# Solution Handling
# Manage Solutions
# New Solution
#### <a class="anchor" id="bkmrk--2"></a>Create a New Solution
A new solution with all the basic elements can be created via Startup Panel item or menu "File" &gt; "New Solution" or Toolbar item.
<div drawio-diagram="7137"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-10/drawing-7-1729755619.png" alt=""/></div>
</div></div></div>In the "New Solution" dialog that appears after selecting one of the above, you can set basic information for your solution using two items: "Create new solution" and "Solution Settings."
<div drawio-diagram="7537"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-11/drawing-7-1732586426.png" alt=""/></div>
##### Create new solution
<table border="1" id="bkmrk-%E5%90%8D%E5%89%8D-%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%90%8D%E5%89%8D-%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7"><colgroup><col></col><col></col></colgroup><tbody><tr><td>**Name**</td><td>Solution name</td></tr><tr><td>**Solution Template**</td><td>Solution template to use for the solution
(There are several for different purposes, such as Empty, 2D Basic, and 3D Basic.)
</td></tr><tr><td>**Platform Name**</td><td>Target platform
</td></tr><tr><td>**Location**</td><td>Save the location of solution
(Use the \[Browse...\] button to select the location to save the new solution.)
</td></tr><tr><td>**Create directory for solution**</td><td>Create a folder to save the new solution.
</td></tr><tr><td>**Create with default State Machine**</td><td>Include a GlobalStateMachine in the new solution.
(This item can only be set if "Empty" is selected in the Solution Template.)
</td></tr><tr><td>**Is Shared Library**</td><td>Set it as a Shareable Component Library (SCL).
(For more information on SCL, see <span style="color: rgb(230, 126, 35);">[Reusable Solution Libraries](https://doc3161en.candera.eu/link/47#bkmrk-page-title)</span>.)
</td></tr></tbody></table>
##### Solution Settings
<table border="1" id="bkmrk-%E5%B9%85%EF%BC%8F%E9%AB%98%E3%81%95-%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%EF%BC%8F%E3%83%AC%E3%83%B3%E3%83%80%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83"><colgroup><col></col><col></col></colgroup><tbody><tr><td>**Width／Height**</td><td>Display/RenderTarget/2D Camera size</td></tr><tr><td>**Units**</td><td>Width/Height unit</td></tr><tr><td>**Pixels/Inch**</td><td>Resolution</td></tr><tr><td>**Clear Color**</td><td>Set the Clear Color.</td></tr><tr><td>**Color Depth**</td><td>True: The Color Depth set in this option will be applied to the Render Target.
False: The Color Depth of the selected Solution Template will be applied to the Render Target.
Once you have completed configuring the solution, click the \[ Finish \] button to create the new solution.
To configure more solution details at solution creation time, use the New Solution Wizard by clicking "Next &gt;". About details, please refer to <span style="color: rgb(230, 126, 35);">[New Solution Wizard](https://doc3161en.candera.eu/link/39#bkmrk-page-title)</span>.
# New Solution Wizard
When a new Solution is created as shown in the <span style="color: rgb(230, 126, 35);">[previous step](https://doc3161en.candera.eu/books/solution-handling/page/new-solution)</span>, it is possible to use the New Solution Wizard. Here, important parts of the solution can be configured:
<div class="contents" id="bkmrk-set-dimension%2C-resol"><div class="contents"><div class="textblock">
- Mange the Data binding source.
- Manage the import of .fbx files.
- Manage the import images.
</div></div></div>After clicking "Finish", the solution will be created with a configured Data binding source, including the imported .fbx and image files.
<p class="callout info">In the ImportView of the "New Solution Wizard", it is possible to delete selected items before they are imported.</p>
<div class="contents" id="bkmrk-"></div>##### Additional settings
Set the Data binding sources and Include Path to be included in the new solution.
<div drawio-diagram="7139"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-10/drawing-7-1729757184.png" alt=""/></div>
<p class="callout info">\[File\] is set to the Data binding source that is prepared in advance in CGI Studio Scene Composer. You can also set any file.</p>
##### Import FBX
Set the FBX file to import when creating a new solution.
<div drawio-diagram="3949"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-06/drawing-4-1687932145.png" alt=""/></div>
Use the \[Remove from Import\] button to remove the FBX file to be imported.
<div drawio-diagram="7190"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-10/drawing-7-1730098215.png" alt=""/></div>
##### Import images
<div class="textblock" id="bkmrk--3"></div><div class="textblock" id="bkmrk-%22new-solution%22---imp-0">Sets the image file to import when creating a new solution.</div><div drawio-diagram="3952"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-06/drawing-4-1687932433.png" alt=""/></div>
<div class="contents" id="bkmrk--5"><div class="contents">
</div></div><div class="contents" id="bkmrk--7"><div class="contents">
</div></div>It is possible to cancel the creation of a new solution at any moment by using the "Cancel" button. There is the possibility to finish the process of creating a new solution with the Wizard at any step by hitting the "Finish" button. If this option is chosen, it will be necessary to do all the successive configuration and importing manually.
Please note that if the name of a file to be imported contains characters that cannot be used in Scene Composer, an alert message will be displayed and the import operation cannot be performed. For more information on character strings that can be used, please refer to "<span style="color: rgb(230, 126, 35);">[SceneComposer Names Validation Rules](https://doc3161en.candera.eu/link/8#bkmrk-scenecomposer-names-)</span>".
# Custom Solution Templates
#### <a class="anchor" id="bkmrk--0"></a>Default Solution
Any created solution can be set as a template solution:
<div class="contents" id="bkmrk-create-a-new-solutio"><div class="contents"><div class="textblock">
- Create a new solution, name it (example: "MySolutionTemplate") and archive it as a .zip file.
- The .zip file will be added into the Solutions folder. Usually, this folder can be found in the directory &lt;cgi\_studio\_root&gt;\\bin\\SceneComposer\\Data\\Solutions
- Add the new default solution to the XML file "solutions.xml" which can be found in the same folder.
- Write "&lt;Solution Name="My Solution Template" File="MySolutionTemplate.zip" IsDefault="True"/&gt;" and save the XML file.
</div></div></div>After restarting SceneComposer, the added solution can be used as template whenever a new solution is created. It will be accessible in the "Solution template" field from the "New Solution" panel.
<div drawio-diagram="4309"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695375768.png" alt=""/></div>
# Scene Templates
A scene created by the user can be set as a template by checking its IsTemplate property. This property is located in the \[ General \] category in the Properties panel.
<div drawio-diagram="5707"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1715079961.png" alt=""/></div>
</div></div></div>The dialogue used to create new scenes allows the user to select an existing template or import. If there are many scenes - 2D or 3D - created as templates, any of them can be selected and used as a template.
<div drawio-diagram="5708"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1715079982.png" alt=""/></div>
Scenes with the property item **Is Template** set are indicated by an orange frame on the icon. This makes it easy to identify them as scene templates.
<div drawio-diagram="5711"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1715080398.png" alt=""/></div>
<p class="callout info">In addition to scenes, the icons of controls and other elements that can be used as templates are marked with an orange frame as shown above.</p>
#### Imported Scene
- A scene created when importing (FBX, GLTF, Smart Importer) is an imported scene.
- An imported scene cannot be edited, only renaming is possible.
- The user can create a scene based on an imported scene (using the imported scene as template). This can be done by right-clicking on the imported scene in the Solution Explorer panel and choosing *Add Scene From Template*. <div drawio-diagram="4583"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-5-1697791682.png" alt=""/></div>
- If the Imported Scene is overwritten (updated) by the SmartImporter, it will also be reflected in scenes created based on the ImportedScene.
#### Template Scene
- A template scene is a scene that can be treated as a template by setting the scene's *IsTemplate* property to *True*.
- The user can create a scene based on a template scene. This can be done by right-clicking on the template scene in the Solution Explorer panel and choosing *Add Scene From Template*. <div drawio-diagram="4582"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-5-1697791649.png" alt=""/></div>
- Changes to the template scene will **not** be reflected in scenes created based on it.
# Open Solution
#### Open an Existing Solution
Open an existing solution via menu "File" &gt; "Open Solution" or Toolbar item.
<div class="contents" id="bkmrk-it-is-possible-to-op"><div class="contents"><div class="textblock"><dl class="note"><dd><p class="callout info">It is possible to open a solution in SceneComposer by dragging the .scs file on "Solution Explorer" or "Scene Tree" panels.</p>
<div drawio-diagram="5746"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715950275.png" alt=""/></div>
</dd><dd></dd><dd></dd></dl></div></div></div>Select the .SCS file associated with the solution in the "Open" dialog.
<div drawio-diagram="4313"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695377101.png" alt=""/></div>
</div></div></div>#### <a class="anchor" id="bkmrk--11"></a>Recent Solutions
The "File" &gt; "Recent Solutions" menu option contains the last five opened solutions with the most recent displayed first.
<div drawio-diagram="138"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676294650.png" alt=""/></div>
</div></div></div>#### <a class="anchor" id="bkmrk--13"></a>Convert a Solution
Since the format of binary asset files generated by SceneComposer differs from version to version, it is required to convert existing solutions for an upgrade to a new CGI Studio version.
Open a solution to convert it into a new SceneComposer version. The "Solution Conversion" dialog will ask for confirmation before converting the solution:
<div drawio-diagram="3956"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-06/drawing-4-1687932929.png" alt=""/></div>
<div class="contents" id="bkmrk--4"><div class="contents"><div class="textblock">
</div></div></div>Confirm the solution conversion by using the "Convert" option and the solution will be converted and placed in the same folder. After selecting the "Converted copy" option, the solution will be saved in a location chosen by the user.
All the old solution shaders need to be aligned with the new solution shaders. The "Convert Shaders" dialog allows the user to choose if the shaders differences will be solved automatically - by using the "Replace" button - or manually - by using the "Skip" button. At the same time, the user has the possibility to select those old shaders - placed in the upper part of the panel - which has to be replaced with the new solution shaders and shader programs - placed in the lower part of the panel.
<div drawio-diagram="140"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676294703.png" alt=""/></div>
<div class="contents" id="bkmrk--6"><div class="contents"><div class="textblock">
</div></div></div>Finally, a message dialog with the result of the conversion is displayed:
<div drawio-diagram="4315"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695377882.png" alt=""/></div>
<div class="contents" id="bkmrk--8"><div class="contents"><div class="textblock">
</div></div></div>If the conversion process encountered some errors, they will be displayed in the "Errors" section of the "Conversion Results" dialog.
**Additional outputs:**
<div class="contents" id="bkmrk-a-conversion-log-fil"><div class="textblock">
- A conversion log file, named "ConversionLogFile.txt", can be found in the solution folder.
- An archived file named like the solution and the conversion date is created. It can be found in the solution folder and contains the original solution before the conversion.
</div></div>
# Save Solution
#### <a class="anchor" id="bkmrk--5"></a>Save a Solution
A solution can be saved via "File" &gt; "Save Solution" menu or Toolbar item.
<div drawio-diagram="5747"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715950355.png" alt=""/></div>
</div></div></div>#### <a class="anchor" id="bkmrk--7"></a>Save a Solution in a New Location
A solution can be saved via "File" &gt; "Save Solution As..."
<div drawio-diagram="3958"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-06/drawing-4-1687933030.png" alt=""/></div>
</div></div></div>Select the new location for the solution in the "Save As" dialog.
<div drawio-diagram="4317"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695378201.png" alt=""/></div>
</div></div></div>after pressing "Save", the solution is saved in the selected folder.
# Clear Solution Cache
For an opened solution the Scene Composer uses a solution cache, which is stored in %appdata% directory of the user. In some cases, clearing of the solution cache might fix some problems (e.g. working in teams on the same solutions) and free up some space.
By clicking on "Clear Solution Cache" in the File menu the cache of the currently opened solution will be cleared. The solution itself will not be modified.
# Solution Report
#### <a class="anchor" id="bkmrk--6"></a>View the Solution Report
A solution report provides data for all vertex buffers and bitmaps available in a solution. It can be inspected as well as saved into a CSV file.
The "Solution Report..." menu opens a "Solution Report" dialog.
<div drawio-diagram="4318"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695378270.png" alt=""/></div>
</div></div></div><div drawio-diagram="5748"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715950472.png" alt=""/></div>
<div class="contents" id="bkmrk--3"><div class="contents"><div class="textblock">
</div></div></div>The "Save Report..." button opens a dialog asking for the name and a saving location for the report.
<div drawio-diagram="4320"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695378409.png" alt=""/></div>
<div class="contents" id="bkmrk--5"><div class="textblock">
</div></div>
# HMI Report
#### <a class="anchor" id="bkmrk--14"></a>Introduction
The HMI report can be presented in the browser as a set of HTML documents. The documents that make up the report are interlinked and can be navigated using the navigation bar. Other output formats are CSV and Excel. The information provided by this report can allow you to answer several questions regarding your solution. These can include, but are not limited to:
<div class="contents" id="bkmrk-how-many-bitmaps-are"><div class="contents"><div class="textblock">
- How many bitmaps are loaded in my solution?
- How many of these bitmaps are actually being used within my solution?
- What is the biggest/smallest bitmap within my solution?
- What controls/widgets/behaviors/texts are contained in my solution, and where are they used?
</div></div></div>The HMI report will be presented in the browser as a set of HTML documents. The documents that comprise this report are interlinked and can be navigated by using the navigation bar.
</div></div></div>#### <a class="anchor" id="bkmrk--17"></a>Generating the Report
Upon opening Scene Composer and loading your solution, click **Report** within the main toolbar. Select the **HMI Report...** option to display the **HMI Report** dialog box, in which you can customize several aspects of your report.
</div></div><div drawio-diagram="3898"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-06/drawing-4-1686704097.png" alt=""/></div>
<div class="contents" id="bkmrk-"><div class="contents">
</div></div><table border="1" class="align-center" id="bkmrk-1-customize-the-sub-" style="border-collapse: collapse; width: 89.3827%; border-width: 1px; height: 203.531px;"><colgroup><col style="width: 6.639%;"></col><col style="width: 25.5823%;"></col><col style="width: 67.7787%;"></col></colgroup><tbody><tr style="height: 57.7812px;"><td style="border-width: 1px; height: 57.7812px;">1</td><td class="align-left" colspan="2" style="border-width: 1px; height: 57.7812px;">Customize the sub-reports included in the generated HMI report. Check the checkboxes for the items to be output. For details on each item, see <span style="color: rgb(230, 126, 35);">[Report Content](#bkmrk-report-content)</span>.
</td></tr><tr style="height: 58.1719px;"><td rowspan="2" style="border-width: 1px; height: 87.9688px;">2
</td><td class="align-left" style="border-width: 1px; height: 58.1719px;">Styling file</td><td class="align-left" style="border-width: 1px; height: 58.1719px;">This will specify where to retrieve the custom .css file to apply to HTML the documents. If left blank, a default styling file will be used.
</td></tr><tr style="height: 29.7969px;"><td class="align-left" style="border-width: 1px; height: 29.7969px;">Report Output Path</td><td class="align-left" style="border-width: 1px; height: 29.7969px;">This is where you specify the output location for the documents.</td></tr><tr style="height: 57.7812px;"><td style="border-width: 1px; height: 57.7812px;">3</td><td class="align-left" colspan="2" style="border-width: 1px; height: 57.7812px;">This option specifies the format of the output report. See <span style="color: rgb(230, 126, 35);">[Output Formats](#bkmrk-report-formats)</span> for more information.
After selecting the report’s output path, style file, and contents, press the Generate report button to proceed with generating your report.
<div class="contents" id="bkmrk--6"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--20"></a>Report Content
##### <span lang="EN-US" style="color: rgb(0, 0, 0);">Report Sites</span>
<span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Report Options fill generate the following report pages:</span></span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Bitmaps </span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Bitmaps(summary):  An overview of all the bitmaps within your solution. Contains data on bitmap averages, largest and smallest bitmaps, referenced pixel formats, and the frequency at which said formats are referenced.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Bitmaps Details(detailed): Contains a paginated display and search bar for visualizing available parameter information for all bitmaps. Entries can be sorted by column.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Used Bitmaps(summary): An overview of the referenced bitmaps within your solution. Contains data on bitmap averages, largest and smallest bitmaps, referenced pixel formats, and the frequency at which said formats are referenced.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Used Bitmaps Details (detailed): Contains a paginated display and search bar for visualizing available parameter information for all bitmaps. Entries can be sorted by column.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Unused Bitmaps(summary): An overview of the unreferenced bitmaps within your solution. Contains data on bitmap averages, largest and smallest bitmaps, referenced pixel formats, and the frequency at which said formats are referenced.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Unused Bitmaps Details(detailed): Contains a paginated display and search bar for visualizing available information for all bitmaps. Entries can be sorted by column.</span></span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Texts</span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">FontsandStyles: Contains outline of how often particular Fonts and Style are used.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Translations: Contains outline of how often particular translations are used.</span></span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Controls </span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Controls: A list with the 30 most used controls (if available) and how many times each control was used in all scenes.</span>
        </span>
        - - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Also includes a list of all controls and how many times each control was used within all available scenes.</span>
                </span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Behaviours</span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Behaviors: A list of all behaviors and the scenes in which they are used. Also includes the scene type, behavior name, and the name of the entity associated with the behavior and a list of all behaviors indexed first by name, then by the scene in which they are used.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Widgets: A list of the 30 most popular widgets (if available) and the frequency each widget was used in all scenes.</span>
        <span style="color: rgb(0, 0, 0);">Also includes a list of all widgets, indexed by widget name and each scene in which said widget was used.</span></span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Scenes</span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">2D Scenes: A list of all 2D scenes within the solution. A table will be created for each scene showing the quantity of each of the following elements:</span>
        </span>
        - - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">B</span></span><span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">itmaps</span>
                </span>
            - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Controls</span>
                </span>
            - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Render Nodes</span>
                </span>
            - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Text Nodes</span>
                </span>
            - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Widgets</span>
                </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">2D Scenes Details (details): A list of all 2D scenes in the solution. A table will be created for each scene containing the names of the following elements:</span>
        </span>
        - - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Bitmaps</span>
                </span>
                </span>
                </span>
                </span>
                </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">3D Scenes: A list of all 3D scenes within the solution including the number of vertices and triangle of each 3D scene.</span>
        </span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Annotations </span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Annotations: A list of all annotations in the scene, for any node whose annotations property is set.</span>
        </span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Rendering</span>
    </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Rendering: A list of all effects that are used, and how often each effect was used within the solution and a similar list is also provided for text caching strategies and a list showing which text caching strategies are associated with each node, as well as the name of the scene in which said nodes can be found.</span>
        </span>
    - <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">Blending: A list of each blending combination effect and how often they have been used and a list of the blending combinations indexed by combination type, scene type (2/3D), scene name, and then by the entity name associated with the blending combination.</span></span>
##### <span lang="EN-US" style="color: rgb(0, 0, 0);">Output Formats</span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">**Excel:** Basic Excel tables will be generated under selected path under in reports\_excel. The particular sites will be accessible as excel pages. </span>
    </span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">**HTML:** Html pages with navigation and basic sorting and filtering will be generated under the selected path in reports\_html.  The particular sites can be accessed through the navbar. </span>
    </span>
- <span lang="EN-US" style="font-size: 10.5pt; font-family: 'Segoe UI',sans-serif; mso-fareast-font-family: 'Times New Roman'; color: #4472c4; mso-themecolor: accent1; mso-ansi-language: EN-US; mso-fareast-language: DE-AT;"><span style="color: rgb(0, 0, 0);">**CSV:** CSV files will be generated under the selected path under in "csv". The respective pages will be accessible as csv files.</span></span>
<div class="contents" id="bkmrk-bitmaps%28summary%29--%3E-"><div class="contents">
</div></div><div class="contents" id="bkmrk--8"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--22"></a>File Structure
HMI Reporting binaries are located within the **Reporting** folder of the bin directory (bin/Reporting).
- **images** - The various icons required to generate the html report.
- **js** - Utility scripts and other dependencies (i.e. jquery).
- **styles** - The available CSS files.
- **logs** – Contains logs that describe potential errors.
- **doc** - Contains a developers guide for the Python pipeline.
- **scripts** - Contains the Python scripts responsible for generating each subreport.
- **apy.py** - Contains several helper functions for computation purposes.
- **driver.py** - Contains the driver logic that generates the report.
- **setup.bat** - Script that install the necessary Python modules (dependencies).
Standard HTML Assets
HMI Reporting assets for HTML pages like css, icons, and js are available under /bin/ HMIReportAssets.
<div class="contents" id="bkmrk-assets-images---the-"><div class="contents"><div class="contents"><div class="textblock">
</div></div></div></div><div class="contents" id="bkmrk--9"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--23"></a>Using the Command Line for Report Generation
<div class="contents" id="bkmrk--11"><div class="contents">
</div></div><div class="contents" id="bkmrk-subreport-keyword-2d"><div class="contents"><div class="contents"><div class="textblock">In command line run /bin/FTCCmd.exe Report {SolutionFile} /outfile {OutputFilePath} /cssfile {CssFilePath} /reports {ReportList}.</div><div class="textblock">
</div><div class="textblock">**SolutionFile** is the absolute path to the .scs file of the solution. </div><div class="textblock">**OutputFilePath** is the desired output folder path.
**CssFilePath** is an alternative absolute css file path.
**ReportList** is a list of sub-reports  that should be generated separated by #.
</div></div></div></div><div class="contents" id="bkmrk--13"><div class="contents">
</div></div>
# Organize a Solution Using Folders
#### <a class="anchor" id="bkmrk--20"></a>Solution Explorer Panel
SceneComposer organizes the solution in folders. Via "View" &gt; "Solution Explorer" the "Solution Explorer" panel can be enabled, which displays the folder structure. This panel reflects the structure of the folders on the disk.
<div drawio-diagram="5617"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-7-1713768535.png" alt=""/></div>
</div></div></div>A new solution comes with a default structure of folders. The main "Solution" folder contains the following folders:
<div class="contents" id="bkmrk-animations%3A-animatio"><div class="contents"><div class="contents"><div class="textblock">
- **Animations:** Animations can be put into this folder.
- **Controls:** The folder for all Controls used in your solution.
- **Resources:** This folder is for Bitmaps, FBX, Fonts, PSD and other imported resources.
- **Scenes:** This is the place for all 2D and 3D scenes.
- **State Machines:** State Machines are best placed into this folder.
</div></div></div></div><div drawio-diagram="5752"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715954880.png" alt=""/></div>
<div class="contents" id="bkmrk-use-the-context-menu"><div class="contents"><div class="textblock"><dl class="note"><dt></dt><dd><p class="callout info">Use the context menu item "Open In File System" to open the selected item in Windows Explorer.</p>
</dd><dd></dd><dd></dd></dl>---
</div></div></div>#### <a class="anchor" id="bkmrk--23"></a>Filtering and Searching
Solution explorer provides a filter area where the object types that will be displayed in the panel can be filtered.
By pressing the small arrow from the left upper side of the panel, the filter area becomes visible.
<div drawio-diagram="5753"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955009.png" alt=""/></div>
</div></div></div>Use the Search edit box on the top of Solution Explorer to search for different items in the solution.
<div drawio-diagram="5754"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955091.png" alt=""/></div>
<div class="contents" id="bkmrk--5"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--26"></a>Multi-Selection of Objects
For multi-selection of objects, press the Ctrl key while left clicking all the desired elements to select.
When the last desired element is selected the Ctrl key can be released.
After the multi-selection operation it is possible to copy, move or delete all selected items as desired.
</div></div></div>#### <a class="anchor" id="bkmrk--27"></a>Copy, Clone, Rename and Delete Items
The Solution Explorer Context menu allows cloning, renaming and deleting content.
