drawio-diagram="9166"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-08/drawing-4-1786585455.png" alt="drawing-7-1732183644.png"/></div>
There are two methods how to set values to the binding items and observe changes in the player.
- During solution development in the Scene Composer, values can be set and simulated through the player panel, as described <span style="color:rgb(230,126,35);">[here](https://doc3161en.candera.eu/books/player/page/data-bindings)</span>.
- By exporting the solution as asset and setting the values with the Player Connector Library, as described <span style="color:rgb(230,126,35);">[here](https://doc3161en.candera.eu/books/cgi-studio-community-edition/page/python-based-data-binding)</span>.
# Blood Pressure Sample
The blood pressure device sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations. For the Community Edition, the sample was extended with a voice activation feature and a data binding sample programmed in Python. The Python part of the sample relies on the <span style="color:rgb(230,126,35);">[Python-Based Player Data Binding Library](https://doc3161en.candera.eu/books/cgi-studio-community-edition/page/python-based-data-binding "Python-Based Player Data Binding Library")</span> to interact with the data bindings of the scene.
General information on this sample can be found in the <span style="color:rgb(230,126,35);">[Blood Pressure Solution](https://doc3161en.candera.eu/books/sample-solutions/page/blood-pressure-solution "Blood Pressure Sample")</span> documentation. This book goes over the sample Python extension, namely the voice activation feature and the integrated data binding.
*\\bin\\CommunityEdition\\Python\\Samples\\BloodPressureDevice*.
<p class="callout warning">The voice activation feature only works if the sample is started from Python using the Player Connector Library with the provided Python sample program. The feature doesn't work if the sample is started from the scene composer or directly with the player. Also, for enterprise edition users, if the Player Connector Library binary is built from source, it must be built with CMake flag `CGIAPP_SAMPLE_SOUNDHOUND_ENABLED` set to `ON`. </p>
#### Python Environment Setup
To play the sample, a minimal Python setup is required. Verify that Python 3.x is installed on the system and either the `py` or the `python` command is on the path. Afterwards, create a virtual environment like below.
1. Navigate to *\\bin\\CommunityEdition\\Python\\Samples\\BloodPressureDevice*
    `py -m venv .`
    `.\Scripts\activate`
4. Install the dependencies from `requirements.txt` with
    `pip install -r .\requirements.txt`
<p class="callout info">The `CanderaAppConnector` and other required types are an installable Python package under \\*bin\\Player\\PlayerConnector*. Although, the package is listed in `requirements.txt` and installed by default. For more information refer to the <span style="color:rgb(230,126,35);">[Python-based Data Binding](https://doc3161en.candera.eu/books/cgi-studio-community-edition/page/python-based-data-binding "Python-based Data Binding")</span> documentation.</p>
#### Soundhound API Setup
The voice to text/command transcription is realized with Soundhound. To use the Soundhound Api in the blood pressure sample, a free account must be created under <span style="color:rgb(230,126,35);">[https://www.houndify.com/login](https://www.houndify.com/login)</span>. Afterwards, a new client must created in the dashboard. In this client, all domains may be deactivated, apart from the "Stored Page Match" domain.
<p class="callout info">As custom commands on Soundhound are only available in English language, the voice activation feature only support English language.</p>
<div drawio-diagram="7463"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064699.png" alt="drawing-7-1732064699.png"/></div>
Now, a new custom can be created by navigating to the section "Custom Commands" in the menu on the left side. Enable the custom commands and click "New Page". After entering an arbitrary name for the command like "BloodPressureDevice", a modal window for configuring the command, opens. In the "Expression" input field enter the string
```bash
```bash
   "action": "Start_BPD"
like in the image below.
<div drawio-diagram="7464"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064740.png" alt="drawing-7-1732064740.png"/></div>
<div drawio-diagram="7465"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064771.png" alt="drawing-7-1732064771.png"/></div>
The Soundhound service is now configured and the client credentials must be copied to the Python source files. Navigate to "Overview &amp; API Key" and copy the credentials to the corresponding fields in the Python source file under:
*\\bin\\Player\\PlayerConnector\\Samples\\BloodPressureDevice\\SoundhoundCommandClient.py*
<div drawio-diagram="7466"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064793.png" alt="drawing-7-1732064793.png"/></div>
**Note**: The field \_\_SOUNDHOUND\_REQUEST\_USER may be an arbitrary string value
#### Creating and running the asset
The sample can be started by executing the python blood pressure device sample program (*\\bin\\CommunityEdition\\Python\\Samples\\BloodPressureDevice\\BloodPressureDevice.py*) with the Python interpreter of the virtual environment. Note that the Python interpreter of the virtual environment is automatically used when the environment is activated. If the environment is activated, the terminal should have "`(BloodPressureDevice)`" written near the command input area.
```python
- "-lbp" is the path to the Player Connector Library binary. Either under \\*bin\\CommunityEdition\\&lt;device&gt;\_Simulation\\PlayerConnector\\PlayerConnectorLibrary\*.dll* or where it was built
- "-abp" is the path to the asset binary
#### Blood Pressure Device Sample
When the sample starts, it plays an intro animation and activates the menu scene. The menu scene is active until an according voice command like "Start",  "Start measurement", "Start blood pressure device", ...  was recorded. A live transcription of the voice input is displayed in the menu scene.
<div drawio-diagram="7467"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064816.png" alt="drawing-7-1732064816.png"/></div>
<div drawio-diagram="7468"><img src="https://doc316en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732064853.png" alt="drawing-7-1732064853.png"/></div>
# Target Setup Guide
Please refer to below for setup guides for each target device supported by CGI Studio Community Edition.
- ⁠⁠**<span style="color:rgb(230,126,35);">[Raspberry Pi](https://doc3161en.candera.eu/books/target-setup-for-community-edition-raspberry-pi "http://cgi1316en.candera.eu/books/target-setup-for-rpi5")</span>**
