# Build Projects
Build-Projects contain so called builds which help to automate the process of generating code and/or building the application. They allow to specify a series of script files which are to be executed and provide arguments which can be configured by the user.
# XML Definition
Builds are defined in an XML Schema file which is located at “cgi\_studio\_connector/schema/BuildProject.xsd”. This file can be used to validate xml files and with some editors (e.g. Visual-Studio) and provide code-completion when writing the XML file.
#### BuildProject-Element
Root Element. Contains list of Root-Paths, global Variables and Builds.
**Attributes:**
<table border="1" id="bkmrk-property-name-descri-7" style="border-collapse: collapse; width: 78.0247%;"><colgroup><col style="width: 20.4442%;"></col><col style="width: 14.4364%;"></col><col style="width: 65.2803%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**version**</td><td class="align-left">Yes</td><td>Version of the Build-Project file.</td></tr></tbody></table>
**Children:**
<table border="1" id="bkmrk-argument-occurrence-" style="border-collapse: collapse; width: 78.0247%;"><colgroup><col style="width: 20.0947%;"></col><col style="width: 23.2345%;"></col><col style="width: 56.6733%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Occurrence**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**RootPaths**</td><td class="align-left">1</td><td>List of Root-Paths</td></tr><tr><td>**Variables**</td><td class="align-left">1</td><td>List of global Variables. These Variables can be used in any Build.</td></tr><tr><td>**Builds**</td><td class="align-left">1</td><td>List of Builds</td></tr></tbody></table>
#### RootPaths-Element
Defines a list of Root-Paths.
**Attributes:**
None
**Children:**
<table border="1" id="bkmrk-argument-occurrence--1" style="border-collapse: collapse; width: 78.0247%;"><colgroup><col style="width: 20.4087%;"></col><col style="width: 23.5485%;"></col><col style="width: 56.0453%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Occurrence**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**RootPath**</td><td class="align-left">0 - \*</td><td>Root-Path</td></tr></tbody></table>
#### Variables-Element
Defines a list of Variables.
**Attributes:**
None
**Children:**
<table border="1" id="bkmrk-argument-occurrence--2" style="border-collapse: collapse; width: 78.0247%;"><colgroup><col style="width: 20.0947%;"></col><col style="width: 23.8624%;"></col><col style="width: 56.0453%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Occurrence**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**Variable**</td><td class="align-left">0 - \*</td><td>Variable</td></tr></tbody></table>
#### Builds-Element
Defines a list of Builds.
**Attributes:**
None
**Children:**
<table border="1" id="bkmrk-argument-occurrence--3" style="border-collapse: collapse; width: 77.7778%;"><colgroup><col style="width: 20.3498%;"></col><col style="width: 23.9973%;"></col><col style="width: 55.653%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Occurrence**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**Build**</td><td class="align-left">0 - \*</td><td>Build</td></tr></tbody></table>
#### RootPath-Element
Defines a Root-Path. Root-Paths can be referenced by variables to make them relative to a common path.
**Attributes:**
<table border="1" id="bkmrk-argument-required-de" style="border-collapse: collapse; width: 78.1481%;"><colgroup><col style="width: 20.4114%;"></col><col style="width: 14.4072%;"></col><col style="width: 65.1814%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**name**</td><td class="align-left">Yes</td><td>Name of the Root-Path.</td></tr><tr><td>**description**</td><td class="align-left">No</td><td>Description of the argument.</td></tr></tbody></table>
**Children:** None
#### Variable-Element
A variable for the build which will be applied for all executed scripts.
**Attributes:**
<table border="1" id="bkmrk-argument-required-de-1" style="border-collapse: collapse; width: 78.0247%; height: 255.578px;"><colgroup><col style="width: 20.4442%;"></col><col style="width: 14.2616%;"></col><col style="width: 65.2966%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 44.7969px;"><td style="height: 44.7969px;">**name**</td><td class="align-left" style="height: 44.7969px;">Yes</td><td style="height: 44.7969px;">Name of the variable.</td></tr><tr style="height: 44.7969px;"><td style="height: 44.7969px;">**type**</td><td class="align-left" style="height: 44.7969px;">Yes</td><td style="height: 44.7969px;">Type of the variable. Valid values are ‘Value’, ‘Option’, ‘Path’ and ‘File’</td></tr><tr style="height: 46.5938px;"><td style="height: 46.5938px;">**root\_path\_key**</td><td class="align-left" style="height: 46.5938px;">No</td><td style="height: 46.5938px;">If set, paths (or files) will be relative to the given Root-Path.</td></tr><tr style="height: 44.7969px;"><td style="height: 44.7969px;">**value**</td><td class="align-left" style="height: 44.7969px;">Yes</td><td style="height: 44.7969px;">Value of the variable.