<div drawio-diagram="5755"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955155.png" alt=""/></div>
<div class="contents" id="bkmrk-imported-scenes-and-"><div class="contents"><div class="textblock"><dl class="note"><dt></dt><dd><p class="callout info">Imported scenes and animation can only be deleted.</p>
</dd></dl></div></div></div>##### <a class="anchor" id="bkmrk--29"></a>Clone Items
"Clone" will make a copy of the item and add it to the same folder as the item selected. The name of the copy will be the name of the item suffixed with a number.
It is possible to specify the number of clones to be generated, simultaneously, for an item. If this number is greater than 1, the name will be read-only and generated automatically.
<div drawio-diagram="4321"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695378771.png" alt=""/></div>
<div class="contents" id="bkmrk--10"><div class="contents"><div class="textblock">
</div></div></div>##### <a class="anchor" id="bkmrk--31"></a>Rename Items
"Rename" activates the "Rename Field" where the name of the item can be modified:
<div drawio-diagram="5757"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955271.png" alt=""/></div>
<div class="contents" id="bkmrk-enter-the-desired-na"><div class="contents"><div class="textblock">
- Enter the desired name in the text box.
</div></div></div>##### <a class="anchor" id="bkmrk--33"></a>Delete Items
Delete items by using the "Delete" option from the context menu of the selected item in Solution Explorer or Scene Tree.
**Delete Items without Dependencies**
If the item to delete is not used in the solution, the "Delete Items" dialog simply lists the items to be deleted:
<div drawio-diagram="5759"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955420.png" alt=""/></div>
<div class="contents" id="bkmrk--15"><div class="contents"><div class="textblock">
</div></div></div>**Delete Items with Dependencies**
If the item to delete is used in one or more scenes of the solution, the "Delete Items" dialog will list those dependencies and asks for a resolution strategy:
<div drawio-diagram="5760"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715955668.png" alt=""/></div>
<div class="contents" id="bkmrk--17"><div class="contents"><div class="textblock">
</div></div></div>The default resolution strategy can be selected, which can be overridden for specific dependencies. The following resolution strategies can be applied:
<div class="contents" id="bkmrk-none%3A-the-%22ok%22-butto"><div class="contents"><div class="contents"><div class="textblock">
- **None**: The "OK" button will not work until a specific strategy will be selected.
- **Replace With**: The selected usage item will be replaced with a different item selected by the user.
- **Delete Usage Item**: The selected usage item will be deleted. The element will not be part of the solution anymore.
- **Replace With Null**: The application will use the null value where the dependent elements are used.
- **Remove Array Item**: If there are many elements which are contained in an array (for instance, a Camera inside a Camera Group), the selected item will be removed from the array.
</div></div></div></div><div drawio-diagram="165"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676295713.png" alt=""/></div>
<div class="contents" id="bkmrk-delete-%3E-replace-wit"><div class="contents"><div class="contents"><div class="textblock">
- **Delete &gt; Replace With Null**: When this resolution is selected the application will try to delete all the dependencies. If this does not succeed, the dependent objects will be replaced with null so they will not be used anymore by the items proposed for deletion.
- **Replace With Null &gt; Delete**: When this resolution is selected the application tries to use the null value where the dependent elements are used. If this is not possible every dependent element will be deleted. It will not be a part of the solution anymore.
</div></div></div></div><div class="contents" id="bkmrk--19"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--37"></a>Move Items and Folders with Drag and Drop
Items and folders can be moved via drag &amp; drop.
Items can also be used by dragging them directly into appropriate panels.
If an object is dragged from one folder to another folder where the same type of object is placed under the same name, the object, which is going to be moved to the new folder, is renamed by adding a numbered suffix.
If a drag operation is performed between 2 panels and the target item is part of a multi-selection, all the selected items in the target panel will be affected. For example when 2 groups are selected in the Scene Tree panel and a billboard is dragged over one of the selected groups, a billboard will be added to both selected groups.
# Reusable Solution Libraries
#### <a class="anchor" id="bkmrk--19"></a>Shareable Component Library (SCL) Usage
<div drawio-diagram="5770"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957044.png" alt=""/></div>
</div></div></div>To export a solution already created as a shareable component library (SCL), first, choose the SCL "Library Type" from "File" &gt; "Solution Options" &gt; "General Configuration".
<div drawio-diagram="5769"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957036.png" alt=""/></div>
</div></div></div>The SCL name can be the same with the SCL solution or it can be modified. Second, after the solution has been saved, the "Export SCL" option will become available under the "File" menu. On this way, the solution can be exported as a shareable component library (SCL) in any place selected by the user.
<div class="contents" id="bkmrk-shareable-component--0"><div class="contents"><div class="textblock"><dl class="note"><dd><p class="callout info">Shareable component library (SCL) are not allowed to contain any display. If an already created solution does contain any display, the user will be noticed through a specific dialogue (see the image below).</p>
</dd></dl></div></div></div><div drawio-diagram="5768"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957021.png" alt=""/></div>
</div></div></div>If an older imported/converted solution already contains a .scl file with displays, the error will be showed in Problems panel. In this way, the user will be noticed and will be allowed to correct this situation.
<div drawio-diagram="5767"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957013.png" alt=""/></div>
</div></div></div>After the export of the solution as a SCL solution, the content can be used in another solution after it is imported via "Solution Explorer" panel where a "References" node is available. When right click on the "References" node, the "Add Reference" from the context menu allows the user to select the SCL solution.
<div drawio-diagram="5766"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957006.png" alt=""/></div>
</div></div></div>After selecting an SCL solution, a dialog will appear prompting you to choose a save path format.
<p class="callout info">However, if the path of the selected SCL solution is located within the Solution folder or the Scene Composer folder, it will automatically be saved as a relative path. In this case, the dialog explained in the below will not be shown.</p>
<div drawio-diagram="8286"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-04/drawing-4-1744249980.png" alt=""/></div>
In this dialog, you can select either a **relative path** or an **absolute path**. If you choose to use a relative path, you can further specify the reference base from the following two options:
<div class="contents" id="bkmrk-relative-to%C2%A0scene-co"><div class="contents"><div class="textblock">
- Relative to Scene Composer
- Relative to solution
</div></div></div>If the selected SCL solution exists on the same drive, the relative path option will be available, as shown in the figure above.
If the selected SCL solution exists on the same drive, the relative path option will be available as shown in the figure above.
However, if the selected SCL solution is located on a different drive, it cannot be converted to a relative path. In such cases, the dialog will display only the "Absolute Path" option.
<div class="contents" id="bkmrk--11"></div>After this step, all the available nodes will become visible under the "References" node in the next panels: "Solution Explorer", "Imports", "Toolbox", "Render Targets" and "Templates".
<div drawio-diagram="5765"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715956998.png" alt=""/></div>
<div class="contents" id="bkmrk--13"><div class="contents"><div class="textblock">
</div></div></div>When an external application needs to access some SCL objects, it is mandatory to know which is the SCL name.
<div class="contents" id="bkmrk--14"><div class="contents"><div class="textblock"><div class="fragment">
</div>---
</div></div></div>#### <a class="anchor" id="bkmrk--26"></a>Control of SCL Items Visibility
<div class="contents" id="bkmrk-inherited-%28the-eleme"><div class="contents"><div class="contents"><div class="textblock">
- Inherited (the element, if it is a leaf, will inherit the property of the parent)
- Public (the element will be available as a reusable/shareable resource)
- Private (the element will not be available as a reusable/shareable resource)
</div></div></div></div><div drawio-diagram="5764"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715956977.png" alt=""/></div>
<div class="contents" id="bkmrk--16"><div class="contents"><div class="textblock">
</div></div></div>All the available elements can be used in a new SCS or SCL solution. The leaves will inherit the desired type of visibility of any node just if the flag is set after the selection of the node in Solution Explorer panel. If this operation is done by selecting the node in any other panel, the item visibility will not be inherited by its leaves.
<div class="contents" id="bkmrk-the-referenced-conte"><div class="contents"><div class="textblock"><dl class="note"><dd><p class="callout info">The referenced content of a SCL solution is available only as read only. No modification can be operated on it. If a modification is needed the user has to operate it on the referenced solution. After the modification has been done, the solution has to be saved and exported, again, as a SCL solution.</p>
# Update the Solution Icon
The solution icons displayed in the "Recent" section of the Welcome to Scene Composer screen can be updated.
<div drawio-diagram="5775"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715962049.png" alt=""/></div>
#### How to update the Solution Icon
Select \[ Update Solution Icon... \] from the context menu of the solution name displayed at the top of the \[ Solution Explorer \] to set the current Scene Composer screen as the solution icon.
<div drawio-diagram="5773"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715957988.png" alt=""/></div>
<div drawio-diagram="5774"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715959763.png" alt=""/></div>
<p class="callout info">The updated Solution Icon will take effect after restarting Scene Composer.</p>
# Context Menu
When you right-click an item in Solution Explorer, a context menu appears according to the type of the selected item. This page summarizes the display condition and role of each menu item.
<p class="callout info">Menu items fall into two groups: those that always appear regardless of the type of the selected item, and those whose visibility changes depending on the type of the selected item. The display condition is stated at the beginning of the **Description** for each item.</p>
<div drawio-diagram="9049"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782197550.png" alt=""/></div>
<table border="1" id="bkmrk-item-description-ope" style="border-collapse: collapse; width: 800px; height: 3013.31px;"><thead><tr style="height: 29.7969px;"><th style="background-color: rgb(35, 111, 161); width: 257.5px; height: 29.7969px;"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="background-color: rgb(35, 111, 161); width: 541.5px; height: 29.7969px;"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Open In File System</td><td style="width: 541.5px; height: 85.7812px;">Always appears, regardless of the type of the selected item.
Opens the storage location of the selected item in Windows Explorer. Use it, for example, to check the location of the original image file of a resource.
See: <span style="color: rgb(230, 126, 35);">[Organize a Solution Using Folders](https://doc3161en.candera.eu/books/solution-handling/page/organize-a-solution-using-folders)</span>
</td></tr><tr style="height: 102.578px;"><td style="width: 257.5px; height: 102.578px;">Suppress All Warnings</td><td style="width: 541.5px; height: 102.578px;">Appears for almost all items except the root solution name.
Hides all Problems related to the selected item. When you select a folder, the Problems of its child objects are also hidden together (errors are not affected).
See: <span style="color: rgb(230, 126, 35);">[Problems Browser](https://doc3161en.candera.eu/books/solution-handling/page/problems-browser)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Show Graph </td><td style="width: 541.5px; height: 68.9844px;">Appears for most items except the root solution name and the References node.
Displays the dependencies and references of the selected item in the Graph Dependency panel.
See: <span style="color: rgb(230, 126, 35);">[Usage and Dependencies](https://doc3161en.candera.eu/books/scene-design/page/usage-and-dependencies)</span>
</td></tr><tr style="height: 46.5938px;"><td style="width: 257.5px; height: 46.5938px;">Activate Item</td><td style="width: 541.5px; height: 46.5938px;">Appears for almost all items except the root solution name.
Activates the selected item (the same operation as double-clicking).
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Add </td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a folder.
Creates a new item (such as a new scene, clear mode, or bitmap profile) under the selected folder.
See: <span style="color: rgb(230, 126, 35);">[Create a New Scene](https://doc3161en.candera.eu/books/scene-design/page/create-a-new-scene)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Import </td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a folder.
Opens the Import Resources dialog and imports files into the selected folder.
See: <span style="color: rgb(230, 126, 35);">[How to Import Resources](https://doc3161en.candera.eu/books/import-of-resources/page/how-to-import-resources)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Delete Unused Imports...</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a folder.
Lists the imports that are not used in the solution and deletes the ones you select to clean up the solution.
See: <span style="color: rgb(230, 126, 35);">[Manage Imports](https://doc3161en.candera.eu/books/import-of-resources/page/manage-imports)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Node Attachment Optimization...</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a folder.
Starts the Node Attachment Optimization wizard and optimizes the entire solution or a specific location.
See: <span style="color: rgb(230, 126, 35);">[Node Attachments](https://doc3161en.candera.eu/books/scene-design/page/node-attachments)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Update Solution Icon...</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select the root solution name (at the top of the tree).
Sets the current Scene Composer screen as the solution icon. The setting takes effect after you restart Scene Composer.
See: <span style="color: rgb(230, 126, 35);">[Update the Solution Icon](https://doc3161en.candera.eu/books/solution-handling/page/update-the-solution-icon)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Add Reference...</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select the **References** node.
Selects an SCL (Shared Component Library) solution and imports its contents into another solution as a reference.
See: <span style="color: rgb(230, 126, 35);">[Reusable Solution Libraries](https://doc3161en.candera.eu/books/solution-handling/page/reusable-solution-libraries)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Add Scene From Template...</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an imported scene or a template scene.
Creates a new scene using the selected scene as a template.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Add State Machine...</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select a scene or a node in the Scene Tree.
Adds a State Machine to the selected target.
See: <span style="color: rgb(230, 126, 35);">[State Machine &gt; Basic Operation](https://doc3161en.candera.eu/books/state-machine/page/basic-operation)</span>
</td></tr><tr style="height: 102.578px;"><td style="width: 257.5px; height: 102.578px;">Render In Display </td><td style="width: 541.5px; height: 102.578px;">Appears when you select a scene, camera, render target, or display object.
Enables or disables the display of a camera on the display (for example, to enable or disable all cameras in a scene together).
See: <span style="color: rgb(230, 126, 35);">[Smart Scene / Camera Preview](https://doc3161en.candera.eu/books/display-configuration/page/smart-scenecamera-preview)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Add Camera To Render Target...</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select a render target.
Adds a camera to the selected render target.
See: <span style="color: rgb(230, 126, 35);">[Linking a Camera to a Render Target](https://doc3161en.candera.eu/books/display-configuration/page/link-a-camera-to-a-render-target)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Set As Default Render Target</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a render target.
Sets the selected render target as the default render target of the solution.
See: <span style="color: rgb(230, 126, 35);">[Default Render Target](https://doc3161en.candera.eu/books/display-configuration/page/default-render-target)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Add this Animation to Animation Group(s)...</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an animation.
Adds the selected existing animation to an animation group.
See: <span style="color: rgb(230, 126, 35);">[Creating an Animation Template](https://doc3161en.candera.eu/books/animation-design/page/create-an-animation-template)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Save as Template...</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select an animation.
Saves the selected animation as a template so that you can reuse it.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Interpolation </td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an animation.
Sets the interpolation method of the animation (such as easing).
See: <span style="color: rgb(230, 126, 35);">[Interpolation](https://doc3161en.candera.eu/books/animation-design/page/interpolation)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Type of Values </td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an animation.
Sets the type of animation values (such as absolute or relative values).
See: <span style="color: rgb(230, 126, 35);">[Type of Values](https://doc3161en.candera.eu/books/animation-design/page/type-of-values)</span>
</td></tr><tr style="height: 102.578px;"><td style="width: 257.5px; height: 102.578px;">Clone...</td><td style="width: 541.5px; height: 102.578px;">Appears when you select an item or subfolder that can be cloned (it does not appear for the top-level Solution folder, the root solution name, or the References node). Creates a copy of the selected item in the same folder. The clone is automatically numbered, and you can also specify how many copies to create.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Copy</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an item that can be copied.
Copies the selected item to the clipboard.
See: <span style="color: rgb(230, 126, 35);">[Manage Nodes](https://doc3161en.candera.eu/books/scene-design/page/manage-nodes)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Cut</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an item that can be moved.
Cuts the selected item (use it to move the item to another location).
</td></tr><tr style="height: 102.547px;"><td style="width: 257.5px; height: 102.547px;">Delete</td><td style="width: 541.5px; height: 102.547px;">Appears when you select an item that can be deleted.
Deletes the selected item. If the item is used by other items, the Delete Items dialog opens, where you select how to handle it.
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Rename</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select an item that can be renamed.
Renames the selected item. If an item with the same name exists in the same location, a warning appears.
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Lock</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select an item other than a folder.
Locks the selected item to prevent unintended changes. A locked item is marked with an icon that indicates the locked state.
See: <span style="color: rgb(230, 126, 35);">[Locking UI Elements](https://doc3161en.candera.eu/books/scene-design/page/locking-ui-elements)</span>
</td></tr><tr style="height: 102.578px;"><td style="width: 257.5px; height: 102.578px;">Find </td><td style="width: 541.5px; height: 102.578px;">Appears when you select an item that has references, such as a scene or an animation.
Searches for the widgets that reference the selected item, or the nodes that the selected item references.
See: <span style="color: rgb(230, 126, 35);">[Searching](https://doc3161en.candera.eu/books/solution-handling/page/searching)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Go to Scml</td><td style="width: 541.5px; height: 85.7812px;">Appears when you select a scene, node, render target, animation, or similar item.
Moves to the element in the SCML that corresponds to the selected item.
See: <span style="color: rgb(230, 126, 35);">[SCML Editor](https://doc3161en.candera.eu/books/scenecomposer-markup-language/page/scml-editor)</span>
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Select </td><td style="width: 541.5px; height: 85.7812px;">Appears when you select an item that has child elements (such as a folder or the References node).
Selects the leaf nodes, child nodes, or all child elements together.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Expand All</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an item that has child elements.
Expands the entire tree under the selected item.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Collapse All</td><td style="width: 541.5px; height: 68.9844px;">Appears when you select an item that has child elements.
Collapses the entire tree under the selected item.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Source Control &gt; Update</td><td style="width: 541.5px; height: 68.9844px;">Appears for solutions under source control (SVN).
Gets the latest version of the solution from the repository.
See: <span style="color: rgb(230, 126, 35);">[Source Control Support](https://doc3161en.candera.eu/books/solution-handling/page/source-control-support)</span>
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Source Control &gt; Revert</td><td style="width: 541.5px; height: 68.9844px;">Appears for solutions under source control (SVN).
Reverts all changes you made since the last update.
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Source Control &gt; Lock / Unlock</td><td style="width: 541.5px; height: 85.7812px;">Appears for solutions under source control (SVN).
Locks the solution so that you are the only one who can commit changes. To release the lock, select Unlock.
</td></tr><tr style="height: 68.9844px;"><td style="width: 257.5px; height: 68.9844px;">Source Control &gt; Commit</td><td style="width: 541.5px; height: 68.9844px;">Appears for solutions under source control (SVN).
Uploads the changes you made to the solution to the repository.
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Source Control &gt; Clean Up</td><td style="width: 541.5px; height: 85.7812px;">Appears for solutions under source control (SVN).
Restores the working copy to a consistent state when it becomes inconsistent, for example because of a server problem.
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Source Control &gt; Resolve Conflict</td><td style="width: 541.5px; height: 85.7812px;">Used when a conflict occurs in a solution under source control (SVN).
Resolves a file conflict (you select a method such as Mine or Theirs).
</td></tr><tr style="height: 85.7812px;"><td style="width: 257.5px; height: 85.7812px;">Source Control &gt; Resolved Conflicts</td><td style="width: 541.5px; height: 85.7812px;">Used when a conflict occurs in a solution under source control (SVN).
Lists the conflicts that have occurred and marks them as resolved.
</td></tr></tbody></table>
# Source Control Support
<span style="color:rgb(230,126,35);">[Source Control Support  ](https://doc3161en.candera.eu/link/12#bkmrk-source-control-suppo)</span>
<span style="color:rgb(230,126,35);">[Source Control Commands  ](https://doc3161en.candera.eu/link/12#bkmrk-file-%3E-source-contro)</span>
<span style="color:rgb(230,126,35);">[Types of Resolve Conflicts ](https://doc3161en.candera.eu/link/12#bkmrk-types-of-resolve-con) </span>
#### Source Control Support: Subversion
SceneComposer's built-in source control support uses the Subversion (SVN) Toolchain.
By default, Source Control Support is disabled. Source Control Support can be enabled through the menu "File" - "Preferences...".
Details on Source Control Preferences can be found in chapter <span style="color:rgb(230,126,35);">[Configure Source Control](https://doc3161en.candera.eu/books/preferences/page/configure-source-control)</span>.
Custom source control support can be implemented by means of a specific source control plugin.
See also:
- Source Control Plugin SDK Interface
#### File &gt; Source Control
All Subversion operations are available via the menu File &gt; Source Control
- Import solution to source control
- Checkout solution from source control
- Update
- Revert
- Lock/Unlock
- Commit
- Cleanup
- Resolve Conflicts
##### Import to Source Control
If an entity is not in repository, it can be added by choosing the menu option "File" &gt; "Source Control" &gt; "Import".
You will be prompted for the repository URL and an optional comment in order to add the solution to the specified repository.
<p class="callout info">You have to enter at least part of the Repository URL into the input field manually. The "Browse..." button opens a repository browser window, which helps you to find your desired location in the repository.</p>
<div drawio-diagram="4328"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695393771.png" alt="drawing-5-1695393771.png"/></div>
##### Checkout solution from source control
A solution that has already been saved in a repository, can be opened from the Source Control by selecting the "Checkout" menu option from "File" &gt; "Source Control".
In the checkout dialog you can fill in the information about the Repository URL and choose the location.
<div drawio-diagram="4330"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695394980.png" alt="drawing-5-1695394980.png"/></div>
The first time you will be asked to authenticate. Following dialog will appear and the username and password for the repository will be requested.
<div drawio-diagram="50"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676273255.png" alt="drawing-4-1676273255.png"/></div>
The content of the solution loaded from source control is displayed as any other solution in the Solution Explorer. All the items will have specific icons indicating their source control status.
<div drawio-diagram="52"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676273288.png" alt="drawing-4-1676273288.png"/></div>
##### Update
In order to get the latest version of the solution from the repository, right click on the solution from the Solution Explorer panel and choose the option "Update" from the context menu. An update dialog displaying all the changes obtained from the repository appears.
<div drawio-diagram="4333"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-09/drawing-5-1695395646.png" alt="drawing-5-1695395646.png"/></div>
##### Revert Entity to Source Control
Undo all changes you made in a solution since the last update by selecting the solution from Solution Explorer panel, right-click and select "Source Control" &gt; "Revert" from the context menu.
##### Lock/Unlock
Be the only person allowed to commit changes on the entire solution; right-click on the item in the "Solution explorer" panel and select the "Lock" option from the context menu. In the same manner the object/solution can be unlocked by choosing the "Unlock" option.
##### Commit Changes
Upload the changes made on the solution to the repository; right-click on the solution in the "Solution explorer" panel and select the "Commit" option from the context menu. A dialog displaying all the changes to commit appears.
##### Clean Up
If a subversion command cannot complete successfully, perhaps due to server problems, your working copy can be left in an inconsistent state. In that case you need to do a cleanup operation by choosing the context menu option "Clean Up" on solution.
##### Resolve Conflicts
Sometimes, when updating/committing the files from the repository one can get a conflict. There are two main types of conflicts:
- **File conflicts** : occurs when two (or more) users have changed the same lines of a file
- **Tree conflicts** : occurs when a user has renamed/deleted/moved a file/folder which another user has either renamed/deleted or moved meanwhile.
In order to understand the further information about the conflicts' resolving, it is necessary to explain some Source Control specific terms:
- **HEAD revision** : represents the latest revision of a file or folder in the repository
- **BASE revision** : represents the current revision of a file or folder in the user's working copy. This is the revision, the file or folder it was in, when the last checkout, update or commit was performed. The BASE revision is normally not equal to the HEAD revision.
#### Types of Resolve Conflicts
- **BASE revision** : represents the current revision of a file or folder in user's working copy. This is the revision, the file or folder which it was in, when the last checkout, update or commit was performed. The BASE revision is normally not equal to the HEAD revision.
##### File Conflicts
A file conflict occurs when more users have changed the same lines of a file. It is the user's responsibility to choose how the conflict should be resolved because there are more possible alternatives. Whenever a file conflict occurs, the Source Control places three new files in the directory:
- FileName.extention**.mine** : this is the file as it existed in the working copy before the update. This file has the latest changes in it and nothing else. It doesn't contain any conflict markers.
