# Preferences
# Environment Options
# General Options
SceneComposer Customization can be done via menu bar \[ File &gt; Preferences... \].
<div drawio-diagram="8508"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754183136.png" alt=""/></div>
#### Hide warnings and messages from imports in Problems panel
If enabled, warnings and messages from imports in the Problem panel will be hidden.
#### Automatically Tick Camera
If enabled, Camera rendering will be automatically enabled when a Camera is linked to a Render Target. Also, this setting only applies to Camera that are newly linked to Render Target, and does not affect the settings of Cameras that are already linked to Render Target.
<div drawio-diagram="5236"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-02/drawing-5-1708072633.png" alt=""/></div>
#### Disable Previews
If enabled, image file previews will be hidden, which may improve Scene Composer performance (e.g. when importing a large number of images).
<div drawio-diagram="5238"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-02/drawing-5-1708072690.png" alt=""/></div>
#### Enable Detailed Logging
If enabled, more detailed Scene Composer log files will be output, which may be useful for debugging analysis and performance improvement.
#### File
This is the path to the detailed log file.
#### Configuration folder
This is the path to the folder where all Scene Composer configuration files are saved.
#### Screenshot Output Folder
<div drawio-diagram="514"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-7-1676357646.png" alt=""/></div>
This sets the output destination for taking Display screenshots.
The default output destination is C:\\Users\\...\\AppData\\Roaming\\SceneComposer\\Screenshots.
You can take a Display screenshot using the following steps.
1. Display the desired Display panel using one of the following methods.
    - In the Render Target panel, double-click the desired Display.
    - From the menu bar, click \[ View &gt; Display \] and then click the desired Display.
2. Take a screenshot using one of the following methods.
    - In the Render Target panel, click \[ Save Screenshot \] from the context menu of the desired Display.
    - From the context menu of the desired Display panel, click \[ Save Screenshot \].
    - With the desired Display panel active, press &lt;F12&gt;.
Once the screenshot is taken, the Screenshot output folder will open and you will see that the screenshot image has been saved in PNG file format.
#### Help file
This is the path to this document (CGI Studio Documentation).
#### Search Tolerance
The percent value given to the option "Search Tolerance" is taken in to account during the search operation for properties of type Float, Color when the operator "about equal" is used.
#### Tab size / Replace tabs with spaces
<div drawio-diagram="5241"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-02/drawing-5-1708072879.png" alt=""/></div>
The user can change the tab size and decide if tabs should be changed to spaces. This option is available for editing shaders in the Shader Editor panel ("View" &gt; "Editors" &gt; "Shader Editor").
<p class="callout info">There are platforms which do not allow shaders editing operation.</p>
#### Number of visible recently opened solutions
Sets the maximum number of recently opened solutions to be displayed in the Startup panel (maximum: 20).
#### Make All Suppressed Dialogs Visible Again
"Make all suppressed dialogs visible again" option enables the display of the dialog boxes asking confirmations for generate asset and import FBX files option. One can disable the option of displaying these dialog boxes by unchecking the "Always show this dialog" option.
<div drawio-diagram="6475"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721990869.png" alt=""/></div>
# Easy Mode
#### Overview
Easy Mode provides a configurable interface for managing the properties of individual elements. It allows you to hide unused properties in the properties panel, helping streamline workflows when working with a large set of attributes. In addition, Easy Mode supports exporting and importing custom property-configuration files, enabling each user (such as designers or developers) to apply the configuration that best fits their role or workflow.
<p class="callout info">This feature was implemented in CGI Studio 3.12 and earlier as a function to generate Easy Mode configuration files using the "SceneComposerConfigurator.exe" file. From CGI Studio 3.13 onward, this has been updated to make it easier than ever to set Easy Mode from "Preferences" in Scene Composer.</p>
#### Target Elements
The following element types support property customization in Easy Mode:
- Behavior
- Effect
- Node（Node 2D, Node 3D）
#### Customizable Items
The following property aspects can be configured in Easy Mode:.
- **Visibility** - Specify whether a property is shown or hidden in the properties panel.
- **Read-only** - Define whether a property can be edited by the user.
- **Initial Value** - Set the default value applied to the property when an element is created.
<p class="callout info">The set of customizable property options varies depending on the specific property.</p>
#### Customizing properties
1. Open the Preferences dialog by selecting  **File &gt; Preferences...** from the menu bar.
2. In Preferences dialog, navigate to **Environment &gt; Easy Mode**.
3. Choose any element and customize its properties by adjusting any of the following options:
    - Visibility
    - Read-only
    - Initial Value
<div drawio-diagram="8949"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-02/drawing-5-1770977626.png" alt=""/></div>
The image above shows how to set the initial value of TextNode2D's Text property to "Default text".
#### Export and Import
- **Export** The property configurations defined in the Preferences dialog can be exported as an XML file. To export the current Easy Mode settings, click the **Export** button located in the upper-right corner of the Preferences dialog (see image below).
- **Import** To import a previously exported XML configuration file click the **Import**  button in the upper-right corner of the Preferences dialog.
<div drawio-diagram="8950"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-02/drawing-5-1770982273.png" alt=""/></div>
#### Restore defaults
Clicking the **Restore defaults** button in the lower-right corner of the Preferences dialog resets all previously customized properties to their original default settings.
<div drawio-diagram="4465"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-7-1696565715.png" alt=""/></div>
<p class="callout info">Clicking **Restore defaults** button will revert all property settings for all elements back to their default values.
Use this function with caution, as all customized configurations will be lost.</p>
# Auto Save
<div drawio-diagram="6478"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721991894.png" alt=""/></div>
#### Autosave solution
Instead of manually saving an ongoing solution at different times, the user has the possibility to set the automatically process of saving the solution.
If the user enables this setting (Disabled by default), the SceneComposer automatically saves your document at certain intervals (30 seconds). If the user is highly concerned about losing data, the interval can be decreased. But if the user is distracted by the hard drive crunching too often, it is possible to increase the interval. Either way, changing this interval is easy by using the "Interval" cursor.
<p class="callout info">A backup can be created manually by using the "Create Backup" button. In the same way a backup can be renamed or deleted.
</p>
#### Save snapshot
Saving snapshots function is important for reducing the risk from unexpected outages. By automatically generating snapshots at set intervals, SceneComposer gives to the user the ability to restore the system to a previous valid state. A "Creating snapshot..." message is displayed in the title bar when the backup solution is made. The "Save snapshot" option lets the user to specify:
- Snapshot interval (minutes): By using the cursor the user can choose a value between 1 and 300 seconds. The default frequency is 30 seconds.
- Number of snapshots: Multiple snapshots can be saved. The default number of snapshots retained is five.
All the saved snapshots can be accesed via Solution Options panel. There, in the "Data Backup" section, the latest snapshots are available in the "Backups for the current solution" field. The user can select one of them in order to restore the solution to it.
<div drawio-diagram="6479"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721991932.png" alt=""/></div>
Any restore point of the solution can be found on the hard disk as follows:
> ...\\AppData\\Local\\SceneComposer\\sol\\...
# Animation Options
<div drawio-diagram="6480"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721991982.png" alt=""/></div>
#### Enable animation grid
The animation grid represents a collection of lines at a configurable step size for each axis (Grid X Frequency and Grid Y Frequency) that is rendered in the background of the CurveEditor of the AnimationTimeline panel.