If the type is ‘Option’, valid values can be specified as a list of values separated by semicolons. If left blank, any value is considered valid.
</td></tr><tr style="height: 44.7969px;"><td style="height: 44.7969px;">**description**</td><td class="align-left" style="height: 44.7969px;">Yes</td><td style="height: 44.7969px;">Description of the variable.</td></tr></tbody></table>
**Children:**
None
#### Build-Element
A build which can be executed.
**Attributes:**
<table border="1" id="bkmrk-argument-required-de-2" style="border-collapse: collapse; width: 78.0247%; height: 175.781px;"><colgroup><col style="width: 20.4087%;"></col><col style="width: 13.1871%;"></col><col style="width: 66.4067%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**name**</td><td class="align-left" style="height: 29.7969px;">Yes</td><td style="height: 29.7969px;">Name of the build.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**description**</td><td class="align-left" style="height: 29.7969px;">Yes</td><td style="height: 29.7969px;">Description of the build.</td></tr></tbody></table>
**Children:**
<table border="1" id="bkmrk-argument-occurrence--4" style="border-collapse: collapse; width: 82.3457%;"><colgroup><col style="width: 20.4204%;"></col><col style="width: 16.519%;"></col><col style="width: 63.0606%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Occurrence**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**ScriptPath**</td><td class="align-left">1</td><td>Path to the script files which should be executed for this build.</td></tr><tr><td>**OutputPath**</td><td class="align-left">1</td><td>Output-Path for this build.</td></tr><tr><td>**Variable**</td><td class="align-left">0 - \*</td><td>Variable for this build</td></tr></tbody></table>
#### ScriptPath-Element
Path to the script files which are executed when this build is started. The script files should start with a number to indicate their execution order.
**Attributes:**
<table border="1" id="bkmrk-argument-required-de-3" style="border-collapse: collapse; width: 77.7778%; height: 175.781px;"><colgroup><col style="width: 20.4087%;"></col><col style="width: 13.1871%;"></col><col style="width: 66.4067%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**value**</td><td class="align-left" style="height: 29.7969px;">Yes</td><td style="height: 29.7969px;">Relative path.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**root\_path**</td><td class="align-left" style="height: 29.7969px;">No</td><td style="height: 29.7969px;">If set, path will be relative to the given Root-Path.</td></tr></tbody></table>
**Children:**
None
#### OutputPath-Element
Main output path for this build. Even if the build doesn’t produce any artifacts or generates output into other directories, at least the log file will be saved here.
**Attributes:**
<table border="1" id="bkmrk-argument-required-de-4" style="border-collapse: collapse; width: 77.9012%; height: 175.781px;"><colgroup><col style="width: 20.4762%;"></col><col style="width: 14.284%;"></col><col style="width: 65.2399%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Argument**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Required**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**value**</td><td class="align-left" style="height: 29.7969px;">Yes</td><td style="height: 29.7969px;">Relative path.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**root\_path**</td><td class="align-left" style="height: 29.7969px;">No</td><td style="height: 29.7969px;">If set, path will be relative to the given Root-Path.</td></tr></tbody></table>
**Children:**
None
# Sample
<span lang="EN-US">Below a sample XML file can be seen</span>
<span lang="EN-US"> </span>
<table cellpadding="0" cellspacing="0" id="bkmrk-%3C%3Fxml-version%3D%221.0%22%3F" width="100%"><tbody><tr><td><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&lt;?</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">xml</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">version</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">1.0</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">?&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">BuildProject</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">xsi:noNamespaceSchemaLocation</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">../../tools/ConnectorApp/Build/Schema/BuildProject.xsd</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">                          </span></span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">xmlns:xsi</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">http://www.w3.org/2001/XMLSchema-instance</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">                          </span></span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">version</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">1</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">RootPaths</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">RootPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CONNECTOR\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Path to CGI Connector executable.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">RootPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">PROJECT\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Path to CGI Connector project file.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">RootPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CGI\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Path to CGI root folder</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;/</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">RootPaths</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variables</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">INTERFACE\_GENERATOR\_OUTPUT\_PATH</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">src/Interface</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">root\_path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">PROJECT\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Path for generated output files.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">INTERFACE\_NAMESPACE</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Application::Interface</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Namespace for generated Interface.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">INTERFACE\_DATAMODEL\_INCLUDE</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Model/!DATAMODEL\_CLASSNAME!.h</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Include for Data-Model.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;"> </span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">BUILD\_CGISTUDIO\_PLATFORM</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">!CONNECTOR\_CGISTUDIO\_PLATFORM!</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CGI-Studio Platform/Device.