- FileName.extention**.rOldVersionNumber** : this is the file that the user checked out before the latest edits. It shows the BASE revision before the latest update of the working copy.
- FileName.extention**.rNewVersionNumber** : this is the file that the Source Control has just received from the server when the user updated the working copy. It corresponds to the HEAD revision of the repository.
Whenever a conflict is reported, you should open the file in question, and search for lines starting with the string &lt;&lt;&lt;&lt;&lt;&lt;&lt;. The conflicting area is marked like this:
<div drawio-diagram="54"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676273448.png" alt="drawing-4-1676273448.png"/></div>
In order to resolve a conflict, the user has more than one option to choose from.
The following alternatives are offered in the "Resolve conflict" dialog that opens from the contextual menu "Source control" &gt; "Resolve conflict" option:
1. Resolve using **Mine** : resolve the current conflict by choosing the local version (FileName.extention.mine) on all conflicts, for the rest it uses the auto-merged. The conflict is "Marked as resolved" by default after choosing this option.
2. Resolve using **MineFull** : resolve the current conflict by choosing the entire local file (FileName.extention.mine). The conflict is "Marked as resolved" by default after choosing this option.
3. Resolve using **Theirs** : resolve the current conflict by choosing "their" file which is the incoming file (FileName.extention.rNewVersionNumber) on all conflicts, for the rest it uses the auto-merged. The conflict is "Marked as resolved" by default after choosing this option.
4. Resolve using **TheirsFull** : resolve the current conflict by choosing the incoming file(FileName.extention.rNewVersionNumber). The conflict is "Marked as resolved" by default after choosing this option.
5. **Edit conflict** : opens an editor where the user can edit the new revision file(FileName.extention.rNewVersionNumber), the file .mine (FileName.extention.mine) and upon these changes the merged file will be changed dynamically. After this, the user will save the changes and will be able to mark the conflict as resolved by pressing the "Mark as resolved" button. Please note that the "Mark as resolved" command does not really resolve the conflict. It just removes the FileName.extention.mine and FileName.extension.r\* files, to allow the user to commit the changes.
6. **Resolved** : the user decides only to mark the conflict as resolved leaving the file as it resulted after the latest update, without making other changes on file. This way the user will be able to commit the file.
<div drawio-diagram="57"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676273620.png" alt="drawing-4-1676273620.png"/></div>
##### Tree Conflicts
As it was previously mentioned, a tree conflict occurs when a user has renamed/deleted/moved a file/folder which another user has either renamed/deleted or moved in the meantime.
There are many different situations that can result in a tree conflict, and all of them require different steps to resolve the conflict. For the moment, SceneComposer subversion feature only offers the option "Resolve" for tree conflicts.
<div drawio-diagram="60"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676273653.png" alt="drawing-4-1676273653.png"/></div>
<p class="callout info">The Resolve command does not really resolve the conflict. It just removes the FileName.extention.mine and FileName.extention.r\* files, to allow the user to commit his changes. The user will manually resolve the tree conflict or use an external tool.
</p>
From the Solution explorer panel, select an item and choose "Source Control" &gt; "Resolved conflict" context menu option.
In the new opened dialog the user will be able to see all existing conflicts and their types (file conflict or tree conflict).
After the user marks the conflict as resolved he can decide whether he will cancel or commit his local changes.
# Solution Options
# General Configuration
This section allows you to configure fundamental settings that affect the entire solution. It includes essential parameters such as the library type (Solution/SCL), identification settings, default culture, text style, and memory usage options. These configurations directly influence the structure, reusability, and behavior of the project. It is recommended to review and define these settings early in the development process.
#### Library Management Settings
<div drawio-diagram="8418"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748310978.png" alt=""/></div>
This group of settings defines the classification and identification properties necessary for managing reusability and uniqueness of a solution. By utilizing the <span style="color: rgb(230, 126, 35);">[SCL format](https://doc3161en.candera.eu/books/solution-handling/page/reusable-solution-libraries)</span>, you can export a solution as a reusable component and share its resources with other projects.
- **Library Type:**
    Specifies whether the current solution should function as a standard project (Solution) or as a reusable library (SCL: Shared Component Library). When configured as an SCL, the solution can be exported as an archive containing SCML, binary files, and metadata, and then reused in other projects.
- **Library Id:**
    A 32-bit unsigned integer used to uniquely identify each item in the library within the solution. If the value is set to 0, it will be automatically generated upon saving.
- **Safety Asset Custom Id:**
    This field is used to assign additional identification information related to safety or functional classification. It can be helpful for asset-specific management and control purposes.
#### Asset Culture
<div drawio-diagram="8419"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748310997.png" alt=""/></div>
The default culture for the solution can be selected from the \[Asset Culture\] dropdown menu. This setting affects the entire solution and determines the base language and regional formatting used for localized texts and assets.
#### Enable uniform setter auto activation
<div drawio-diagram="8420"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311020.png" alt=""/></div>
When this option is enabled, ShaderParamSetter configurations are automatically applied. If the "Auto activation scope" property is set to *Local*, per-asset parameter settings that would normally require manual configuration are handled automatically.
If the scope is set to *Global*, the system uses shader-defined Auto Uniforms to determine and apply all relevant activation flags at asset generation time.
This feature simplifies the configuration process while ensuring consistent rendering behavior. For further information, refer to the <span style="color: rgb(230, 126, 35);">[Generic ShaderParamSetter](https://doc3161en.candera.eu/link/146#bkmrk-generic-shaderparams)</span> documentation.
#### Preserve SCML document formatting
<div drawio-diagram="8421"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311037.png" alt=""/></div>
Enabling this option allows the SCML Editor to preserve the original formatting and comments in the SCML source files. This is useful for maintaining manually added annotations or structured formatting. For more information, refer to the <span style="color: rgb(230, 126, 35);">[SCML Editor](https://doc3161en.candera.eu/books/scenecomposer-markup-language/page/scml-editor)</span> documentation.
#### Enable byte alignment of bitmap pixels data in asset
<div drawio-diagram="8422"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311053.png" alt=""/></div>
When this option is enabled, Scene Composer aligns bitmap pixel data within asset files to 8-byte boundaries. This alignment can improve graphical processing performance and optimize data transfers in certain environments.
#### Enable automatic import
<div drawio-diagram="8424"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311093.png" alt=""/></div>
To automate the import of image and FBX files, enable this option and configure monitored folders. When new files are added or existing ones updated in the specified folders while the solution is running, the import process is triggered automatically. The <span style="color: rgb(230, 126, 35);">[monitored folder](https://doc3161en.candera.eu/books/import-of-resources/page/automatic-imports)</span> must be set separately.
#### Maximum number of scenes rendered in display preview
<div drawio-diagram="8425"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311116.png" alt=""/></div>
This setting defines the upper limit of scenes rendered simultaneously in the display preview. It helps prevent excessive resource usage and rendering overhead. Which scenes are rendered depends on the cameras enabled in the **Render Targets** panel.
We recommend using the dedicated commands in the "Render In Display" menu to enable or disable scenes, cameras, and displays appropriately. If the defined limit is exceeded, a warning is displayed to the user.
#### Shows text from the master culture instead of the text Id
<div drawio-diagram="8426"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311131.png" alt=""/></div>
When enabled, this option displays the actual text from the master culture instead of the <span style="color: rgb(230, 126, 35);">[text ID](https://doc3161en.candera.eu/link/162#bkmrk-switching-cultures)</span>. If no text is defined for the master culture, the text ID will be shown as a fallback.
#### Exports only the master culture
<div drawio-diagram="8427"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311145.png" alt=""/></div>
When enabled, only the master culture’s text entries will be included in the exported asset. This is useful when generating lightweight assets prior to localization.
#### Default text style
<div drawio-diagram="8428"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311164.png" alt=""/></div>
The selected "Default Text Style" is applied only to newly added text nodes within the template solution. It does not affect any pre-existing elements. The style is applied exclusively when a user adds a new text node to the template solution by dragging and dropping it.
#### Default memory pool
<div drawio-diagram="8429"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-4-1748311189.png" alt=""/></div>
Selects the memory pool used when loading image data. This setting can affect asset performance and memory usage.
- **VideoMemory:**
    Stores images in GPU video memory (VRAM). Recommended when high rendering performance is required.
- **ClientMemory:**
    Stores images in CPU system memory (RAM). Useful for maximizing compatibility or when VRAM usage needs to be minimized.
- **ExternalMemory:**
    Uses externally managed memory regions. This is typically used in embedded environments where memory is shared or managed by external systems.
Choose the most appropriate memory pool based on your target system’s architecture and performance requirements.
#### Default Startup scene
<div drawio-diagram="9132"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-07/drawing-4-1785386325.png" alt=""/></div>
The **Default startup scene** option specifies which scene appears when you open the solution. Select the checkbox, and then choose the scene to display from the drop-down list. When the checkbox is cleared, the solution opens with the scene you viewed last.
# Data Backup
Creating backups function is important for reducing the risk from unexpected outages. In this way, SceneComposer gives to the user the ability to restore the system to a previous valid state.
All the saved snapshots can be accesed via Solution Options panel. There, in the "Data Buckup" section, the latest snapshots are available in the "Backups for the current solution" field. The user can select one of them in order to restore the solution to it.
<div drawio-diagram="6645"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599266.png" alt=""/></div>
</div></div></div>Any restore point of the solution can be found on the hard disk as follows:
# References
The content of an SCL solution can be used in another solution after it is imported through the "Solution Options" panel. Here is a specific section - "References" - where all the imported references are visible and additional references can be added.
<div drawio-diagram="6646"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599309.png" alt=""/></div>
# Cultures
In order to compose texts in different languages, a culture (language setting) must first be created.
<div drawio-diagram="6647"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599409.png" alt=""/></div>
<table border="1" id="bkmrk-%281%29-%E3%82%AB%E3%83%AB%E3%83%81%E3%83%A3%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%83%9C%E3%82%BF%E3%83%B3-%E3%82%AB%E3%83%AB%E3%83%81%E3%83%A3" style="border-collapse: collapse; width: 100%;"><colgroup><col style="width: 8.89988%;"></col><col style="width: 22.2497%;"></col><col style="width: 68.8504%;"></col></colgroup><tbody><tr><td class="align-center">(1)</td><td class="align-left">Add Culture button</td><td>Add a new culture setting row.
</td></tr><tr><td class="align-center">(2)</td><td class="align-left">Remove Culture button</td><td>Delete the selected culture setting row.</td></tr><tr><td class="align-center">(3)</td><td class="align-left">Search field</td><td>You can search for a specific text entry by entering any string into the search field.
</td></tr><tr><td class="align-center">(4)</td><td class="align-left">Culture</td><td>You can select a language from the Culture drop-down menu. This language will serve as the target language for the localization.
</td></tr><tr><td class="align-center">(5)</td><td class="align-left">Layout Direction</td><td>Selects the direction in which the text is displayed. Normally, the appropriate text orientation is selected automatically, depending on the selected Culture.
</td></tr><tr><td class="align-center">(6)</td><td class="align-left">Translated Texts</td><td>Shows the number of text entries linked to the culture.</td></tr><tr><td class="align-center">(7)</td><td class="align-left">Owned by</td><td>The name of the solution for which this setting has made is displayed.</td></tr><tr><td class="align-center">(8)</td><td class="align-left">OK button</td><td>Use this button to save settings.</td></tr><tr><td class="align-center">(9)</td><td class="align-left">Cancel button</td><td>Use this button to close the dialog box without saving settings such as added or deleted cultures.
<div class="contents" id="bkmrk-to-add-a-new-culture"><div class="contents"><div class="contents"><div class="textblock">
- Similar settings can also be made via the Culture Solution Options button on the toolbar.
- For information on how to set up multiple languages after setting up a culture, please click <span style="color: rgb(230, 126, 35);">[here](https://doc3161en.candera.eu/books/scene-design/page/create-and-manage-cultures-and-translatable-texts)</span>.
# Solution Information
This feature allows you to set an easily recognizable name, description, and thumbnail image for each solution. This makes it possible to instantly grasp the content of a solution on the Scene Composer <span style="color: rgb(230, 126, 35);">[Startup Panel](https://doc3161en.candera.eu/link/9#bkmrk-startup-panel)</span>, preventing mix-ups and editing mistakes. Even when managing multiple projects in parallel, you can immediately identify the purpose of each solution, making it a powerful management tool that helps streamline your daily editing work and project progress.
<div drawio-diagram="8486"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-07/drawing-4-1751962071.png" alt=""/></div>
<table border="1" id="bkmrk-title-sets-the-name-" style="border-collapse: collapse; width: 100%; height: 283.594px;"><colgroup><col style="width: 25.0596%;"></col><col style="width: 75.0596%;"></col></colgroup><tbody><tr style="height: 80.1875px;"><td style="height: 80.1875px;">Title</td><td style="height: 80.1875px;">Sets the name of the solution.
You can assign any name that differs from the file name, allowing you to identify the solution with a clear and meaningful name for project management. The name is displayed in the tooltip on the Scene Composer Startup Panel.
</td></tr><tr style="height: 80.1875px;"><td style="height: 80.1875px;">Description</td><td style="height: 80.1875px;">Allows you to set a description for the solution.
By noting the purpose of the solution, testing objectives, or key points in its editing history, this description serves as a useful reference when managing multiple solutions. The description is displayed in the tooltip on the Scene Composer Startup Panel.
</td></tr><tr style="height: 93.422px;"><td style="height: 93.422px;">Selected Image</td><td style="height: 93.422px;">Allows you to set a reference image that makes it easier to visually identify the solution. This image is displayed as a thumbnail on the Scene Composer Startup Panel.
- **Browse**: Select a static image file to use as the thumbnail. This disables the ***default behavior*** for the solution’s thumbnail.
- **Revert**: Delete the currently set image (whether a static image or the most recent screenshot) and enable the ***default behavior***.
<p class="callout info">***Default behavior:*** When you perform **\[Save\]** for the solution, a screenshot of the current state is captured automatically and used as the thumbnail. Therefore, after performing **Reset**, be sure to perform **\[Save\]** for the solution.</p>
</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">Image Preview</td><td style="height: 29.7969px;">When an image is selected using “Selected Image,” a preview of the image will be displayed here.</td></tr></tbody></table>
# Default Render Mode
#### Default Render Mode Settings
You can open the Solution Options dialog from \[ File &gt; Solution Options \] in the menu bar to configure various rendering properties under \[ Default Render Mode \]. These properties are automatically applied by SCHost unless another render mode is explicitly set for the object.
<div drawio-diagram="8483"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-07/drawing-4-1751960845.png" alt=""/></div>
If there is a render mode associated with an object, Scene Composer compares these property values with the default render mode settings and includes a bitmask used by the Candera engine within the asset to optimize rendering.
#### Render Mode
<table border="1" id="bkmrk-setting-description-" style="width: 800px; height: 1442.98px; border-collapse: collapse;"><tbody><tr style="height: 29.7969px;"><th style="width: 16.9382%; height: 29.7969px;">Setting</th><th style="width: 82.9427%; height: 29.7969px;">Description</th></tr><tr style="height: 120.422px;"><td style="width: 16.9382%; height: 120.422px;">**CullMode**</td><td style="width: 82.9427%; height: 120.422px;">Configure culling (excluding surfaces from rendering) according to the selected setting. Applying front or back culling optimizes rendering.
- **FrontFaceCulling:** Does not render the front faces.
- **BackFaceCulling:** Does not render the back faces.
- **NoCulling:** Renders all faces without culling.
</td></tr><tr style="height: 86.8281px;"><td style="width: 16.9382%; height: 86.8281px;">**Winding**</td><td style="width: 82.9427%; height: 86.8281px;">Defines the front face of a polygon by setting the vertex drawing order to clockwise or counterclockwise.
- **Clockwise:** Renders with clockwise winding.
- **CounterClockwise:** Renders with counterclockwise winding.
</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Color Write Enabled**</td><td style="width: 82.9427%; height: 46.5938px;">Enables or disables writing fragment color values to the color buffer, configurable per RGBA channel.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Enable Depth Write**</td><td style="width: 82.9427%; height: 46.5938px;">Enables or disables writing to the depth buffer during rendering. When enabled, depth information is recorded in the depth buffer during rendering.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Enable Depth Test**</td><td style="width: 82.9427%; height: 46.5938px;">Enables or disables depth testing. When enabled, the depth buffer is used to control rendering based on depth. If disabled, depth writing is also disabled.</td></tr><tr style="height: 204.406px;"><td style="width: 16.9382%; height: 204.406px;">**Depth Comparison**</td><td style="width: 82.9427%; height: 204.406px;">Configure the comparison function that determines which source (new) pixel depth values pass the depth test. The source depth is compared with the destination (existing) pixel depth using the selected comparison function.
- **Never:** Always fails (never passes any comparison).
- **Less:** Passes when the source depth is smaller than the destination depth.
- **Equal:** Passes when the source depth is the same as the destination depth.
- **LessEqual:** Passes when the source depth is smaller than or the same as the destination depth.
- **Greater:** Passes when the source depth is greater than the destination depth.
- **NotEqual:** Passes when the source depth does not match the destination depth.
- **GreaterEqual:** Passes when the source depth is greater than or the same as the destination depth.
- **Always:** Always passes (passes every comparison).
</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Depth Bias Scale Factor**</td><td style="width: 82.9427%; height: 46.5938px;">Specifies the scale factor to determine how much bias to apply to primitives, mainly used to avoid z-fighting (depth conflicts).</td></tr><tr style="height: 29.7969px;"><td style="width: 16.9382%; height: 29.7969px;">**Depth Bias Units**</td><td style="width: 82.9427%; height: 29.7969px;">Specifies a constant depth offset value used together with the scale factor to adjust and avoid z-fighting.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Enable Blending**</td><td style="width: 82.9427%; height: 46.5938px;">Enables or disables blending (color composition). When enabled, the source color is blended with the destination color in the framebuffer.</td></tr><tr style="height: 29.7969px;"><td style="width: 16.9382%; height: 29.7969px;">**Blend Color**</td><td style="width: 82.9427%; height: 29.7969px;">Defines the constant blend color used when a constant color blend factor is selected.</td></tr><tr style="height: 338.781px;"><td style="width: 16.9382%; height: 338.781px;">**RGB Source Blend Factor**</td><td style="width: 82.9427%; height: 338.781px;">Sets the blend factor applied to the source color in the RGB channels.
- **Zero:** Treated as zero, has no effect during blending.
- **One:** Treated as one, uses the original value.
- **SourceColor:** Uses the RGB value of the source color.
- **InverseSourceColor:** Uses the inverse of the source RGB value (one minus source color).
- **SourceAlpha:** Uses the alpha value of the source color.
- **InverseSourceAlpha:** Uses the inverse of the source alpha value (one minus source alpha).
- **DestColor:** Uses the RGB value of the destination color.
- **InverseDestColor:** Uses the inverse of the destination RGB value (one minus destination color).
- **DestAlpha:** Uses the alpha value of the destination color.
- **InverseDestAlpha:** Uses the inverse of the destination alpha value (one minus destination alpha).
- **ConstantColor:** Uses the specified constant color (set in Blend Color).
- **InverseConstantColor:** Uses the inverse of the specified constant color (one minus constant color).
- **ConstantAlpha:** Uses the specified constant alpha value.
- **InverseConstantAlpha:** Uses the inverse of the specified constant alpha value (one minus constant alpha).
- **SourceAlphaSaturate:** Uses the minimum of the source and destination alpha values for saturated addition, a special blend mode heavily influenced by the source value.
</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**RGB Destination Blend Factor**</td><td style="width: 82.9427%; height: 46.5938px;">Sets the blend factor applied to the destination color in the RGB channels. Available values are the same as RGB Source Blend Factor.</td></tr><tr style="height: 137.219px;"><td style="width: 16.9382%; height: 137.219px;">**RGB Blend Operation**</td><td style="width: 82.9427%; height: 137.219px;">Specifies the operation used for blending RGB values.
- **Add:** Adds values.
- **Subtract:** Subtracts the source from the destination.
- **ReverseSubtract:** Subtracts the destination from the source.
- **Min:** Uses the minimum value.
- **Max:** Uses the maximum value.
</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Alpha Source Blend Factor**</td><td style="width: 82.9427%; height: 46.5938px;">Specifies the blend factor for the source alpha channel, with the same available values as RGB Source Blend Factor.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Alpha Destination Blend Factor**</td><td style="width: 82.9427%; height: 46.5938px;">Specifies the blend factor for the destination alpha channel, with the same available values as RGB Source Blend Factor.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Alpha Blend Operation**</td><td style="width: 82.9427%; height: 46.5938px;">Specifies the operation for blending alpha values, using the same options as RGB Blend Operation.</td></tr><tr style="height: 46.5938px;"><td style="width: 16.9382%; height: 46.5938px;">**Enable Stencil Test**</td><td style="width: 82.9427%; height: 46.5938px;">Enables or disables stencil testing on the stencil buffer, allowing control of rendering based on stencil buffer conditions (area control, masking, etc.).</td></tr></tbody></table>
#### Stencil Front / Stencil Back
<table border="1" id="bkmrk-setting-description--1" style="width: 800px; border-collapse: collapse;"><tbody><tr><th style="width: 18.3501%;">Setting</th><th style="width: 81.6499%;">Description</th></tr><tr><td style="width: 18.3501%;">**Comparison Function**</td><td style="width: 81.6499%;">Configure the comparison function that determines which source (new) values pass the stencil test. The masked reference value (Value) and the masked stencil buffer value are compared, and pass/fail is determined by the selected function.
- **Less:** Passes when the reference value after masking is smaller than the stencil value after masking.
- **Equal:** Passes when the reference value after masking is the same as the stencil value after masking.
- **LessEqual:** Passes when the reference value after masking is smaller than or the same as the stencil value after masking.
- **Greater:** Passes when the reference value after masking is greater than the stencil value after masking.
- **NotEqual:** Passes when the reference value after masking does not match the stencil value after masking.
- **GreaterEqual:** Passes when the reference value after masking is greater than or the same as the stencil value after masking.
</td></tr><tr><td style="width: 18.3501%;">**Value**</td><td style="width: 81.6499%;">Specifies the reference value used with the comparison function for stencil testing.</td></tr><tr><td style="width: 18.3501%;">**Mask**</td><td style="width: 81.6499%;">Specifies the mask value applied to the source and destination data during stencil testing, useful for targeting specific bits during comparison.</td></tr><tr><td style="width: 18.3501%;">**StencilFail**</td><td style="width: 81.6499%;">Sets the stencil buffer operation if the stencil test fails.
- **SetToZero:** Sets the value to zero.
- **Keep:** Keeps the current value.
- **Replace:** Replaces with the reference value.
- **Increment:** Increments by one, clamps at max.
- **Decrement:** Decrements by one, clamps at zero.
- **Invert:** Inverts bits.
- **IncrementWrap:** Increments by one, wraps to zero if exceeded.
- **DecrementWrap:** Decrements by one, wraps to max if below zero.
</td></tr><tr><td style="width: 18.3501%;">**DepthFail**</td><td style="width: 81.6499%;">Sets the operation if the stencil test passes but the depth test fails. Options are the same as StencilFail.</td></tr><tr><td style="width: 18.3501%;">**DepthPass**</td><td style="width: 81.6499%;">Sets the operation if both the stencil and depth tests pass. Options are the same as StencilFail.</td></tr><tr><td style="width: 18.3501%;">**WriteMask**</td><td style="width: 81.6499%;">Specifies the mask value used when writing values to the stencil buffer, allowing control over which bits are written.</td></tr></tbody></table>
# Default Shader Config
<p class="callout info">For Shader Configuration in detail, see <span style="color: rgb(230, 126, 35);">[Shader Configuration](https://doc3161en.candera.eu/books/scene-design/page/shader-configuration)</span>.</p>
During FBX import, no automatic shader assignment for the imported scene is performed. This means the imported nodes have no shader attachments in the node appearance, and rendering is done according to a default shader configuration as specified in the Default Shader Configuration dialog (See below image).