#### Grid X Frequency
If \[Enable animation grid\] is enabled, set the interval for displaying the animation grid along the X axis.
#### Grid Y Frequency
If \[Enable animation grid\] is enabled, set the interval for displaying the animation grid along the Y axis.
#### Enables animation snap to grid
The "Enables animation snap to grid" option enables the keyframes to become aligned to the grid when being translated in the Curve Editor of AnimationTimeline panel.
#### Snap Sensitivity
If \[Enables animation snap to grid\] is enabled,  set the desired sensitivity (the range is the distance to guideline where the keyframes stick to the grid).
#### Snap when shifting animation keyframes
If enabled, animation keyframes can be set in units of 5 frames on the animation timeline. If disabled, they can be set in units of 1 frame.
<div drawio-diagram="6481"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721995821.png" alt=""/></div>
# Properties Panel - Favorites
<div drawio-diagram="5249"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-02/drawing-5-1708076766.png" alt=""/></div>
#### Enable favorites
You can save any property as a favorite property.
##### Add / Remove Properties to Favorites
Any property can be saved as a favorite property just by right-clicking on it, after the favorites are enabled. A "Favorites" category will appear in the Properties, where you can see all the selected favorite properties.
<div drawio-diagram="6482"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996082.png" alt=""/></div>
Right click on a property in the "Favorites" category and select "Remove from Favorites" in the context menu to remove a single one.
<div drawio-diagram="6483"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996134.png" alt=""/></div>
#### Import favorities... / Export favorities...
Use "Export favorites..." in the "Environment - Property" section for saving all the selected favorite properties on a chosen location (as an .XML document). Any exported .XML favorites document could be imported by using the "Import favorites..." button from the "Environment - Properties panel" section.
#### Reset favorites
The "Reset favorites" button in the "Environment - Properties" panel section allows to reset all the available favorite properties.
#### Show Asset ID as hexadecimal
If enabled, Asset IDs (ID property in the Assets section of the Properties panel) are displayed in hexadecimal, if disabled they are displayed in decimal.
# Shortcut Customization
#### Shortcut Options
SceneComposer provides many default shortcuts available on a list that can be accessed from the "Help" &gt; "Hot keys" menu or by using the shortcut Ctrl + H.
![image.png](https://doc3161en.candera.eu/uploads/images/gallery/2023-07/scaled-1680-/5YPimage.png)
Due to the huge number of available hot-keys (shortcuts), it could be difficult to find a specific hot-key. In order to solve this issue, a search option is available in the upper side of the Hot Key panel ("Help" &gt; "Hot Keys").
<div drawio-diagram="6485"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996254.png" alt=""/></div>
It is possible to create a different profile (i.e. "Hot keys" list) on which the user can set his/her own shortcuts. In the "Environment" section from the "Preferences", the "Shortcuts" panel allows the creation of new shortcuts.
<div drawio-diagram="6486"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996317.png" alt=""/></div>
Practically speaking, the user may create as many new profiles as are necessary, every of them with its own shortcuts. Every of these new profiles can be saved, exported (to make a list of all new shortcuts available), or deleted. If the user creates a new shortcut based on a default shortcut from the "Default Profile", the new shortcut has to be associated with a new profile - created by using "Save As" option.
<p class="callout info">It is not possible to create a shortcut by using the "Shift" + key or "Alt" + key.
</p>
#### Create Shortcuts
To create new shortcuts there are three major steps:
Select one of the operations for which you would like to create a new shortcut in the left panel.
Here you have two different possibilities:
- Remove the default shortcut by clicking "X" Button in column "Remove". Click in the "Press shortcut keys" field and press the new shortcut keys - a new shortcut is created.
- Create a new shortcut (without removing the default shortcut) by clicking in the "Press shortcut keys" field and pressing the new shortcut keys. In that case the new shortcut will appear under the default one.
<div drawio-diagram="8513"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754294247.png" alt=""/></div>
<table border="1" id="bkmrk-%281%29-%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB-%E9%81%A9%E7%94%A8%E4%B8%AD%E3%81%AE%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%88%E3%82%AB" style="border-collapse: collapse; width: 92.0238%;"><colgroup><col style="width: 7.25403%;"></col><col style="width: 19.4342%;"></col><col style="width: 73.3138%;"></col></colgroup><tbody><tr><td>(1)</td><td>Profile</td><td>Applied Shortcut Profile</td></tr><tr><td>(2)</td><td>Delete</td><td>Delete the shortcut profile selected in (1)</td></tr><tr><td>(3)</td><td>Save</td><td>Save the shortcut profile selected in (1)</td></tr><tr><td>(4)</td><td>Export…</td><td>Export the shortcut profile selected in (1)</td></tr><tr><td>(5)</td><td>ー</td><td>Commands for which shortcuts can be assigned are listed.</td></tr><tr><td>(6)</td><td>ー</td><td>Displays the shortcut for the selected command selected in (5).</td></tr><tr><td>(7)</td><td>Shortcut target</td><td>Set the Panel on which the shortcut is available.
(If set to "Global," the shortcut will be available in all Panels.)
</td></tr><tr><td>(8)</td><td>Press shortcut keys</td><td>Click this field and press the shortcut key you want to add.</td></tr><tr><td>(9)</td><td>Click Target</td><td>If you want to add a mouse operation to a shortcut, perform the mouse operation in this field. The mouse operation performed will be displayed in (8).</td></tr><tr><td>(10)</td><td>ー</td><td>Add the shortcut displayed in (8) to the shortcut profile.</td></tr><tr><td>(11)</td><td>Currently used for</td><td>You will be notified if a shortcut added in (8) or (9) is being used by another command.</td></tr></tbody></table>
After all the new shortcuts are created the "Save As" button may be used to create a new profile with a desired name or just press the "OK" button to save all newly created shortcuts in the "Custom" profile.
<p class="callout info">It is possible to use many shortcuts associated with the same operation in a specific profile. In this way, you have the opportunity to use different shortcuts for the same operation.
</p>
If the new selected shortcut is used for another operation, you will be notified in the field entitled "Currently used for".
<div drawio-diagram="6488"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996409.png" alt=""/></div>
If you would like to get back the default shortcuts, the "Restore defaults" button provides the possibility to get them back.
# Perspectives
Any saved perspective (Display layout of each panel of Scene Composer)  can be exported in order to use it any time when is necessary. This operation can be done via "Preferences" panel: "File" &gt; "Preferences".
Here in the "Environment" section of the panel a "Perspective" section provides two buttons: "Import perspectives" and "Export perspectives". By using them the export/import operations can be performed.
<div drawio-diagram="8509"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754188811.png" alt=""/></div>
# Widgets
Two options for disabling widgets are available in the Preferences menu:
#### Enable widget instantiation
True by default. If this option is disabled, the widgets will still be accessible in the solution, but they will not be instantiated by SCHost, therefore their behaviour will not be available. Disabling this option will disable the following one and may help figuring out if a widget corrupts content within a solution/scene.
<p class="callout info">This option becomes available just after the application is restarted.
