GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. The right side displays a List of devices. When a device gets selected, an associated Sub-List Control with two TextButtons will be shown.
Preparing the Options scene
A scene will be created and the camera will be configured in the Render Targets panel.
  1. Create a new scene via the menu bar "Scene" - "New 2D Scene" or press < Ctrl+2 > on your keyboard
  2. In the first row select "/Scenes" from the drop-down menu. Enter "SceneOptions" as name and press [OK] OK ]. We use the prefix "Scene" to have all scenes listed next to each other in the Solution Explorer panel.
  4. In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [Camera] Camera ] section change the sequence number to 2.
Importing Images
  1. In the menu bar select Import > Import Resources...
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 16 files and press [Open] Open ]
      Import Resources
      Path
  3. In the "Import Images" dialog select folder "/Resources", make sure to create a new folder "Options" for the imported images and click [OK] OK ].
Configuring the Background
This scene is composed of two parts: Connection and Devices. For each of these parts a 2D Group node will be created. To position the background image a BitmapNodeBimapNode will be configured with one of the images imported in the previous section.
  1. From the Toolbox panel's [ Node 2D]2D ] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
  2. From the Toolbox panel's [ Node 2D]2D ] section drag a BitmapNodes onto the 2D Group node.
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
  5. In the Scene Tree panel select theboth BitmapNodes called "Background". This can be achieved by selecting one afterBitmapNode, holding down the other<Ctrl> key and performkeeping it pressed while clicking on the followingsecond instructions on both background nodes:BitmapNode. In Scene Tree panel's right side select the "BitmapBrushBlend" effect. In the Properties panel's [Effect] Effect ] section click on the magnifying glass icon next to the Image property.
  6. The "Choose Item" dialog will be opened.
  7. In the "Choose Item" dialog select the image as in the table below and click [OK] OK ].
      Node
      Effect Property
      Path
      Connection > Background BitmapBrush Blend Image
      /Resources/Options/ConnectionOptionsENBOSBmp Connection > Background BitmapBrush Blend Image
    • In the Scene Tree panel select the "Connection" group. In the Properties panel's [Transformations] Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
        Target Name
        Position X
        Position Y
        Connection
        78.00
        58.00
        Devices
        551.00
        58.00
    The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
    1. From the Toolbox panel's [Controls] Controls ] section under Touchable drag a Dial control into the Scene Tree panel directly onto the "Connection" group.
    2. In the Scene Tree panel select the Dial control. In the Properties panel's [Transformation] Transformation ] section adjust its position according to the table below.
        Target Name
        Position X
        Position Y
        Dial
        72.00
        163.00
    The following steps show how to configure the Dial control with new images.
    1. In the Properties panel's [Control] Control ] section click on the magnifying glass icon next to property "Knob Image".
    2. In the "Choose Item" dialog select the image as in the table below and click [OK] OK ].
      • The "Choose Item"Item dialog will be closed.
        Property
        Path
        Knob Image
    3. In the Properties panel's [Control] Control ] section click on the the "BackgroundImages" section.
    4. In the Properties panel's [BackgroundImages] sectionpanel click on the magnifying glass next to "BackgroundImages 0".
    5. In the "Choose Item"Item dialog navigate to "/Resources/Options/NewDial_background_leftBmp", select thethis image as in the table below and click [OK] OK ].
      • In the Properties panel the first one of the BackgroundImagesBackgroundImage has been configured.
        Property
        Path
        BackgroundImages 0
      • Repeat steps 4 and 5 to configure the remaining BackgroundImages. After this step the BackgroundImages areas configured according toin the table below.
          StateImages
          Image Path
          BackgroundImages 1
          BackgroundImages 2
      • In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [Bitmap] Bitmap ] section enable "Pivot Hint" by checking the respective checkbox.
      • Configure the "Pivot Hint" as in the table below.
          Target Name
          Pivot Hint Y
          88,00
      • In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 710 and 8,11, enabling and configuring the Pivot Hint of these three images according to the table below.
          Target Name
          Pivot Hint Y
          true 84,50
          88,00
          130,50
          130,50 NewDial_background_middleBmp true
          130,50 130,50 NewDial_Background_rightBmp true
          130,50 130,50
      TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
      1. From the Toolbox panel's [ Nodes 2D]2D ] drag and drop a TextNode into the Scene Tree panel directly onto the "Connection" group node.
      2. In the Scene Tree panel select the new TextNode. In the Properties panel's [ 2D Text Node]Node ] section click on the magnifying glass icon next to property "Style".
