# Quick Guide
This chapter aggregates recommendations concerning major points explained very shortly.
# Optimize Number of Nodes
A reduced number of nodes lead to fewer node-related render state activations that have to be processed. Thus, whenever geometry can be safely combined to a single node like e.g. a mesh, then this way should be favoured. For instance a tire and a rim form a logical group sharing the same transformation. In that case the designer can unify separate geometries in a single mesh with the aid of a digital content creation (DCC) tool.
Consequently, the rim and tire do their texture lookup in a single texture, which further leverages performance gains by texture caching.
<div drawio-diagram="1801"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676619365.png" alt=""/></div>
<div class="contents" id="bkmrk--0"><div class="contents"><div class="textblock"></div></div></div>See below crucial prerequisites for combining Nodes:
<div class="contents" id="bkmrk-nodes-share-same-tra"><div class="contents"><div class="textblock">
- Nodes share same transformation (position, rotation, scale).
- Nodes share the same Appearance (textures, shaders, material, render-mode, render-order)
- Nodes are within the same render-order bin.
</div></div></div><div drawio-diagram="1803"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676619452.png" alt=""/></div>
<div class="contents" id="bkmrk--2"><div class="textblock"></div></div>
# Avoid Buffer Clearing
Clear only buffers that need to be cleared.
<div class="contents" id="bkmrk-color-buffer%3A-the-co"><div class="textblock">
- Color buffer: The color buffer does not have to be cleared if the scene is known to cover all of it.
    For instance, this is the case if the background image or a sky map covers the whole surface.
- Stencil buffer: Only needs to be cleared if it is actually used.
- Depth buffer: If depth test is enabled.
</div></div>
# Disable Depth Test and Adjust Depth Range
#### <a class="anchor" id="bkmrk-"></a>Disable Depth Test if Not Required
If it can be easily predicted that an object is not occluded by other objects then disable depth test (See Render-Mode).
#### <a class="anchor" id="bkmrk--0"></a>Adjust Depth Range
As the float resolution in depth buffer is highly limited, the depth range should be as small as possible to reduce depth-fighting artifacts. Further, geometry beyond the near and far plane can be discarded in the clipping stage
# Vertex Buffer Optimization
#### <a class="anchor" id="bkmrk-"></a>Vertex Buffer Editor
Loading of vertex geometry has impact on the bandwidth and on the performance of the caching mechanism for vertices. Scene Composer offers a Vertex Buffer Editor that can be used to remove the unused/unneeded vertex buffer attributes so the performance increase.
<div class="contents" id="bkmrk-read-more..."><div class="contents"><div class="textblock"><table class="doxtable"><tbody><tr><td bgcolor="#f5e7b6"><span style="color: rgb(230, 126, 35);">[Read more...](https://doc3161en.candera.eu/books/scene-design/page/vertex-buffer-editor)</span></td></tr></tbody></table>
</div></div></div>#### <a class="anchor" id="bkmrk--0"></a>Shader Consistency Checker
The information contained in the vertex buffer and the shader attributes should match otherwise conversion is needed and that costs performance. Scene Composer validates the shader parameters, the attributes and the uniforms defined in shaders and gives warnings that can indicate performance issues.
<div class="contents" id="bkmrk-read-more...-0"><div class="contents"><div class="textblock"><table class="doxtable"><tbody><tr><td bgcolor="#f5e7b6"><span style="color: rgb(230, 126, 35);">[Read more...](https://doc3161en.candera.eu/link/146#bkmrk-shader-consistency-c)</span></td></tr></tbody></table>
</div></div></div>#### <a class="anchor" id="bkmrk--1"></a>Node Attachment Optimization
The more node attachments are shared the more performance increases because of reusing the data instead of loading it. SceneComposer provides a wizard to automatically detect node attachments which could be replaced by shared node attachments templates.
<div class="contents" id="bkmrk-read-more...-1"><div class="textblock"><table class="doxtable"><tbody><tr><td bgcolor="#f5e7b6"><span style="color: rgb(230, 126, 35);">[Read more...](https://doc3161en.candera.eu/link/132#bkmrk-cube-map-texture-0)</span></td></tr></tbody></table>
</div></div>
# Startup Time
#### <a class="anchor" id="bkmrk-"></a>Loading Data
<span style="color: rgb(230, 126, 35);">[Asset Tool](https://doc3161en.candera.eu/books/asset-tool)</span> can be used to partition an asset for a startup scene in a faster flash memory.
An another option would be to load a small startup scene and use <span style="color: rgb(230, 126, 35);">[asynchronous asset loading](https://doc3161en.candera.eu/books/candera/page/asynchronous-asset-loading)</span> to load next scene in background.
Loading a lot of data at startup is generally a bad idea. Distribute loading tasks over time.
Also avoid to copy the whole asset from NAND flash to RAM. A better solution would be to implement a paging and caching mechanism using a custom Asset Repository.
#### <a class="anchor" id="bkmrk--0"></a>Persist Pre-compiled Shaders
Use this feature by enabling CANDERA\_SHADER\_PROGRAM\_PERSIST\_INTERFACE\_ENABLED flag in the CMake project.
#### <a class="anchor" id="bkmrk--1"></a>Scope Masks
Upload data to VRAM using Scope Masks as presented in the <span style="color: rgb(230, 126, 35);">[documentation](https://doc3161en.candera.eu/link/537#bkmrk-uploading-to-multipl)</span> and in the <span style="color: rgb(230, 126, 35);">[example](https://doc3161en.candera.eu/link/537#bkmrk-uploading-to-multipl-0)</span>.
#### <a class="anchor" id="bkmrk--2"></a>Startup Animation
Here are some hints for the startup animation:
<div class="contents" id="bkmrk-avoid-large-images-u"><div class="textblock">
- Avoid large images
- Use image compression
- Restrict the frame rate (e.g. 30 fps)
- Realize a flipbook startup animation with asynchronous image fetching
</div></div>
