# Target setup for STM32MP157
This is a setup guide for the **CGI Studio Professional Edition** on the STM32MP157 with a Wayland display server. It covers the preparation of the target image and environment, the installation of CGI Studio player and the creation of a simple solution including the data binding script.
This target setup guide does not cover the optional **SoundHound integration**, which is used by the BloodPressureSample for voice interaction. Please check the [Blood Pressure Sample](http://cgi3151en.candera.eu/books/cgi-studio-professional-edition/page/blood-pressure-sample) for further information about it.
# STM32MP157 Target Setup Guide
### <span lang="en-us">Before you Begin</span>
<span lang="en-us">Before starting with the setup guide, we recommend the following to get familiar with CGI-Studio:</span>
- <span lang="en-us">Explore CGI-Studio
    Read the <span style="color:rgb(230,126,35);">[Quick Start Guide](https://doc3161en.candera.eu/books/getting-started/chapter/quick-start-guide)</span>.
    </span>
- <span lang="en-us">Learn to create SceneComposer Solutions
    *&lt;cgi-studio-installation-path&gt;\\bin\\SceneComposer\\SceneComposer.exe*</span>
- <span lang="en-us">Generate Assets for Simulation and Target Environments
    You can find guidance on generating assets from solutions (binary files containing solution information for the player) for both simulation and target environments in the <span style="color:rgb(230,126,35);">[documentation](https://doc3161en.candera.eu/books/asset-library-generation)</span>.
    </span>
<span lang="en-us">With this knowledge you should be fit to complete this guide.</span>
### <span lang="en-us">Software Image Setup</span>
#### <span lang="en-us">Flashing the Target Device</span>
<span lang="en-us">Download the prepared image provided by Candera:
FlashLayout\_sdcard\_stm32mp157f-dk2-opteemin.raw</span>
<span lang="en-us">To flash the image to a micro SD card with minimum size of 8GB, use a tool such as [<span style="color:rgb(230,126,35);">Etcher.io</span>](https://etcher.balena.io/). After the flashing process is complete, insert the SD card into the STM32MP157 Discovery Kit, then power on the device to boot from the SD card.
</span><span lang="en-us">Please check that your boot settings are correctly set to boot from the SD card according to the <span style="color:rgb(230,126,35);">[official guide](https://wiki.st.com/stm32mpu/wiki/STM32MP15_Discovery_kits_-_Starter_Package)</span>.</span>
<span lang="en-us">After booting, connect to the target device via a serial terminal (e.g. <span style="color:rgb(230,126,35);">[Tera Term](https://teratermproject.github.io/index-en.html)</span>) or SSH and run the following setup script to complete the installation of required packages and configuration:</span>
cd /opt/cgistudio/PlayerConnector
./install.sh
<span lang="en-us">At Candera we have used <span style="color:rgb(230,126,35);">[WinSCP](https://winscp.net/eng/index.php)</span> to transfer additional files to the target device as needed.</span>
<span lang="en-us">After this step, your target system will be prepared to run Python-based data binding examples or any assets using the CGI-Studio runtime environment.
To change the location of the Weston taskbar (which is positioned at the bottom by default) or to remove it entirely you can use our *set\_weston\_panel.sh* script located in */opt/cgistudio/PlayerConnector/set\_weston\_panel.sh.*
</span>
### Blood Pressure Sample
We have prepared several samples to demonstrate the capabilities of CGI-Studio on the target image. These samples are located at:
*/opt/cgistudio/PlayerConnector/Samples/* on the target image and in *&lt;cgi-studio-installation-path&gt;\\bin\\ProfessionalEdition\\Python\\Samples* on the host computer.
We will use the Blood Pressure Sample as an example to demonstrate how to run our samples. The Blood Pressure device sample is a Scene Composer sample that showcases a blood pressure measurement device with exemplary scenes and animations.
In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Player Connector Library. For this chapter the completed “Image Setup” is required.