      3. In the "Text Style Palette" dialog select "OpenSans25" and click [OK] OK ].
      4. In the Scene Tree panel right click onto the TextNodeConnection and select "Clone..." from the context menu.
      5. In the "Clone Item" dialog change to the "Multiple Clone" tab. Configure "Number of Copies" to "3" and click [OK] OK ].
          Text Position X Position Y
          TextNode_Cable Cable 20 200
          TextNode_Other Other 315 200
      The right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
      1. In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy"  or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
        • In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group.
        • In the Scene Editor another Textnode with "Connection" is visible.
      2. In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
        • In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D.
      3. In the Scene Tree panel select TextNode_Devices. In the Properties panel's [ 2D Text Node]Node ] section change the TextNode's Text property and in the [Transformation] Transformation ] section adapt its Position according to the table below.
        • Text and position of the TextNode are configured.
        • In the Scene Editor you can see that the devices part has got a headline.
          TextNode_Devices Devices 145 61
      4. From the Toolbox panel's [Control] Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
      5. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node]Node ] from the context menu.
      6. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node]Node ] from the context menu.
      7. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
      8. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [OK] OK ].
        • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [Controls] Controls ] section as last item of the list.
      Configure MyList Control
      Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
      1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
      2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [OK] OK ].
      5. In the "Delete Item" dialog press [OK] OK ].
        • The List node is deleted.
      6. From the Toolbox panel's [Control] Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
      7. In the Scene Tree panel select "MyList". In the Properties panel's [Control] Control ] section set the "Scrollbar Visibility" to "Visible".
      Customize MyList's Scrollbar
      Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
          Thumb Images
          Image Path
          VerticalPrevItem Images
          Image Path
          VerticalNextItem Images
          Image Path
      Configure MyList's Main Item
      Our MyList control will be composed of MainItems. Whenever a certain MainItem gets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
      2. From the Toolbox panel'Toolbar's [ 2D Nodes]Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
      3. From the Toolbox panel'Toolbar's [ 2D Nodes]Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
      4. In the Scene Tree panel select the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
          Initial Name
          New Name
          OverlayLayout MainItem
          TextNode EntryName
          RenderNode FocusImage
      5. In the Scene Tree panel select the List (Group2D). In the Properties panel's  [Transformation] Transformation ] section configure the position and size according to the following table.
          Target Item
          Transformation
          Layout
          List (Group2D)
          58
          134
          300
          300
      6. In the Scene Tree panel select the TextNode2D (MainItem > EntryName). In the Properties panel's [ TextNode2D ] section click on the magnifying glass icon to the right of the Style property.
        • The Text Style Palette dialog will be opened.
        In the Text Style Palette dialog select "OpenSans25" and click [ OK ].
          The Text Style Palette will be closed. In the Scene Editor the EntryName's text will be displayed in a smaller font.
          Target Item
          Style
          MainItem > EntryName OpenSans25
          In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
          3. In the "Choose Item" dialog select the image as in the table below and click [OK] OK ].
              Target Item
          4. In the Properties panel change the Color property by entering new values for "Red", "Green" and "Blue" according to the table below.
              Target Item
              Color
              Red
              Green
              Blue
              0.62
              0.00
          5. In the Scene Tree panel select the FocusImage node. In the Properties panel's [Layout] Layout ] section set the StretchBehavior to "Fill" according to the table below.
            • In the Scene Editor the FocusImage RenderNode will appear highlighted with an orange outline.
              Target Item
              Layout > StretchBehavior
              Fill
          Create MyList's Sub-List
          A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
          1. From the Toolbox panel's [Controls] Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
          2. From the Toolbox panel's [Node 2D]Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
          3. From the Toolbox panel's [Controls] Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
          4. In the Scene Tree panel select the StackLayout. In the Properties panel's [Transformation] Transformation ] and [Layout] Layout ] section configure the properties as in the table below.
              Target Item
              Transformations
              Layout
              Scale X
              Scale Y
              Margin Left
              TextButton
              0,75
              0,75
              12
          5. In the Properties panel's [Control] Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
          6. In the "Choose Item" dialog select the image according to the table below and click [OK] OK ].
          7. Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
              Target Item
              Image Path
              Normal Image
              Pressed Image
              Focused Image
          10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [Control] Control ] section according to the table below.
            • The texts of the TextButtons have been changed.