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">BUILD\_CGISTUDIO\_PLATFORM\_CONFIG</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">!CONNECTOR\_CGISTUDIO\_PLATFORM\_CONFIG!</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CGI-Studio Platform/Device configuration.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;/</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variables</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Builds</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Build</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Generate Code</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Generates only code</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">ScriptPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">../BuildScripts/GenerateCode</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">root\_path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CONNECTOR\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">OutputPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">""</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">root\_path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">PROJECT\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">/&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;/</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Build</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">        </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Build</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Generate and Build (Simulation)</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Generates code and builds the application.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">ScriptPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">../BuildScripts/BuildApplication</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">root\_path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">CONNECTOR\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">OutputPath</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">build</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">root\_path</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">PROJECT\_ROOT</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">/&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">BUILD\_TARGET</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Application</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Build target</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">BUILD\_CONFIGURATION</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Option</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Release;Debug</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Build configuration/&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">            </span>&lt;</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Variable</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">name</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">BUILD\_CMAKE\_CUSTOM\_FLAGS</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">type</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">value</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">-DCOURIER\_ADD\_SCHOST\_PROJECT=1 -DAPPLICATION\_IPC\_ENABLED -DAPPLICATION\_IPC\_INTERFACE\_ENABLED -DAPPLICATION\_CONNECTOR\_SIMULATION=1</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> </span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: red;">description</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">=</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">Additional CMake flags.</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: black;">"</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"> /&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;"><span style="mso-spacerun: yes;">    </span>&lt;/</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">Builds</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
<span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&lt;/</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: #a31515;">BuildProject</span><span lang="EN-US" style="font-size: 7.0pt; font-family: 'Cascadia Mono'; mso-bidi-font-family: 'Cascadia Mono'; color: blue;">&gt;</span>
# Editor
<span lang="EN-US">An editor for the Build-Projects definition can be found here:
“</span><span class="DescriptionChar"><span lang="EN-US">cgi\_studio\_connector/bin/BuildProjectEditor.exe</span></span><span lang="EN-US">”</span>
<span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">If called with a file as first argument the editor will try to open the specified file.</span>
#### Global
<div drawio-diagram="6958"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-10/drawing-7-1728344045.png" alt=""/></div>
**Root-Paths**
Root-Paths allow the user to make path/file variables relative to a specified path. When a build is started these Root-paths must be set by the user beforehand.
They can be added and removed via the respective buttons on the right of the group.
<div drawio-diagram="8312"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614347.png" alt=""/></div>
**Properties:**
<table border="1" id="bkmrk-property-name-descri-7" style="border-collapse: collapse; width: 87.284%;"><colgroup><col style="width: 17.806%;"></col><col style="width: 82.194%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Property Name**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**Name**</td><td>Name of the Root-Path</td></tr><tr><td>**Description**</td><td>Description of the Root-Path.</td></tr></tbody></table>
**Variables**
<div drawio-diagram="8313"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614384.png" alt=""/></div>
**Propertise:**
<table border="1" id="bkmrk-property-name-descri" style="border-collapse: collapse; width: 87.284%;"><colgroup><col style="width: 17.9365%;"></col><col style="width: 82.0635%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Property Name**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**Name**</td><td>Name of the Variable. This is the same name that is to be used in the scripts.</td></tr><tr><td>**Description**</td><td>Description of the Variable.</td></tr><tr><td>**Type**</td><td>Type of the Variable. The following options are available:
\- Value: Simple value type
\- Option: Value that must be set at run time.
\- Path: A path (folder)
\- File: Full file path
</td></tr><tr><td>**Root-Path**</td><td>If the variable type is Path or File, this is used to reference a specified Root-Path. Doing so will treat the path as a relative path.</td></tr><tr><td>**Value**</td><td>Value of the variable. In case of ‘Option’ type values, the valid choices can be restricted by defining multiple values separated with a semicolon.</td></tr></tbody></table>
If the type is set to ‘Option’ the ‘Option Editor’ can be opened by clicking on the ‘…’ button next to the Value field.