#### Run Blood Pressure Sample with Target Player
- **Navigate to the Player directory** Navigate to the Player directory before running the asset:
    cd /opt/cgistudio/TargetPlayer
- **Run the Asset** Execute the below command in remote terminal, to run the player and asset
    ./Player ../PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
    <div drawio-diagram="7880"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738913227.png" alt="drawing-7-1738913227.png"/></div>
#### Run Blood Pressure Sample with Python
In this section, we explain how to execute the Blood Pressure sample including Python-based data binding with our Player Connector Library. The Player Connector Library allows the simple connection between CGI Studio Player and a Python-based script.
##### Python Script
Before we proceed with executing the script, let's first take a moment to review the key components of the Player Connector Library script, which can be found at the following location on your host computer:
*&lt;cgi-studio-installation-path&gt;\\bin\\ProfessionalEdition\\Python\\Samples\\BloodPressureDevice\\BloodPressureDevice.py*
This script can also be found in */opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice.py* on the image.
1. Import the Player Connector Library and additional required libraries.
    import argparse
    import time
    import signal
2. Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
    #Looping until sig int
    try:
      while not sigintCaptured:
      App.Step()
    normalizedProgress * 100.0)
    except KeyboardInterrupt:
    finally:
      App.ShutDown()
      if SoundhoundCommandClient is not None:
    exit()
More information on the capabilities of our library can be found [<span style="color:rgb(230,126,35);">here</span>](https://doc3161en.candera.eu/books/cgi-studio-professional-edition/page/python-based-data-binding).
##### Run Blood Pressure Sample with Player Connector Library in Simulation Environment (Host)
To run the Python-based data binding in the simulation environment (on the host computer) execute the steps below on the **host computer**:
- **Open a command line interface in** *&lt;cgi-studio-installation-path&gt;\\bin\\ProfessionalEdition\\Python\\Samples\\BloodPressureDevice*
- **Install libraries:** In order to install the Player Connector Library and other required libraries you need to execute:
    pip install -r requirementsWithoutSoundhound.txt
- **Run Blood Pressure Sample Simulation Asset with Python-based Data Binding** By running the sample, you will be presented with a start scene waiting for your input. To continue using the sample, simply press the 'Start' button on the player.
    Please note that the -wsh parameter is only necessary for the Blood Pressure Sample and not for the Slider and Gauge sample script.
    py BloodPressureDevice.py -lbp ..\..\..\STM32MP157_Simulation\PlayerConnector\PlayerConnectorLibrary.dll
    <div drawio-diagram="8407"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-05/drawing-7-1747876958.png" alt="drawing-7-1747876958.png"/></div>
##### Run Blood Pressure Sample with Player Connector Library in Target Environment
It’s assumed that a remote terminal (Tera Term) connection is established and the setup script */opt/cgistudio/PlayerConnector/install.sh* was executed successfully.
- **Navigate to the BloodPressureDevice folder**
    cd /opt/cgistudio/PlayerConnector/Samples/BloodPressureDevice
- **Run asset with Python-based Data Binding** By running the sample, you will be presented with a start scene waiting for your input. To continue using the sample, simply press 'Start' button on the target screen.
    python3 BloodPressureDevice.py -wsh -lbp ../../libPlayerConnectorLibrary.so -abp BloodPressureDevice_Target.bin
### Empty Solution with Slider and Gauge Control
Before proceeding with the example, it is recommended to explore CGI-Studio by reading the [<span style="color:rgb(230,126,35);">Quick Start Guide</span>](https://doc3161en.candera.eu/books/getting-started/chapter/quick-start-guide), both of which are available in the CGI-Studio Documentation.
- Start Scene Composer in *&lt;cgi-studio-installation-path&gt;\\bin\\SceneComposer\\Scenecomposer.exe*
- Open Empty Solution by either double clicking the empty solution thumbnail or through the File &gt; New Solution dialog.
