# Type Editor Plugins
# A Complex Custom Type Editor Example
This example demonstrates how to create a custom type that will be displayed in the Scene Composer property grid as custom editor. This example assumes the developer is familiar with WPF DataTemplating, DataBinding, CusotmControls, and DependencyProperties.
The example will create a custom control that will be used to edit a flags enum as a list of CheckBoxes. This example assumes you are already familiar with scene composer plugins and you are familiar with implementing a simple custom type editor as described in <span style="color: rgb(230, 126, 35);">[A Simple Custom Type Editor](https://doc3161en.candera.eu/books/extending-scenecomposer/page/a-simple-custom-type-editor "A Simple Custom Type Editor")</span> and enum custom types as described in <span style="color: rgb(230, 126, 35);">[A Custom Enum Type Editor](https://doc3161en.candera.eu/books/extending-scenecomposer/page/a-custom-enum-type-editor "A Custom Enum Type Editor")</span>
#### <a class="anchor" id="bkmrk-"></a>Providing a custom editing Data Template
Scene composer will invoke the GetDataTemplate method to request a WPF DataTemplate for editing the custom types. If this method returns null the default datatemplate will be used. If the method returns a DataTemplate then this custom template will be used. The class will load a resource dictionary that has the data template defined and will return a template with a specific key.
 ResourceDictionary res = Application.LoadComponent(new Uri("/CustomTypeEditor;component/CustomComplexTypeEditorPluginUtils/DataTemplateDictionary.xaml", UriKind.Relative)) as ResourceDictionary;
 public System.Windows.DataTemplate GetDataTemplate(string type)
    //We return the data template by name
    // See CustomComplexTypeEditorPluginUtils/DataTemplateDictionary.xam for more details on the data template.
    return (DataTemplate)res["flagsTemplate"];
#### <a class="anchor" id="bkmrk--0"></a>Define a custom editing Data Template
The data template is defined in a resource dictionary. The data template will be instantiated in the property grid on the right side where the property value is usually located. The template can contain any valid control. The passing of values between the template and the property grid is done using the DataContext of the DataTemplate The most important property of the DataContext is the Value property which represents the value of the property. This property is the only way for the DataTemplate to pass a value back to the property grid. Other read-only properties that the data template can use are:
<div class="contents" id="bkmrk-bool-isreadonly-spec"><div class="contents"><div class="textblock">
- bool IsReadOnly specified weather the value should be read-only or not
- IEnumerable AvailableValues a list of the values that was returns by the GetAvailableValues of the TypeEditorPlugin
- CustomType - the name custom type name of the property
- Description - the description of the property extracted from metainfo
- Format - the format to be used for the property, also exacted from metainfo
- IsEnabled - !IsReadOnly, used for convenient binding instead of IsReadOnly
- IsError - If the conversion of the property fails, this property will be true. Can be used to show UI indicating the value is invalid
- IsUndefined - If there are more items selected in the property grid, and their values for the property is different this property will be true
- MaxValue - The double max value extracted from metainfo
- MinValue - The double min value extracted from metainfo
- Name - The name of the property extracted from metainfo.
    <ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
                        xmlns:e="clr-namespace:CustomTypeEditor.CustomComplexTypeEditorPluginUtils"
                        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
       <DataTemplate x:Key="flagsTemplate">
          <e:CustomFlagsEditor Value="{Binding Value, Mode=TwoWay}"></e:CustomFlagsEditor>
       </DataTemplate>
    </ResourceDictionary>
    The datatemplate uses a custom control CustomFlagsEditor that is detailed in the code but not explained. The control is a WPF Custom control that uses standard data binding techniques to display a list of check boxes for editing the value.
</div></div></div>The full code for the example:
#### <a class="anchor" id="bkmrk--1"></a>CustomComplexTypeEditorPlugin.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows.Controls;
using FTC.SDKInterface.Plugins;
using System.Windows;
namespace CustomTypeEditor
   /// <summary>
   /// This example demonstrates how to create a custom type that will be displayed in the Scene Composer property grid as custom editor.