              Target Item
              New Name
              Control - Text
          Configure Behaviors for the Focus Handling of MyList's MainItem
          Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus and FocusLeave behaviors are used to enable or disable the rendering of the FocusImage. The behaviors are configured using Fusion.
          A detailed explanation about Fusion, how to operate Fusion (how to add Fusion Nodes) and a configuration example can be found in the documentation about Fusion.
          1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [Item] Item ] section uncheck "Enable Rendering".
          2. In the Scene Tree panel select the MainItem GroupNode. Then press the [Fusion...] button on the right side of the Scene Tree.
            • Fusion panel is opened displaying the Fusion diagram with the MainItemMainItem's Fusion Node.
            • The MainItem Fusion node has a Behaviors connector on its right side.
          3. AddDrag Fusionthe NodesBehaviors connector to the MainMenuright Fusionand Nodethen usingrelease itsthe Behaviorsmouse connectorbutton. according
            • The [Select Behavior] dialog will be opened, which displays a list of behaviors.
            The behaviors are organized in groups similar to the tablebehaviors below.list in the Toolbox panel. There is an input field just above the behaviors list. Click into the input field and start typing "Handle Control State".
            • ThreeWhile typing the list of behaviors will be narrowed down.
            When you find the behavior "Handle Control State" double-click it.
              A new Fusion node will be added to the Fusion diagram: [Handle Control State,State]. Focus, FocusLeave. FocusUsing the same mechanism add a [Focus] and [FocusLeave] behavior to the MainItem's Behaviors connector.
                Two new Fusion Nodenodes will be added to the Fusion diagram: [Focus] and FocusLeave[FocusLeave].
                FusionThese Nodetwo new nodes can be configured with actions using their [Action]Actions] connectors.
                Connect to
                Connector
                Add Fusion Nodes
                MainItem Fusion Node
                Behaviors
                Behaviors
                Focus
                Behaviors
                FocusLeave Add Fusion[EnableRendering] Nodesactions to the FocusFusion nodes [Focus] and [FocusLeave].
                  Two new Fusion Nodenodes andwill thebe FocusLeave Fusion Node using their Actions connectors accordingadded to the table below.
                    An EnableRendering Fusion Nodediagram: willan be[EnableRendering] connectedattached to the Focus[Focus] Fusionnode Node.an Ananother EnableRendering[EnableRendering] Fusion Node will be connectedattached to the FocusLeave[FocusLeave] Fusion Node.
                    Connect to
                    Connector
                    Add Fusion Nodes
                    Focus Fusion Node
                    Actions EnableRendering FocusLeave Fusion Node
                    Actions EnableRendering node. Configure the properties "Visible" and "TargetTarge Node" for both EnableRendering Fusion Nodes[EnableRendering] nodes according to the table below.
                    • Whenever the MainItem looses the focus, the FocusImage will get invisible.
                      Behavior
                      Visible
                      Target Node
                      Focus - EnableRendering
                      FocusLeave - EnableRendering
                    1. In the Scene Tree panel select item MyList > List > ListContentGroup > MainItem. Then press the [Fusion...] button on the right side of the Scene Tree.
                      • Fusion is opened displaying the Fusion diagram with the MainItemMainItem's Fusion Node.
                      • The MainItem Fusion Nodenode has a Behaviors connector on its right side.
                    2. AddDrag Fusionthe NodesBehaviors connector to the MainItemright Fusionand Nodethen usingrelease itsthe Behaviorsmouse connectorbutton. according
                      The behaviors are organized in groups similar to the tablebehaviors below.list in the Toolbox panel. There is an input field just above the behaviors list. Click into the input field and start typing "Event Handler".
                        While typing the list of behaviors will be narrowed down. When you find the behavior "Event Handler" double-click it.
                        • A new Fusion node will be added to the Fusion diagram: [Event Handler Fusion Node.Handler].
                        • The [Event HandlerHandler] Fusion node has 2 connectors on its right: a Condition connector and an Action connector.
                          Connect to Fusion Node
                          Connector
                          Add Fusion Nodes
                          MainItem
                          Behaviors
                          Event Handler
                        AddDrag Fusionthe NodesCondition connector to the Eventright Handlerand Fusionrelease Nodethe accordingmouse button.
                          The [Select Behaviors] dialog will be opened displaying a list of suitable behaviors. Find the condition "Check Logic Condition" by starting to type into the tableinput below.field. Double-click [Check Logic Condition].
                          • A new Fusion node will be added to the Fusion diagram: [Check Logic ConditionCondition].
                          Fusion Node.