</p>
<div drawio-diagram="6489"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996468.png" alt=""/></div>
#### Enable widget update
True by default, indicates whether or not the widgets will be updated. By using the "Enable/Disable updating for all widgets in all scenes" button, the user can control whether the widgets from all scenes will be updated or just the ones from the current scene.
<div drawio-diagram="6490"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721996542.png" alt=""/></div>
If this option is disabled, the Update() method of the widget will not be called by SCHost and also the "Enable/Disable updating for all widgets in all scenes" button from the toolbar will be disabled.
**See also:**
- - - [<span style="color: rgb(230, 126, 35);">Update Widgets in all Scenes</span>](https://doc3161en.candera.eu/link/200#bkmrk-update-widgets-in-al) in SceneComposer User Manual
# Scripting
The user can edit scripts by using an external editor, too. The script code will be automatically updated and validated in SceneComposer after any modification in the external editor. Any error will be showed. To set up the path to the external editor a specific section is available in "Preferences" panel (see the image bellow).
<div drawio-diagram="5258"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-02/drawing-5-1708080563.png" alt=""/></div>
Here the user can browse and select the external editor. As it is mentioned above, after the selection of the external editor any script that will be edited in it will be automatically updated and validated in SceneComposer.
# Language
This option allows you to select **English** or **Japanese** as the display language. After choosing a language you must **manually restart Scene Composer** for the interface to switch to the selected language.
<div drawio-diagram="8510"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754189164.png" alt=""/></div>
# AI Service
On this panel, you configure the connection that the AI features in Scene Composer use.
The features concerned are the **Docs Agent** panel and Search Helper. These features send questions and instructions to the AI service and receive answers. On **AI Service**, you configure how Scene Composer connects to **Candera Operator**, which relays that communication.
<p class="callout info">Every setting has a default value, and the features normally work with these defaults. You do not need to change them. Change a setting only when a connection problem occurs, or when you must specify the connection target explicitly.</p>
#### Prerequisites
Candera Operator requires **.NET Runtime 10.0**. If CGI Studio was delivered with an installer, the installer also installs the runtime, and you do not have to do anything. If CGI Studio was delivered without an installer, install the runtime yourself before you use the AI features. If the runtime is missing, the requirements check dialog that appears when you start Scene Composer lists it as a missing item.
#### Settings
<div drawio-diagram="9205"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-09/drawing-4-1788938719.png" alt=""/></div>
<table border="1" id="bkmrk-setting-description-" style="border-collapse: collapse; width: 800px; border-width: 1px;"><thead><tr><th style="width: 179.625px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">**Setting**</span></th><th style="width: 619.648px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">**Description**</span></th></tr></thead><tbody><tr><td style="width: 179.625px;">Mode</td><td style="width: 619.648px;">Selects how Scene Composer connects to Candera Operator, either **Local** or **Network**.
With **Local**, Scene Composer starts the Candera Operator process and connects to it. With **Network**, Scene Composer connects to a Candera Operator that already runs. Depending on your selection, the panel shows either **Executable Path** or **Host URL**.</td></tr><tr><td style="width: 179.625px;">Executable Path</td><td style="width: 619.648px;">Appears when **Mode** is set to **Local**.
Specifies the path to the Candera Operator executable. You can also select the file with **Browse...**.
</td></tr><tr><td style="width: 179.625px;">Host URL</td><td style="width: 619.648px;">Appears when **Mode** is set to **Network**.
Specifies the Candera Operator to connect to, as a `wss://` URL. You can specify only `localhost` or `127.0.0.1`.
</td></tr><tr><td style="width: 179.625px;">Port</td><td style="width: 619.648px;">Specifies the port number that Scene Composer uses to communicate with Candera Operator. A default port number is already set.</td></tr><tr><td style="width: 179.625px;">Test Connection</td><td style="width: 619.648px;">Tests whether Scene Composer can connect to Candera Operator with the current settings. The button becomes available after you change a setting, and a pop-up shows whether the connection succeeded.</td></tr><tr><td style="width: 179.625px;">Restore defaults</td><td style="width: 619.648px;">Click this button to restore the settings to their initial state.</td></tr></tbody></table>
#### Choosing a Mode
##### Local
Scene Composer starts the Candera Operator process from the executable that you specify in **Executable Path**, and connects to it on the port number that you specify in **Port**. Use this mode under normal circumstances.
##### Network
Scene Composer connects to a Candera Operator that already runs. It connects to the host that you specify in **Host URL** and the port number that you specify in **Port**. In this mode, you do not specify an executable path, and Scene Composer does not start the Candera Operator process.
<p class="callout warning">You can specify only `localhost` or `127.0.0.1` as the connection target. You cannot connect to a Candera Operator that runs on another machine on the network.</p>
#### About Candera Operator
Candera Operator is a server that relays the communication between the AI features in Scene Composer and the AI backend. It runs as an application separate from Scene Composer.
AI features connect to Candera Operator first, and Candera Operator relays the communication to the AI backend. Because all AI features share the same relay point, they use a single authentication method and a single communication method. The authentication relies solely on the HASP key, and the product embeds no API key. Scene Composer sends only the identifier of the HASP key; it never sends the key itself. **Candera Operator itself does not require a HASP key, because the connecting Scene Composer provides it.**
**In Local mode, Scene Composer starts Candera Operator automatically.** It starts the process when you send the first question or instruction to an AI feature.
<p class="callout warning">In **Local** mode, do not start Candera Operator manually. A manually started process conflicts with the process and the port that Scene Composer starts, and the connection fails. To use a Candera Operator that you started yourself, set **Mode** to **Network**.</p>
#### Troubleshooting
<table border="1" id="bkmrk-symptom-what-to-chec" style="border-collapse: collapse; width: 800px; border-width: 1px;"><thead><tr><th style="width: 310.636px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">**Symptom**</span></th><th style="width: 488.636px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">**What to check**</span></th></tr></thead><tbody><tr><td style="width: 310.636px;">**Test Connection** fails</td><td style="width: 488.636px;">Check that the path to the Candera Operator executable that you specify in **Executable Path** is correct. Also check that no other system uses the port number that you specify in **Port**. If the port number conflicts, change the value of **Port**.</td></tr><tr><td style="width: 310.636px;">The panel of an AI feature shows <code>Client could not connect&#33;</code></td><td style="width: 488.636px;">Scene Composer cannot connect to Candera Operator. Check the settings on **Environment &gt; AI Service**, and then test the connection with **Test Connection**. Also check that **.NET Runtime 10.0** is installed.</td></tr></tbody></table>
# State Machine
In Preferences, \[ Enviroment \] &gt; \[ State Machine \] allows you to configure settings related to the display of State Machine Editor.
<div drawio-diagram="4613"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-7-1698049834.png" alt=""/></div>
#### General
<table border="1" id="bkmrk-%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%89%B2-fusion%E3%83%91%E3%83%8D%E3%83%AB%E4%B8%8A%E3%81%AB%E8%A1%A8%E7%A4%BA" style="width: 100%;"><colgroup><col style="width: 23.6013%;"></col><col style="width: 76.3987%;"></col></colgroup><tbody><tr><td>Default Colors</td><td>Default colors can be set for States and Transitions displayed in State Machine Editor. Even if you change this setting, it does not apply to States and Transitions that have already been created.
