Mixed Reality
VideoStream
A control that makes it possible to render a video source into a texture.
Properties
Property Name
Type
Source Type SourceType::Enum
Specify if the video is part of the asset or an external source. Options are External or Internal.
Video Source String
URI to video resource (e.g. path to file or URL).
Please also see example strings below.
Scale To Video Source
bool
If enabled the texture will be resized to the video size, otherwise the size of the current texture will persist.
Flip Vertically
bool
Flips video vertically.
Timestamp
UInt32
Can be used to bind the timestamp of the video to an external timestamp data (e.g. a camera tracker that needs to be synchronized with the video).
Target Node
Node The node on which the video will be displayed. If nothing is selected, the node on the anchor will be used.
Blend Type
BlendType::Enum The blend type that will be set.
Examples of valid Video Source strings
Source
Example Video Source String
From asset
asset://Resources#Videos#VideoSourceSample1.mp4
From website
http://www.cgistudio.at/VideoSourceSample2.mp4
From file
file:///C:/Videos/Streaming/VideoSourceSample3.mp4
NavigationPath3D
Visualizes the proposed route of the navigation system. Input points are received via data binding. This control is available for 3D scenes.
Properties
Property Name
Type
Mesh Appearance AppearanceType The appearance used for the navigation path mesh.
Color Mode
ColorMode::Enum (Color, RGBA)
Select how color is displayed.
Color
Candera::Color Determines the color of the mesh.
Path Width
Float
Determines the width of the mesh.
Path Length
Float
Determines the length of the mesh.
Y Offset
Float
Applies y-offset to the mesh.
Input Points
InputPointsType This property is used to bind input points.
Input Point Handling
InputPointHandling::Enum (Attach, Replace)
Determines how new input points are used for the mesh.
Interpolation Type
InterpolationType::Enum (Linear, Bezier, Spline, None)
Determines which interpolation method is used.
Path Mesh Type
MeshType::Enum (Solid, Points)
Determines which primitive type is used.
Advanced
bool
Enables advanced settings of the behavior. (see next 6 properties in this table)
Input Point Min Distance Float Minimum distance of two control points. Input points that are closer together will be rejected.
Req Fragment Size
SizeType
Size of the fragment that is requested from the input point list.
Req Threshold Distance
Float
If the distance between camera and the last point is below this threshold, request a new fragment of input points.
Num Of Rows Per Input Point
UInt32
Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant.
Num Of Vertex Rows
UInt32 Amount of vertical vertices in the mesh.
Num Of Vertex Columns
UInt32 Amount of horizontal vertices in the mesh.
Blend Type
PoiManager3D
The PoiManager handles the creation and destruction of POIs. It receives the camera position via event and uses that information to request all POIs in a certain perimeter from the model. The model responds with a list POIs from a dictionary.
For each type of POI, a custom control that serves as a template has to be created and configured with a valid Asset ID. The PoiManager can then instantiate the correct control according to the dictionary from the Asset ID as a child node. However, the PoiManager does not handle the metadata of its children, but simply forwards metadata messages to them. (For more information on metadata handling see Poi Metadata Handler)
Properties
Property Name
Type
Street Points
StreetPointsType
List of points of the street. Used to align the rotation of POIs.
Street Points Min Distance
Float
Minimum distance between two street points. Street points that are closer together will be rejected.
Req Distance
Float
The distance in which POIs are requested from the model.
Float
Once the camera has moved this specified distance a new request will be sent.
PoiMetaData
PoiMetaDataType Use databinding to receive metadata updates for the POIs
Poi Street Name String Name of this poi.
Street Control Id
Candera::Id
ID of the control that is associated with PoiName.
Poi Parking Name
Parking Control Id
Candera::Id ID of the control that is associated with PoiName.
Poi Building Name
Building Control Id
Blend Type
VideoStream3D
This Control makes it possible to render a video source into a texture. The VideoStream3D Control is available for 3D scenes.
It is similar to the VideoStream Control, offering the same properties.