                          With the [Check Logic ConditionCondition] you can combine 2 conditions with a configurable logic operation (And, Or, Xor).
                          Connector
                          Add Fusion Nodes
                          Event Handler
                          Condition
                          Add two Fusion Nodes toIn the [Check Logic ConditionCondition] Fusionconfigure Nodethe Operation to "Or" and add two conditions using its Conditions connector according to the table[Conditions] below.
                          connector.
                            See 2configuration newdetails Fusion Nodes will be added to the Fusion diagram: Check Key Input Fusion Node and Check Click Fusion Node.
                            Connector
                            Add Fusion Nodes
                            Condition
                            Check Key Input
                            Condition
                            Check Click Configure the Condition Fusion Nodes according toin the table below.
                            • [Check ClickClick] and [Check Key InputInput] condition are logically combined through [Check Logic condition.Condition].
                            • The [Check Logic conditionCondition] will evaluate to TRUE if either the [Check ClickClick] condition or the [Check Key InputInput] condition is TRUE.
                              Condition
                              Property
                              Value
                              Operation
                              Or
                              Check Click  - -
                            AddFrom athe [Event Handler] Fusion Nodenode drag the Event Handler Fusion Node using its Action[Actions] connector according to the tableright below.
                            and release the mouse button to open the [Select Behavior] dialog. Find "Send Value as Event" and double-click it.
                            • A new Fusion Nodenode will be added to the Fusion diagram: [Send Value as Event] will be created that is connected to the [Event Handler] Fusion Node.
                              Connector
                              Add Fusion Nodes
                              Event Handler
                              Action
                              Send Value As Event
                              node.
                            Configure the [Send Value as Event] Fusion node according to the table below.
                            • Send Value As Event is configured according to the table.
                            • On every click or enter key press a boolean value will be sent to the Sub-List control.
                              To configure the TargetNode click on the magnifying glass icon to open the [Choose Item] dialog. Navigate to the desired object and press [OK].
                              Behavior
                              Property
                              Value
                              Value Bool - TRUE
                              Change Value
                              Relative
                            The visibility of the Sub-List shall be toggled by clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
                            1. In the Scene Tree panel select item MyList > List > ListContentGroup > Sub-List node. Then click the [Fusion...] button on the right side of the Scene Tree.
                              • Fusion is opened displaying the Fusion diagram with the Sub-List's Fusion Node.
                              • The Fusion node has a Behaviors connector on its right side.
                            2. Add a Fusion NodeDrag the Sub-List Fusion Node using its Behaviors connector according to the tableright below.
                              and then release the mouse button. In the opened [Select Behavior] dialog find the [Value] behavior and double-click it.
                              • A new Fusion Nodenode will be added to the Fusion diagram: Value[Value].
                            3. The [Value] Fusion Node.node
                              has a [Receivers] Connectconnectors toon Fusionits Noderight side.
                              Connector
                              Add Fusion Nodes
                              Sub-List
                              Behaviors
                              Value
                            4. Configure the Value[Value] Fusion Nodenode according to the table below.
                              • The Value behavior's type has been changed to Bool.
                                Behavior
                                Property
                                Value
                                Value
                                Variant Bool - FALSE
                            5. Add aan Fusion[Action NodeOn theValue] Value Fusion Node using its Receivers connector accordingbehavior to the table[Value] below.
                              node's [Receivers] connector. To do this, drag the [Receivers] connector to the right and release the mouse button. In the [Select Behavior] dialog find the behavior [Action On Value] and double-click it.
                              • A new Fusion Nodenode will[Action beOn addedValue] toappears in the Fusion diagram: Action On Value Fusion Node.
                                Connect to Fusion Nodediagram.
                                Connector
                                Add Fusion Nodes
                                Value
                                Receivers
                                Action On Value
                            6. Add twoa Fusion[Check NodeProcessed theValue] Action On Value Fusion Node accordingbehavior to the table[Action below.
                              On
                                Value]
                              • 2node's new[Condition] Fusionconnector. NodesAdd willa be[Set addedControl State] behavior to the Fusion diagram: Check Processed Value Fusion Node and Set Control State Fusion Node.
                                Connector
                                Add Fusion Nodes
                                [Action On Value
                                Value] Condition
                                node's Check[Actions] Processedconnector Value
                                and configure
                                Actions
                                Set Control State
                              Configure the newly added Fusion Nodesthem according to the table below.
