# Target setup for DRM/KMS
This document describes the setup required to build and run CGI Studio applications with DRM/KMS device package.
It is explained how to run the DRM/KMS target demo application part of the release package, how to setup the build environment and how to build own applications for DRM/KMS.
Table of Contents
# DRM/KMS BSP
# DRM/KMS: Prerequisites
#### Hardware: Raspberry Pi 4
CGI Studio has been tested on  **Raspberry Pi 4** Board.
##### CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned <span style="color: rgb(230, 126, 35);">[here](https://doc3161en.candera.eu/books/build-system-setup/page/prerequisites)</span>.
##### Linux Toolchain (BSP)
<div class="contents" id="bkmrk-yocto-poky-3.1.11-pr"><div class="contents"><div class="contents"><div class="textblock">
- Create an SD card image with Raspberry Pi Imager - Raspberry Pi OS 64 Legacy, 64-bit (Debian Bullseye). Make sure to activate ssh access. This can be done with the Raspberry Pi Imager advanced options (strg+shift+x).
- Start the target
- On Target install the \*-dev packages needed for your application plus
    apt-get -yqq update && \
        apt-get -yqq install libinput-dev libudev-dev libgles2-mesa-dev libdrm-dev libgbm-dev libegl1-mesa-dev
- If an image with display server is used please make sure to boot to cli.
- On host install a VM / WSL with Ubuntu 20.04 LTS (Focal Fossa)
        apt-get -yqq install python3 build-essential crossbuild-essential-armhf crossbuild-essential-arm64
    Install CMake
    Copy /usr/lib and /usr/include from target SD Card to /opt/raspberry/bullseye/sysroot or /opt/raspberry/bullseye/sysroot64 if you use the 64 bit version.
- Compiler/s used for this release is GCC (GNU 9.4.0).
</div></div></div></div><p class="callout info">SD Card image, SDK and cross-compiler/s are not part of the delivery and have to be provided by the customer.</p>
#### Hardware: iMX8QM
CGI Studio has been tested on Toradex Apalis **iMX8QM** Board.
##### CMake
<div class="contents" id="bkmrk-yocto-6.6.0-built-at"><div class="contents"><div class="contents"><div class="textblock">
- Yocto 6.6.0 built at Candera according to Toradex manuals.
- Image and SDK were prepared by the Candera.
- The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
- Compiler/s used for this release is GCC (GNU 11.4.0).
#### Hardware: R-Car E3
CGI Studio has been tested on **R-Car E3** System Evaluation Board.
##### CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned [here](https://doc3161en.candera.eu/books/build-system-setup/page/prerequisites).
<div class="contents" id="bkmrk-linux-version-5.4.3-"><div class="contents"><div class="textblock">
- The SDK used for this release is based on Yocto Poky 2.4.3.
- SD card image and SDK were prepared by according to the RCar-E3 user guide.
- GCC (GNU 7.3.0)
#### Hardware: R-Car M3N
CGI Studio has been tested on **R-Car M3N** Customer Board.
##### CMake
<div class="contents" id="bkmrk-yocto-poky-3.1.11-pr-1"><div class="contents"><div class="contents"><div class="textblock">
- Yocto Poky 3.1.11 provided by the customer was used to test this release .
- Image and SDK were prepared by the customer.
- Compiler/s used for this release is GCC (GNU 9.3.0).
# Running the CGI Player Demo Application on DRM/KMS
Copy the application and the asset to the target. This can be done by copying the filed to the SD card containing the system, via ssh or with an USB flash drive.
#### Loading and running the application
Note that no other application that uses graphics hardware can be running when using the Player, the CourierSampleApp or the CitDemoApp.
If your Yocto image is built with Weston or X you must shut these down before running the application.
Player can be run by using the command:
$ /PathToPlayer/Player /PathToAsset/AssetName.bin
<div class="contents" id="bkmrk-if-touch-input-handl"><div class="textblock"><div class="fragment">
</div><dl class="note"><dt></dt><dd><p class="callout info">If touch input handling is enabled, touch devices must be assigned to seat so that display identifier matches seat number. For example, display-0 must be assigned to seat0. Refer to udev documentation for more information on how to assign devices to seats.</p>
</dd></dl></div></div>
# Building Own Application for DRM/KMS
#### Building Application
<div class="contents" id="bkmrk-make-sure-that-the-e"><div class="textblock"><dl class="note"><dd><p class="callout info">Make sure that the environment variables for the Yocto SDK are set in the terminal! Either reuse the terminal used to start CMake for building the Player or call the environment setup script again.</p>
$source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
<div class="contents" id="bkmrk-open-cmake-gui-and-c"><div class="textblock">
1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
</div></div><div class="contents" id="bkmrk-for-couriersampleapp"><div class="textblock"><dl class="note"><dd><p class="callout info">For CourierSampleApp and CitDemoApp asset file must be created with a matching SCHost.dll as the SCHost.dll for the CourierSampleApp and CitDemoApp contain specialized Widgets.</p>
</dd></dl></div></div>#### Generate Makefiles with CMake
For general information about CGI Studio Build System and CMake properties available to configure Candera applications refer to <span style="color: rgb(230, 126, 35);">[CGI Studio Build System](https://doc3161en.candera.eu/books/build-system-setup/chapter/build-system-overview)</span>
<div class="contents" id="bkmrk-open-a-terminal.-set"><div class="contents"><div class="textblock">
1. Open a terminal.
    - Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player <div class="image"><div drawio-diagram="2938"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567539.png" alt=""/></div>
        </div>
    - Root directory for build artifacts <div class="image"><div drawio-diagram="2939"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567561.png" alt=""/></div>
        </div>
6. Configure
    - Specify Unix Makefiles as generator for the project.
    - Specify tool-chain file for cross-compiling. <div class="image"><div drawio-diagram="2940"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567581.png" alt=""/></div>
        </div>
    cgi\_studio\_devices/src/DrmKms/ToolchainFiles/GCC-toolchain-&lt;platform&gt;-DrmKms-Linux.txt
8. Adapt the CMake settings, if necessary, e.g.:
    - CMAKE\_BUILD\_TYPE-&gt; Debug or Release.
    - Enable/disable features.
    - Press Configure.
9. Press Generate.
</div></div></div><div class="contents" id="bkmrk-"><div class="textblock"><dl class="note"></dl></div></div>