<div drawio-diagram="6649"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599470.png" alt=""/></div>
The default initial shader values for each 3D object type are shown in the table below.
<table border="1" cellpadding="5" cellspacing="0" id="bkmrk-3d-object-type-shade" style="border-collapse: collapse; width: 800px; border-width: 1px; border-spacing: 0px; height: 355.125px;" width="700"><tbody><tr bgcolor="#d4d4d4" style="height: 27.7969px;"><th style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.7969px;">**<span style="vertical-align: inherit;"><span style="vertical-align: inherit;">3D Object Type</span></span>**</th><th style="width: 245.45px; border-width: 1px; padding: 5px; height: 27.7969px;">**<span style="vertical-align: inherit;"><span style="vertical-align: inherit;">ShaderProgram</span></span>**</th><th style="width: 299.5px; border-width: 1px; padding: 5px; height: 27.7969px;">**<span style="vertical-align: inherit;"><span style="vertical-align: inherit;">UniformSetter</span></span>**</th></tr><tr style="height: 33.375px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 33.375px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">Billboard</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 33.375px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTrans\_RefTex</span></span></td><td style="width: 299.5px; border-width: 1px; padding: 5px; height: 33.375px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransShaderParamSetter</span></span></td></tr><tr style="height: 27.7969px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">CanvasSpriteWithNoTexture</span></span></td><td rowspan="2" style="border-width: 1px; padding: 5px; height: 55.5875px; width: 245.45px;">RefCanvasTrans\_RefTex
</td><td rowspan="2" style="border-width: 1px; padding: 5px; height: 55.5875px; width: 299.5px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">Canvas<span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransShaderParamSetter</span></span></span></span>
</span></span></td></tr><tr style="height: 27.7969px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.8px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">CanvasSpriteWith1Texture</span></span></td></tr><tr style="height: 28.5938px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 29.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">MeshWithNoTexture</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 29.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1\_RefColor</span></span></td><td style="border-width: 1px; padding: 5px; height: 29.5875px; width: 299.5px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransLightShaderParamSetter</span></span></span></span></span></span><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">
</span></span></td></tr><tr style="height: 27.7969px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">MeshWith1Texture</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1\_RefColorTex</span></span></span></span></td><td style="border-width: 1px; padding: 5px; width: 299.5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransMorphingMeshTexShaderParamSetter</span></span></span></span></span></span></td></tr><tr style="height: 27.7969px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 29.3875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">MorphingMeshWithNoTexture</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 29.3875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1Morph\_RefColor</span></span></span></span></td><td style="border-width: 1px; padding: 5px; height: 29.3875px; width: 299.5px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransMorphingMeshShaderParamSetter</span></span></span></span></span></span></span></span><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">
</span></span></td></tr><tr style="height: 31.5938px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 31.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">MorphingMeshWith1Texture</span></span></span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 31.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1Morph\_RefColorTex</span></span></span></span></span></span></td><td style="border-width: 1px; padding: 5px; width: 299.5px; height: 31.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransMorphingMeshTexShaderParamSetter</span></span></span></span></span></span></span></span></td></tr><tr style="height: 33.5938px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 33.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">PlanarShadow</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 33.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTrans\_RefUniDiffuseMat</span></span></td><td style="width: 299.5px; border-width: 1px; padding: 5px; height: 33.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransUniDiffuseMat<span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">ShaderParamSetter</span></span></span></span></span></span></span></span></span></span></td></tr><tr style="height: 32.5938px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 32.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">PointSprite</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 32.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransPointSprite\_RefPointSprite</span></span></span></span></td><td style="width: 299.5px; border-width: 1px; padding: 5px; height: 32.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransPointSpriteShaderParamSetter</span></span></span></span></span></span></span></span></span></span></td></tr><tr style="height: 28.5938px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 28.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">SkyBox</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 28.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransCubeMap\_RefCubeMapTex</span></span></td><td style="width: 299.5px; border-width: 1px; padding: 5px; height: 28.5875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">-</span></span></td></tr><tr><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.6px;">SkinningMeshWithNoTexture</td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 27.6px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1Skin\_RefColor</span></span></td><td rowspan="3" style="border-width: 1px; padding: 5px; height: 27.6px; width: 299.5px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">TransLightShaderParamSetter</span></span>
</td></tr><tr><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.6px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">SkinningMeshWithTexture</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 27.6px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">RefTransLight1Skin\_RefColorTex</span></span></span></span></td></tr><tr style="height: 27.7969px;"><td style="width: 254.25px; border-width: 1px; padding: 5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">CanvasText</span></span></td><td style="width: 245.45px; border-width: 1px; padding: 5px; height: 27.7875px;"><span style="vertical-align: inherit;"><span style="vertical-align: inherit;">-</span></span></td></tr></tbody></table>
- The initial value of **SharedInstanceId** is "0" for all types.
- In CanvasText, there is an **AppearanceCollection**, with an initial value of "CanvasText".
# Default Shader Params
On this panel, you can change the default names of values specific to the semantics of the UniformSetter.
<div drawio-diagram="6650"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599545.png" alt=""/></div>
- Select the target for editing from the \[ Auto Uniforms \] and \[ Shader Attributes \] tabs.
- After changing the default name, click the arrow button (the orange frame in the above image) to return the name to the default name.
- Clicking on \[ Reset All \] will return all edited items to their default names.
- Clicking \[ Clear All \] will delete all names.
- When the editing operation is complete, click \[ OK \] button at the bottom of the Solution Options dialog to save the edited results.
- If \[ Cancel \] button is pressed, the edits will not be saved.
# Color Palette
#### <a class="anchor" id="bkmrk--7"></a>Color and Font as Template
Each TextNode (the text brush) has to be configured for using:
<div class="contents" id="bkmrk-a-specific-color-a-s"><div class="contents"><div class="textblock">
- a specific Color
- a specific Font
</div></div></div>It is possible to define some color templates or font templates by using "Color Palette..." or "Font Palette..." that can be found in Solution Options menu ("File" &gt; "Solution Options").
##### <a class="anchor" id="bkmrk--8"></a>Color Palette
By using the Color Palette many color templates can be saved and kept for future projects. The color templates can be used later to create other solutions and scenes without defining again the properties of a new color.
<div drawio-diagram="6651"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599583.png" alt=""/></div>
<div class="contents" id="bkmrk-font%3A-defines-the-ca"><div class="contents"><div class="contents"></div></div></div>#### <a class="anchor" id="bkmrk--12"></a>Color Preview
Selecting a color from the Properties panel will apply the selected color to the elements as preview before closing the editor.
<div class="contents" id="bkmrk-the-element-of-the-o"><div class="contents"><div class="contents"><div class="textblock">
- The element of the object should be selected on the Scene Tree.
- All its material colors properties can be set by using the Color palette. The Color palette opens when any type of color - Ambient/Diffuse/Emissive/Specular - is selected in the Properties panel.
- Any modification of the color will be previewed before closing the editor.
</div></div></div></div><div drawio-diagram="5839"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1716561570.png" alt=""/></div>
<div class="contents" id="bkmrk--4"><div class="contents"><div class="textblock">
</div></div></div>If there are some color templates previously created, they can be used on any object by selecting them from the Color Palette combo box in the Material's section on Properties.
<div drawio-diagram="5840"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1716561673.png" alt=""/></div>
<div class="contents" id="bkmrk--6"><div class="textblock">
</div></div>
# Font Palette
To use specific fonts in each TextNode (text brush), you need to configure the font settings in advance. By using the Font Palette available in the Solution Options menu, you can create and manage font templates that define the font type, size, scale, face, and other font properties to be used.
The created font templates can be applied to each TextNode through the <span style="color: rgb(230, 126, 35);">[Text Style Editor](https://doc3161en.candera.eu/link/54#bkmrk-text-style-editor)</span> and can be used across all solutions and scenes during project development. This allows you to apply consistent font settings efficiently across multiple text elements without the need to specify the fonts individually each time.
#### Font Palette UI
<div drawio-diagram="8467"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-06/drawing-4-1751006308.png" alt=""/></div>
<table border="1" id="bkmrk-1-font-select-the-fo" style="border-collapse: collapse; width: 100%; height: 357.563px;"><colgroup><col style="width: 5.24434%;"></col><col style="width: 21.8588%;"></col><col style="width: 72.8969%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td style="height: 29.7969px;">1</td><td style="height: 29.7969px;">Font</td><td style="height: 29.7969px;">Select the font to use. Choose from the fonts available in the system or within the project from the dropdown list.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">2</td><td style="height: 29.7969px;">Size</td><td style="height: 29.7969px;">Specify the font size in points. The larger the number, the larger the text will appear.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">3</td><td style="height: 29.7969px;">Scale X/Y</td><td style="height: 29.7969px;">Specify the scaling ratio for the horizontal (X) and vertical (Y) directions of the text. The default value is 1 (original size), and setting it to 2 will double the width/height. This option provides the optimal way to scale text without pixelating the glyphs.
</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">4</td><td style="height: 29.7969px;">Face</td><td style="height: 29.7969px;">Select the style included in the font (such as Regular, Bold, Italic). This can be used when the selected font contains multiple styles. For TTC fonts, it is recommended to create individual styles for each face included within the font.
</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">5</td><td style="height: 29.7969px;">Blur Effect</td><td style="height: 29.7969px;">The **Blur Effect** is a function that adds a glow effect to the font. It can be used to enhance visibility or to add design accents by applying a soft glow around the text.
- **Glow**: Enables the glow effect when checked.
- **Width**: Specifies the width of the glow effect. It can be set in five levels, with higher values creating a wider glow.
- **Opacity**: Specifies the opacity of the glow effect. 100% is fully opaque, while 0% is fully transparent.
<p class="callout info">For details about this option, please refer to <span style="color: rgb(230, 126, 35);">[here](#bkmrk-procedure-to-enable-)</span>.</p>
</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">/6</td><td style="height: 29.7969px;">Import fonts</td><td style="height: 29.7969px;">Import external font files into the project. Supports formats such as \*.ttf and \*.otf.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">7</td><td style="height: 29.7969px;">Save</td><td style="height: 29.7969px;">Save the current settings as a new font definition. It will be registered under a different name from existing definitions.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">8</td><td style="height: 29.7969px;">Update</td><td style="height: 29.7969px;">Overwrite and update the selected font definition with the current settings.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">9</td><td style="height: 29.7969px;">Delete</td><td style="height: 29.7969px;">Delete the selected font definition. Note that deletion is irreversible.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">10</td><td style="height: 29.7969px;">Rename</td><td style="height: 29.7969px;">Rename the selected font definition. The name will serve as the identifier when using the font settings in the <span style="color: rgb(230, 126, 35);">[Text Style Editor](https://doc3161en.candera.eu/link/54#bkmrk-text-style-editor)</span> and other areas.</td></tr></tbody></table>
#### Procedure to Enable the Blur Effect
This option can only be configured when `CANDERA_FONTENGINE` is set to `Monotype`. If any other setting is used, this option will not be displayed and cannot be utilized.
##### Configuring the CGI Studio Build Environment (CMake)
For information on building a build environment using CMake, please refer to <span style="color: rgb(230, 126, 35);">[this page](https://doc3161en.candera.eu/link/394#bkmrk-cmake-usage)</span>.
1. Open the CMake configuration for your CGI Studio project.
    - Please refer to <span style="color: rgb(230, 126, 35);">[this page](https://doc3161en.candera.eu/books/build-system-setup/page/new-cmake-environment)</span> for information on the source directory to specify when using CMake.
2. Set the `CANDERA_FONTENGINE` CMake flag to `Monotype`.
    - Please refer to <span style="color: rgb(230, 126, 35);">[this page](https://doc3161en.candera.eu/link/294#bkmrk-overview%3A-cmake-sett)</span> for instructions on how to configure Monotype using CMake.
3. Use CMake to “Configure” the changes and then “Generate” the solution files.
##### Building SCHost.dll
Close SceneComposer before building SCHost.dll, otherwise SCHost.dll cannot be copied to the SceneComposer location.
1. Open the generated Visual Studio solution (e.g., `Player.sln`).
2. Build the `SCHost` project.
3. Ensure that Scene Composer is not running before starting the build.
    - Copy the built `SCHost.dll` to the directory where the Scene Composer executable resides.
    - If the CMake variable `CGIAPP_SCENE_COMPOSER_PATH` is properly configured, the DLL will be automatically copied to the directory containing the Scene Composer executable.
    - If it is not configured, you will need to copy the DLL manually.
4. If you are using the 64-bit version of Scene Composer, ensure that `SCHost.dll` is also built as a 64-bit DLL.
After completing the above steps, launch Scene Composer and confirm that the Blur Effect option is displayed in the **Solution Options &gt; Font Palette** dialog box.
# Text Style Palette
The Text Styles palette section allows you to create, edit, and delete various text style templates.
<div drawio-diagram="4586"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-5-1697796476.png" alt=""/></div>
If there are no imported fonts, fonts can be imported using the \[ Import Fonts... \] button in the upper right corner of the Text Styles palette section. The \[ Import Fonts \] dialog window displayed by this button can also be displayed by selecting fonts from the menu bar \[ Import &gt; Import Resources... \].
<div drawio-diagram="6652"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599634.png" alt=""/></div>
</div></div></div>Text styles are required for nodes and controls that display text. For example, 2D text nodes have a property called \[ Style \] and controls such as text controls and text button controls have a property called \[ TextStyle \]. These properties can be used to set the text style.
<div drawio-diagram="5686"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714612386.png" alt=""/></div>
#### Adding a new Text Style
To add a new text style, press the Add Text Style button to open the Add New Text Style dialog.
<div drawio-diagram="5688"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714612625.png" alt=""/></div>
<p class="callout info">Please refer to <span style="color: rgb(230, 126, 35);">[Font Palette](https://doc3161en.candera.eu/books/solution-handling/page/font-palette "Color Palette / Font Palette")</span> for detailed information about the "Default font" field.
</p>
<div class="contents" id="bkmrk--9"><div class="contents"><div class="textblock"><dl class="note"><dd></dd></dl>
</div></div></div>The newly created created text style has four different sections on the right side of the Text Styles palette window.
- Text Style
- Metrics
- General
- Asset
The following subsections are provided below the text style section.
- Entries
- Cultures
<div class="contents" id="bkmrk--11"><div class="contents"><div class="textblock">
</div></div></div><p class="callout info">Fonts can be configured based on unicode range and language. In other words, the ISO code of the language (the standard nomenclature used to classify languages) conditions the font selection.</p>
##### Entries
Entries can be set to different fonts, which are used for text edited in Scene Composer. First, new children must be added using the "+" button. Any child can be deleted and the order in which they appear can be changed. Every new child has three main properties.
- Lower Bound
- Upper Bound
- Font
<div class="contents" id="bkmrk-bounds-%28lower-and-up"><div class="contents"><div class="contents">
</div></div></div><div drawio-diagram="5689"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714612875.png" alt=""/></div>
<div class="contents" id="bkmrk--14"><div class="contents"><div class="textblock">
</div></div></div>**Bound** in Entries represents an ASCII decimal value corresponding to all the letters of the Latin alphabet (65 to 90 are uppercase letters from A to Z, 97 to 122 are lowercase letters). If a specific font is selected, and the Lower Bound selected is 65 (= U+0041) and the Upper Bound is 90 (= U+005A), then all uppercase letters in text using that style will be rendered in that specific selected font.
<p class="callout info">Bound set in decimal is automatically converted to the corresponding ISO code when the Enter key is pressed.
For example, if Lower Bound is set to 3311, pressing the Enter key will automatically display it as the ISO code "U+0CEF". If Lower Bound is set to 200000, it will automatically display it as the ISO code "U+1E8480".
Values greater than U+010000 are plane units.
</p>
<div class="contents" id="bkmrk-after-any-bound-has-"><div class="contents"><div class="textblock"><dl class="note"><dd>
##### Cultures
</dd><dd></dd></dl></div></div></div>In Culture, different items can be set after adding children in the same way as above. In this way, all text style items are grouped by Culture. For more information, see <span style="color: rgb(230, 126, 35);">[Culture Setting](https://doc3161en.candera.eu/link/49#bkmrk-culture-setting)<span style="color: rgb(0, 0, 0);">.</span></span>
<div drawio-diagram="5690"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714613245.png" alt=""/></div>
<div class="contents" id="bkmrk--17"><div class="contents"><div class="textblock"><dl class="see"></dl>
</div></div></div>In the image below different cultures and entries can be seen (Click to enlarge image).
[![02&#95;text-style&#95;7.png](https://doc3161en.candera.eu/uploads/images/gallery/2023-02/scaled-1680-/02-text-style-7.png)](https://doc3161en.candera.eu/uploads/images/gallery/2023-02/02-text-style-7.png)
<div drawio-diagram="5744"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1715943518.png" alt=""/></div>
<div class="contents" id="bkmrk-the-%22text-style%22-sec"><div class="contents"><div class="contents"><div class="textblock">
- The **"Text Style"** section has a great importance because of the selection of the main font used in association with a created style.
- The **"Metrics"** section presents font line spacing information. The edited results are reflected in the Scene Editor, and the edited values are also used when outputting assets.
    - Ascender: defines the part of a lower-case letter that is taller than the font's x-height
    - Descender: defines the portion of a letter that extends below the baseline of a font.
    - Line Height: represents the vertical distance between lines of text
</div></div></div></div><div drawio-diagram="236"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676339672.png" alt=""/></div>
<div class="contents" id="bkmrk-%22text-style%22-in-the-"><div class="contents"><div class="textblock">
- The **"General"** section provides all the necessary information about the created style: Name, Description, Icon and so forth.
- The **"Asset"** section provides information about exporting, Id, Symbolic name, and [<span style="color: rgb(0, 0, 0);">Candera</span>](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") name and path.
</div></div></div>To find the cultures that are used and the fonts that were set, a verification is done until a valid configuration is found. The codepoint resolution is done according to rules verified in the following order:
<div class="contents" id="bkmrk-check-if-active-cult"><div class="contents"><div class="textblock">
- Check if Active Culture is in the Culture list of the current TextStyle
- Check if Active Culture is in the Culture list of the Base Style
- Configuration of Entries in current Text Style
- Configuration of Entries in Base Style
- Default Font from current Text Style
- Default Font from Base Style
</div></div></div>If none of the above checks will give any result, the default code point will be used.
#### Text Style Editor
There are three ways to open the Text Style Editor:
- Select a TextStyle in the Text Style Palette and press the *Edit text style* button, which will open the *Text Style Editor*.
- Double-click on a TextStyle in the Solution Explorer panel.
- Select a TextStyle in the Solution Explorer panel and choose *Edit* from the context menu.
<div drawio-diagram="5692"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714613516.png" alt=""/></div>
<p class="callout info">TextStyles from the ConstructionKit are not editable.</p>
The Text Style Editor is a dialog that is focused on editing Text Style properties. It provides three sections, which can also be found in the Properties panel:
- Text Style properties
- Entries
- Cultures
<div drawio-diagram="5693"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714614245.png" alt=""/></div>
All text styles are based on the Default Font, which can be changed by clicking on the item selection icon on the right (see figure below). After clicking on the icon, the Font Palette dialog opens and the Default Font can be selected from the selection box.
<div drawio-diagram="5694"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714614392.png" alt=""/></div>
Items in the \[ Entries \] and \[ Cultures \] sections can be edited using the toolbar on the right (see figure below). Pressing the \[ Add Item \] icon opens the <span style="color: rgb(230, 126, 35);">[Text Style Entry Editor dialog](#bkmrk-text-style-entry-edi)</span> where you can edit additional items.
The items in the "Entries" and "Cultures" section can be edited using the little toolbars on the right.
<div drawio-diagram="5695"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714614572.png" alt=""/></div>
<p class="callout info">When sorting configuration items within Cultures, only items within the same Cultures can be sorted.
In the figure below, the user can swap rows 1 and 2 (both with Culture as "en"), but not rows 2 and 3.</p>
<div drawio-diagram="5696"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714614679.png" alt=""/></div>
#### Text Style Entry Editor
The Text Style Entry Editor is used to add or edit items. This editor can be displayed in two ways The Text Style Entry Editor UI that is displayed also depends on the method selected.
1. Press the + icon on the right side of the Entries or Cultures section of the Text Style Editor ( <span style="color: rgb(230, 126, 35);">[Add Entries](#bkmrk-add-entries)</span> ).
2. Double-click on an item that has already been set ( <span style="color: rgb(230, 126, 35);">[Edit Entries](#bkmrk-edit-entries)</span> ).
<div drawio-diagram="5698"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714614883.png" alt=""/></div>
##### Add Entries
As mentioned above, if you press the + icon to the right of the Entries section in the Text Style Editor, the Text Style Entry Editor shown below will appear. Settings can be made for multiple Entries.
<div drawio-diagram="5699"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615023.png" alt=""/></div>
<table border="1" class="align-center" id="bkmrk-1-add%2Fremove-bounds-" style="border-collapse: collapse; width: 700px; height: 89.3907px; border-width: 1px;"><colgroup><col style="width: 46px;"></col><col style="width: 258px;"></col><col style="width: 396px;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td style="border-width: 1px; height: 29.7969px;">1</td><td class="align-left" style="border-width: 1px; height: 29.7969px;">Add/Remove Bounds button</td><td class="align-left" style="border-width: 1px; height: 29.7969px;">Add and remove Bounds ranges for use in Entries. Press the + button to add and the - button to delete.
- By pressing the + button, the Bounds range is added to the "Setting Bounds List" in the next section.
- To delete an item, select the item to be deleted in the "Setting Bounds List" in the next section and press the - button.
</td></tr><tr style="height: 29.7969px;"><td style="border-width: 1px; height: 29.7969px;">2</td><td class="align-left" style="border-width: 1px; height: 29.7969px;">Setting Bounds List</td><td class="align-left">The Bounds list range added/edited in the previous section will be displayed.
</td></tr><tr style="height: 29.7969px;"><td style="border-width: 1px; height: 29.7969px;">3</td><td class="align-left">Select All / Deselect All button</td><td class="align-left" style="border-width: 1px; height: 29.7969px;">Select and deselect the checkboxes of the displayed Bounds items (red frame in the above figure) at once.
- By pressing the left button, all check boxes are checked.
- By pressing the right side button, the currently selected checkboxes will be unchecked all together.
The Lower/Upper Bound value is automatically set according to the check status of the Bounds item's checkbox. For more information on the behavior of the set values, see <span style="color: rgb(230, 126, 35);">[Bounds Range Setting](#bkmrk-bounds-range-setting)</span>.
##### Edit Entries
Bounds editing for the selected Entry on the Text Style Editor. Here you will perform editing operations on the Bounds range set in  <span style="color: rgb(230, 126, 35);">[Add Entries](#bkmrk-add-entries)</span>.
Similar to the explanation for Add Entries, the selection status of the checkboxes in the Boud list (red frame in the figure below) changes when the \[Select All/Deselect All\] button (orange frame in the figure below) is operated.
<div drawio-diagram="5700"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615463.png" alt=""/></div>
##### Bounds range setting
In the Text Style Entry Editor, the Bounds range for each Entry is set by checking the checkbox for each Bound displayed in the list.
- Click on the \[ Select All \] button
    All Bounds will be checked and the Lower/Upper Bound values will be set as follows.
    Lower Bound value: U+0000
    Upper Bound value: U+FFFFFFFFFFF
    <div drawio-diagram="5701"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615696.png" alt=""/></div>
- Click on the \[ Deselect All \] button
    All Bounds will be unchecked and the Lower/Upper Bound values will be set as follows.
