# Target setup for Fbdev
This document describes the setup required to build and run CGI Studio applications with Fbdev device package.
It is explained how to run the Fbdev target demo application part of the release package, how to setup the build environment and how to build own applications for Fbdev.
# Fbdev BSP
# Fbdev: Prerequisites
#### Hardware: Telechips Dolphin 5
CGI Studio has been tested on Telechips Dolphin 5 Board.
##### CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned <span style="color: rgb(230, 126, 35);">[here](https://doc3161en.candera.eu/books/build-system-setup/page/prerequisites)</span>.
##### Linux Toolchain (BSP)
<div class="contents" id="bkmrk-yocto-6.6.0-built-at"><div class="contents"><div class="contents"><div class="textblock">
- poky-telechips-systemd 4.0.17
- Image and SDK were prepared by the Candera.
- The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
- Compiler/s used for this release is GCC (GNU 11.2.1).
</div></div></div></div><p class="callout info">SD Card image, SDK and cross-compiler/s are not part of the delivery and have to be provided by the customer.</p>
#### Hardware: Allwinner T507
CGI Studio has been tested on Allwinner T507 Board.
##### CMake
<div class="contents" id="bkmrk-to-build-the-player-"><div class="contents"><div class="contents"><div class="textblock">
- <span style="font-size: inherit;"><span data-teams="true">To build the Player for the target platform, you need to download the additional library package: OKT507-linux-sdk20.tar.bz2</span></span>
- <span style="font-size: inherit;"><span data-teams="true">The build requires an older version of Debian or Ubuntu. In our case, the entire build was performed on **Ubuntu 18.04.6 LTS** running in WSL on **Windows 11**.</span></span>
- Compiler/s used for this release is <span data-teams="true">GCC 5.3.1 (Linaro GCC 5.3-2016.05)</span>.
# Running the CGI Player Demo Application on Fbdev
Copy the application and the asset to the target. This can be done by copying the filed to the SD card containing the system, via ssh or with an USB flash drive.
#### Loading and running the application
Note that no other application that uses graphics hardware can be running when using the Player, the CourierSampleApp or the CitDemoApp.
If your Yocto image is built with Weston or X you must shut these down before running the application.
Player can be run by using the command:
$ /PathToPlayer/Player /PathToAsset/AssetName.bin
<div class="contents" id="bkmrk-if-touch-input-handl"><div class="textblock"><div class="fragment">
</div><dl class="note"><dt></dt><dd><p class="callout info">If touch input handling is enabled, touch devices must be assigned to seat so that display identifier matches seat number. For example, display-0 must be assigned to seat0. Refer to udev documentation for more information on how to assign devices to seats.</p>
</dd></dl></div></div>
# Building Own Application for Fbdev
#### Generate Makefiles with CMake
For general information about CGI Studio Build System and CMake properties available to configure Candera applications refer to <span style="color: rgb(230, 126, 35);">[CGI Studio Build System](https://doc3161en.candera.eu/books/build-system-setup/chapter/build-system-overview)</span>
<div class="contents" id="bkmrk-open-a-terminal.-set"><div class="contents"><div class="textblock">
1. Open a terminal.
    Dolphin 5 (Yocto based SDK)
    ```shell
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    Allwinner T507 (Buildroot based SDK)
    ```shell
    export SDKTARGETSYSROOT=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot
    export PATH=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH
    ```shell
    cd <build directory>
    cmake-gui .
    ```shell
    # Environment variables for sdk
    export SDKTARGETSYSROOT="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot"
    export PATH="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH"
    export SYSROOT="$SDKTARGETSYSROOT"
    export SDKSYSROOT="$SYSROOT"
    export PKG_CONFIG="/usr/bin/pkg-config"
    export PKG_CONFIG_SYSROOT_DIR="$SYSROOT"
    export PKG_CONFIG_PATH="$SYSROOT/usr/lib/pkgconfig"
    export CXX="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-g++ --sysroot=$SYSROOT"
    export CC="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-gcc --sysroot=$SYSROOT"
    export LD="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-ld --sysroot=$SYSROOT"
    cmake-gui .
    - Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player <div class="image"><div drawio-diagram="2938"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567539.png" alt=""/></div>
        </div>
    - Root directory for build artifacts <div class="image"><div drawio-diagram="2939"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567561.png" alt=""/></div>
        </div>
6. Configure
    - Specify Unix Makefiles as generator for the project.
    - Specify tool-chain file for cross-compiling. <div class="image"><div drawio-diagram="2940"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-02/drawing-4-1677567581.png" alt=""/></div>
        </div>
    cgi\_studio\_devices/src/Fbdev/ToolchainFiles/GCC-toolchain-&lt;platform&gt;-Fbdev-Linux.txt
8. Adapt the CMake settings, if necessary, e.g.:
    - CMAKE\_BUILD\_TYPE-&gt; Debug or Release.
    - Enable/disable features.
    - Press Configure.
9. Press Generate.
</div></div></div>#### Building Application
<div class="contents" id="bkmrk-make-sure-that-the-e"><div class="textblock"><dl class="note"><dd><p class="callout info">Make sure that the environment variables for the Yocto/Buildroot SDK are set in the terminal! Either reuse the terminal used to start CMake for building the Player or call the environment setup script again.</p>
</dd></dl></div></div>Dolphin 5 (Yocto based SDK)
```shell
```shell
<div class="contents" id="bkmrk-open-cmake-gui-and-c"><div class="textblock">
1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
</div></div><div class="contents" id="bkmrk-for-couriersampleapp"><div class="textblock"><dl class="note"><dd><p class="callout info">For CourierSampleApp and CitDemoApp asset file must be created with a matching SCHost.dll as the SCHost.dll for the CourierSampleApp and CitDemoApp contain specialized Widgets.</p>