   /// This example assumes the developer is familiar with WPF DataTemplating, DataBinding, CusotmControls, and DependencyProperties.
   /// The example will create a custom control that will be used to edit a flags enum as a list of CheckBoxes.
   /// To use the example plug-in type copy the output of this project in the ($FTCInstallPath$)\Plugins directory.
   /// If you do not have a widget that uses this type, but with to test it woks in Scene Composer, also copy the WidgetMetaInfo.txt in the ($FTCInstallPath$) directory.
   /// This will override any other widgets and will load only the test widget that contains the custom type.
   /// You can modify the WidgetMetaInfo.txt to include other custom types you wish to test.
   /// </summary>
   public class CustomComplexTypeEditorPlugin : ICustomTypeEditorExt
      /// <summary>
      /// The actual enum used for the values.
      /// </summary>
      [Flags]
      public enum CustomEnumFlags
         EnumValue1 = 1,
         EnumValue2 = 1 << 2,
         EnumValue3 = 1 << 3
      public string Name
         get { return "Custom Type Editor"; }
      public string Description
         get { return "Sample custom type editor"; }
      public string Version
         get { return "1.1"; }
      /// <summary>
      /// The name used for the enum. This will be used to identify the type in the WidgetMetaInfo file.
      /// The name in the metainfo file should be prefixed with "custom://", to mark the fact that this is a custom type.
      /// For this type the metainfo type name should be "custom://CustomFlagsEnumTypeName"
      /// </summary>
      private const string CustomFlagsEnumTypeName = "CustomFlagsEnumTypeName";
      /// <summary>
      /// Returns a list of types supported by the plug-in.
      /// </summary>
      public IEnumerable<string> SupportedTypes
         get
            yield return CustomComplexTypeEditorPlugin.CustomFlagsEnumTypeName;
      public void Initialize()
      /// <summary>
      /// Returns the value that will be written in the asset file.
      /// </summary>
      /// <param name="type">The type of the value.</param>
      /// <param name="value">The value</param>
      /// <returns>The string to be written in the asset file.</returns>
      public string GetAssetValue(string type, string value)
         return value;
     /// <summary>
      /// Returns the default value for a type. This method will be used to initialize the value of the property, but also when the user clicks the "R" button in the property grid.
      /// </summary>
      /// <param name="type">The type for which the default value is requested.</param>
      /// <returns>The default value</returns>
      public string GetDefaultInternalValue(string type)
         switch (type)
            default:
               throw new ArgumentException("Unsupported type '" + type + "' in plugin " + this.Name);
            case CustomComplexTypeEditorPlugin.CustomFlagsEnumTypeName:
               return "0";
      /// <summary>
      /// Tests if the value is valid for the type.
      /// </summary>
      /// <param name="type">The type of the value</param>
      /// <param name="value">The value to be tested for validity</param>
      /// <returns>Weather the value is valid for the type</returns>
      public bool IsInternalValueValid(string type, string value)
         int intValue;
         switch (type)
            default:
              string[] tokens = value.Split(';');
              return tokens.Length == 2 && int.TryParse(tokens[0], out intValue);
     /// <summary>
      /// Used to display a dialog that allows the user to edit a value of  a given type.
      /// This method is invoked when the user presses the edit button (usually with the text '...' on it).
      /// The dialog can be defined inside the plug-in module and will AUTOMATICALLY inherit the Scene Composer theme, provided explicit style is set on the dialog.
      /// See the CustomEditor.xaml for more details.
      /// </summary>
      /// <param name="type">The type to be edited.</param>
      /// <param name="initialValue">The initial value of the type.</param>
      /// <param name="value">The new value that the user inputs</param>
      /// <returns>Weather the user confirmed the edit. (Aka weather the OK button was pressed)</returns>
      public bool ShowEditValueDialog(string type, string initialValue, out string value)
         value = initialValue;
         return false;
      /// <summary>
      /// Returns the available values for a certain type.