    Lower Bound value: Lower value of the upper Bound item in the list among the Bound items in the selected range.
    Upper Bound value: Same value as the Lower Bound value already set.
    <div drawio-diagram="5702"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615711.png" alt=""/></div>
- Check any Bound item
    When any Bound item is checked, the Lower/Upper Bound values are set as follows.
    Upper Bound value: Upper value of the lower Bound item in the list among the Bound items in the selected range.
    <div drawio-diagram="5704"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615788.png" alt=""/></div>
##### Font
Pressing the item selection icon opens the <span style="color: rgb(230, 126, 35);">[Font Palette dialog](https://doc3161en.candera.eu/link/53#bkmrk-font-palette)</span>, where you can select a new font.
<div drawio-diagram="5705"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1714615968.png" alt=""/></div>
##### Select Culture
When editing items in the Cultures section of the Text Style Editor (orange frame below), you can use this pull-down menu (red frame below) to select the culture.
<div drawio-diagram="5712"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-4-1715129570.png" alt=""/></div>
<p class="callout info">When editing the Text Style Entry Editor from the Entries section of the Text Style Editor (blue frame above), the pull-down menu in the Culture section (red frame above) is disabled and Culture cannot be selected.</p>
<div drawio-diagram="4590"></div>
# Clear Mode
The "Clear Mode" item can be created via "Solution Explorer" panel by using the context menu option ("Add" &gt; "New Item"). In this way, all its specific properties ("Clear Color", "Enable Color Write", "Enable Depth Clear" and "Enable Stencil Clear") are related with just one item instead of being included among many other properties of every render target.
A Clear Mode Palette View is available in Solution Options. By using it ("File" &gt; "Solution Options"), it is possible to create different clear mode items which can be saved and reused.
<div drawio-diagram="6653"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599676.png" alt=""/></div>
</div></div></div>If there are many render targets which are referencing the same clear mode item, it is enough to modify the desired property just once rather than modifying all of them.
<div drawio-diagram="5866"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717134650.png" alt=""/></div>
<div class="contents" id="bkmrk--2"><div class="contents"><div class="textblock">
</div></div></div>After the creation of a "Clear Mode" item, it can referenced by one or more Render Targets. This operation can be done using the "Clear Mode" property available in the "Properties" panel associated with any available render target.
<div class="contents" id="bkmrk-if-a-clearmode-is-a-"><div class="textblock"><dl class="note"><dd><p class="callout info">If a ClearMode is a associated to a RenderTarget, the RenderTarget is cleared using that ClearMode before any of the attached cameras renders to it.</p>
</dd></dl></div></div><div drawio-diagram="5870"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717135069.png" alt=""/></div>
<div class="contents" id="bkmrk-see-also%3A-candera%3A%3Ac"><div class="textblock"><dl class="see"><dt>**See also:**</dt><dd>
- [Candera::ClearMode](http://dev.doc.cgistudio.at/APILINK/class_candera_1_1_clear_mode.html "Describes how a viewport is cleared. The color buffer may be cleared using a given color...")
# Bitmap Profile
#### <a class="anchor" id="bkmrk--11"></a>Bitmap Profile
When a graphic object that contains one or many bitmaps is imported, the user has the possibility to set an explicit bitmap profile. Any bitmap profile contains three basic properties which can be set to create a specific profile: "Converter", "Format", and "Origin".
The "Bitmap Profile" feature is accessible in the lower part of any import panel that imports objects which contain bitmaps ("Import FBX", "Import Images", "Import from Solution", "Import from Photoshop").
<div drawio-diagram="5872"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717137473.png" alt=""/></div>
If there are available many bitmap profiles, the user will be able to select any of them by using the drop-down menu. If not, the user can use the "Browse" but to open the "Bitmap Profiles" dialogue which allows the creation of any desired bitmap profile.
Alternatively, the "Bitmap Profile" dialogue can be open via "Solution Options" panel. (Select "File" &gt; "Solution Options".)
<div drawio-diagram="6654"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599715.png" alt=""/></div>
</div></div></div>The Solution Explorer context menu allows the creation of a bitmap profile, too. ("Add" &gt; "New Item")
<div drawio-diagram="5873"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717137552.png" alt=""/></div>
</div></div></div>All the created bitmap profiles are available in "Solution Explorer" panel. They can be organized in a separate folder. By double clicking on any bitmap profile the "Bitmap Profiles" panel becomes accessible.
<div drawio-diagram="5874"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717137673.png" alt=""/></div>
<div class="contents" id="bkmrk--6"><div class="contents"><div class="textblock">
</div></div></div>A default bitmap profile can be specified and it will be used for all bitmaps which do not have a profile set explicitly. If necessary, it is possible to set a default bitmap profile by copying any profile previously created by the user. To do this operation it is enough to use the context menu by right click on a created bitmap profile as can be seen in the image below.
<div drawio-diagram="5875"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717137782.png" alt=""/></div>
<div class="contents" id="bkmrk--8"><div class="contents"><div class="textblock">
</div></div></div>#### Known Issues
When the selected bitmap profile is RLE, RGB565 or RGB888, and the Alpha channel is cut off, a displayed image seems scrambled. In fact, the image is not scrambled, but contains all the artifacts in the source. The affected pixels have a color component and an alpha value of zero. Therefore, the artifacts are not visible when the alpha channel is enabled. When the alpha channel is cut off, then the color channels are shown and therefore those areas get visible.
The solution to this is that the source image has to be modified to remove the color from the areas within zero alpha.
# Icon Picker
It is possible to set any type of image as an icon. This "Icon Picker" feature is accesible in the "Solution Options" panel. (Select "File" &gt; "Solution Options".)
<div drawio-diagram="6655"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599741.png" alt=""/></div>
</div></div></div>The first step towards the creation of a new set of icons is to add images. To select images use the "Import Icons" button which can be found in the upper right corner of the panel. In this way the "Import Icons" panel will become available.
<div drawio-diagram="5876"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717141272.png" alt=""/></div>
</div></div></div>By using the "Select Files" button any desired image and destination folder, for imported images, can be chosen. All images imported as icons will be available as icons and they can be set for any library item (an item which has a folder as Parent) in the solution. The icon can be chosen in the Properties panel.
<div drawio-diagram="5877"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717141374.png" alt=""/></div>
</div></div></div>When an icon is selected for an item, the icon will become immediately visible in the Options panel.
<div drawio-diagram="5878"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717141433.png" alt=""/></div>
<div class="contents" id="bkmrk--6"></div>
# Design Master
The Design Master allows selecting an image that will be displayed as background image in the camera view in order to help on editing.
<div class="contents" id="bkmrk-enable-this-feature-"><div class="contents"><div class="contents"><div class="textblock">
- Enable this feature by checking the checkbox "Enable" and then selecting the desired image from the existing images of the solution (previous imported images).
- After that all 2D scenes will have the selected image set as default Design master.
- Change the image used as background for a specified scene by selecting a different image for the scene property "Design Master" from the Properties panel.
</div></div></div></div><div drawio-diagram="6656"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599772.png" alt=""/></div>
</div></div></div><p class="callout info">When Design Master is enabled, you can select how the Design Master is applied using the Scene2D Design Master Scope property. For details, refer to the [<span style="color: rgb(230, 126, 35);">Scene2D Properties section</span>](https://doc3161en.candera.eu/link/196#bkmrk-scene2d).</p>
This feature can also be enabled by using the button placed near Active Rendering.
<div drawio-diagram="5880"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717142291.png" alt=""/></div>
<div class="contents" id="bkmrk--2"><div class="textblock">
</div></div>
# Problems Configuration
”Errors", "Warnings" and "Messages" that appear in the Problems panel are listed.
<div drawio-diagram="6657"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599838.png" alt=""/></div>
- By checking the \[ Suppress \] checkbox on the panel, you can hide the notifications that appear in the Problems panel.
- Even if this option is enabled, "Warnings" and "Messages" will be hidden, but "Errors" will still be displayed.
<p class="callout info">For more information about the Problems Panel, see <span style="color: rgb(230, 126, 35);">[Problems Browser](https://doc3161en.candera.eu/books/solution-handling/page/problems-browser)</span>.</p>
# Player Configuration
<div drawio-diagram="8518"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-08/drawing-7-1754985941.png" alt=""/></div>
<table border="1" id="bkmrk-%E3%83%91%E3%83%8D%E3%83%AB%E3%83%91%E3%82%B9-%5B-%E5%8F%82%E7%85%A7-%5D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%80%81c" style="width: 96.4286%;"><tbody><tr><td style="width: 25.3874%;">Panel Path</td><td style="width: 74.6126%;">Specifies the path to the CGI Panel. By default, the path points to the correct executable but the path can be changed or browsed for with the \[ Browse \] button.
</td></tr><tr><td style="width: 25.3874%;">Panel Path Type</td><td style="width: 74.6126%;">Specify the path type to the CGI panel from the following three types. \[ Relative to Scene Composer\] is selected by default.
- Absolute
- Relative to solution
- Relative to Scene Composer
</td></tr><tr><td style="width: 25.3874%;">System Parameters</td><td style="width: 74.6126%;">Parameters that are automatically sent to the player at startup (not editable).</td></tr><tr><td style="width: 25.3874%;">User Parameters</td><td style="width: 74.6126%;">Additional command line arguments can be customized here. These arguments will be executed in addition to the arguments specified in System Parameters.
</td></tr><tr><td style="width: 25.3874%;">Default Scene</td><td style="width: 74.6126%;">Select the scene that will be selected by default for the player. To use this option check the checkbox and select the default scene from the scenes set in the solution.
</td></tr><tr><td style="width: 25.3874%;">Automatic port selection</td><td style="width: 74.6126%;">If enabled, a different port will be automatically assigned if the port set in the Application port field is already in use.
</td></tr><tr><td style="width: 25.3874%;">Application port</td><td style="width: 74.6126%;">Specifies the port to use when setting up a TCP connection with the application. Normally, there is no need to change the default value of "13048".
# Default Render Target Configuration
In the File-&gt;Solution Options menu the "Default Render Target Configuration" section allows to set a default render target or to choose whether the camera is activated or not after it has been automatically assigned to the default render target. Default Render Target can also be set to any render target added within the solution.
For more information on how to add a new render target, please refer to Chapter <span style="color: rgb(230, 126, 35);">[Add a new Render Target](https://doc3161en.candera.eu/books/display-configuration/page/add-a-new-render-target)</span>.
<div drawio-diagram="8485"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-07/drawing-4-1751960967.png" alt=""/></div>
Not all cameras can be assigned to a default render target (e.g. newly created 2D camera cannot be assigned to a default 3D render target).
# IBL HDR
Simply specify a single **HDR panorama (latlong) image**, and the Engine will automatically generate the required IBL textures. Here, you can configure the target image. The generated IBL will be used as a shared resource within the project. You can also configure the **HDR panorama (latlong) image** settings during <span style="color: rgb(230, 126, 35);">[importing a glTF file](https://doc3161en.candera.eu/link/1101#bkmrk-images%2C-fonts%2C-shade)</span>.
<div drawio-diagram="8602"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-10/drawing-4-1759384957.png" alt=""/></div>
# Layout Configuration
<div drawio-diagram="6661"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725599958.png" alt=""/></div>
#### Default Bidi Base Level
Defines how alignment is handled in cases where right-to-left characters such as Arabic or Hebrew (Bidi/Bidi) are mixed in with left-to-right writing such as English.
- **Implicit:** Depends on the first strong character in the string. In other words, if the string begins with "a", it is searched from left to right, and if it begins with "ت", the search is from right to left. If it begins with a space, colon and so on, the first character is searched for in the explicit direction.
- **LeftToRight:** Placement is fixed from left to right.
- **RightToLeft:** Placement is fixed from right to left.
- **Culture:** The orientation set in Culture will be applied regardless of the orientation of the parent layout.
- **Inherited:** The placement inherits from the parent's layout orientation. If no layout orientation is set for any parent, the orientation specified in Culture will be applied.
- **Deprecated:** Same as **Inherited**.
#### Default Layout Direction
The Layout Direction property defines how the alignment is handled.
- **LeftToRightDirection**: The alignment is fixed to left-to-right
- **Right-To-LeftDirection**: The alignment is fixed to right-to-left
- **AutomaticDirection**: This is the default layout direction. The default interpretation of AutomaticDirection is to inherit the parent’s value (InheritDirection). If no value is set on any parent, and therefore nothing can be inherited, the culture layout direction is used (CultureDirection).
- **InheritDirection**: Alignment is inherited from the parent layout direction. If no layout direction is set on any parent, the direction of the current culture is used.
- **CultureDirection**: The alignment depends on the culture and is independent of the parent layout direction.
    - Right-to-left for Arabic and Hebrew
    - Left-to-right for most languages (e.g. English, German...)
# Associated Vertex Buffer
<div drawio-diagram="6662"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725600017.png" alt=""/></div>
Here, the original mesh vertex buffer and wireframe vertex buffer information are managed as unique vertex buffer association information.
<table border="1" id="bkmrk-vertex-buffer-vertex" style="border-collapse: collapse; width: 100%;"><colgroup><col style="width: 24.6228%;"></col><col style="width: 75.487%;"></col></colgroup><tbody><tr><td>Vertex Buffer</td><td>Vertex buffer to provide model geometry data</td></tr><tr><td>Wireframe Vertex Buffer</td><td>Wireframe vertex buffer providing model geometry data</td></tr></tbody></table>
<p class="callout info">When importing an FBX file, the vertex buffer and the wireframe vertex buffer are automatically registered if the \[ <span style="color: rgb(230, 126, 35);">[Import as wireframe](https://doc3161en.candera.eu/books/import-of-resources/page/import-dialog-options#bkmrk--01)</span> \] is enabled.</p>
If the vertex buffer association information is available, you will see \[ Wireframe Enabled \] in the context menu of the 3D scene or 3D node.
<div drawio-diagram="7566"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-11/drawing-5-1732883259.png" alt=""/></div>
<div drawio-diagram="6722"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-09/drawing-4-1725624198.png" alt=""/></div>
# Import Images Config
This panel lets you specify, at the solution level, the pixel format applied when importing Radiance HDR (.hdr) files. The format selected here is used as the default value for the **Radiance HDR Format** option in the <span style="color: rgb(230, 126, 35);">[Import Dialog Options](https://doc3161en.candera.eu/books/import-of-resources/page/import-dialog-options#bkmrk-import-dialog)</span>.
<div drawio-diagram="8984"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-04/drawing-4-1777264966.png" alt=""/></div>
#### Format
Select the pixel format used when importing Radiance HDR files. The five available formats are:
<table border="1" id="bkmrk-format-description-r" style="border-collapse: collapse; width: 100%; height: 178.781px;"><colgroup><col style="width: 31.8453%;"></col><col style="width: 68.2739%;"></col></colgroup><tbody><tr style="height: 29.7969px;"><td style="height: 29.7969px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Format</span></td><td style="height: 29.7969px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">**Description**</span></td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">RgbFloatingPoint9E5PixelFormat
</td><td style="height: 29.7969px;">A **shared-exponent** format (equivalent to GL\_RGB9\_E5) that stores a 9-bit mantissa per RGB channel and a single 5-bit exponent shared across all three channels. Each pixel takes **32 bits (4 bytes)** — one third of the footprint of a full RGB float texture. The format cannot represent negative values; its representable range is approximately 0–65,408. Best suited for HDR images that do not require an alpha channel, such as environment maps, skies, and backgrounds.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">RgbFloatPixelFormat</td><td style="height: 29.7969px;">Stores each RGB channel as a **32-bit IEEE 754 single-precision float**, for **96 bits (12 bytes) per pixel**. It offers the widest representable range (≈ ±3.4×10³⁸) and the lowest quantization error of all the formats listed here. Recommended for highest-quality authoring and for preserving the original fidelity of HDR source images, at the cost of the largest memory footprint among the RGB formats.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">RgbHalfFloatPixelFormat</td><td style="height: 29.7969px;">Stores each RGB channel as a **16-bit IEEE 754 half-precision float**, for **48 bits (6 bytes) per pixel**. Its representable range (≈ ±65,504) comfortably covers the dynamic range needed for HDR10 display content. It uses **half the memory of the full float format**, making it the recommended choice when balancing quality and footprint.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">RgbaFloatPixelFormat</td><td style="height: 29.7969px;">Extends RgbFloatPixelFormat with a **32-bit float alpha channel**, yielding **128 bits (16 bytes) per pixel**. Use this format when an HDR image must also carry alpha information (transparency, masks, or auxiliary data) at maximum precision. This is the largest format among the five.</td></tr><tr style="height: 29.7969px;"><td style="height: 29.7969px;">RgbaHalfFloatPixelFormat</td><td style="height: 29.7969px;">Extends RgbHalfFloatPixelFormat with a **16-bit half-float alpha channel**, yielding **64 bits (8 bytes) per pixel**. Use this format when both HDR tonal range and an alpha channel are needed, with half the memory of the full RGBA float format. This is the standard choice for HDR textures that require transparency.</td></tr></tbody></table>
<span style="font-family: -apple-system, BlinkMacSystemFont, 'Segoe UI', Oxygen, Ubuntu, Roboto, Cantarell, 'Fira Sans', 'Droid Sans', 'Helvetica Neue', sans-serif; font-size: 1.666em; font-weight: 400;">Limitations</span>
<p class="callout warning">In an OpenGL ES 2.0 environment, none of the five pixel formats listed above are supported. If your solution contains any of these formats, a warning is shown in the **Problems** panel.</p>
# Annotations
#### Add Annotations
A property named "Annotations" is available on each SceneComposer element. By using this property the user can add individual information to selected objects. The property is located in the "Properties" panel under the "General" section next to the "Description" property. It is provided with a "Restore Default" button which allows the user to reset it. Inside the field of the mentioned property, it is possible to add multi-line information as desired; a new line can be started using &lt;CTRL&gt;&lt;Enter&gt;
<div drawio-diagram="5883"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717145201.png" alt="drawing-5-1717145201.png"/></div>
#### Annotations in SCML Editor
The "Annotations" is serialized only to SCML (no asset, no mff). In this way, the user will be able to see any added "Annotations" in SCML Editor (see the image below).
<div drawio-diagram="4801"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700222733.png" alt="drawing-5-1700222733.png"/></div>
#### Annotations in HMI Reports
The information added on any desired item (scene, bitmap etc.) is shown in the generated HMI report under a separate "Annotations" section.
<div drawio-diagram="5886"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717145525.png" alt="drawing-5-1717145525.png"/></div>
For many details related to the HMI Reports please, consult chapter <span style="color:rgb(230,126,35);">[HMI Report](https://doc3161en.candera.eu/books/solution-handling/page/hmi-report)</span>.
# Searching
#### Search for Objects in a Solution
This chapter describes how to use the "Search" panel for advanced searching for objects in a solution.
##### Specify Search Criteria
Make the Search tab visible in Scene panel. This can be done through the menu "View" - "Search". The select box "Search of Type" allows limiting the search to a specific type of object.
**Objects of the following types can be distinguished** (listed in alphabetical order):
<table id="bkmrk-any-object-any-node-" style="border-collapse:collapse;width:100%;border-width:1px;"><colgroup><col style="width:20.0165%;"></col><col style="width:20.0165%;"></col><col style="width:20.0165%;"></col><col style="width:20.0165%;"></col><col style="width:20.0165%;"></col></colgroup><tbody><tr><td style="border-width:1px;">Any object
Any node
2D Camera
2D Node
3D Camera
</td><td style="border-width:1px;">3D Node
Animation
Appearance
Behavior
Bitmap
</td><td style="border-width:1px;">Control
Control Node 2D
Control Node 3D
Effect
Folder
</td><td style="border-width:1px;">Light
Material
Mesh
Render Node
Render Target
</td><td style="border-width:1px;">Scene
Script Component
Texture
Vertex Buffer
Widget
In the list below the search type and the search button, specific search criteria can be defined related to a specific property of the selected object type. In the example below, a search for all Bitmaps is defined, where the name contains "Gauge".
<div drawio-diagram="5887"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717147737.png" alt="drawing-5-1717147737.png"/></div>
1. Adds additional search criteria. The search function will consider an "AND" operation between several search criteria.
2. Deletes an existing search criterion.
3. Triggers search action. Pressing the Enter key has the same effect.
It is possible to search nodes referred by a widget having property types "Node" and to search widgets which use a node or its descendant as widget properties. For convenience purpose this functionality is also offered as a context menu on widgets and nodes in the Solution Explorer.
<div drawio-diagram="4804"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700223802.png" alt="drawing-5-1700223802.png"/></div>
Any referencing widget can be found by using the context menu via Scene Tree.
<div drawio-diagram="5900"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717161051.png" alt="drawing-5-1717161051.png"/></div>
If a node is referenced by a widget, the node can be found by using the context menu via Widgets panel.
##### Search Results
Search results are listed at the right area of the Search panel. Double-click on an object from the result list and it will be highlighted in the Scene tree. If the searched value cannot be converted to the property type selected, a warning message is displayed.
##### Multiple Selection and Editing
In the result list, multiple objects can be selected. The Properties panel will display all the common properties of the selected items:
- The value column is filled only for properties with the same value for all selected items.
- For the rest of the properties the value column will stay empty.
It is possible to change the value of a property for all the selected items at once, by editing the property value in the Properties panel.
<div drawio-diagram="5889"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717149611.png" alt="drawing-5-1717149611.png"/></div>
#### Text Search
"Text Search" is a feature that provides the possibility to search a desired text inside a whole solution or just in a single scene.
Make the Search tab visible in Libraries panel via the menu "View" &gt; "Text Search".
<div drawio-diagram="5891"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717149701.png" alt="drawing-5-1717149701.png"/></div>
From a logical point of view, the first field that should be set is "Look in". You can select a single scene or the entire solution.
As soon as the "Find what" field is completed, the "Find Next" button becomes active. When the desired word is found, all the other buttons become active. In this way it is possible to find a previous text, or to go forward and find the next one. Replace any of the texts which are found in a solution by:
- using the "Replace" button this action is done for a single entry.
- using "Replace All" button this action is done for all the places where the desired word is found.
<div drawio-diagram="5892"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717149940.png" alt="drawing-5-1717149940.png"/></div>
##### Case sensitive searching:
If the "Match case" check box is checked, only words that match the case of the word or phrase that you typed in the "Find what" field are found. For example, if you search for "Car" (with a capital "C"), the result includes "Car" but not "car".
<p class="callout info">All the search events are displayed in the SCML Editor.</p>
#### Type Ahead Search
In SceneComposer every search field offers the possibility to progressively search for and filter through text. When the text is typed, one or more possible matches for the text are found instantly and immediately presented to the user. This feedback allows stopping short of typing the entire word or phrase they were looking for. You may also choose a closely related option from the presented list.
<div drawio-diagram="5894"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717152651.png" alt="drawing-5-1717152651.png"/></div>
To increase the flexibility and efficiency of searching it is possible to use different wildcards - characters that can be used as a substitute for any of a class of characters.
- The "Star wildcard" is the most frequently employed and the most useful wildcard, which is the same as an asterisk (\*). The star wildcard can represent zero characters, all single characters or any string. For instance, we can use "c\*rs" to find "cars" string.
- The "Question Mark" wildcard (?) is used to represent exactly one character, which can be any single character. Thus, two question marks in succession would represent any two characters in succession, and three question marks in succession would represent any string consisting of three characters. For example, it is possible to use five question marks in a row (?????) to find all the scenes that have names which contain five characters.
- The "Slash" (/) character can be used to follow a given path.
#### Search Helper
**Search Helper** is a feature that lets you build search criteria in natural language. When you describe what you want to find, **Search Helper** generates the corresponding search criteria, and you can apply them to the Search panel.