</td></tr><tr><td>Show transition details</td><td>If this option is enabled, detailed information about the Transition (e.g., conditions under which the Transition occurs) will be displayed.</td></tr><tr><td>Transition Connection Type</td><td>This option allows you to set the line type (Polyline/Bezier/Spline) for Transition to be displayed.</td></tr></tbody></table>
<p class="callout info">Your changed configurations will not be applied to **States** and **Transitions** that have already been created.</p>
# Fusion
Open the Preferences dialog by selecting **File &gt; Preferences...** from the menu bar. In the Preferences dialog, navigate to **Environment &gt; Fusion** to configure settings that control how information is displayed within the Fusion panel.
<div drawio-diagram="6491"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-07/drawing-5-1721997234.png" alt=""/></div>
#### General
<table border="1" id="bkmrk-default-colors-you-c" style="border-collapse: collapse; width: 100%;"><colgroup><col style="width: 23.115%;"></col><col style="width: 76.885%;"></col></colgroup><tbody><tr><td>Default Colors</td><td><span style="color: rgb(0, 0, 0);">You can customize the color of newly created Fusion nodes displayed in the Fusion panel. </span>
<span style="color: rgb(0, 0, 0);">Changing the default color does **not** affect nodes that have already been created. However, the updated color will be applied to existing nodes in the Fusion diagram if the user selects "<span style="color: rgb(230, 126, 35);">[Restore Default Header Color](https://doc3161en.candera.eu/link/1060#bkmrk-lock-performs-an-edi)</span>" from the context menu.</span>
</td></tr><tr><td>Grid Enabled</td><td>When this option is enabled, a grid is displayed in the <span style="color: rgb(230, 126, 35);">[Fusion panel](https://doc3161en.candera.eu/books/fusion/page/fusion-editor-ui)</span>, providing visual guidance for aligning and positioning nodes.</td></tr><tr><td><span style="color: rgb(0, 0, 0);">Restore Defaults</span></td><td>Clicking the **Restore defaults** button resets all settings in this section to their original default values.</td></tr></tbody></table>
# Configure Source Control
#### Configure Source Control
When working with a solution stored in a repository and using Scene Composer's built-in source control integration, you must configure an external comparison and merge tool.
To configure this, open the Preferences dialog (**File** &gt; **Preferences** in the menu bar). In the **Source Control** section, specify the application to be used for merge and diff operations. You can also define the command-line parameters required for each operation (e.g. **Merge** and **Diff**).
Before performing any merge operations, ensure that the external merge tool is **enabled** by selecting the corresponding checkbox.
<div drawio-diagram="8955"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-02/drawing-5-1771575834.png" alt=""/></div>
<table border="1" id="bkmrk-%E6%9C%89%E5%8A%B9-%E6%9C%89%E5%8A%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C" style="border-collapse: collapse; width: 89.881%;"><colgroup><col style="width: 19.8899%;"></col><col style="width: 80.1101%;"></col></colgroup><tbody><tr><td>Enabled</td><td>If enabled, the use of the configured merge tool is enabled.</td></tr><tr><td>Merge Tool</td><td>Configures the path to the external merge tool to use.</td></tr><tr><td>Merge</td><td>Specifies the commands for merge operations.</td></tr><tr><td>Diff</td><td>Specifies the commands for diff operations.</td></tr><tr><td>Synchronized mode</td><td>If enabled, Scene Composer automatically retrieves the solution status from the server. Because communication with the server can be time-consuming, you may choose to disable this option. In that case, you can manually update the status by selecting **Refresh status** from the source control context menu whenever needed. </td></tr></tbody></table>
<p class="callout info">The value of the **Enabled** checkbox is evaluated only when a solution is opened or created.</p>
# Configure Imported Bitmap Name Suffix
By using the "Image Importer" or the FBX Importer" option from "File &gt; Preferences &gt; Environment" it is possible to configure the Bitmap suffix used by the FBX importer and the Image importer. For this the desired suffix should be written inside the field "Bitmap name suffix". The default suffix ("Bmp") can be restored by using the button which is placed in the lower right corner of the panel.
<div drawio-diagram="8511"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754189361.png" alt=""/></div>
#### Imported Bitmap Name Suffix
In order to avoid name conflicts when importing multiple items (for example importing a FBX may create a scene, an animation, a vertex buffer and a bitmap all with the same name) a suffix is appended to the name of the item. This suffix is Bmp for bitmap, VB for vertex buffer and for all other items is same as the type (Scene, Animation, etc).
# Configure the Smart Importer
#### Smart Importer
<div drawio-diagram="8021"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-03/drawing-4-1741134188.png" alt=""/></div>
**Add Cameras in imported scenes to the render target**
Enable: Add a camera of an imported scene to a render target.
Disable: Not add a camera of an imported scene to a render target.
**Enable editing 9-patch**
Enable: You can set-up 9-patch on Smart Importer dialog.
Disable: You cannot set-up 9-patch on Smart Importer dialog.
**Edge Detection** When this option is enabled, in the Smart Importer dialog, enable Include Edges detection to make the appropriate controls detectable. The edge width is set in pixels.
**Freehand dialog background color**
When setting the pivot point in Freehand, the background color of the displayed dialog can be selected from black or gray.
**Text Format**
Set the default value of each property when importing with the Smart Importer.
# Editor Options
# General Options
#### Editor General Options
General Editor options can be found in "File" &gt; "Preferences" section "Editor".
<div drawio-diagram="8617"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-7-1760596615.png" alt=""/></div>
#### Enable scene camera manipulation
"Enable scene camera manipulation" enables the manipulation of the scene's cameras via the Scene Render panel. The cameras can be manipulated via navigation panel or using the appropriate shortcut commands (hot keys) combined with mouse operations when a scene camera is selected from the scenes combobox' from Toolbar.
##### Enable scissoring visualization
By using this feature all the pixels which are outside of the intersection area of the viewport and scissor rectangle can be clipped. After the activation of this feature the scissor rectangle's values have to be defined. This rectangle specifies a region within the Camera's RenderTarget. The rectangle's width and height values must be greater than 0. These values can be set on the Camera's Properties panel.
<div drawio-diagram="6534"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724393084.png" alt=""/></div>
By using the "Scissoring visualization color" a desired color can be chosen and its transparency can be set.
<div drawio-diagram="8622"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-7-1760600101.png" alt=""/></div>
The chosen color can be saved to keep its info.
![image.png](https://doc3161en.candera.eu/uploads/images/gallery/2023-07/scaled-1680-/ED1image.png)
This feature allows the visualization of the scissoring rectangle in the display window as in the next figure.
<div drawio-diagram="6535"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724397484.png" alt=""/></div>
##### Enable render target border
By checking the "Enable Render Target Border" box (which is available in Preferences &gt; Editor, General Selection), the border of a render target can be colored. Any desired color can be chosen in the Color Palette.
<div drawio-diagram="4060"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-07/drawing-5-1688744413.png" alt=""/></div>
In this way, it is possible to see the borders of the RenderTargets graphically as colored rectangles.
<div drawio-diagram="6537"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724400286.png" alt=""/></div>
##### Enable display border
It is possible to visualize the Display border by enabling this feature. In Preferences dialog - Editor, the "Enable display box" should be checked. By using the "Display border color" a desired color can be chosen and its transparency can be set.
