Docs Agent
  • Summarize long documentation pages
  • Connect concepts across different pages
  • Point you to specific tutorials
  1. Directly in the product documentation to directly get AI-powered summaries across many pages
  2. As MCP Server if you need your AI agent to check for you (like Claude.ai or Claude Code, Codex, Antigravity, or similar)
How to Access
How to use
1 Help button A **Help**Help menu is available in the top bar of the Docs Agent window. From there, you can open the following information:
  • Help: Displays overview information about Docs Agent.
  • Privacy Policy: Launches a web browser and displays the privacy policy information.
  • Third-Party: Displays third-party information (such as licenses).
2 Minimize button Clicking this button closes the Docs Agent window.
3 Maximize / Restore button Clicking this button maximizes the Docs Agent window. Click it again to restore the window to its original size.
4 Suggested prompts Before you enter a custom prompt, suggested prompts are displayed. Clicking a suggested prompt inserts its content so you can ask a question immediately.
5 Chat input field Enter your question in the chat input field and press ENTER to receive a response from Docs Agent.
6 Relevant Documents Links to the documentation pages that Docs Agent referenced when generating the answer are shown. The numbers at the end of the answer indicate the corresponding source links as reference numbers. Clicking a number opens the associated source link and displays the referenced documentation page.
7 Action button Action buttons are displayed below the response from Docs Agent.
  • Give feedback on last response: Send your feedback on the document content.
  • Copy to clipboard: Copies the response to the clipboard.
  • Clear history: Clears the chat history.
  • Retry last response: Re-runs the most recent question.
While the agent is optimized for accuracy, AI responses can occasionally be incorrect or misleading. Before proceeding with any implementation, always use the **source links**links (see figure) to review the original article.
Troubleshooting
Privacy
Docs Agent MCP Server
Enable your AI tools to communicate with the Docs agent via the Model Context Protocol. Your AI agent queries the Docs Agent directly, instead of you opening the online or offline product documentation and passing the information on yourself.
This is useful when you:
  • develop HMIs, custom behaviors or custom controls for CGI Studio with the support of an AI assistant, and want it to consult the CGI Studio documentation while it works
  • work through a complex CGI Studio problem together with an AI assistant
If you are reading the documentation yourself, use the Docs Agent in the product documentation instead — it requires no setup.
Requirements
  • An MCP client that supports remote MCP servers over HTTP with OAuth authentication (for example Claude.ai, Claude Code, Codex, Antigravity, or Cursor).
  • A Google or GitHub account to sign in with.
  • Access from your machine to https://chatbot.cgistudio.at (check your firewall or proxy settings if the connection fails).
  • The MCP Server is available with every CGI Studio edition, including the Community Edition.
How to Access
The server endpoint is:
https://chatbot.cgistudio.at/api/mcp
Add this URL to your MCP client. The exact steps depend on the client; the following examples cover the most common ones.
Claude Code
Run the following command in your terminal:
claude mcp add --transport http docs-agent https://chatbot.cgistudio.at/api/mcp
Then start Claude Code and run /mcp to complete the sign-in.
Claude.ai (web and desktop)
Open Settings → Connectors → Add custom connector, enter a name (for example CGI Studio Docs Agent) and the server URL above, then confirm and connect.
Clients using a JSON configuration file (for example Cursor and many others)
Add the server to the mcpServers section of the client's MCP configuration file (exact elements may differ slightly):
	"mcpServers": {
		"docs-agent": {
			"type": "http",
			"url": "https://chatbot.cgistudio.at/api/mcp"
Antigravity
Open the Agent panel, go to the MCP server settings and choose to edit the configuration file (mcp_config.json). Add the server under mcpServers — note that Antigravity uses serverUrl for remote servers:
	"mcpServers": {
		"docs-agent": {
			"serverUrl": "https://chatbot.cgistudio.at/api/mcp"
Save the file and refresh the MCP servers in the Agent panel. It will present you with an "Authenticate" button - click it and then follow the browser sign-in described below.