<p class="callout info">**Search Helper** does not answer questions about how to use the product. When you need an explanation of an operation or a feature, use the product documentation (this document) or the <span style="color:rgb(230,126,35);">[Docs Agent panel](https://doc3161en.candera.eu/books/solution-handling/page/docs-agent-panel)</span>.</p>
**Search Helper** communicates with the AI service through Candera Operator. For the settings, see <span style="color:rgb(230,126,35);">**[Preferences &gt; AI Service](https://doc3161en.candera.eu/books/preferences/page/ai-service-Bm5)**</span>.
##### Opening and Closing **Search Helper**
Click the star icon in the Search panel. The **Search Helper** chat window appears and overlays the input area for the search criteria. To close the chat window, click the × button in the upper right corner.
<div drawio-diagram="9209"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-09/drawing-4-1788939494.png" alt="drawing-4-1788939494.png"/></div>
##### Panel Layout
<div drawio-diagram="9228"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-09/drawing-4-1789350806.png" alt="drawing-4-1789350806.png"/></div>
<table id="bkmrk-no-item-description-" style="border-collapse:collapse;width:800px;border-width:1px;height:383.273px;"><tbody><tr style="height:29.5227px;"><td style="width:50.4091px;background-color:rgb(35,111,161);height:29.5227px;"><span style="color:rgb(255,255,255);">**No**</span></td><td style="width:227.42px;background-color:rgb(35,111,161);height:29.5227px;"><span style="color:rgb(255,255,255);">**Item**</span></td><td style="width:521.443px;background-color:rgb(35,111,161);height:29.5227px;"><span style="color:rgb(255,255,255);">**Description**</span></td></tr><tr style="height:46.3182px;"><td class="align-center" style="width:50.4091px;height:46.3182px;">1</td><td style="width:227.42px;height:46.3182px;">Suggested prompts</td><td style="width:521.443px;height:46.3182px;">Suggested instructions that appear when the chat history is empty. When you click one, **Search Helper** sends it as it is.</td></tr><tr style="height:29.5227px;"><td class="align-center" style="width:50.4091px;height:29.5227px;">2</td><td style="width:227.42px;height:29.5227px;">Input field</td><td style="width:521.443px;height:29.5227px;">Describe in words what you want to find.</td></tr><tr style="height:29.5227px;"><td class="align-center" style="width:50.4091px;height:29.5227px;">3</td><td style="width:227.42px;height:29.5227px;">Send button</td><td style="width:521.443px;height:29.5227px;">Sends what you entered. Pressing the Enter key has the same effect.</td></tr><tr style="height:63.1136px;"><td class="align-center" style="width:50.4091px;height:63.1136px;">4</td><td style="width:227.42px;height:63.1136px;">Search criteria</td><td style="width:521.443px;height:63.1136px;">Shows the generated search criteria in the same structure as the Search panel: search type, attribute, operator, and value. You can add, change, or delete them manually before you apply them.</td></tr><tr style="height:46.3182px;"><td class="align-center" style="width:50.4091px;height:46.3182px;">5</td><td style="width:227.42px;height:46.3182px;">Apply &amp; Search</td><td style="width:521.443px;height:46.3182px;">Applies the generated search criteria to the Search panel and runs the search. After **Search Helper** applies them, the button changes to **Undo**.</td></tr><tr style="height:46.3182px;"><td class="align-center" style="width:50.4091px;height:46.3182px;">6</td><td style="width:227.42px;height:46.3182px;">Undo</td><td style="width:521.443px;height:46.3182px;">When you click **Apply &amp; Search**, the button name changes to **Undo**. Click this button to revert the search criteria that you applied last.</td></tr><tr style="height:46.3182px;"><td class="align-center" style="width:50.4091px;height:46.3182px;">7</td><td style="width:227.42px;height:46.3182px;">Restore Checkpoint</td><td style="width:521.443px;height:46.3182px;">Appears at each break in the construction of the search criteria. When you click it, **Search Helper** restores the search criteria of that point and runs the search again.</td></tr><tr style="height:46.3182px;"><td class="align-center" style="width:50.4091px;height:46.3182px;">8</td><td style="width:227.42px;height:46.3182px;">Action buttons</td><td style="width:521.443px;height:46.3182px;">Appear when you hold the pointer over a message. They are hidden by default. You can copy the content and clear the chat history.</td></tr></tbody></table>
##### Basic Operations
1. Click the star icon in the Search panel to open **Search Helper**.
2. Enter what you want to find in the input field, and then press the Enter key or click the send button.
3. **Search Helper** generates the search criteria. Check them and, if necessary, add, change, or delete criteria manually.
4. Click **Apply &amp; Search**. **Search Helper** overwrites the search criteria in the Search panel and runs the search.
    - The search results appear at the right side of the **Search Helper** window.
5. Check the search results. To return to the state before you applied the criteria, click **Undo**.
    - If you have built and run several sets of search criteria, click the **Restore Checkpoint** of the set that you want instead of clicking **Undo**. The results for that set appear.
<p class="callout info">The result of clicking **Apply &amp; Search** appears in the search results at the right side of the Search panel. The display of the **Search Helper** chat window does not change.</p>
##### Refining the Criteria
**Search Helper** knows the search criteria that exist at the moment you send an instruction. Therefore, you can instruct it to refine the criteria relative to the previous ones, for example, "of those, only the ones whose name contains Rect".
If the Search panel cannot handle the criteria that you instruct, **Search Helper** tells you so. If it cannot determine the criteria from your instruction, it asks you to confirm.
##### Checking the Generated Search Criteria
<p class="callout warning">The generated search criteria do not always match the intent of your instruction. Always check the generated search criteria before you click **Apply &amp; Search**.</p>
If you instruct a condition that the operators of the Search panel cannot express directly, **Search Helper** might select an operator that does not match your intent. For example, if you instruct "the ones whose name does not contain Cluster" and Search Helper selects `!=`, the condition becomes "does not exactly match Cluster", and **Search Helper** does not exclude names such as `Cluster_Speed`.
You can change the generated search criteria manually as long as you have not applied them. If they do not match your intent, correct the operator or the value, or give the instruction again.
##### Restore Checkpoint
Each time you send an instruction, **Search Helper** saves the search criteria of that moment as a checkpoint. When you click **Restore Checkpoint**, which appears at each break in the exchange, **Search Helper** restores the search criteria of that point and runs the search again.
<table id="bkmrk-action-chat-history-" style="width:70.9524%;"><tbody><tr><td style="width:56.4404%;background-color:rgb(35,111,161);"><span style="color:rgb(255,255,255);">**Action**</span></td><td style="width:43.7021%;background-color:rgb(35,111,161);"><span style="color:rgb(255,255,255);">**Chat history and checkpoints**</span></td></tr><tr><td style="width:56.4404%;">Close **Search Helper** and open it again</td><td style="width:43.7021%;">Retained</td></tr><tr><td style="width:56.4404%;">Close the Search panel and open it again</td><td style="width:43.7021%;">Retained</td></tr><tr><td style="width:56.4404%;">Restart Scene Composer</td><td style="width:43.7021%;">Cleared</td></tr></tbody></table>
##### Troubleshooting
If **Search Helper** shows `Client could not connect.` in a red error box, Scene Composer cannot connect to Candera Operator. Open **File &gt; Preferences** from the menu bar, go to **Environment &gt; <span style="color:rgb(230,126,35);">[AI Service](https://doc3161en.candera.eu/books/preferences/page/ai-service-Bm5)</span>**, and check the settings and the connection.
# Wireframe Scene Design
#### Wireframe Scene Design
It can be really difficult to find a specific object in a complex scene with many objects(objects hidden by other, bigger objects). A good solution in SceneComposer is the usage of the wireframe nodes preview type. Wireframe rendering applies for meshes (mesh, planar shadow, morphing mesh) and billboards, regardless of their provenience (created by the user, imported, or created by a widget).
There are four different modes available for an entire solution created in SceneComposer: Normal, User Defined, Wireframe and Alpha Blending. Those are from the combo button near the isolated editing button, in the Toolbar.
<div drawio-diagram="5895"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717152868.png" alt="drawing-5-1717152868.png"/></div>
When the Normal type is selected all the nodes are visible in a usual, non-wire framed, manner. When the User Defined option is selected, at first, all nodes are rendered like in normal mode. But, with the user defined render mode, you can select single nodes and change their "Node Preview Type" property to "Wireframe". These nodes will then always be rendered in wireframe when User Defined rendering is selected, whereas everything else will be rendered normally.
<div drawio-diagram="5896"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717153382.png" alt="drawing-5-1717153382.png"/></div>
This possibility is available for every selected node, for an entire scene or for the whole solution. Use the User Defined option when the wireframe of only one node should be displayed. In this way, if the Wireframe type of the chosen node is selected, the geometrical structure of the selected object will become visible.
<div drawio-diagram="85"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676276766.png" alt="drawing-4-1676276766.png"/></div>
When the Wireframe option in the Toolbar is selected, all the nodes from all the scenes in an opened/newly created solution are displayed as wireframes. Now any new object added to the scene will also be displayed as a wireframe.
<div drawio-diagram="86"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676276786.png" alt="drawing-4-1676276786.png"/></div>
# Output
The Output panel can be shown by selecting \[ View &gt; Output &gt; Output \] in the menu bar.
<div drawio-diagram="5532"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-7-1712717674.png" alt="drawing-7-1712717674.png"/></div>
The Output panel displays all trace information about Scene Composer.
<div drawio-diagram="5533"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-7-1712717862.png" alt="drawing-7-1712717862.png"/></div>
When a message is displayed in the output panel, a context menu is displayed by right-clicking on the panel.
<div drawio-diagram="5534"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-7-1712717948.png" alt="drawing-7-1712717948.png"/></div>
<table class="align-center" id="bkmrk-%E3%81%99%E3%81%B9%E3%81%A6%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88-%E5%87%BA%E5%8A%9B%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C"><tbody><tr><td class="align-left">Export All</td><td class="align-left">Export all messages displayed in the output panel to a file.
</td></tr><tr><td class="align-left">Copy</td><td class="align-left">Copies the message selected on the output panel to the clipboard.
</td></tr><tr><td class="align-left">Clear</td><td class="align-left">Clears all messages currently displayed.</td></tr></tbody></table>
# Problems Browser
#### Problems Browser
A dedicated problems browser is available, which can be activated through "View" &gt; "Output" &gt; "Problems"
<div drawio-diagram="5897"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717154126.png" alt="drawing-5-1717154126.png"/></div>
A problem is a message related to one item in the solution.
In addition to the message itself the problem also has a numeric Id, a severity category (Info, Warning or Error) and a source service (Scml Parser, Shader compiler, etc). By right clicking on the header, it is possible to hide any of its sections or, by using the drag and drop option it is possible to change their order.
<div drawio-diagram="5898"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717154171.png" alt="drawing-5-1717154171.png"/></div>
The problems browser lists three different categories of problems:
- SCML Errors
- Shader Compiler Errors and Messages
- Missing Dependencies
It is possible to explicitly select information related to one of these categories in the "Category" checkbox. With the buttons placed in the top of the Problems browser, the displayed problems can be filtered according to their origins:
- "Show Only the Suppressed Problems": Display just those problems which were suppressed by the user.
- "Filter Problems by Selected Scene": Display problems only related to the selected scene.
- "Filter Problems by Selected Animation": Display problems only related to the selected animation.
To get focused on problems related to SceneComposer solution configuration, it is possible to suppress warnings or messages solely related to imported content. The first option is ticking the checkbox "Hide warnings and messages from imports in Problems panel" in the "Environment" section of the "Preferences".
<div drawio-diagram="5899"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717160640.png" alt="drawing-5-1717160640.png"/></div>
The same persistent setting can be toggled directly in the Problems panel by using the button "Hide/Show warnings and messages from imports":
<div drawio-diagram="5901"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717161247.png" alt="drawing-5-1717161247.png"/></div>
Another possibility to hide warnings is by using the context menu. This operation can be done in both "Solution Explorer" and "Imports" panels. If in the "Solution Explorer" panel the context menu is opened by right clicking on any existing solution or to any of its children, a "Suppress all Warnings" is available. When this is option is selected all the warnings will be hidden.
<p class="callout info">If one object is selected there will be hidden all the problems related with that object. If the same operation is done for a folder, there will be hidden all the problems related with any children which pertains to that folder.
</p>
The forth way to hide warnings is from the problems configuration dialogue - by ticking the "Suppress" checkbox - which is available from the problem browser via "Configure problems" button.
<div drawio-diagram="5902"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717161287.png" alt="drawing-5-1717161287.png"/></div>
<p class="callout info">The option to hide warnings is available just for "Warnings" and "Info", not for "Errors".</p>
<p class="callout info">This setting can also be made in <span style="color:rgb(230,126,35);">[Solution Options &gt; Problems Configuration](https://doc3161en.candera.eu/books/solution-handling/page/problems-configuration)</span>.</p>
The buttons on the right side of the "Problems" panel can be used to select the type of information to be displayed:
- Errors
- Warnings
- Messages
It is possible to combine the results of these three types of filtering to obtain the desired output.
<div drawio-diagram="5904"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717161417.png" alt="drawing-5-1717161417.png"/></div>
When right clicking on any selected problem, a context menu gets opened. The context menu shows three different options.
- **Export All** : a .csv file with al the problems will be exported in a place specified by the user.
- **Resolve** : Offers an additional context menu to resolve the problem.
- **Go to Problem** : the user will be able to reach immediately the place where is located the problem which has to be solved.
- **Copy** : the message of the problem will be copied on the clipboard.
- **Suppress Warning** : You can choose if the problem should be suppressed for this item or for the entire solution.
<div drawio-diagram="5905"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717161501.png" alt="drawing-5-1717161501.png"/></div>
#### Types of Errors
##### SCML Errors
When faulty SCML modifications are being committed in the SCML Editor, SCML errors are displayed in the Problems view:
##### Go to Error
When one of the displayed errors is double-clicked, the scene where the error pertains will be loaded and the object will become highlighted on the Scene Tree.
##### Custom Formats Error
Currently the custom bitmap formats are not supported by Candera 3D (only Candera 2D supports them).
A validation was added to prevent the usage of custom formats in 3D scenes. An error will be displayed in the problem browser panel for every 3D texture which uses a bitmap (or a bitmap theme entry) with custom bitmap format. The validation is applied to the data which is put into the asset (for example an imported bitmap may have the format RGBA but using a bitmap converter the format may be changed to a custom format, this will result in an error).
The asset will not be generated if it would contain any 3D scene which use bitmaps with custom formats.
##### Shader Compiler Errors
When faulty shader program modifications are being committed in the Shader Editor, shader compiler errors are displayed in the Problems view:
<div drawio-diagram="5906"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717162430.png" alt="drawing-5-1717162430.png"/></div>
After successful shader compilation, a regarding message is displayed:
##### Mip-Mapping Warning
A warning should be displayed if mip-mapping is activated on a texture that has non-power-of-two dimensions.
##### Missing Dependencies
All the missing dependencies are listed on the Problem Browser, too.
# Text Size Report
The Text Size Report is a tool that can be used to ensure that the texts and their translations fit their desired sizes. The Text Size Report renders scenes in different cultures and reports any sizing issues the text might have inside of the Text Size Report panel.
The Text Size Report panel is displayed by selecting \[ View &gt; Output &gt; Text Size Reportesults \] from the menu bar.
<div drawio-diagram="5953"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-06/drawing-4-1717635882.png" alt="drawing-4-1717635882.png"/></div>
#### Text Size Report Panel UI
<div drawio-diagram="5991"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-06/drawing-4-1717736297.png" alt="drawing-4-1717736297.png"/></div>
<table id="bkmrk-1-switch-switches-th" style="border-collapse:collapse;width:780px;border-width:1px;height:335.547px;"><colgroup><col style="width:6.79852%;"></col><col style="width:28.222%;"></col><col style="width:64.9795%;"></col></colgroup><tbody><tr style="height:35.3906px;"><td class="align-center" style="border-width:1px;height:35.3906px;">1</td><td style="border-width:1px;height:35.3906px;">Switch</td><td style="border-width:1px;height:35.3906px;">Switches the panel display style between list view (default) and tree view.
</td></tr><tr style="height:92.4219px;"><td class="align-center" style="border-width:1px;height:92.4219px;">2</td><td style="border-width:1px;height:92.4219px;">Filter
</td><td style="border-width:1px;height:92.4219px;">Two filters are used to narrow down the items in the list.
- Left icon: Text node that failed Text Size Report
- Middle icon: Text node that has been tested
- Right icon: Show only possible remote text notes
</td></tr><tr style="height:35.3906px;"><td class="align-center" style="border-width:1px;height:35.3906px;">3</td><td style="border-width:1px;height:35.3906px;">Search field</td><td style="border-width:1px;height:35.3906px;">Searches for items in the list via the name and path.
</td></tr><tr style="height:56.7812px;"><td class="align-center" style="border-width:1px;height:56.7812px;">4</td><td style="border-width:1px;height:56.7812px;">Execute</td><td style="border-width:1px;height:56.7812px;">Executes Text Size Report For more information, see <span style="color:rgb(230,126,35);">[Executing Text Size Report<span style="color:rgb(0,0,0);">.</span>](#bkmrk-executing-the-text-l)</span>
[ ](#bkmrk-executing-the-text-l)</td></tr><tr style="height:80.1719px;"><td class="align-center" style="border-width:1px;height:80.1719px;">5</td><td style="border-width:1px;height:80.1719px;">Refresh</td><td style="border-width:1px;height:80.1719px;">Refreshes the information in the panel. It is used to update the information when editing operations are performed on a scene, for example, when a node is added.
</td></tr><tr style="height:35.3906px;"><td class="align-center" style="border-width:1px;height:35.3906px;">6</td><td style="border-width:1px;height:35.3906px;">Export</td><td style="border-width:1px;height:35.3906px;">Export the configured Text Size Reportdata in csv file format.
##### View style
By pressing \[ Switch \] icon, you can switch between list view and tree view.
##### List View
By default the panel is in list view mode and it lists all of the combinations of cultures and texts within the solution.
<div drawio-diagram="5955"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-06/drawing-4-1717636432.png" alt="drawing-4-1717636432.png"/></div>
##### Tree View
In case of large solutions with many scenes and cultures the tree view is recommended. The tree view items are adhering to the following hierarchy: Culture &gt; Scene &gt; Scene Hierarchy.
<div drawio-diagram="5956"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-06/drawing-4-1717636478.png" alt="drawing-4-1717636478.png"/></div>
In both view style, should any additional text nodes be rendered without being present in the scene, they will be added to the list view along the other nodes and in case of the tree view they will be added to the unpaired nodes.
##### Executing Text Size Report
The Text Size Reportcan be executed either by clicking the run icon in the Text Size Report panel or using Report &gt; Text Size Reportin the menu bar. The following dialog will appear:
<div drawio-diagram="5952"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-06/drawing-4-1717632422.png" alt="drawing-4-1717632422.png"/></div>
The target scenes and cultures should be selected for the Text Size Report Subsequently the inspection can be executed using the \[ Check \] button. To select multiple scenes and execute them all at once, press the \[ Check All \] button. During inspection, \[ check \] button will be replaced with \[ Stop \] button, this can be used to interrupt the Text Size Report The collected data will persist even if the Text Size Reportis not fully complete.
#### Remote
A remote text size check can be used in order to check the text nodes on a running system. In this mode the rendered text nodes will send a tcp message to the scene composer which will save the results. When dealing with duplicate results the text size report will prefer to hightlight the results that have failed the check at some point (not every result is displayed due to high count of entries).
##### Setup
In order to use the Remote TSR the Player application needs to start the TSR Server and the scene composer needs to start the TSR Client. The order of these steps is not relevant. Both Player and Scene composer need to be on devices with Internet or same LAN connection. The device needs to have the port 13060 free.
To automatically start the application with a TSR server on, build the application with the CANDERA\_TEXT\_SIZE\_REPORT\_ENABLED Cmake Flag set to true. Alternatively if a custom server startup is necessary, a call to DefaultTextStatisticsHost::GetOrCreateHost() from the TextEngine project can be used to start the TSR server inside of the application.
To start the TSR Client in Scene Composer, click the "Execute" icon (see <span style="color:rgb(230,126,35);">[Panel UI](#bkmrk-text-length-check-re)</span>) in the Text Size Report panel. Select the \[ Remote Check \] tab at the top of the Text Size Report dialog that appears, enter the IP of the device on which the Player is running, and click the \[ Connect \] button. When interacting with the Player the results should appear in the panel.
##### Covered Use Cases
The Text Size Report covers the following usecases:
- Static Texts
- Culture dependent text
- Text nodes with inherited and provided sizes
- Text nodes with truncation, wordwrap
The Text Size Report  won't work on:
- Text Nodes with disabled rendering
- Text Nodes outside of the render area
- Text Nodes with cached layout enabled.
- Clipped Text Nodes (Height check only works on word wrapping. Should the first line already be too small it will not check it. )
- Occluded Text Nodes
- Dynamic use cases like changing text or size properties at runtime
- Behavior functionality which rely on Courier features are not properly evaluated in Scene Composer
# Candera Logging
The SceneComposer Output panel is similar to the Candera logging panel. Activate the panel via "View" &gt; "Output" &gt; "Candera Logging"
<div drawio-diagram="5907"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717162571.png" alt="drawing-5-1717162571.png"/></div>
All Candera traces can be displayed.
<div drawio-diagram="5908"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717162654.png" alt="drawing-5-1717162654.png"/></div>
In the Candera logging panel the first mandatory action is to enable the tracing by using the "Enable/Disable Candera tracing" button. The second setting that is necessary is the configuration of the Candera logging (Press the Candera Logging Configuration button). By default, the lowest level is set to "Off".
<div drawio-diagram="5909"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717162736.png" alt="drawing-5-1717162736.png"/></div>
To change this setting the "Lowest logging message level" dialog should be used. All the levels are hierarchically ordered based on the quantity of information that is delivered.
<div drawio-diagram="106"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1676280203.png" alt="drawing-4-1676280203.png"/></div>
Enabling one level will enable the lower levels as well. For instance, enabling "Warning level" for one module will also enable "Error" and "Fatal" levels, or enabling "Debug level" will also enable all other lower levels.
If you would like to realize a distinction between traces (especially when there are many traces), an useful feature is the "Add mark" button. By using it, as many markers as necessary will be introduced to separate different traces.
<p class="callout info">All the information (including the markers) are kept in a .xml file on the hard disk. Every time when the Candera trace feature is used, all the previous information is displayed.</p>
All Candera traces are delivered and displayed as "Raw" traces. If necessary, it is possible to filter all the traces by adding new filters. For example, (\[up almost\] &amp;&amp; collinear) \|\| (!New) represents an "expression" created to filter the Candera traces. The logical operators used here are &amp;&amp; (Or), II (And), ! (Not). The \[\] brackets can be used on the same way as any other "match case" feature usual in different applications. The () brackets are used to create more complex filters.
<div drawio-diagram="5910"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717162937.png" alt="drawing-5-1717162937.png"/></div>
All the Candera traces can be exported as a .csv file by using the "Export traces" button at a chosen location on the hard disk.
By default, the "Autoscroll" button is always activated. On this way, the latest traces are displayed in the panel without handling the scrollbar. If necessary, the "Autoscroll" button can be used to change the default status to manual use the scrollbar.
# Undo and Redo Operations
#### <a class="anchor" id="bkmrk--8"></a>Undo and Redo Operations
Any operation concerning scene design and animation design can be undone or redone.
**Undo** an operation via menu "Edit" &gt; "Undo" or Toolbar item.
<div drawio-diagram="4819"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700229326.png" alt="drawing-5-1700229326.png"/></div>
</div></div></div>**Redo** an undone operation via menu "Edit" &gt; "Redo" or Toolbar item.