    <div drawio-diagram="7882"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738913524.png" alt="drawing-7-1738913524.png"/></div>
- In the Render Targets panel (on the right side of the SceneComposer), set the resolution of Display (0) to X Resolution (width) of 800 and Y Resolution (height) of 480.
    <div drawio-diagram="7883"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738913629.png" alt="drawing-7-1738913629.png"/></div>
- Drag and drop a Slider Control and a Gauge Control from the Control section of the Toolbox (on the right side of the Scene Composer) into the Scene Editor.
    <div drawio-diagram="7884"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738913876.png" alt="drawing-7-1738913876.png"/></div>
- You can move the controls in the Scene Editor by selecting the translation icon (the red square in the screenshot below) in the top left corner of the Scene Editor and then selecting the control which you want to move. Just select the item you want to move and drag it to a new location.
    <div drawio-diagram="7885"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738913959.png" alt="drawing-7-1738913959.png"/></div>
- Select the Gauge Control in either the Scene Editor or the Scene Tree, navigate to the properties, and adjust the scale to ensure it fits comfortably within the display.
    <div drawio-diagram="7886"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738914100.png" alt="drawing-7-1738914100.png"/></div>
- To set up a data binding for the Gauge value, first select the Gauge either in the Scene Editor or the Scene Tree. In the properties panel locate the Value property under the Control section and click the chain icon next to it to establish the binding.
    <div drawio-diagram="7887"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738914200.png" alt="drawing-7-1738914200.png"/></div>
    <div drawio-diagram="7888"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738914285.png" alt="drawing-7-1738914285.png"/></div>
- To set a data binding for the Slider property, select the Slider control in either the Scene Editor or the Scene Tree. Then, click the chain icon next to the Value property in the Control section of the Properties panel. Next, choose Item2 (under PredefinedBindingSource1) from the available options.
- Next, generate two asset libraries for both the target and simulation environments to run the solution in the player.
    - Save the solution, then go to File &gt; Generate Asset Library
        <div drawio-diagram="7889"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738914354.png" alt="drawing-7-1738914354.png"/></div>
    - A popup window will appear each time, allowing you to generate the asset library. Choose your desired asset location, set the environment to “Simulation” for the first run and to “Target” for the next, then click “Generate” to create each asset library.
        <div drawio-diagram="7891"><img src="https://doc3161en.candera.eu/uploads/images/drawio/2025-02/drawing-7-1738914952.png" alt="drawing-7-1738914952.png"/></div>
- Next, create a Python script. You can use the provided Sample.py file located in
    *&lt;cgi-installation-path&gt;\\bin\\ProfessionalEdition\\Pythony\\Samples\\SliderAndGauge\\Sample.py* in your local CGI-Studio installation folder and in */opt/cgistudio/PlayerConnector/Samples/SliderAndGauge/Sample.py* on the target image.
- Run the asset in the simulation environment (Host):
    Do it analogous to the steps from chapter <span style="color:rgb(230,126,35);">[Run Blood Pressure Sample with Player Connector Library in Simulation Environment (Host)](https://doc3161en.candera.eu/link/1251#bkmrk-run-blood-pressure-s-2)</span>.
    <p class="callout info">A requirements.txt file is not necessary, since only the Player Connector Library needs to be installed:
    </p>
- Run the asset on the **target device**:
    Ensure the device is set up correctly according to the chapter [<span style="color:rgb(230,126,35);">Software Image Setup</span>](https://doc3161en.candera.eu/link/1251#bkmrk-image-setup). Use WinSCP or a similar tool to copy the generated target asset from the host computer to the target device.
    Run it analogous to the steps from chapter <span style="color:rgb(230,126,35);">[Run Blood Pressure Sample with Player Connector Library in Target Environment](https://doc3161en.candera.eu/link/1251#bkmrk-run-blood-pressure-s-3)</span>.
### Final comments
