# iMX6 Integrity
# iMX6 Integrity Prerequisites
#### Hardware: NXP iMX6 SABRE Automotive
CGI Studio has been tested on NXP iMX6 DualPlus SABRE Automotive Infotainment Board (Sabre AI).
#### CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned <span style="color: rgb(230, 126, 35);">[here](https://doc3161en.candera.eu/books/build-system-setup/page/prerequisites)</span>.
CMake is able to create the cross compilation make files that can be used with Green Hills MULTI compiler.
#### MinGW
To allow cross compilation with makefiles, MinGW 5.1.6 was used for this release.
#### Green Hills Toolchain
The build tool chain is not part of the delivery. Green Hills MULTI compiler, Green Hills Integrity and the according iMX6 Sabre BSP patch have to be obtained directly from Green Hills and installed according to their installation guide.
CGI Studio was tested with **MULTI IDE 6.1.6, Compiler 2014.1.6** with **compiler patch 9431** and **INTEGRITY for ARM v11.0.4** including iMX6 SABRE Automotive BSP and Vivante Graphics Stack **Vivante\_GPU\_v5011p4\_r223261** . We recommend a clean install of Integrity and iMX6 SABRE Automotive BSP!
The Green Hills Probe was setup with **Green Hills Probe Firmware prerelease Version 5.3**.
#### Vivante Graphics Driver
The graphics driver is not part of this release. CGI Studio was integrated and tested with the Vivante Graphics stack included in The Green Hills iMX6 SABRE Automotive BSP mentioned above
# Running the Player Demo Application on iMX6 Integrity
#### Download the Application
To download and debug the application you need a Green Hills probe with firmware 4.4.0 or higher that is configured for your according iMX6 SABRE hardware.
##### Monolith Application
In MULTI launcher select "Open debugger" and choose the application from your build folder with postfix Monolith. Then hit F5 and connect to target (mpserv connection via Ethernet). Choose "Download to RAM" and choose ID 1. After the application is downloaded, connect an rtserv2 connection directly to the board via Ethernet that allows you to start the Player application. There are three ways to specify the IP address of the board that shall be used for rtserv2:
<div class="contents" id="bkmrk-as-u-boot-environmen"><div class="contents"><div class="textblock">
- as u-boot environment variable (will overrule the other two options)
- In the global\_table.c file of the kernel (in your int1104 folder)
- via the command "nc" after the Monolith was started
</div></div></div>##### Loading the asset
The Player demo application has the asset file added by teh linker. It will be loaded to RAM together with the application. As a default, the tunnel asset is linked. This can be changed in the file cgiapp\_device\_specific\_inc.cmake in the CGIApplication/Platform/IntegrityiMX6 folder.
</div></div></div>#### Logging Output and Key Input
Use TeraTerm or another terminal software to connect to the target via COM to receive logging output and use key input.
<div class="contents" id="bkmrk--0"><div class="contents"><div class="textblock"><div drawio-diagram="2960"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2023-03/drawing-7-1677657313.png" alt=""/></div>
</div></div></div>
# Building Own Application for iMX6 Integrity
#### Compile Tool Chain Preparations
Make sure to install the tool chain as described in <span style="color: rgb(230, 126, 35);">[iMX6 Integrity Prerequisites](https://doc3161en.candera.eu/link/674#bkmrk-page-title)</span>
</div></div></div>#### Generate Makefiles with CMake
To configure and generate makefiles for compiling the Player for IMX6 Integrity, follow below steps:
<div class="contents" id="bkmrk-point-cmake-to-sourc"><div class="contents"><div class="textblock">
    - Folder containing top-level "CMakeLists.txt", e.g. \\cmake\\Candera\\Player
3. Configure
    - \\cgi\_studio\_candera\\cmake\\toolchain-files\\MULTI-toolchain-iMX6-Sabre.txt
    - CMAKE\_BUILD\_TYPE-&gt; Debug or Release
    - Press Configure
6. Press Generate
</div></div></div>If the package supports "harfbuzz" as CANDERA\_TEXTSHAPER please set this entry appropriately because by default it is set to "ComplexLib". Resume the configuration by pressing “Configure” again.
</div></div></div>#### Building Application
The output monolith file can be found in your build directory's subfolder CGIApplication.
Open this file with the Green Hills MULTI IDE debugger and load it to RAM as described in the previous chapter.