<div drawio-diagram="6538"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724400390.png" alt=""/></div>
After this feature is enabled, the borders of the display can be graphically seen as a colored rectangle.
<div drawio-diagram="6539"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724400468.png" alt=""/></div>
#### Enable background color for editor camera
If enabled, you can set the background color of the Editor Camera to any color. Click Background color for editor camera to open the color palette dialog and select the desired color.
#### Enable Active Rendering
This feature is to provide continuous rendering means in SceneComposer so that widgets get a regular update trigger in order to provide a convenient and friendlier development environment for development purposes . This feature can be activated/ deactivated from the "File" &gt; "Preferences" dialog section Editor option or from the button ActiveRendering from the Toolbar.
<div drawio-diagram="6540"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724400572.png" alt=""/></div>
When the ActiveRendering option is enabled, SceneComposer will start an internal repeatable timer with a configurable timeout (default value = 250ms) given in milliseconds by the value of option "Rendering Interval". Every time this timer expires SceneComposer calls RenderScene in SCHost which performs the rendering of the current content. This will trigger the update method for all widgets within all loaded scenes.
#### Show Scope Mask in Hexadecimal Format
The option "Show scope mask in hexadecimal format", when it is enabled, ensures that the values for Scope property will be displayed in hex in the Properties panel. This option is available in the Preferences dialog opened from "File" &gt; "Preferences" menu, section Editor.
<div drawio-diagram="8623"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-7-1760600164.png" alt=""/></div>
# 2D Editing Helpers
#### 2D Editing Helpers
The SceneComposer offers a set of editing helpers that allow editing 2D scenes as simple and intuitive as possible.
All editing aids which have a visual presentation are configurable so that the user can disable them easily if not desired. This can be done from the dialog that opens from "File" &gt; "Preferences" menu under the "Editor" node, the "2D" option.
<div drawio-diagram="6543"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724401581.png" alt=""/></div>
In 2D scenes, SceneComposer offers the following entries in the 2D section of Editor-Preferences:
- Ruler
- World Transformations
- Grid
- Snap to Grid
- Snap to Guidelines
- Snap to Objects
You can also find some 2D Editing Aids in the "View" menu in section "2D Editing Utilities".
<div drawio-diagram="6545"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724401678.png" alt=""/></div>
#### Scene Design Helpers
##### Rulers
Rulers provide a sense on the world space that the camera viewport bounds; display measuring points and their corresponding values (numbers).
- Two rulers are drawn: one on the top of the rendering panel another on the left side of the rendering panel.
- They will be drawn always having a fixed position and orientation in space.
- The rulers will be attached to a 2D camera and they will always measure the space that the camera viewport bounds regardless of the camera orientation.
- The rulers' starting coordinates for vertical and horizontal ruler will be the camera top-left viewport world space point.
- In order to enable this editing helper, check the property "Enable Ruler" from the "Editor - 2D" section of Preferences dialog.
#### World Transformations
To use the **World Transformations**, enable this option and select an object in the Scene Editor Window. Now,a tooltip is displayed in the lower left corner of the Scene Editor that shows absolute coordinates and sizes.
<div drawio-diagram="6546"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724401872.png" alt=""/></div>
The following values are displayed:
- **WorldPivotPosition**: horizontal value, vertical value
- **WorldPivotPointPosition**: horizontal value, vertical value
- **WorldPosition**: horizontal value, vertical value
- **WorldBoundingBox**: horizontal value, vertical value, width, height
#### Snapping
##### Grid
Grid represents a collection of points (1px) laid at a configurable step size for each axis (step in pixels for x or for y).
- The grid is enabled by checking the checkbox "Enable" from the section Grid, in the "Preferences" &gt; "Editor - 2D" dialog.
- The steps X and Y are configurable using the slides controls "Step X" and "Step Y". Default step is 10(x)/10(y).
- The grid is rendered in the background.
##### Snap to Grid
Snap to grid enables an object to become aligned to the grid when being translated.
- Snapping is enabled for the object relative to the upper-left point of its bounding box.
- To enable this feature check the checkbox "Enable" from the section "Snap To grid" and configure the desired sensitivity (the range is the distance to guideline where the object sticks to the point).
##### Snap to Guidelines
Snap to guidelines enables an object to be aligned to a guideline when being translated. A guideline represents a simple line, locked to a predefined world-space coordinate value.
- Snapping to guidelines is configurable; it can be enabled or disabled by checking the checkbox "Snap to guidelines" from the "Preferences - Editor - 2D" dialog.
- Also the snapping sensitivity - the range (distance to guideline) where the object sticks to the guideline - can be configured using the slide control "Sensitivity".
**Guidelines**
- Guidelines are created in SceneComposer by click and drag from the ruler. In order to be removed, a guideline is dragged outside the view.
- Multiple guidelines can be drawn in a scene and they are bound to a scene and not camera viewport.
- The configured guidelines are visible and editable in the scene's properties.
<div drawio-diagram="6547"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724401930.png" alt=""/></div>
##### Snap to Objects
Snap to objects enables an object to be aligned to another object's rendering area when being translated. The rendering area is the area that bounds the vertices of the bounding box of the object.
- An object will be snapped to the closest other object in its proximity.
- Snapping is available for RenderNodes objects only.
- A render node is in the proximity of another object (thus will be snapped) if one of the four points of its bounding box is in the proximity of the rendering area of the other object (rendering area is always a not-rotated rectangle and it bounds the points of the bounding box).
- The snap feature can be activated/deactivated by checking/unchecking the checkbox "Enable" from the section "Snap to objects" and the proximity range is configurable using the slide control "Sensitivity".
#### Positioning
##### Move to back/front, move back/front
This feature allows the user to manipulate objects such that they can be placed on top-most level, or sent to background. Layering is done through a property called DepthValue, in a range of 0..255.
The following operations are available:
- **Move back**: increase depth value by 1
- **Move front**: decrease depth value by 1
- **Move to back**: set depth value to 255
- **Move to front**: set depth value to 0
<div drawio-diagram="7613"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-12/drawing-5-1733490211.png" alt=""/></div>
You can manipulate these values from the context menu, or by setting the value of property DephValue from Properties panel.
- Candera 2D doesn't specify a rule for rendering objects that have the same depth value.
- There might be X objects with depth value 0 (top-most), but only one object of those ones is rendered topmost.
- Conflicts at the interval end (0 or 255) have to be handled.
**Object alignment (top, middle, bottom, left, center, right / relative to other objects)**
This feature enables automatically re-positioning of objects such that they are aligned on a specific criterion. Only render nodes and groups are eligible for alignment and this feature applies to a selection consisting of at least 2 render nodes and/or groups.
<p class="callout info">First selected object serves as reference for alignment.
</p>
The object alignment feature is available for the 2D scenes by selecting the appropriate button from the Toolbar. Each button corresponds to a criterion of alignment.
<div drawio-diagram="6549"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724402302.png" alt=""/></div>
##### Available criteria
- **Top/bottom alignment**: the selected objects (excluding the reference one) will be positioned such that the top/bottom side of their rendering area is aligned to the top/bottom side of the first object's rendering area.
- **Left/right alignment**: the selected objects (excluding the reference one) will be positioned such that the left/right side of their rendering area is aligned to the left/right side of the first object's rendering area.