<div drawio-diagram="4821"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700234312.png" alt="drawing-5-1700234312.png"/></div>
</div></div></div>#### <a class="anchor" id="bkmrk--11"></a>Undo/Redo Actions' History
A very helpful function associated with Undo/Redo options is the "Actions' History". All the previous actions can be shown by pressing the "v" button, which is placed between "Undo" and "Redo" buttons visible in Toolbar.
<div drawio-diagram="4823"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700234433.png" alt="drawing-5-1700234433.png"/></div>
<div class="contents" id="bkmrk--5"><div class="contents"><div class="textblock">
</div></div></div>By using this function all the previous actions are displayed. In this way, it is possible to choose which of the previous actions should be undone.
<div drawio-diagram="4824"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700234490.png" alt="drawing-5-1700234490.png"/></div>
<div class="contents" id="bkmrk--7"><div class="contents"><div class="textblock">
</div></div></div>After all the selected actions have been undone, the "Actions' History" menu will reflect the current state of actions.
After undoing multiple actions, the Redo of "History' Actions" button, which is placed on the right side of the Undo arrow, will become available. The Redo "Actions' History" shows all the actions that have been undone.
<div class="contents" id="bkmrk-importing-a-resource"><div class="textblock"><dl class="note"><dt></dt><dd><p class="callout info">Importing a resource into Scene Composer, regardless of type, will result in your undo/redo history being cleared.</p>
# Device Capabilities and Constraint Violations
### <a class="anchor" id="bkmrk--3"></a>Device Capabilities and Constraint Violations
Device capabilities for both target and simulation are displayed in SceneComposer via menu item "Platform" &gt; "Device capabilities".
<div drawio-diagram="5911"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717163208.png" alt="drawing-5-1717163208.png"/></div>
</div></div></div>The "Device Capabilities" panel provides two distinct columns where both "Simulation device capability value" and "Target device capability value" are displayed.
<div drawio-diagram="4825"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700234599.png" alt="drawing-5-1700234599.png"/></div>
</div></div></div>Violations of supported capabilities are reported into the problem viewer panel.
# SCHost Information
In order to help the user identify which font engine is active in SceneComposer, a Platform menu entry is available: "SCHost Information".
<div drawio-diagram="5676"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-4-1714394919.png" alt="drawing-4-1714394919.png"/></div>
</div></div></div>It displays the configuration that was used to build SCHost, including the font engine.
<div drawio-diagram="5675"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-04/drawing-4-1714394841.png" alt="drawing-4-1714394841.png"/></div>
</div></div>
# Item Names Validation
The validation rules for item names are now applied also during imports and solution loading. These rules are:
<div class="contents" id="bkmrk-the-item-name-mustn%27"><div class="contents"><div class="textblock">
- The item name mustn't be null or empty;
- Only the following characters are allowed in item names:
</div></div></div>In the User Interface (UI)
<div class="contents" id="bkmrk-symbol-ascii-descrip"><div class="contents"><div class="textblock"><table style="width:500px;"><tbody><tr style="background-color:#a6a6a6;"><th align="right" style="width:44.9531px;">
</th><th style="width:89.766px;">Symbol</th><th style="width:114.766px;">ASCII</th><th style="width:249.516px;">Description</th></tr><tr><td align="right" style="width:44.9531px;">1</td><td align="center" style="width:89.766px;">No symbol</td><td align="center" style="width:114.766px;">ASCII(32)</td><td style="width:249.516px;">Space</td></tr><tr><td align="right" style="width:44.9531px;">2</td><td align="center" style="width:89.766px;">!</td><td align="center" style="width:114.766px;">ASCII(33)</td><td style="width:249.516px;">Exclamation mark</td></tr><tr><td align="right" style="width:44.9531px;">3</td><td align="center" style="width:89.766px;">$</td><td align="center" style="width:114.766px;">ASCII(36)</td><td style="width:249.516px;">Dollar</td></tr><tr><td align="right" style="width:44.9531px;">4</td><td align="center" style="width:89.766px;">%</td><td align="center" style="width:114.766px;">ASCII(37)</td><td style="width:249.516px;">Procenttecken</td></tr><tr><td align="right" style="width:44.9531px;">5</td><td align="center" style="width:89.766px;">'</td><td align="center" style="width:114.766px;">ASCII(39)</td><td style="width:249.516px;">Single quote</td></tr><tr><td align="right" style="width:44.9531px;">6</td><td align="center" style="width:89.766px;">(</td><td align="center" style="width:114.766px;">ASCII(40)</td><td style="width:249.516px;">Open parenthesis (or open bracket)</td></tr><tr><td align="right" style="width:44.9531px;">7</td><td align="center" style="width:89.766px;">)</td><td align="center" style="width:114.766px;">ASCII(41)</td><td style="width:249.516px;">Close parenthesis (or close bracket)</td></tr><tr><td align="right" style="width:44.9531px;">8</td><td align="center" style="width:89.766px;">+</td><td align="center" style="width:114.766px;">ASCII(43)</td><td style="width:249.516px;">Plus</td></tr><tr><td align="right" style="width:44.9531px;">9</td><td align="center" style="width:89.766px;">,</td><td align="center" style="width:114.766px;">ASCII(44)</td><td style="width:249.516px;">Comma</td></tr><tr><td align="right" style="width:44.9531px;">10</td><td align="center" style="width:89.766px;">-</td><td align="center" style="width:114.766px;">ASCII(45)</td><td style="width:249.516px;">Hyphen</td></tr><tr><td align="right" style="width:44.9531px;">11</td><td align="center" style="width:89.766px;">.</td><td align="center" style="width:114.766px;">ASCII(46)</td><td style="width:249.516px;">Period, dot or full stop</td></tr><tr><td align="right" style="width:44.9531px;">12</td><td align="center" style="width:89.766px;">;</td><td align="center" style="width:114.766px;">ASCII(59)</td><td style="width:249.516px;">Semicolon</td></tr><tr><td align="right" style="width:44.9531px;">13</td><td align="center" style="width:89.766px;">=</td><td align="center" style="width:114.766px;">ASCII(61)</td><td style="width:249.516px;">Equals</td></tr><tr><td align="right" style="width:44.9531px;">14</td><td align="center" style="width:89.766px;">@</td><td align="center" style="width:114.766px;">ASCII(64)</td><td style="width:249.516px;">At symbol</td></tr><tr><td align="right" style="width:44.9531px;">15</td><td align="center" style="width:89.766px;">^</td><td align="center" style="width:114.766px;">ASCII(94)</td><td style="width:249.516px;">Caret - circumflex</td></tr><tr><td align="right" style="width:44.9531px;">16</td><td align="center" style="width:89.766px;">\_</td><td align="center" style="width:114.766px;">ASCII(95)</td><td style="width:249.516px;">Underscore</td></tr><tr><td align="right" style="width:44.9531px;">17</td><td align="center" style="width:89.766px;">&#96;</td><td align="center" style="width:114.766px;">ASCII(96)</td><td style="width:249.516px;">Grave accent</td></tr><tr><td align="right" style="width:44.9531px;">18</td><td align="center" style="width:89.766px;">{</td><td align="center" style="width:114.766px;">ASCII(123)</td><td style="width:249.516px;">Opening brace</td></tr><tr><td align="right" style="width:44.9531px;">19</td><td align="center" style="width:89.766px;">}</td><td align="center" style="width:114.766px;">ASCII(125)</td><td style="width:249.516px;">Closing brace</td></tr><tr><td align="right" style="width:44.9531px;">20</td><td align="center" style="width:89.766px;">~</td><td align="center" style="width:114.766px;">ASCII(126)</td><td style="width:249.516px;">Equivalency sign - tilde</td></tr></tbody></table>
</div></div></div>In the SceneComposer Markup Language (SCML)
<div class="contents" id="bkmrk-symbol-ascii-descrip-0"><div class="textblock"><table style="width:500px;"><tbody><tr style="background-color:#a6a6a6;"><th align="right" style="width:41.9531px;">
</th><th style="width:92.766px;">Symbol</th><th style="width:114.766px;">ASCII</th><th style="width:249.516px;">Description</th></tr><tr><td align="right" style="width:41.9531px;">1</td><td align="center" style="width:92.766px;">\#</td><td align="center" style="width:114.766px;">ASCII(35)</td><td style="width:249.516px;">Number</td></tr><tr><td align="right" style="width:41.9531px;">2</td><td align="center" style="width:92.766px;">\[</td><td align="center" style="width:114.766px;">ASCII(91)</td><td style="width:249.516px;">Opening bracket</td></tr><tr><td align="right" style="width:41.9531px;">3</td><td align="center" style="width:92.766px;">\\</td><td align="center" style="width:114.766px;">ASCII(92)</td><td style="width:249.516px;">Backslash</td></tr><tr><td align="right" style="width:41.9531px;">4</td><td align="center" style="width:92.766px;">\]</td><td align="center" style="width:114.766px;">ASCII(93)</td><td style="width:249.516px;">Closing bracket</td></tr></tbody></table>
- The item name cannot be "." or "..";
- The item name can not end with ".";
- Additionally Backslash (ASCII 92) and Number (ASCII 35) can be part of an item name if that name is generated by SceneComposer.
</div></div>
# Items AssetId
#### **<a class="anchor" id="bkmrk--6"></a>**Item Asset Validation
In [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") the objects are now identified using a numerical Id. For Library Items (scene, bitmap, etc) the maximum value is 1FF FFFF (25 bits), for Node Attachment Templates (appearance collection, material, render mode, uniform setter, texture) is 7FFFF (19 bits) and for nodes is 3FFF FFFF (30 bits). The Id will be generated automatically if its value is set to 0.
<div drawio-diagram="5912"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717163403.png" alt="drawing-5-1717163403.png"/></div>
</div></div></div>For library items the Ids must be unique for all objects of the same type. For nodes the Ids must be unique inside the scene. If necessary, the property can be copied by using the small button near the field of the property.
<div drawio-diagram="5913"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717163561.png" alt="drawing-5-1717163561.png"/></div>
<div class="contents" id="bkmrk-the-copy-option-is-p"><div class="contents"><div class="textblock"><dl class="note"><dt></dt><dd><p class="callout info">The copy option is possible by using the context menu (right click inside the AssetId field).</p>
</dd><dd></dd></dl>---
</div></div></div>#### <a class="anchor" id="bkmrk--9"></a>Symbolic Names
This type of names can be assigned to items to make their Id accessible from applications. A symbolic name can be assigned via Properties panel in the field which can be seen in the image below.
<div drawio-diagram="5914"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717163739.png" alt="drawing-5-1717163739.png"/></div>
<div class="contents" id="bkmrk--3"><div class="contents"><div class="textblock">
</div></div></div>A symbolic name can be created by the user or by using the "Generate Symbolic Name" button.
<div class="contents" id="bkmrk-%C2%A0-%22generate-symbolic"><div class="contents"><div class="textblock"></div></div></div>A C++ header with all the symbolic names from the solution can be generated via File-&gt;Export Symbolic Names.
<div class="textblock" id="bkmrk--4"></div><div class="textblock" id="bkmrk--5"><div drawio-diagram="4831"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-11/drawing-5-1700235243.png" alt="drawing-5-1700235243.png"/></div>
</div>
# Auto Values
#### <a class="anchor" id="bkmrk--6"></a>Introduction
Auto values are values which are internally computed by SceneComposer or Candera or inherited from other objects in certain situations. In these situations, it is useful to show the computed value and an information that the value is computed.
Example: TextNode2D.LineHeight property can have a computed value. Setting it to any other value than 0, will make the value fixed and effectively used by Candera to separate the lines of text. But when setting it to 0, internally, Candera will use instead the line height value (let’s say 42) specified by the associated text style. In this case, the value 0 is a trigger for computing a different value internally. And we call the computed 42 value an auto value.
<div class="contents" id="bkmrk-"><div class="contents"><div class="textblock">
</div></div></div>---
#### <a class="anchor" id="bkmrk--7"></a>Triggers of Auto-Value Properties
There are several triggers for a property to have an auto value:
1. **Value**. This is the most common one - a certain value of the property makes the property auto (usually the default value is the trigger value – in examples above, for Line Height, 0 is also the default value. In this case, having the default value triggers becoming auto).
2. **Other configuration** – like properties of parent, parent type, and so on.. (example: when a node is a child of a layout group, the node’s position becomes auto because it’s computed by the layout group).
3. **Always Auto** – they are values computed by Candera for properties which are not configurable (for example, PreferredSize is a value computed during measuring elements in a Layout process. This is not configurable, but is a value computed based on other values. It may be meaningful for users when understanding of layout is needed).
#### <a class="anchor" id="bkmrk--8"></a>Functionality of Auto-Values
The text "(Auto)" inside of a read-only properties field indicates that this property has an Auto-Value. The user can interact with auto-values through the switch button which is available in the Properties panel on the right side of the Auto-Value field. In the image below, you can see that the vertical and horizontal size value is an Auto-Value, each having a corresponding switch button on their right.
<div drawio-diagram="5915"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717164002.png" alt="drawing-5-1717164002.png"/></div>
<div class="contents" id="bkmrk-read-only-value-and-"><div class="contents"><div class="textblock">
</div></div></div>As can be seen in the image above, a suffix indicates that the value is "auto". As expected, if the button is used the value will become editable and the user will be allowed to modify it as desired.
<div class="contents" id="bkmrk--5"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--9"></a>Auto-Value Properties
<div class="contents" id="bkmrk-textnode2d.lineheigh"><div class="contents"><div class="contents"><div class="textblock">
- TextNode2D.LineHeight
    - Type: integer
    - Trigger: having default value (0)
    - Is metainfo property: No
    - Retrieve auto value: retrieve the line height metric from the metrics of the associated TextStyle
- CanvasText.LineHeight
    - Same as TextNode2D.LineHeight
- Node2D.Position
    - Type: Vector2
    - Trigger: parent is layouter
    - Retrieve auto value: query SCHost, requires scene being loaded
- Node2D.Scale
    - Type: Vector2
    - Trigger: parent is layouter and stretch is not None except for when the node has a 9-patch image
- CanvasNode.Position
    - Type: Vector3
    - Trigger: parent is layouter. Only X and Y are auto
- CanvasNode.Scale
    - Type: Vector2
- Node2D.BoundingRectangle
    - Type: Rectangle
    - Trigger: Width and Height having default value (-1)
    - Retrieve auto value: query SCHost, add method to retrieve the computed bounding box, requires scene being loaded
- Camera2D.Viewport
    - Type: Rectangle
    - Retrieve auto value: compute the value based on RenderTarget dimensions and [Candera](http://dev.doc.cgistudio.at/APILINK/namespace_candera.html "&#91;DataBinding&#95;RefTypeSample&#93;") rules
- Camera2D.ScissorRectangle
    - Type: Rectangle (only Width and Height can be auto)
- RenderTarget.Width
    - Type: integer
    - Trigger: having default value (-1)
    - Is metainfo property: Yes
    - Retrieve auto value: compute the value based on display dimensions (-1 means display width)
- RenderTarget.Height
    - Type: integer
    - Retrieve auto value: compute the value based on display dimensions (-1 means display height)
- Node.Size (Layout)
    - Type: Vector2
    - Trigger: having default value (-1; -1)
    - Retrieve auto value: retrieve the ActualSize value from SCHost, which is computed by the Layouter. SCHost already acquires that value to use it to show the adorner for size (using a layout monitor which is notified about layout processing events and values).
- CanvasNode.Size (Layout)
    - Type: Vector3 (only X and Y can be auto)
    - Trigger: having default values (-1; -1) for X and Y (only X and Y can be auto)
- CanvasText.Size
    - This property is different from the layout size, but has the same name.
    - Type: Vector2
    - Retrieve auto value: retrieve value computed by the CanvasNode through SCHost.
</div></div></div></div><div class="contents" id="bkmrk--10"><div class="contents"><div class="textblock">---
</div></div></div>#### <a class="anchor" id="bkmrk--11"></a>Improving Other UI Areas
The introduction of auto-value concept has an important consequence: user no longer sees the values if the values are the default ones (like 0 for LineHeight or -1 for Viewport.X). However, there are still cases for which, the default value is shown but auto-value cannot be implemented because doesn’t make sense. For these situations, additional improvements can be made.
<div class="contents" id="bkmrk-maxsize%3A-this-layout"><div class="contents"><div class="textblock">
- **MaxSize**: This Layout property has a default value of -1 which represents that value is not specified and should be considered infinite. This property can be turned into an optional property, so that by default it shows an unchecked checkbox indicating that MaxSize is not set.
- **MinSize**: Same as for MaxSize, can be turned into optional.
</div></div></div>There are also properties which are not configurable in SceneComposer, nor they are visible in the property panel. They could be displayed in the property panel, but stay read-only, only for the purpose of providing information about internals.
<div class="contents" id="bkmrk-preferredsize%3A-read-"><div class="textblock">
- **PreferredSize**: Read-only property, can be added to Layout category to display the corresponding value computed by Candera. Value to be retrieved from SCHost.
- **ArrangeSize**: Read-only property, can be added to Layout category to display the corresponding value computed by Candera. Value to be retrieved from SCHost.
- **ArrangePosition**: Read-only property, can be added to Layout category to display the corresponding value computed by Candera. Value to be retrieved from SCHost.
</div></div>---
# Diagram Bird's Eye
This feature is available in Fusion/State Machine. This feature provides a Bird's eye view of the entire Fusion diagram and/or State Machine Editor and marks the current location in the Fusion/State Machine Editor panel with a blue frame. The blue frame in Diagram Bird's Eye can be moved by dragging with the mouse, and its position in Fusion/State Machine Editor panel changes accordingly, providing a bird's eye view of the entire diagram when working with the Fusion diagram/state machine editor.
The following figure shows an example of the display in the Fusion diagram (click to enlarge the figure). The same view is also available in the State Machine Editor.
<div drawio-diagram="5916"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717165094.png" alt="drawing-5-1717165094.png"/></div>
<div drawio-diagram="5918"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717166593.png" alt="drawing-5-1717166593.png"/></div>
#### How to use
Here is an example of how it is used in Fusion (the basic operation is the same for state machines).
1. Select \[ View &gt; Fusion &gt; Diagram Bird's Eye \] from the menu bar to display the Diagram Bird's Eye panel.
    - Normally, the panel is displayed as a floating window.
    - Before displaying the Fusion panel, only the message "Diagram is inactive. Double click to display diagram." will appear in the Diagram Bird's Eye panel.
    - In case of State Machine Editor, select \[ View &gt; State Machine &gt; Diagram Bird's Eye \].
        <div drawio-diagram="5919"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717166742.png" alt="drawing-5-1717166742.png"/></div>
2. Display the Fusion panel.
    - The fusion diagram in the panel is shown in the Diagram Bird's Eye panel.
    - By dragging the blue frame in the Diagram Bird's Eye with mouse operation, the diagram displayed in the Fusion panel is also moved.
        <div drawio-diagram="5920"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2024-05/drawing-5-1717166862.png" alt="drawing-5-1717166862.png"/></div>
#### Toolbar in Diagram Bird's Eye
\[ Zoom \] in the lower left part of Diagram Bird's Eye panel is linked to \[ Zoom \] in the toolbar of Fusion panel. Changing the \[ Zoom \] in Fusion panel will also change the zoom value in Diagram Bird's Eye (The reverse operation yields the same result.).
<div drawio-diagram="4629"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-4-1698307403.png" alt="drawing-4-1698307403.png"/></div>
When \[ Zoom \] in Diagram Bird's Eye panel is changed, the size of the blue frame in the panel changes.
<div drawio-diagram="4630"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-10/drawing-4-1698307579.png" alt="drawing-4-1698307579.png"/></div>
# Docs Agent Panel
The Docs Agent panel is an assistant panel where you can ask questions about the content of the CGI Studio product documentation. You can ask your questions directly in Scene Composer while you work, without opening the product documentation separately. The panel references the same documents and uses the same answer generation mechanism as <span style="color:rgb(230,126,35);">**[Docs Agent ](https://doc3161en.candera.eu/books/about-this-document/page/docs-agent)**</span>in the product documentation.
To distinguish it from the Docs Agent feature in OfflineDoc, this documentation refers to this panel as the **Docs Agent panel**.
<p class="callout info">The Docs Agent panel communicates with the AI service through Candera Operator. For the settings, see <span style="color:rgb(230,126,35);">**[Preferences &gt; AI Service](https://doc3161en.candera.eu/books/preferences/page/ai-service-Bm5)**</span>.</p>
### Displaying the Panel
By default, the Docs Agent panel appears as a tab in the same panel group as **Scene Tree** and **Search**. As with any other panel, you can resize it, undock it, and move it to another position.
<p class="callout info">If you close the panel, you can display it again from **View &gt; Docs Agent** on the menu bar.</p>
#### Panel Layout
<div drawio-diagram="9229"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-09/drawing-4-1789381256.png" alt="drawing-4-1789381256.png"/></div>
<table id="bkmrk-no-%E9%A0%85%E7%9B%AE-%E8%AA%AC%E6%98%8E-1-%E5%80%99%E8%A3%9C%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88-%E3%83%81" style="border-collapse:collapse;width:800px;border-width:1px;"><thead><tr><th style="width:55.3864px;background-color:rgb(35,111,161);"><span style="color:rgb(255,255,255);">**No**</span></th><th style="width:226.409px;background-color:rgb(35,111,161);"><span style="color:rgb(255,255,255);">**Item**</span></th><th style="width:517.477px;background-color:rgb(35,111,161);"><span style="color:rgb(255,255,255);">**Description**</span></th></tr></thead><tbody><tr><td class="align-center" style="width:55.3864px;">1</td><td style="width:226.409px;">Suggested prompts</td><td style="width:517.477px;">Suggested questions that appear when the chat history is empty. When you click one, the panel sends it as it is.</td></tr><tr><td class="align-center" style="width:55.3864px;">2</td><td style="width:226.409px;">Input field</td><td style="width:517.477px;">Enter your question here. Press the Enter key to send it. Press Shift + Enter to insert a line break.</td></tr><tr><td class="align-center" style="width:55.3864px;">3</td><td style="width:226.409px;">Send button and stop button</td><td style="width:517.477px;">Sends the question that you entered. While the panel generates an answer, this button changes to the stop button.</td></tr><tr><td class="align-center" style="width:55.3864px;">4</td><td style="width:226.409px;">Question</td><td style="width:517.477px;">Shows the question that you sent, in an orange frame.</td></tr><tr><td class="align-center" style="width:55.3864px;">5</td><td style="width:226.409px;">Answer</td><td style="width:517.477px;">Shows the generated answer. The panel formats headings, bulleted lists, bold text, and code notation. While the panel generates the answer, it shows an animation of three dots.</td></tr><tr><td class="align-center" style="width:55.3864px;">6</td><td style="width:226.409px;">Reference number</td><td style="width:517.477px;">A number such as <code>&#91;1&#93;</code> that appears in the answer text. When you click it, the source page opens.</td></tr><tr><td class="align-center" style="width:55.3864px;">7</td><td style="width:226.409px;">Relevant Documents</td><td style="width:517.477px;">At the end of the answer, the panel lists as links the pages that it referenced to generate the answer.</td></tr><tr><td class="align-center" style="width:55.3864px;">8</td><td style="width:226.409px;">Action buttons</td><td style="width:517.477px;">Appear below the answer. They are hidden by default, and appear when you hold the pointer over the answer. You can copy the content of the answer and clear the chat history.</td></tr></tbody></table>
##### Accepting the Privacy Policy
The first time you use the Docs Agent panel, the panel asks you to accept the **Privacy Policy**. You cannot enter a question until you accept it.
##### Asking a Question
1. Enter your question in the input field. If the chat history is empty, you can also click one of the suggested prompts to send it.
2. Press the Enter key or click the send button.
3. The panel generates an answer.
4. Open the source page from a link under **Relevant Documents** at the end of the answer, or from a reference number in the answer text.