      /// This method is usually use with simple enums or lists of values. In this example we will not use this method. For an example see the CustomEnumTypeEditorPlugin class.
      /// </summary>
      /// <param name="type"></param>
      /// <returns></returns>
      public IEnumerable<CustomTypeDisplayValue> GetAvailableValues(string type)
         if (type == CustomFlagsEnumTypeName)
            return null;
         else
            throw new ArgumentException("Unsupported type '" + type + "' in plug-in " + this.Name);
      /// <summary>
      /// The resource dictionary that contains the data template to be used
      /// </summary>
      /// <summary>
      /// Returns the data template used for editing the value.
      /// this example loads the data template from
      /// </summary>
      /// <summary>
      /// Specified weather the type has a editor dialog.
      /// The editor dialog button is usually shown on the right side of the property grid field with the text '...'
      /// Since in this plug-in we want to use a custom control to show the enum value, the editor dialog is not required.
      /// </summary>
      public bool HasShowEditValueDialog(string type)
         return false;
#### <a class="anchor" id="bkmrk--2"></a>DataTemplateDictionary.xaml
   We create a data template for our custom flags enum.
   The most important property of the DataContext is the Value property which is bound here to the CustomFlagsEditor control.
   Other read-only properties are:
   </DataTemplate>
#### <a class="anchor" id="bkmrk--3"></a>CustomFlagsEditor.xaml
<UserControl x:Class="CustomTypeEditor.CustomComplexTypeEditorPluginUtils.CustomFlagsEditor"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d"
             d:DesignHeight="300" d:DesignWidth="300">
    <Grid x:Name="Root">
      <ItemsControl ItemsSource="{Binding Items}">
         <ItemsControl.ItemTemplate>
            <DataTemplate>
               <CheckBox IsChecked="{Binding IsChecked}" Content="{Binding Name}"></CheckBox>
            </DataTemplate>
         </ItemsControl.ItemTemplate>
      </ItemsControl>
   </Grid>
</UserControl>
#### <a class="anchor" id="bkmrk--4"></a>CustomFlagsEditor.xaml.cs
using System;
using System.Linq;
using System.Text;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using System.ComponentModel;
namespace CustomTypeEditor.CustomComplexTypeEditorPluginUtils
   /// <summary>
   /// This is a custom control used for the actual value editing.
   /// The control has a Value property which is bound to the value property for the data context of the data template.
   /// When changing the value of the Value property it will be passed back in the property grid.
   /// The control uses standard WPF methods to present a list with checkboxes, but the control could be modified to contain any other UI.
   /// </summary>
   public partial class CustomFlagsEditor : UserControl
      public CustomFlagsEditor()
         InitializeComponent();
         this.Root.DataContext = new CustomFlagsEditorDataContext(this);
      public string Value
         get { return (string)GetValue(ValueProperty); }
         set { SetValue(ValueProperty, value); }
      // Using a DependencyProperty as the backing store for Value.  This enables animation, styling, binding, etc...