- **Center alignment**: the selected objects (excluding the reference one) will be positioned such that their rendering area's geometric center is aligned to the geometric center of the first object's rendering area.
- **Middle alignment**: the selected objects (excluding the reference one) will be positioned such that their rendering middle is aligned to the middle of the first object's rendering area
##### Geometric center localizer
For all selected objects (render nodes, groups, cameras) the geometric center (center = (0, 0) point in the local coordinate system) will be displayed as an image of a small dimension consisting of a circle and a dot in the center of the circle. It represents the pivoting point for rotation or translation transformation.
<div drawio-diagram="6550"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724402750.png" alt=""/></div>
Three translate operations can be selected from the transformation combobox:
<div drawio-diagram="6551"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724402897.png" alt=""/></div>
- **"PivotAndObject"**: moves the object and its pivot
- **"PivotOnly"**: moves only the pivot, the object remains on the same position
- **"ObjectOnly"**: moves only the object, the pivot's position remains unchanged
<p class="callout info">After choosing the "PivotOnly" option for translate mode, the pivot will move only if the user starts dragging it inside the area delimited by the borders of the object.</p>
#### Groups
For grouping elements on the same level add a group to the selected objects as parent if they are on the same level. From the SceneTree panel, keep Ctrl key pressed and select more objects. On the last object that is desired to be part of the group press right click and select the option "Create group" from the context menu.
<div drawio-diagram="7614"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-12/drawing-5-1733490322.png" alt=""/></div>
# 3D Editing Helpers
#### 3D Editing Helpers
The SceneComposer offers a set of editing helpers that allow editing 3D scenes as simple and intuitive as possible.
All editing aids, which have a visual presentation, are configurable so that the user can disable them easily if not desired. This can be done from the dialog that opens from "File" - "Preferences" menu under the "Editor" node, the "3D" option.
<div drawio-diagram="8620"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-7-1760596795.png" alt=""/></div>
In 3D scenes, SceneComposer offers the following entries in the 3D section of Editor-Preferences:
- Navigation Controls
- Grid
- Snap to Grid
- Snap to Objects
- Selection help
- Default Camera
<p class="callout info">For more details about Exact camera view, please refer to <span style="color: rgb(230, 126, 35);">[Other 3D Editing Aids](https://doc3161en.candera.eu/link/110#bkmrk-other-3d-editing-aid)</span>.</p>
You can also find some 3D Editing Aids in the "View" menu in section "3D Editing Helpers".
<div drawio-diagram="6555"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724403400.png" alt=""/></div>
#### Navigation Controls
##### Lift factor
Lift refers to up and down moving and the lift factor represents a multiplication factor of moving up and down speed. 0 = no action.
The greater the value the faster the camera is moved. Example values: 1, 1.5, 2
##### Strafe factor
Strafe refers to sidewise moving and strafe factor represents a multiplication factor of sidewise moving speed. 0 = no action.
##### Rotation Pitch Angle
Rotation refers to rotation the camera around its position and rotation pitch angle represents the pitch rotation angle applied to the camera after 1 second at full rotation speed (mouse outside of the rotation button).
The angle is specified in Degrees.
##### Rotation Yaw Angle
Angle represents the Yaw rotation angle applied to the camera after 1 second at full rotation speed (mouse outside of the rotation button).
##### Pivot Rotation Pitch Angle
Pivot rotation refers to orbiting - rotation of the camera around a pivot point (a point in the scene) and pivot rotation pitch angle represents the pitch pivot rotation (orbiting) angle applied to the camera after 1 second at full rotation speed (mouse outside of the rotation button).
##### Pivot Rotation Yaw Angle
Represents the Yaw pivot rotation (orbiting) angle applied to the camera after 1 second at full rotation speed (mouse outside of the rotation button).
##### Zoom Factor
Zoom refers to moving camera forward / backward (perspective) or scaling the camera view (orthographic). The Zoom factor represents a multiplication zooming factor. 0 = no action.
The greater the value the faster the camera is zoomed. Example values: 1, 1.5, 2
<div drawio-diagram="601"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-7-1676363297.png" alt=""/></div>
#### Snapping
##### 3D Grid
Enable 3D Grid option, when it is checked, enables the grid in a scene 3D. Grid represents a collection of points (1px) laid at a configurable step size.
- The grid is enabled by checking the checkbox "Enable" from the section Grid, in the "Preferences" - "Editor" - "3D" dialog.
##### Snap to Grid
- When snap to grid is enabled, the grid you set works as a magnet; when a selected object is moved, the grid points appear to pull on it when it approaches. This is useful for accurate placement of image elements.
- Snapping is enabled for all the global bounding box coordinates.
- To enable this feature check the checkbox "Enable" from the section "Snap to grid" and configure the desired sensitivity (the range is the distance to guideline where the object sticks to the point).
- A render node is in the proximity of another object (thus will be snapped) if one of the eight points of its bounding box is in the proximity of the rendering area of the other object (rendering area is always a not-rotated rectangle and it bounds the points of the bounding box).
#### Positioning
##### Selection Help
There are three different types available for selection helper.
- Bounding box: when this option is selected, the user will be able to see the edges of the surrounding invisible bounding box.
- Region sphere:
    - Camera aligned bounding circle: on this mode the camera will always be oriented toward one bounding circle that will surround the bounding box of the selected object.
    - Static gimbal: a circle for each axis - X, Y, Z will be displayed - not aligned to the camera.
<p class="callout info">The bounding circle will be visible just if the "Radius" property under the "Bounding Local Shapes" section will be set at a value greater than 0.
</p>
- Both previous types are available. All the modes available for the "Region sphere" type will be available, too.
##### Object alignment
Object alignment (X Min, X Mid, X Max, Y min, Y Mid, Y Max, Z min, Z Mid, Z Max / relative to other objects): this feature enables automatically re-positioning of selected objects such that they are aligned on a specific criterion.
</p>
- It could be very helpful to use any of the predefined orthogonal views (Front, Rear, Top, Bottom, Left, and Right) of the camera.
- The object alignment feature is available for the 3D scenes by selecting the appropriate button from the toolbar. Each button corresponds to a criterion of alignment.
<div drawio-diagram="6560"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724403834.png" alt=""/></div>
- **X Min alignment**: the selected objects (excluding the reference one) will be positioned such that the minimum point of the edge which corresponds to the X axis of their global bounding box is aligned to the minimum point of the edge which corresponds to the X axis of the first (reference) object's global bounding box.
- **X Mid alignment**: the selected objects (excluding the reference one) will be positioned such that the middle point of the edge which corresponds to the X axis of their global bounding box is aligned to the middle point of the edge which corresponds to the X axis of the first (reference) object's global bounding box.
- **X Max alignment**: the selected objects (excluding the reference one) will be positioned such that the maximum point of the edge which corresponds to the X axis of their global bounding box is aligned to the maximum point of the edge which corresponds to the X axis of the first (reference) object's global bounding box.
- **Y Min alignment**: the selected objects (excluding the reference one) will be positioned such that the minimum point of the edge which corresponds to the Y axis of their global bounding box is aligned to the minimum point of the edge which corresponds to the Y axis of the first (reference) object's global bounding box.