<div drawio-diagram="8314"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614486.png" alt=""/></div>
In the Option Editor window individual options can be easily added and removed using the ‘plus’ and ‘minus’ buttons on the right side.
<div drawio-diagram="8324"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744704010.png" alt=""/></div>
#### Builds
<div drawio-diagram="6961"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-10/drawing-7-1728344180.png" alt=""/></div>
**<span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Properties</span>**
<div drawio-diagram="8316"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614568.png" alt=""/></div>
<table border="1" id="bkmrk-property-name-descri-1" style="border-collapse: collapse; width: 87.9012%;"><colgroup><col style="width: 18.0939%;"></col><col style="width: 81.9061%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Property Name**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr><td>**Name**</td><td>Name of the build.</td></tr><tr><td>**Description**</td><td>Description of the build.</td></tr><tr><td>**Script Path**</td><td>Path to the script file which should be executed for this build. All scripts (.bat/.cmd) inside the specified folder are executed in alphabetical order so it is recommended to begin the filename with the number of the execution step.
**(Script Path)**
</td><td>Root-Path of the Script Path.</td></tr><tr><td>**Output Path**</td><td>Main output path for this build. Even if the build doesn’t produce any artifacts or generates output in other directories, at least the log file will be saved here.</td></tr><tr><td>**Root-Path**
**(Output Path)**
</td><td>Root-Path of the Output Path.</td></tr></tbody></table>
**Variables**
<span lang="EN-US">Variables for this build can be set here.</span>
<span lang="EN-US">They can be added and removed via the respective buttons on the right of the group.</span>
<div drawio-diagram="8317"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614619.png" alt=""/></div>
**Properties:**
<table border="1" id="bkmrk-property-name-descri-2" style="border-collapse: collapse; width: 89.5062%; height: 235.156px;"><colgroup><col style="width: 21.5637%;"></col><col style="width: 78.4363%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Property Name**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**Name**</td><td style="height: 29.7969px;">Name of the Variable. This is the same name that is to be used in the scripts.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**Description**</td><td style="height: 29.7969px;">Description of the Variable.</td></tr><tr style="height: 80.1875px;"><td style="height: 80.1875px;">**<span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Type</span>**</td><td style="height: 80.1875px;">Type of the Variable. The following options are available:
</td></tr><tr style="height: 35.7812px;"><td style="height: 35.7812px;">**<span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Root-Path</span>**
</td><td style="height: 35.7812px;">If the variable type is Path or File, this is used to reference a specified Root-Path. Doing so will treat the path as a relative path.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**Value**</td><td style="height: 29.7969px;">Value of the variable. In case of ‘Option’ type values, the valid choices can be restricted by defining multiple values separated with a semicolon.</td></tr></tbody></table>
<div drawio-diagram="8318"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614715.png" alt=""/></div>
<div drawio-diagram="8319"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-7-1744614753.png" alt=""/></div>
# Default variables
Besides user configured variables the following default environment variables will be set.
<table border="1" id="bkmrk-property-name-descri" style="border-collapse: collapse; width: 64.8148%; height: 129.188px;"><colgroup><col style="width: 35.1185%;"></col><col style="width: 64.8845%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Name**</span></td><td class="align-center" style="background-color: rgb(230, 126, 35); height: 29.7969px;"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**BUILD\_NAME**</td><td style="height: 29.7969px;"><span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Name of the build</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**BUILD\_DESCRIPTION**</td><td style="height: 29.7969px;"><span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Description of the build</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">**BUILD\_SCRIPT\_PATH**</td><td style="height: 29.7969px;"><span lang="EN-US" style="font-size: 10.0pt; mso-bidi-font-size: 11.0pt; line-height: 107%; font-family: 'Daytona',sans-serif; mso-fareast-font-family: 游明朝; mso-fareast-theme-font: minor-fareast; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-language: EN-US; mso-fareast-language: JA; mso-bidi-language: AR-SA;">Path to build script files</span></td></tr><tr style="height: 10px;"><td style="height: 10px;">**BUILD\_OUTPUT\_PATH**</td><td style="height: 10px;">Output path of the build
# Command Line Interface
It is possible to start a build from the Command Line via the Build-CLI tool. For more information, please refer to the <span style="color: rgb(230, 126, 35);">[“Tools”](https://doc3161en.candera.eu/books/cgi-studio-connector/chapter/tools)</span> chapter.