      public static readonly DependencyProperty ValueProperty =
          DependencyProperty.Register("Value", typeof(string), typeof(CustomFlagsEditor), new UIPropertyMetadata("", (d,e)=>
             var editor = d as CustomFlagsEditor;
             ((CustomFlagsEditorDataContext)editor.Root.DataContext).UpdateValue();
   public class CustomFlagsEditorDataContext
      public CustomFlagsEditorDataContext(CustomFlagsEditor editor)
        this.Editor = editor;
         this.Items = (from e in Enum.GetValues(typeof(CustomComplexTypeEditorPlugin.CustomEnumFlags)).OfType<CustomComplexTypeEditorPlugin.CustomEnumFlags>()
                       select new CustomFlagsItem(this)
                          Name = e.ToString(),
                          Value = e
                       }).ToArray();
      public void UpdateValue()
         this.value = (CustomComplexTypeEditorPlugin.CustomEnumFlags)Enum.Parse(typeof(CustomComplexTypeEditorPlugin.CustomEnumFlags), this.Editor.Value);
         foreach (var item in Items)
            item.RaisePropertyChanged("IsChecked");
      public IEnumerable<CustomFlagsItem> Items { get; set; }
      public CustomFlagsEditor Editor { get; set; }
      CustomComplexTypeEditorPlugin.CustomEnumFlags value;
      public CustomComplexTypeEditorPlugin.CustomEnumFlags Value
         get { return this.value; }
         set
            if (this.value != value)
               this.value = value;
              this.Editor.Value = ((int)value).ToString();
   public class CustomFlagsItem : INotifyPropertyChanged
      private CustomFlagsEditorDataContext customFlagsEditorDataContext;
     public CustomFlagsItem(CustomFlagsEditorDataContext customFlagsEditorDataContext)
         this.customFlagsEditorDataContext = customFlagsEditorDataContext;
      public bool IsChecked
         get { return (this.customFlagsEditorDataContext.Value & this.Value) != 0; }
         set
            if (this.IsChecked != value)
               if (value)
                  this.customFlagsEditorDataContext.Value |= this.Value;
               else
                  this.customFlagsEditorDataContext.Value &= ~this.Value;
               this.RaisePropertyChanged("IsChecked");
      public string Name { get; set; }
      public CustomComplexTypeEditorPlugin.CustomEnumFlags Value { get; set; }
      public event PropertyChangedEventHandler  PropertyChanged;
      public void RaisePropertyChanged(string name)
         if(this.PropertyChanged != null)
            this.PropertyChanged(this, new PropertyChangedEventArgs(name));
# A Custom Enum Type Editor
This example demonstrates how to create a custom enum type that will be displayed in the Scene Composer property grid as a combo of values.
#### <a class="anchor" id="bkmrk-"></a>Defining the plugin class
To implement advances custom type feature the plugin class must implement ICustomTypeEditorExt instead of ICustomTypeEditor Most of the methods are the same, just that this interface adds several other features we will use for this sample
 public class CustomEnumTypeEditorPlugin : ICustomTypeEditorExt
#### <a class="anchor" id="bkmrk--0"></a>The Enum
We define an actual C# enum for the values of our custom enum. The values of this enum will never reach Scene Composer, as the actual values for out custom type will always be strings, but for our sample it is more convenient to use the values from this enum as a basis for our custom type.
    EnumValue1,
    EnumValue2,
    EnumValue3
#### <a class="anchor" id="bkmrk--1"></a>Available Values
The GetAvailableValues method must return the available values for the type. The values will be wrapped in a CustomTypeDisplayValue that holds both the actual value the custom type will have, but also a display string for the value.
    if (type == CustomEnumTypeName)
       return from v in <a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___core2_d.html#gaa4cc311d76d6576e74f346fa9f6d87cb" title="TextNode2DRenderState enumeration defines the states a text can have in view of rendering the text...">Enum</a>.GetValues(typeof(CustomEnum)).OfType<CustomEnum>()
              select new CustomTypeDisplayValue()
                 DisplayName = v.ToString(),
                 <a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___behaviors_control.html#ggae7abc816df647d0ecbc280480fefb788a08ac9fea94a6bce4e06a71394ca534d3">Value</a> = ((int)v).ToString()
    else
       throw new ArgumentException("Unsupported type '" + type + "' in plug-in " + this.<a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___behaviors_mixed_reality.html#gga70813433b87d1347efaf56d755a186c1aa161dba378f926eef1e116dd38c4b6c6">Name</a>);
#### <a class="anchor" id="bkmrk--2"></a>Implementing other interface methods.
As with the simple custom type example (<span style="color: rgb(230, 126, 35);">[A Simple Custom Type Editor](https://doc3161en.candera.eu/books/extending-scenecomposer/page/a-simple-custom-type-editor "A Simple Custom Type Editor")</span>) we must implement the methods for offering the default value, value validation, and asset value. The full code might be seen on the bottom of the page.