- **Y Mid alignment**: the selected objects (excluding the reference one) will be positioned such that the middle point of the edge which corresponds to the Y axis of their global bounding box is aligned to the middle point of the edge which corresponds to the Y axis of the first (reference) object's global bounding box.
- **Y Max alignment**: the selected objects (excluding the reference one) will be positioned such that the maximum point of the edge which corresponds to the Y axis of their global bounding box is aligned to the maximum point of the edge which corresponds to the Y axis of the first (reference) object's global bounding box.
- **Z Min alignment**: the selected objects (excluding the reference one) will be positioned such that the minimum point of the edge which corresponds to the Z axis of their global bounding box is aligned to the minimum point of the edge which corresponds to the X axis of the first (reference) object's global bounding box.
- **Z Mid alignment**: the selected objects (excluding the reference one) will be positioned such that the middle point of the edge which corresponds to the Z axis of their global bounding box is aligned to the middle point of the edge which corresponds to the X axis of the first (reference) object's global bounding box.
- **Z Max alignment**: the selected objects (excluding the reference one) will be positioned such that the maximum point of the edge which corresponds to the X axis of their global bounding box is aligned to the maximum point of the edge which corresponds to the Z axis of the first (reference) object's rendering area.
<div drawio-diagram="604"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-7-1676363633.png" alt=""/></div>
##### Pivot 3D
The translate mode is possible only for the selected object or for the selected objects and its children.
<div drawio-diagram="6562"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724404192.png" alt=""/></div>
- "ObjectOnly": translate only object
- "ObjectAndChildren": translate object and its children
#### Default Camera
You can set the default camera for each Scene Editor (Scene Editor -0 through Scene Editor -3). The available default cameras are the Editor Camera, Scene Camera, and Orthogonal Cameras (Front/Rear/Top/Bottom/Left/Right).
<div drawio-diagram="8621"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-7-1760596887.png" alt=""/></div>
<p class="callout info">When the default camera is set to "Scene Camera", the first Camera node in the scene, in alphabetical order by name, is used. If the scene does not contain any Camera nodes, the Editor camera will be used instead.</p>
#### Other 3D Editing Aids
Other 3D editing helpers available in SceneComposer are:
##### Exact Camera View in Scene Editor
"Exact Camera View" menu option will make the camera from the scene to ignore the current aspect ratio of the scene render.
- When Exact Camera View is disabled the view of the active camera is stretched on the available rendering surface.
- When Exact Camera View is enabled, SceneComposer makes additional computations on the camera so that the camera view image does not get distorted on the scene rendering panel.
- Using this mode may lead to different output compared to the rendering output on display (the display on which the camera renders).
<div drawio-diagram="6585"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724412443.png" alt=""/></div>
<div drawio-diagram="6586"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724412453.png" alt=""/></div>
##### Zoom to Selected Objects
Zoom to selected objects offers a shortcut command by using the "A" key for zoom operation on previous selected object. This functionality is available only in producer camera (perspective and orthogonal camera).
##### Zoom to Scene
Zoom to scene offers a shortcut command by using the "F" key for zoom operation on the current scene. This functionality is available only in producer camera (perspective and orthogonal camera).
<p class="callout info">"A" and "F" keys are activating the "Scene" or "Selection" option of the combobox from Toolbar. </p>
# Graphic Options
# Anti-Aliasing
#### Enable anti-aliasing
Enables anti-aliasing effect.
Anti Aliasing is a technique of adjusting pixel positions or setting pixel intensities so that there is a more gradual transition between the color of a line and the background color in order to give a smoother appearance of the object. The image bellow illustrates the Antialiasing effect on an object.
<div drawio-diagram="617"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-7-1676365018.png" alt=""/></div>
<div drawio-diagram="6587"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724412635.png" alt=""/></div>
<p class="callout info">The changing of the anti aliasing will only take effect after the application is restarted.</p>
# False Color Mipmap
#### Enable false color mipmap for all textured elements
Enables the False Color MipMap feature.
Mipmapping is a texturing technique for reducing artifacts caused by mapping a large texture onto a small area in screen space. It is accomplished by creating pre-downsized versions of the texture. A mipmap level is a single downsized version of the original texture, at some resolution.
<div drawio-diagram="619"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-7-1676365125.png" alt=""/></div>
In the false-color mipmap technique each mip level has a different contrasting color. This can be seen in the image bellow:
The textures of the ground surface and the car's exterior are configured with Mipmap Filter "MipMapNearest".  "False color mipmap" is enabled in the Preferences window. False color mapmap visualizes different mipmap levels by different colors in Scene Editor panel as well as in the display view.
<div drawio-diagram="6591"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724415505.png" alt=""/></div>
# Plugin Options
#### Plugins Available
Available plugins are displayed under  \[ Plugins \] in the Preferences dialog.
All available plugins are enabled by default. To disable a plugin, click the button to the right of its properties. When the button displays "Enable," the plugin is disabled.
<div drawio-diagram="8531"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1755754648.png" alt="drawing-7-1755754648.png"/></div>
<table id="bkmrk-%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%82%99%E8%80%83-astcbit" style="border-collapse:collapse;width:100%;height:681.875px;"><colgroup><col style="width:29.9166%;"></col><col style="width:62.4553%;"></col><col style="width:7.62813%;"></col></colgroup><tbody><tr style="height:29.7969px;"><td class="align-center" style="height:29.7969px;background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Plugin Name**</span></td><td class="align-center" style="height:29.7969px;background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td><td class="align-center" style="height:29.7969px;background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Note**</span></td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">AstcBitmapConverter</td><td style="height:35.3906px;">This is an ASTC bitmap converter. Converts RGBA unsigned byte data to ASTC RGBA.</td><td class="align-center" style="height:35.3906px;">[<span style="color:rgb(0,0,0);"><span style="color:rgb(230,126,35);">Details</span></span>](https://doc3161en.candera.eu/books/3d-devices-common-documentation/page/astcbitmapconverter)</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Used Behavior plugin</td><td style="height:29.7969px;">This plugin extracts the type names of all behaviors included in the solution. When generating assets, a CMake file is generated according to the plugin's specific settings.</td><td class="align-center" style="height:29.7969px;">[<span style="color:rgb(230,126,35);">Details</span>](https://doc3161en.candera.eu/books/build-system-setup/page/used-behaviors-plugin)</td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">Cgi-Studio Image Update</td><td style="height:35.3906px;">This is a plugin for the Image Update function.</td><td class="align-center" style="height:35.3906px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/import-of-resources/page/image-update)</span></td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">CommandLinePlugin</td><td style="height:35.3906px;">This is a plugin for executing commands when generating assets.</td><td class="align-center" style="height:35.3906px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/asset-library-generation/page/plugin-notification-after-generation)</span></td></tr><tr style="height:46.5938px;"><td style="height:46.5938px;">List Property Editor</td><td style="height:46.5938px;">This is a plugin for the List Editor. The List Editor can be used with controls such as BarGraph and LineGraph.
</td><td class="align-center" style="height:46.5938px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/controls-and-behaviors/page/charts)</span></td></tr><tr style="height:46.5938px;"><td style="height:46.5938px;">SpecificationPlugin</td><td style="height:46.5938px;">This is a plugin for Define application specification. Define application specification is required to link data binding sources with Scene Composer.