##### Copying an Answer and Clearing the Chat History
When you hold the pointer below an answer, the action buttons appear. You can copy the content of the answer to the clipboard, and you can clear the chat history.
#### Opening the Source Page
When you click a reference number in the answer text or a link under **Relevant Documents**, the offline product documentation opens at the corresponding page. If the offline product documentation is already open, Scene Composer closes it and then reopens it at that page. The display language follows the display language setting of Scene Composer.
If you ask about support, the panel returns links to the contact form on the Candera website and to the Lighthouse forum.
#### Important Notes
<p class="callout warning">Answers that the AI generates might contain inaccurate or misleading content. For important information, open the source page from a link under **Relevant Documents** and verify the content.</p>
If the Docs Agent panel shows `Client could not connect.` in a red error box, Scene Composer cannot connect to Candera Operator. Open **File &gt; Preferences** from the menu bar, go to **Environment &gt; <span style="color:rgb(230,126,35);">[AI Service](https://doc3161en.candera.eu/books/preferences/page/ai-service-Bm5)</span>**, and check the settings and the connection.
# Add New Item
# Animation
Adds a <span style="color: rgb(230, 126, 35);">[new animation](https://doc3161en.candera.eu/books/animation-design/page/new-animation)</span> to the solution.
<div drawio-diagram="9026"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106611.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Play direction</td><td style="width: 77.4763%;">Specifies the playback direction of the animation.
- **Forward**: Plays the animation in the forward direction.
- **Reverse**: Plays the animation in the reverse direction.
</td></tr><tr><td style="width: 22.5237%;">Speed Factor</td><td style="width: 77.4763%;">Sets the multiplier that increases or decreases the playback speed of the animation.</td></tr><tr><td style="width: 22.5237%;">Repeat Times</td><td style="width: 77.4763%;">Sets the number of times the animation repeats. Repeat means that the animation plays again after it ends. The default value is <code>1</code>, which means the animation does not repeat. When you set the value to <code>0</code>, the animation plays infinitely. Note that this property has no effect in Scene Composer.</td></tr><tr><td style="width: 22.5237%;">Repeat Mode</td><td style="width: 77.4763%;">Specifies the playback mode that applies when the animation repeats.
- **Replay**: After playing to the end, the animation plays again from the beginning.
- **Bounce**: After playing to the end, the animation reverses direction and plays back.
# AnimationGroup
Adds a new <span style="color: rgb(230, 126, 35);">[**animation group**](https://doc3161en.candera.eu/books/animation-design/page/animation-groups)</span> to the solution. Use an animation group to handle multiple animations together as a single group.
<div drawio-diagram="9027"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106686.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Speed Factor</td><td style="width: 77.4763%;">Sets the multiplier that increases or decreases the playback speed of the entire animation group.</td></tr></tbody></table>
# AssetProfile
Adds a new asset profile to the solution. The system references this profile during asset generation and uses it in combination with the asset file path and the asset ID.
<div drawio-diagram="9028"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106721.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item. The system references this name through the &#96;$AssetProfileName&#96; macro variable during asset generation.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr></tbody></table>
# BehaviorBuildingBlock
This item adds a new **<span style="color: rgb(230, 126, 35);">[Behavior Building Block](https://doc3161en.candera.eu/books/controls-and-behaviors/page/behavior-building-blocks-behavior-blocks)</span>** to the solution. Use a Behavior Building Block to nest multiple behaviors into a single block and handle that block as a reusable component.
<div drawio-diagram="9029"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106755.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item in the Behaviors section.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr></tbody></table>
# BitmapProfile
A bitmap profile defines how a Bitmap resource is converted. Add a new bitmap profile to the solution and configure its Converter, Format, and Origin properties. You can then reference the bitmap profile from the properties of a Bitmap resource, or when importing a Bitmap resource (from the FBX, image, solution, or PSD import panel).
<div drawio-diagram="9030"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106799.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Converter</td><td style="width: 77.4763%;">The system converts the exported bitmap with the converter specified here.
- (Empty): Not specified
- DefaultBitmapConverter
- ArtInChipBitmapConverter
- AstcBitmapConverter
- RZA1HBitmapConverter
- Traveo2BitmapConverter
- VGLiteBitmapConverter
Note: Depending on which platform plugins are enabled, converters other than those listed above, such as `RT117XBitmapConverter`, might appear.
</td></tr><tr><td style="width: 22.5237%;">Format</td><td style="width: 77.4763%;">The system converts the exported bitmap to the format (pixel format) specified here. The available values change according to the &#96;Converter&#96; selection.</td></tr><tr><td style="width: 22.5237%;">Origin</td><td style="width: 77.4763%;">Configures the pixel layout in the asset. When you select <code>PlatformDependent</code>, the system uses the platform setting of the corresponding engine according to the intended use of the bitmap (2D or 3D). If neither use applies, the system exports the imported content without flipping it.
- **PlatformDependent**: Uses the platform setting of the corresponding engine according to the intended use (2D or 3D).
- **OpenGL**: Uses an OpenGL-compatible pixel layout.
- **ReversedOpenGL**: Uses a vertically flipped OpenGL-compatible pixel layout.
### Format
The `Format` options change according to the value selected for `Converter`. The following sections list the options for each converter.
#### When DefaultBitmapConverter is selected
- RgbUnsignedShort565PixelFormat
- RgbaUnsignedShort4444PixelFormat
- RgbaUnsignedShort5551PixelFormat
- RgbUnsignedBytePixelFormat
- RgbaUnsignedBytePixelFormat
- AlphaUnsignedBytePixelFormat
- LuminanceUnsignedBytePixelFormat
- LuminanceAlphaUnsignedBytePixelFormat
- Etc2CompressedRgbPixelFormat
- Etc2CompressedSrgbPixelFormat
- Etc2Alpha1CompressedRgbaPixelFormat
- Etc2Alpha1CompressedSrgbaPixelFormat
- Etc2EacCompressedRgbaPixelFormat
- Etc2EacCompressedSrgbaPixelFormat
- SrgbUnsignedBytePixelFormat
- SrgbaUnsignedBytePixelFormat
- RgbFloatingPointR11G11B10PixelFormat
- RgbFloatingPoint9E5PixelFormat
- RgbaUnsignedIntRev10A2PixelFormat
- RgbHalfFloatPixelFormat
- RgbaHalfFloatPixelFormat
- RgbFloatPixelFormat
- RgbaFloatPixelFormat
#### When ArtInChipBitmapConverter is selected
- ArtInChipBitmapFormatARGB4444
- ArtInChipBitmapFormatARGB1555
- ArtInChipBitmapFormatRGB565
- ArtInChipBitmapFormatRGB888
- ArtInChipBitmapFormatARGB8888
- ArtInChipBitmapFormatXRGB8888
#### When AstcBitmapConverter is selected
- AstcCompressedRgba4x4
- AstcCompressedRgba5x4
- AstcCompressedRgba5x5
- AstcCompressedRgba6x5
- AstcCompressedRgba6x6
- AstcCompressedRgba8x5
- AstcCompressedRgba8x6
- AstcCompressedRgba8x8
- AstcCompressedRgba10x5
- AstcCompressedRgba10x6
- AstcCompressedRgba10x8
- AstcCompressedRgba10x10
- AstcCompressedRgba12x10
- AstcCompressedRgba12x12
#### When RZA1HBitmapConverter is selected
- RZA1HExtendedBitmapFormatA1
- RZA1HExtendedBitmapFormatA4
- RZA1HExtendedBitmapFormatA8
- RZA1HExtendedBitmapFormatARGB4444
- RZA1HExtendedBitmapFormatARGB1555
- RZA1HExtendedBitmapFormatRGB565
- RZA1HExtendedBitmapFormatARGB8888
- RZA1HExtendedBitmapFormatXRGB8888
- RZA1HExtendedBitmapFormatR8G8B8A8
- RZA1HExtendedBitmapFormatJpg
#### When Traveo2BitmapConverter is selected
Because the number of options is very large, the following list shows representative options.
- Traveo2BitmapFormatA1 / A2 / A4 / A8
- Traveo2BitmapFormatR3G3B2
- Traveo2BitmapFormatRleA1 / RleA2 / RleA4 / RleA8
- Traveo2BitmapFormatR4G4B4A4
- Traveo2BitmapFormatRleR5G5B5A1
- Traveo2BitmapFormatRleR5G6B5
- Traveo2BitmapFormatRleR8G8B8
- Traveo2BitmapFormatRleR8G8B8A8
- Traveo2BitmapFormatA4RGB4
- Traveo2BitmapFormatRGB8
- Traveo2BitmapFormatA8RGB8
- Traveo2BitmapFormatRleRGB1
- Traveo2BitmapFormatRleA4RGB4
- Traveo2BitmapFormatRleRGB8
- Traveo2BitmapFormatRleA8RGB8
- Traveo2ExtendedBitmapFormatRIaA1 / RIaA2 / RIaA4 / RIaA8
- Traveo2ExtendedBitmapFormatRIaR1G1B1A1
- Traveo2ExtendedBitmapFormatRIaR4G4B4A4
- Traveo2ExtendedBitmapFormatRIaR5G5B5A1
- Traveo2ExtendedBitmapFormatRIaR5G6B5
- Traveo2ExtendedBitmapFormatRIaR6G6B6
- Traveo2ExtendedBitmapFormatRIaR6G6B6A6
- Traveo2ExtendedBitmapFormatRIaR8G8B8A8
- Traveo2ExtendedBitmapFormatRIaRGB1
#### When VGLiteBitmapConverter is selected
- VGLiteExtendedBitmapFormatA8
- VGLiteExtendedBitmapFormatARGB4444
- VGLiteExtendedBitmapFormatARGB1555
- VGLiteExtendedBitmapFormatRGB565
- VGLiteExtendedBitmapFormatARGB8888
- VGLiteExtendedBitmapFormatXRGB8888
# CameraGroup
Adds a new camera group to the solution. By grouping multiple cameras, you can enable or disable rendering for the entire group at once.
<div drawio-diagram="9031"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106835.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr></tbody></table>
# CanvasControl
Adds a new canvas control to the solution. The system creates the control with `Is Canvas Control` enabled.
<div drawio-diagram="9032"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106871.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Is Canvas Control</td><td style="width: 77.4763%;">Indicates whether the control is of type Canvas. The system creates a CanvasControl item with this property enabled.</td></tr></tbody></table>
# ClearMode
Adds a new clear mode to the solution. A clear mode groups the clear-related properties of a render target into a single item, and you can reference it from the `ClearMode` property of a render target.
<div drawio-diagram="9033"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106902.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Enable Color Clear</td><td style="width: 77.4763%;">Specifies whether color clearing is enabled.</td></tr><tr><td style="width: 22.5237%;">Enable Depth Clear</td><td style="width: 77.4763%;">Specifies whether depth clearing is enabled.</td></tr><tr><td style="width: 22.5237%;">Enable Stencil Clear</td><td style="width: 77.4763%;">Specifies whether stencil clearing is enabled.</td></tr></tbody></table>
# ConditionBlock
Adds a new **Condition Block** to the solution. In the **<span style="color: rgb(230, 126, 35);">[Condition Editor](https://doc3161en.candera.eu/books/view-editor/page/condition-editor)</span>**, you build a logical expression for the created Condition Block by placing and connecting Check, AND, OR, and NOT nodes. You can then reference the Condition Block from the **<span style="color: rgb(230, 126, 35);">[Action Chain Editor](https://doc3161en.candera.eu/books/view-editor/page/action-chain-editor)</span>** or from the Condition property of a behavior.
<div drawio-diagram="9034"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106933.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr></tbody></table>
# Control2D
Adds a new 2D control to the solution.
<p class="callout info">For the procedure to create a control, refer to <span style="color: rgb(230, 126, 35);">[Create Controls](https://doc3161en.candera.eu/books/controls-and-behaviors/page/create-controls)</span>.</p>
<div drawio-diagram="9035"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106966.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr></tbody></table>
# Control3D
Adds a new 3D control to the solution.
<div drawio-diagram="9036"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782106999.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Is Canvas Control</td><td style="width: 77.4763%;">Indicates whether the control is of type Canvas.</td></tr></tbody></table>
# EditorProfile
Adds a new editor profile to the solution. You associate the editor profile with a scene, and the scene references it through its `Editor Profile` property. By associating an EditorProfile you have created with a scene or a control, you can assign individual [<span style="color: rgb(230, 126, 35);">Editor Options</span>](https://doc3161en.candera.eu/books/preferences/chapter/editor-options) to each EditorProfile.
<p class="callout info">For details on how to configure an EditorProfile, refer to <span style="color: rgb(230, 126, 35);">[SCML Editor](https://doc3161en.candera.eu/books/scenecomposer-markup-language/page/scml-editor)</span>.</p>
<div drawio-diagram="9037"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107030.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr></tbody></table>
# RenderTarget
Adds a new render target to the solution. In `Render Target Template`, you select the type of render target to create.
<p class="callout info">For render targets, also refer to <span style="color: rgb(230, 126, 35);">[Add a new Render Target](https://doc3161en.candera.eu/books/display-configuration/page/add-a-new-render-target)</span>.</p>
<div drawio-diagram="9038"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107299.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset. When enabled, the system always exports the item during asset generation.</td></tr><tr><td style="width: 22.5237%;">Render Target Template</td><td style="width: 77.4763%;">Specifies the render target template, which is the type of the item as defined in Candera.
- **Hybrid 2D/3D Window Surface**: Creates the render target as a window surface that appears on the screen.
- **Hybrid 2D/3D Off-Screen Surface**: Creates the render target as an off-screen surface, which you can reuse as a texture.
- **Software Layer**: Creates the render target as a software layer.
</td></tr><tr><td style="width: 22.5237%;">Display</td><td style="width: 77.4763%;">Specifies the display that the render target links to. You can set this property only when &#96;Render Target Template&#96; is &#96;Hybrid 2D/3D Window Surface&#96;.
- **Display**: Links the render target to the standard display.
# SafetyScene
Adds a new safety scene to the solution. The system creates the scene as a scene that supports the functional safety of the solution.
<p class="callout info">This panel is displayed only if the safety feature is enabled in the <span style="color: rgb(230, 126, 35);">[Using Licenses](https://doc3161en.candera.eu/books/starting-scenecomposer/page/using-licenses)</span> panel.</p>
<div drawio-diagram="9039"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107337.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Is Locked</td><td style="width: 77.4763%;">Specifies whether the item is locked.</td></tr><tr><td style="width: 22.5237%;">IsView</td><td style="width: 77.4763%;">Specifies whether the scene is also used as a View.</td></tr></tbody></table>
# Scene2D
Adds a new 2D scene to the solution. You can choose whether to create an empty scene or to create the scene from an available scene template.
<div drawio-diagram="9040"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107372.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Is Locked</td><td style="width: 77.4763%;">Specifies whether the item is locked.</td></tr><tr><td style="width: 22.5237%;">IsView</td><td style="width: 77.4763%;">Specifies whether the scene is also used as a View.</td></tr><tr><td style="width: 22.5237%;">Is Template</td><td style="width: 77.4763%;">When you enable this option, the scene becomes a template for creating other scenes.</td></tr><tr><td style="width: 22.5237%;">Add Camera</td><td style="width: 77.4763%;">Specifies whether to add a camera to the new scene.</td></tr><tr><td style="width: 22.5237%;">Create empty scene / Use available scene template</td><td style="width: 77.4763%;">Provides radio buttons that switch the creation method of the new scene.
- Select **Create empty scene** to create an empty scene.
- Select **Use available scene template** to choose a template from the template tree at the bottom.
</td></tr><tr><td style="width: 22.5237%;">Search</td><td style="width: 77.4763%;">Provides a field that searches the template tree.</td></tr><tr><td style="width: 22.5237%;">Template tree</td><td style="width: 77.4763%;">Displays a tree view that lets you select the source template when you select **Use available scene template**.</td></tr></tbody></table>
# Scene3D
Adds a new 3D scene to the solution. You can choose whether to create an empty scene or to create the scene from an available scene template.
<div drawio-diagram="9041"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107405.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 180px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 619.2px; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 180px;">Destination path</td><td style="width: 619.2px;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 180px;">Name</td><td style="width: 619.2px;">Sets the name of the new item.</td></tr><tr><td style="width: 180px;">Description</td><td style="width: 619.2px;">Describes the new item in detail.</td></tr><tr><td style="width: 180px;">Annotations</td><td style="width: 619.2px;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 180px;">URI</td><td style="width: 619.2px;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 180px;">Export Always</td><td style="width: 619.2px;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 180px;">Is Locked</td><td style="width: 619.2px;">Specifies whether the item is locked.</td></tr><tr><td style="width: 180px;">IsView</td><td style="width: 619.2px;">Specifies whether the scene is also used as a View.</td></tr><tr><td style="width: 180px;">Is Template</td><td style="width: 619.2px;">When you enable this option, the scene becomes a template for creating other scenes.</td></tr><tr><td style="width: 180px;">Add Camera</td><td style="width: 619.2px;">Specifies whether to add a camera to the new scene.</td></tr><tr><td style="width: 180px;">Create empty scene / Use available scene template</td><td style="width: 619.2px;">Provides radio buttons that switch the creation method of the new scene.
</td></tr><tr><td style="width: 180px;">Search</td><td style="width: 619.2px;">Provides a field that searches the template tree.</td></tr><tr><td style="width: 180px;">Template tree</td><td style="width: 619.2px;">Displays a tree view that lets you select the source template when you select **Use available scene template**.</td></tr></tbody></table>
# Script
Adds a new script to the solution. You select Empty, Basic, or Full as the code template. The system adds the created script to the solution as a file with the `.lua` extension.
<div drawio-diagram="9042"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107443.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Code Template</td><td style="width: 77.4763%;">Selects the type of code template that you use when you create the script.
- **Empty**: An empty template that contains no code.
- **Basic**: A code template that contains the commonly used callback functions.
- **Full**: A code template that contains the complete set of callback functions that you implement.
# Shader
Adds a new shader to the solution. Use the toggle icons in `Type` to select whether to create a fragment shader or a vertex shader. A shader program then references the created shader.
<div drawio-diagram="9043"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107479.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Type</td><td style="width: 77.4763%;">Specifies the type of shader to create. The two icons on the left and the right switch between a fragment shader and a vertex shader.
- Fragment shader
- Vertex shader
# ShaderProgram
Adds a new shader program to the solution. The shader program pairs a fragment shader with a vertex shader, and you can apply it to the appearance of a node.
<div drawio-diagram="9044"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107510.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click Browse... to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Category</td><td style="width: 77.4763%;">Specifies the category that the new item belongs to. The Toolbox uses this category to classify the item.</td></tr><tr><td style="width: 22.5237%;">Order Index</td><td style="width: 77.4763%;">The Toolbox uses the Order Index to sort controls.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Fragment Shader</td><td style="width: 77.4763%;">A shader program that runs on the GPU (Graphics Processing Unit) to perform complex per-pixel effects. You select the fragment shader from the fragment shaders listed in the Shader panel, that is, the &#96;Shader&#96; items defined in the solution whose &#96;Type&#96; is fragment shader.</td></tr><tr><td style="width: 22.5237%;">Vertex Shader</td><td style="width: 77.4763%;">A shader program that runs on the GPU (Graphics Processing Unit) to perform complex per-vertex effects. You select the vertex shader from the vertex shaders listed in the Shader panel, that is, the <code>Shader</code> items defined in the solution whose <code>Type</code> is vertex shader.</td></tr></tbody></table>
# StateMachine
Adds a new state machine to the solution. In the State Machine Editor, you define the States and the Transitions of the created state machine.
<div drawio-diagram="9045"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107666.png" alt=""/></div>
# TextStyle
Adds a new text style to the solution. The `Style` property of a 2D Text Node and the `TextStyle` property of controls such as the text control and the text button control reference this text style.
<div drawio-diagram="9046"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107706.png" alt=""/></div>
<table border="1" id="bkmrk-%E9%A0%85%E7%9B%AE%E5%90%8D-%E8%AA%AC%E6%98%8E-%E4%BF%9D%E5%AD%98%E5%85%88%E3%83%91%E3%82%B9-%E6%96%B0%E8%A6%8F%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%82%A2" style="width: 800px; border-collapse: collapse;"><thead><tr><th style="width: 22.5237%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Item</span></th><th style="width: 77.4763%; background-color: rgb(35, 111, 161);"><span style="color: rgb(255, 255, 255);">Description</span></th></tr></thead><tbody><tr><td style="width: 22.5237%;">Destination path</td><td style="width: 77.4763%;">Specifies the folder in the solution where the system places the new item. Click **Browse...** to select an existing folder.</td></tr><tr><td style="width: 22.5237%;">Replacement Character</td><td style="width: 77.4763%;">Specifies the character that the system uses as a substitute when the requested character is not available in the font. The default value is <code>U&#43;FFFD</code>.</td></tr><tr><td style="width: 22.5237%;">Name</td><td style="width: 77.4763%;">Sets the name of the new item.</td></tr><tr><td style="width: 22.5237%;">Description</td><td style="width: 77.4763%;">Describes the new item in detail.</td></tr><tr><td style="width: 22.5237%;">Annotations</td><td style="width: 77.4763%;">Serves as storage for notes and other project-related information. The system exports the entered text to the HMI report.</td></tr><tr><td style="width: 22.5237%;">URI</td><td style="width: 77.4763%;">You can set any URI. If you enter a valid URI, clicking it launches the browser and displays the contents of the link.</td></tr><tr><td style="width: 22.5237%;">Export Always</td><td style="width: 77.4763%;">Specifies whether the system always includes this item as part of the asset.</td></tr><tr><td style="width: 22.5237%;">Base Style</td><td style="width: 77.4763%;">Specifies the base Style. A <code>GetFont</code> method call for a code point in a range that is not defined in a StyleEntry is resolved by the base Style specified here. The following are typical styles included in the ConstructionKit (they may differ depending on your environment).
- ConstructionKit.ArabicRegularStyle
- ConstructionKit.EnglishRegularStyle
- ConstructionKit.JapaneseRegularStyle
- ConstructionKit.KoreanRegularStyle
- ConstructionKit.OpenSans25 / OpenSans35 / OpenSans96
- ConstructionKit.OpenSansRegular25 / OpenSansRegular35 / OpenSansRegular96
- ConstructionKit.Roll Lens
- ConstructionKit.SimplifiedChineseRegularStyle
- ConstructionKit.ThaiRegularStyle
- ConstructionKit.Vera25 / Vera32 / Vera96
</td></tr><tr><td style="width: 22.5237%;">Default Font</td><td style="width: 77.4763%;">Specifies the default font by path. When no base Style is defined, the <code>GetFont</code> method retrieves the default font specified here for code points that do not fall within any range defined in StyleEntry. Click the browse button on the right to select a font.</td></tr></tbody></table>
# View
Adds a new **<span style="color: rgb(230, 126, 35);">[View](https://doc3161en.candera.eu/books/view-editor/page/view)</span>** to the solution. In the <span style="color: rgb(230, 126, 35);">[**View Definition Editor**](https://doc3161en.candera.eu/books/view-editor/page/view-definition-editor)</span>, you define the created View as a screen-level configuration by combining Scenes and existing Views.
<div drawio-diagram="9047"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107744.png" alt=""/></div>
# ViewTree
Adds a new <span style="color: rgb(230, 126, 35);">[**View Tree**](https://doc3161en.candera.eu/books/view-editor/page/view-tree)</span> to the solution. On the created View Tree, you configure the screen transition logic by arranging multiple Views in a tree structure. During asset generation, the system outputs the configured tree structure as a **<span style="color: rgb(230, 126, 35);">[Global State Machine](https://doc3161en.candera.eu/link/203#bkmrk-global%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3)</span>**.
<div drawio-diagram="9048"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2026-06/drawing-4-1782107786.png" alt=""/></div>