The other method of the ICustomTypeEditorExt, GetDataTemplate, interface will be explained in the <span style="color: rgb(230, 126, 35);">[A Complex Custom Type Editor Example](https://doc3161en.candera.eu/books/extending-scenecomposer/page/a-complex-custom-type-editor-example "A Complex Custom Type Editor Example")</span> example. For now the method will simply return null defaulting to Scene Composer standard handling for custom enums, which is to display a ComboBox with the values.
    return null;
using System;
using System.Linq;
using System.Text;
   /// <summary>
   /// This example demonstrates how to create a custom enum type that will be displayed in the Scene Composer property grid as a combo of values.
   /// If you do not have a widget that uses this type, but you want to test it woks in Scene Composer, also copy the WidgetMetaInfo.txt in the ($FTCInstallPath$) directory.
   /// This will override any other widgets and will load only the test widget that contains the custom enum type.
   /// </summary>
      /// <summary>
      /// Since the enum is never actually exposed to Scene Composer and the values stored as strings, is is not mandatory for it to exist as a .NET enum. But for this example it makes it easier to write the necessary conversion code.
      /// </summary>
         EnumValue1,
         EnumValue2,
         EnumValue3
      public string Name
      /// <summary>
      /// For this type the metainfo type name should be "custom://CustomEnumTypeName"
      /// </summary>
      private const string CustomEnumTypeName = "CustomEnumTypeName";
      /// <summary>
      /// </summary>
         get
           yield return CustomEnumTypeEditorPlugin.CustomEnumTypeName;
      /// <summary>
      /// </summary>
         return value;
      /// <summary>
      /// </summary>
         switch (type)
            default:
            case CustomEnumTypeEditorPlugin.CustomEnumTypeName:
               return "0";
      /// <summary>
      /// </summary>
         int intValue;
         switch (type)
            default:
      /// <summary>
      /// </summary>
         return false;
      /// <summary>
      /// If the enumeration is not null then a combo box will be used for editing this type.
      /// This method is intended to be used with custom enums or lists of values.
      /// In this case the method returns the values of the CustomEnum type.
      /// The values could be taken from any other source provided the ICustomTypeEditor knows how to handle the values when they are passed back to it
      /// </summary>
            return from v in Enum.GetValues(typeof(CustomEnum)).OfType<CustomEnum>()
                      Value = ((int)v).ToString()
         else
      /// <summary>
      /// In this example we will use the default custom enum behavior in scene composer so we will return null to use the default template.
      /// </summary>
         return null;
      /// <summary>
      /// Since in this plug-in we want to use a combo box to show the enum values the editor dialog is not required.
      /// </summary>
        return false;
# A Simple Custom Type Editor
#### <a class="anchor" id="bkmrk-"></a>Creating a custom type editor
To run this example you must first create a C# project that refrecnes FTC.SDKInterface.dll. The resulting dll from your project (along with any non .NET dependecies) must be placed in the Plugins directory in the FTC install location.
##### <a class="anchor" id="bkmrk--0"></a>The Plugin class.
The first step is to create a class that implements the ICustomTypeEditor interface. This is the type that will be instantiated by Scene Composer whose methods will be called to handel custom type specific actions.
 public class CustomTypeEditorPlugin : ICustomTypeEditor
##### <a class="anchor" id="bkmrk--1"></a>Implementing IPlugin
Next we must implement the IPluginService interface members.
 public string <a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___behaviors_mixed_reality.html#gga70813433b87d1347efaf56d755a186c1aa161dba378f926eef1e116dd38c4b6c6">Name</a>
 public void Initialize(IUnityContainer unityContainer)
##### <a class="anchor" id="bkmrk--2"></a>Specifying what types are supported
We implement the SupportedTypes member of the ICustomTypeEditor. This property defines the name of the custom types supported by the plugin. These names will be passed back to the plugin wherever the type must be identified. Also these are the names that should be used in the meta info file.
 private const string CustomTypeName = "CustomTypeEditor";
 private const string AnotherCustomTypeName = "AnotherCustomTypeEditor";
    get
       yield return CustomTypeEditorPlugin.CustomTypeName;
       yield return CustomTypeEditorPlugin.AnotherCustomTypeName;
##### <a class="anchor" id="bkmrk--3"></a>Defining the values of the type
Next we implement value related methods.