Codex (ChatGPT app)
Codex is configured from the ChatGPT app UI:
  1. Open Settings → Plugins.
  2. Click Add → Add MCP Server.
  3. Switch Type to Streamable HTTP.
  4. Enter a Name (for example CGI Studio Docs Agent) and the URL above.
  5. Click Save.
  6. Click Authenticate and sign in with Google or GitHub (see below).
  7. Once the sign-in completes, the server is connected and ready to use.
Signing in
The first time your client connects, it opens a browser window and asks you to choose a login provider — Google or GitHub. After you have signed in and approved the access request, the browser returns to your MCP client and the connection is established. Your client stores the resulting access token, so this step is only required once per client (and again whenever the token expires or you revoke it).
How to use
Once connected, the server provides one tool and two resources to your AI assistant.
Type Name Description
Tool chat Asks a question about the CGI Studio documentation and returns an answer, including references to the relevant documentation pages.
Resource cgi://platforms The list of available hardware platforms, so the assistant can pick a valid value for the platforms parameter.
Resource cgi://versions The list of available CGI Studio product versions, so the assistant can pick a valid value for the cgistudioVersion parameter. CGI Studio 3.16.0.0 and later are supported.
In normal use you do not call these directly. Simply ask your assistant a CGI Studio question — for example:
Ask the Docs Agent how to set up a state machine in CGI Studio 3.16 and summarize the steps.
The assistant then calls the chat tool on your behalf and answers with the information it received. Questions are sent to the server in English; if you ask in another language, your assistant translates the question before sending it. If you are unsure which hardware platforms an answer can be scoped to, ask your assistant to list them — it reads them from the cgi://platforms resource.
The chat tool accepts the following parameters. Your AI agent / MCP client fills them in automatically, but it is useful to know that you can steer them from your prompt (for example: "ask the Docs Agent about … for CGI Studio 3.16 on i.MX8", or ask for general questions like "ask the DocsAgent for some samples on implementing custom behaviors?" and it will default to the latest CGI Studio version across all available platforms ).
Parameter Required Description
query yes The question, in English. If you ask in another language, the AI is instructed to translate the question before sending it.
cgistudioVersion no The CGI Studio version you are working with, for example 3.16.0.0. If omitted, the current default version (latest CGI Studio release) is used.
platforms no The target platforms to scope the answer to, for example imx8 or wayland. Use all to include all platforms.
session_id no A conversation handle returned by a previous call. Passing it back continues the same conversation with its history; omitting it starts a new conversation.
Checking the parameters before a call
Most MCP clients ask you to confirm a tool call before it is executed and show the parameters that will be sent. If you want to be certain which CGI Studio version or platform an answer is based on, review the call at that point, or name the version and platform in your prompt.
Conversation history
Each conversation is identified by a session_id that the server returns with every answer. As long as your client passes that handle back, follow-up questions keep the context of the previous ones. A conversation expires 24 hours after the last message and is then deleted. A conversation can only be continued by the user who started it — a handle from another user is rejected.
Answer quality
As with the Docs Agent in the product documentation, AI responses can occasionally be incorrect or misleading. The answers contain references to the documentation pages that were used. Always open those pages and review the original article before you rely on an answer for your implementation.
Troubleshooting
Symptom What to check
The client cannot reach the server Check your internet connection, firewall, and proxy settings for https://chatbot.cgistudio.at. Also verify that the URL is entered exactly as shown, including the /api/mcp path.
The browser does not open for sign-in, or the login window fails Make sure pop-ups are allowed and that your MCP client is permitted to open a browser. Some clients offer a manual command (for example /mcp in Claude Code) to trigger the sign-in again.
The tool answers Not authenticated: this tool requires a signed-in user. Your access token is missing or has expired. Disconnect and reconnect the server in your client to sign in again.
The tool answers that the conversation belongs to a different user The session_id was created by another user or in another account. Start a new conversation without a session_id.
A previous conversation no longer has context Conversations expire after 24 hours of inactivity. Continue by asking your question again without the old handle.
Upstream request failed. A temporary service interruption. Retry the question; if the problem persists, contact support.
Privacy
Your questions and the resulting answers are processed by the same service as the Docs Agent in the product documentation and are subject to the same privacy policy. In addition, note the following for the MCP server:
  • Signing in via Google or GitHub shares your account identifier (and e-mail address) with the service. It is used to authenticate you and to keep your conversations separate from those of other users.
  • Conversation content is stored on Cloudflare servers in the EU and is deleted automatically 24 hours after the last message of that conversation.
  • Your MCP client stores the access token locally on your machine. Remove the server from the client's configuration to delete it.