</td><td class="align-center" style="height:46.5938px;">[Details](https://doc3161en.candera.eu/link/1178#bkmrk-2.-876%AE-sc)</td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">DataBindingEditorPlugin</td><td style="height:35.3906px;">This is a plugin for the Data Binding bind icon and Live Preview panel.
</td><td class="align-center" style="height:35.3906px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/scene-design/page/databinding-ui)</span></td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">Dirty Area Dependency Plugin</td><td style="height:35.3906px;">This is a plugin for the Dirty Area Management (DAM).</td><td class="align-center" style="height:35.3906px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/courier/page/dirty-area-management)</span></td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">ExecutableGenerationPlugin</td><td style="height:29.7969px;">This is a plugin for executing scripts when generating assets.
</td><td class="align-center" style="height:29.7969px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/extending-scenecomposer/page/executable-generation)</span></td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">ExternalResourceContainerPlugin</td><td style="height:29.7969px;">This is a plugin for the Referencing external resource function.
</td><td class="align-center" style="height:29.7969px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/scene-design/page/referencing-external-resource)</span></td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">iMX6 Shader Compiler</td><td style="height:35.3906px;">This is a shader compiler for iMX6.</td><td class="align-center" style="height:35.3906px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/target-setup-for-imx6-with-qnx-os/page/compile-shaders)</span></td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">RCarD3 Shader Compiler</td><td style="height:29.7969px;">This is a shader compiler for RCarD3.</td><td class="align-center" style="height:29.7969px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/target-setup-for-r-car-d3/page/shader-compiler)</span></td></tr><tr><td>RT117XBitmapConverter</td><td>This is a bitmap converter for RT117X.</td><td>[<span style="color:rgb(230,126,35);">Details</span>](https://doc3161en.candera.eu/books/target-setup-for-nxp-rt117x/page/rt117xbitmapconverter)</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">RZA1HBitmapConverter</td><td style="height:29.7969px;">This is a bitmap converter for RZA1H.</td><td class="align-center" style="height:29.7969px;"><span style="color:rgb(230,126,35);">[Details](https://doc3161en.candera.eu/books/target-setup-for-rza1h/page/rza1hbitmapconverter)</span></td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">Cgi-Studio Translator</td><td style="height:35.3906px;">This is a plugin for Localization.</td><td class="align-center" style="height:35.3906px;">[Details](https://doc3161en.candera.eu/books/candera/page/scenecomposer-translator-plugin)</td></tr><tr style="height:35.3906px;"><td style="height:35.3906px;">Traveo2BitmapConverter</td><td style="height:35.3906px;">This is a custom bitmap converter for Traveo2.</td><td class="align-center" style="height:35.3906px;">[<span style="color:rgb(230,126,35);">Details</span>](https://doc3161en.candera.eu/books/target-setup-for-traveo2/page/traveo2bitmapconverter)</td></tr></tbody></table>
<p class="callout info">Enabling/disabling the plugin will take effect after restarting Scene Composer.</p>
#### Plugin-Specific Settings
<div drawio-diagram="8532"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1755760580.png" alt="drawing-7-1755760580.png"/></div>
##### ASTC Configuration
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%9C%A7%E7%B8%AE%E9%80%9F%E5%BA%A6-%E5%9C%A7%E7%B8%AE%E9%80%9F%E5%BA%A6" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:22.5596%;"></col><col style="width:77.5596%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Compression Speed</td><td>The Compression Speed can be set to one of five levels.
##### Behavior Config Generation
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%8B%95%E4%BD%9C%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%9C%89%E5%8A%B9-%E5%AE%9B" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:26.5801%;"></col><col style="width:73.4199%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Behavior Configuration Enabled</td><td>If enabled, a CMake file containing the configuration of all behaviors included in the solution will be generated.
</td></tr><tr><td>Destination path</td><td>Set the path to the CMake file in the CMake flag "CONTROLS\_USED\_BEHAVIORS\_CONFIG\_PATH".
##### Commnad Line
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3-%C2%A0" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:22.5268%;"></col><col style="width:77.4732%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Command Line</td><td>Sets the command to be executed when generating assets.
##### Dirty Area Dependency
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E3%82%A2%E3%82%BB%E3%83%83%E3%83%88%E3%81%AB%E5%90%AB%E3%82%81%E3%82%8B-" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:22.5268%;"></col><col style="width:77.4732%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Include in asset</td><td>If enabled, information about Dirty Area Management will be output to the asset.
##### iMX6 Shader Compiler
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F-%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:24.7914%;"></col><col style="width:75.2086%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Generated output format</td><td>Set the output format from three options (Text, Binary, or Binary program).
</td></tr><tr><td>Custom command line string</td><td>Enter the tool or identifier to execute in command line format. This setting can only be set when the output format is Binary or Binary program.
##### RCarD3 Shader Compiler
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F-%E5%87%BA%E5%8A%9B%E5%BD%A2%E5%BC%8F-1" style="border-collapse:collapse;width:100%;"><colgroup><col style="width:24.6719%;"></col><col style="width:75.3281%;"></col></colgroup><tbody><tr><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr><td>Generated output format</td><td>Set the output format from three options (Text, Binary, or Binary program).
##### Translator
<table id="bkmrk-%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D-%E8%AA%AC%E6%98%8E-%E5%B8%B8%E3%81%AB%E5%87%BA%E5%8A%9B-%E6%9C%89%E5%8A%B9%E3%81%AE%E5%A0%B4" style="border-collapse:collapse;width:100%;height:178.781px;"><colgroup><col style="width:33.2539%;"></col><col style="width:66.7461%;"></col></colgroup><tbody><tr style="height:29.7969px;"><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Setting item**</span></td><td class="align-center" style="background-color:rgb(230,126,35);"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Export always</td><td style="height:29.7969px;">If enabled, all translated text will be included in asset.</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Export Only Used Translatable Texts</td><td style="height:29.7969px;">If enabled, only translated text used in behaviors, etc. will be included in assets.</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Enable Language Pack Source Monitoring</td><td style="height:29.7969px;">If enabled, Language Pack Source files will be monitored.</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Language Pack Source</td><td style="height:29.7969px;">Set the Language Pack Source to be monitored.</td></tr><tr style="height:29.7969px;"><td style="height:29.7969px;">Solution Path</td><td style="height:29.7969px;">The root path of the solution will be displayed.</td></tr></tbody></table>
<p class="callout info">Changes to Plugin-Specific settings will take effect after restarting Scene Composer.
</p>
# Export / Import
##### Plugin Specific Options
Use the "Export" / "Import" buttons, placed above the Preferences window, to export or to import Preferences.
<div drawio-diagram="6595"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-08/drawing-5-1724416152.png" alt="drawing-5-1724416152.png"/></div>
The export process will not imply Shortcuts and Favorites categories (available in Properties panel) which are distinctively exportable.
All the values and settings which belong to the application itself and to the configurable properties of the available plugins will be exported in a desired location. The exported .sccfg archive will contain different .XML files like CustomUIConfig, IAppConfig and ISVNConfig, etc. ...
For any configurable plugin, another specific .XML file will be added in this archive. This .sccfg archive that contains a given configuration could be imported on many other stations to provide the same desired Preferences settings. In this way, it will not be necessary to re-configure every workstation.