The GetDefaultInternalValue will return the default value for a type, for our types the defaults are "0;" and "0". The first custom type is a complex type that has two components separated by ';' the first component must be an integer, while the second will be a simple string. The second custom type is a simple integer value.
    switch (type)
       default:
          throw new ArgumentException("Unsupported type '" + type + "' in plugin " + this.<a class="code" href="http://dev.doc.cgistudio.at/APILINK/group___behaviors_mixed_reality.html#gga70813433b87d1347efaf56d755a186c1aa161dba378f926eef1e116dd38c4b6c6">Name</a>);
       case CustomTypeEditorPlugin.CustomTypeName:
          return "0;";
       case CustomTypeEditorPlugin.AnotherCustomTypeName:
          return "0";
The IsInternalValueValid method validates whether the value passed as argument is valid for the type.
    int intValue;
    switch (type)
       default:
          return int.TryParse(value, out intValue);
The GetAssetValue converts the internally stored value for a type to an asset compatible value. This value is dependant on the consumer of the property. For our example we will use the same strig as the internal value.
    switch (type)
       default:
          return value;
          return value;
Last we must define the ShowEditValueDialog method that is used for the actual value editing. We assume the existence of CustomEditor dialog window which will be detailed later, that has two textboxes that out custom editor can access.
The method calls the dialog, and collects the values from the textboxes. If the user hits ok in the dialog then the method will return true, otherwise it will return false, and the new value will not be saved.
    int intValue;
    var dlg = new CustomEditor();
    switch (type)
       default:
          string[] tokens = initialValue.Split(';');
          if (tokens.Length == 2)
             if (int.TryParse(tokens[0], out intValue))
                dlg.textBox0.Text = tokens[0];
             dlg.textBox1.Text = tokens[1];
          if ((bool)dlg.ShowDialog())
             string newValue = dlg.textBox0.Text + ";" + dlg.textBox1.Text;
             if (this.IsInternalValueValid(type, newValue))
                value = newValue;
                return true;
          break;
          if (int.TryParse(initialValue, out intValue))
             dlg.textBox0.Text = initialValue;
          dlg.textBox1.Visibility = System.Windows.Visibility.Collapsed;
          if ((bool)dlg.ShowDialog() && this.IsInternalValueValid(type, dlg.textBox0.Text))
             value = dlg.textBox0.Text;
             return true;
          break;
    return false;
##### <a class="anchor" id="bkmrk--4"></a>Defining the Dialog Window
Implicitly any dialog show in scene composer will use the same look and feel for the controls. For the window however, an explicit style must be set to give it the Scene Composer look and feel, that style is named 'DialogWindow'
 <Window x:Class="CustomTypeEditor.CustomEditor"
      Style="{DynamicResource DialogWindow}" ...>
##### <a class="anchor" id="bkmrk--5"></a>CustomTypeEditorPlugin.cs
 using System;
 using System.Linq;
 using System.Text;
          get
         switch (type)
            default:
               return value;
               return value;
          switch (type)
             default:
                return "0;";
                return "0";
          int intValue;
          switch (type)
             default:
          int intValue;
          switch (type)
             default:
                      value = newValue;
                      return true;
                break;
                   return true;
                break;
          return false;
##### <a class="anchor" id="bkmrk--6"></a>CustomEditor.xaml
   The resources for controls are implicitly inherited from the application, so all the controls should look the same as in scene composer.
   To have a dialog window that looks the same as Scene Composer's you must specify the DialogWindow style resource.
   Other useful resource keys are :
      - NormalBrush - Used for the background of some items
      - LightBrush - Used for the background of some items
      - TextBrush - Used for the text color.