                              • The [Action On Value Fusion NodeValue] is configured with an action that will be executed wheneverwhen a new value is received. In ouror case the Sub-List's Control State is set to enabled when the Bool value "TRUE" is received.
                                Behavior
                                Property
                                Value
                                ConditionOperator Equal
                                ConditionValue Bool, TRUE
                                Set Control State
                                State Enabled
                                ChangeTo TRUE
                              Repeat steps 4 and 5 to configure another set[Action ofOn Fusion NodesValue] to the Value[Value] Fusionbehavior's Node[Receiver] usingconnector. its Receivers connector according toConfigure the table below.
                                3 new Fusion[Action NodesOn willValue] bewith addedanother to[Check Processed Value] condition and another [Set Control State] action. Set the Fusion diagram:nodes' Action On Value_1 Fusion Node, Check Processed Value_1 Fusion Node and Set Control State_1 Fusion Node.
                                Connector
                                Add Fusion Nodes
                                Value
                                Receivers
                                Action On Value_1
                                Action On Value
                                Condition
                                Actions
                                Set Control State_1
                                Configure the newly added Fusion Nodesproperties according to the table below.
                                • The [Action On Value_1 Fusion NodeValue] is configured with an action that will be executed wheneverwhen a new value is received. In ouror case the Sub-List's Control State is set to disabled (enabled = FALSE) when the Bool value "FALSE" is received.
                                  Behavior
                                  Property
                                  Value
                                  Action On Value_1
                                  ConditionOperator Equal ConditionValue Bool, FALSE Set Control State_1
                                  State Enabled ChangeTo FALSE
                                Test MyList in the Player
                                Let's test if the configured behaviors of MyList control are functional.
                                1. Save your solution either via the menu bar "File - Save Solution" or via the keyboard <Ctrl + S>.
                                  • The solution has been saved.
                                2. In the Scene Composer's Toolbar click on "Play selected scenario...".
                                  • The resources will be generated and the Player will be started.
                                3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
                                  • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
                                4. In the Player window click the first item of the Devices List, the text of which is "Text".
                                  • In the Player window's Devices List an orange border will be displayed indicating the selected MainItem.
                                  • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
                                5. In the Player window click the selected MainItem again.
                                  • The TextButtons of the Sub-List will disappear.
                                6. In the Scene Composer's Toolbar click the "Close the Player" button.
                                  • The Player and CGI Panel window will be closed.
                                So far we have been working on our MyList control with only one single list entry. Now that this first list entry is fully configured, we can create more of them.
                                1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [Copy] Copy ] and [Paste] Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
                                  • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
                                2. In the Scene Tree panel select the MainItems individually. Use Fusion to configure the appropriate TargetNode for the [Send Value As Event] Fusion nodes (see table below).
                                  • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
                                    SendValueAsEvent of
                                    TargetNode
                                    MainItem /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List
                                    MainItem_1 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1
                                    MainItem_2 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2
                                    MainItem_3
                                    /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3
                                    MainItem_4
                                    /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
                                3. In the Scene Tree panel select MainItem's EntryName. In the Properties panel's [ 2D Render Node]Node ] section change the property "Text" according to the table below.
                                  • In the Scene Editor you can see the changed texts.
                                    TextNode2D
                                    Text
                                    Phone (Private)
                                    MainItem_1 > EntryName Phone (Work)
                                    MainItem_2 > EntryName New Device
                                    MainItem_3 > EntryName
                                    New Device
                                    MainItem_4 > EntryName
                                    New Device
                                In the Scene Tree panel select the MainItem's EntryNames individually. In the Properties panel's [ 2D Text Node ]
                                Check the Options Scene
                                The Options scene is now finished.
                                1. To check the result of configuring the first scene, open the display view. This view represents the final rendered result and can be opened via the menu bar: View - Display - Display-0.
                                2. In the Scene Composer's Toolbar make sure that the item "Generate and Play" is selected in the drop-down menu and click the [ > ] button to the left.
                                3. In the CGI Panel tick the checkbox next to "Scenes#SceneOptions"Scenes#SceneClimate" and uncheck "Scenes#SceneHome".
                                  • SceneOptionsSceneClimate will become visible in the Player.
                                4. You can now play around with the configured Options Controls in the scene and watch the results.
                                  • Grab the Connection Dial Control and switch between Cable, Bluetooth and Other.
                                  • Click into the Devices List to open the Sub-List.
                                  • Click on the Sub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects.
                                  • Click on several devices in the Devices List to make multiple Sub-Lists visible. Now you can test the scrollbar.