      - NormalBorderBrush - The normal border color of a control
      - HoverBrush - used for highlighting the hover over an element
      - ControlBackgroundBrush - used for the background of a control
      - SelectedBackgroundBrush - used to highlight a selected element
      - WindowBackgroundBrush - used for the color of the window background
    Title="Custom Type Editor" Height="172" Width="249" KeyDown="OnKeyDown" ResizeMode="NoResize" WindowStartupLocation="CenterScreen">
    <Grid>
      <Button Margin="34,99,0,0" Name="button1" HorizontalAlignment="Left" Width="76" Click="OnOkButtonClick" Height="23" VerticalAlignment="Top">OK</Button>
      <Button HorizontalAlignment="Right" Margin="0,99,21,0" Name="button2" Width="75" Click="OnCancelButtonClick" Height="23" VerticalAlignment="Top">Cancel</Button>
      <TextBlock Height="25" HorizontalAlignment="Left" Margin="12,33,0,0" Name="label0" VerticalAlignment="Top" Width="76">Number:</TextBlock>
      <TextBlock Height="25" Margin="12,64,0,0" Name="label1" VerticalAlignment="Top" HorizontalAlignment="Left" Width="76">Text:</TextBlock>
      <TextBlock Height="25" Margin="12,-1,0,0" Name="label4" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120">Custom Type:</TextBlock>
      <TextBox Height="25" Margin="86,33,0,0" Name="textBox0" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120" />
      <TextBox Margin="86,64,0,0" Name="textBox1" Height="25" VerticalAlignment="Top" HorizontalAlignment="Left" Width="120" />
   </Grid>
</Window>
##### <a class="anchor" id="bkmrk--7"></a>CustomEditor.xaml.cs
 using System;
 using System.Linq;
 using System.Text;
    public partial class CustomEditor : Window
       public CustomEditor()
       private void OnOkButtonClick(object sender, RoutedEventArgs e)
          this.DialogResult = true;
          this.Close();
       private void OnCancelButtonClick(object sender, RoutedEventArgs e)
          this.Close();
       private void OnKeyDown(object sender, KeyEventArgs e)
          switch (e.Key)
             case Key.Escape:
                this.Close();
                return;
             case Key.Enter:
                this.OnOkButtonClick(this, new RoutedEventArgs());
                return;
# Widget Metainfo Example
This file is an example of a metainfo file that defines a widget. This file can be used to test the functionally of custom types. To do this you must copy the content below in a file called WidgetMetaInfo.txt and place it in the directory where Scene Composer is installed. This will replace the existing widget set with the widget defined in this file.
You can the replace the custom:// entries with your own custom types.
WidgetCount = 1
  WidgetType = Widget3D
  Requirements =
  Name = Test3DWidget
  ReadableName = Test3DWidget
  Description = Test3DWidget. Used to test the functionality of custom types in the sample custom editor.
  Category = Sample
  PropertyCount = 4
    Name = CustomFlags
    ReadableName = Custom Flags
    Description = An example of a custom type that uses a custom control to edit the value.
    Category = Sample
    Type = custom://CustomFlagsEnumTypeName
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
    Name = CustomEnum
    ReadableName = Custom Enum
    Description = An example of a custom type that uses the default enum behavior in Scene Composer
    Category = Sample
    Type = custom://CustomEnumTypeName
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
    Name = CustomType
    ReadableName = Custom Type
    Description = An example of a custom type that uses a dialog for editing
    Category = Sample
    Type = custom://CustomTypeEditor
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
    Name = AnotherCustomTypeEditor
    ReadableName = Another Custom Type
    Description = An example of another custom type that uses a dialog for editing
    Category = Sample
    Type = custom://AnotherCustomTypeEditor
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
    Name = AssociatedNode
    ReadableName = AssociatedNode
    Description = The associated root node associated to the widget
    Category = Sample
    Type = builtin://NodeEditor
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
    Name = Name
    ReadableName = Name
    Description = The name of the widget instance
    Category = Sample
    Type = builtin://StringEditor
    RangeMin =
    RangeMax =
    DefaultValue =
    IsChangeable = 1
