Candera Reference Shaders
This document describes content and usage of Candera Reference Shaders part of CGI Studio releases. Within this document the set of Candera Reference Shaders is listed with additional information how to use and combine them in 3D applications based on Candera.
Location of Reference Shaders
Candera delivers a set of reference shader implementations, which can be found at following location:
- \cgi_studio_candera\src\Candera\Engine3D\RefShaders
The same set of reference shaders is available in SceneComposer.
Preferred way of usage is to export shaders to a binary asset file and to load it in an application based on Candera. Shaders part of exported scenes are automatically added to the asset file and loaded by Candera.
Used Include Files
Some parts of shader code used in Candera Reference Shaders have been collected into several files in order to be reused as include files.
Following files are available and can be used as include files:
| Include File | Supports | Include In | Note | Displaces |
| RefEnvironment.inc | Platform specific defines | All Shaders | Shall be included in each Shader as first statement | Environment.incv, Environment.incf |
| RefLighting.inc | Lighting specific functions, also functions for anisotropic lighting | Shaders that support lighting | Useful helper functions for vertex lighting and pixel lighting | DefaultLighting.incv |
| RefTexturing.inc | Texturing specific functions, e.g. Environment Mapping | Shaders that support certain texture effects | Useful helper functions especially for common texture effects | Texturing.incv |
| RefSkinning.inc | Skinning specific features | Shaders that support skinning | Useful helper functions for skinning | Skinning.incv |
Reference Vertex Shaders
| Vertex Shaders | Supports | Combine with Fragment Shaders | GenericShaderParamSetter Configuration | Note |
| Core/RefTrans | Transformation, Texture |
Core/RefTex, Core/RefUniColor, Core/RefUniColorTex, Core/RefTex2LightMap, Core/RefUniDiffuseMatTex, Effects/RefTexDofBlur, Effects/RefTexDofCombine |
SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Lighting has no influence. |
| Core/RefTransColor | Transformation, VertexColor, Texture |
Core/RefColor, Core/RefColorTex, Core/RefColorTexAlpha, Effects/RefColorTexAlphaOutline |
| Core/RefTransLight1 | Transformation, Vertex Lighting with one light source, Texture |
Core/RefColor, Core/RefColorTex |
SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
If Texture is used, depends on corresponding fragment shader only. |
| Core/RefTransLight2 | Transformation, Vertex Lighting with two light sources. Texture |
| Core/RefTransLight3 | Transformation, Vertex Lighting with three light sources. Texture |
| Core/RefTransWorldLight1 | Transformation, Lighting in WorldSpace with 1 Light Texture |
SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(World) |
Lighting calculations are processed in world space instead of model space (For details see function Light::SetCoordinateSpace). If Texture is used, depends on corresponding fragment shader only. |
| Effects/RefTransSphereMap | Transformation, Sphere Texture Mapping |
Core/RefTex, Core/RefUniColorTex, Core/RefUniDiffuseMatTex |
SetModelViewMatrix4Enabled(true) SetNormalModelViewMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Used to process a sphere texture for environment mapping. |
| Effects/RefTransLight1SphereMap | Transformation, Vertex Lighting with one light source, Sphere Texture Mapping |
Core/RefColorTex | SetModelViewMatrix4Enabled(true) SetNormalModelViewMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
| Effects/RefTransLight2SphereMap | Transformation, Vertex Lighting with two light sources, Sphere Texture Mapping |
| Effects/RefTransLight3SphereMap | Transformation, Vertex Lighting with three light sources, Sphere Texture Mapping |
| Core/RefTransPointSprite | Transformation of PointSprite | Core/RefPointSprite | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Use with PointSprite. As usual for point sprites, lighting has no influence. |
| Core/RefTransLight1Morph | Transformation, VertexLighting with one lighe source, Morphing Weights |
Use with MorphingMesh. If Texture is used, depends on corresponding fragment shader only. |
| Effects/RefTransLight1BumpMap | Transformation, Calculation of lighting vectors in tangent space. |
Effects/RefLight1BumpMap | SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetCameraPositionEnabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(World) |
Used to prepare lighting vectors for bump map shaders. |
| Effects/RefTransLight1ProceduralWood | Transformation, Vertex Lighting with one light source, Passing position to fragment shader for procedural calculations. |
Effects/RefProceduralWood | SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
| Effects/RefTransAnisotropicLight1Strand | Transformation, passes vertex attributes in world space to fragment shader. Calculates direction of anisotropy, eye vector and light direction. | Effects/RefAnisotropicLight1StrandTex | SetModelViewProjectionMatrix4Enabled(true) SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetCameraPositionEnabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(World) |
| Effects/RefTransAnisotropicLight1 | Transformation, Passes vertex attributes in world space to fragment shader. |
Effects/RefAnisotropicLight1SpecularTex | SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetCameraPositionEnabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(World) |
| Effects/RefTransFur | Transformation, Indexed Multi pass upscaling in direction of normals, Texture |
Effects/RefUniColorTexFur | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
| Effects/RefTransCubeMapReflection | Transformation, Texturing reflection using one CubeMap texture |
Core/RefCubeMapTex | SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetCameraPositionEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Environment mapping reflections using a CubeMap texture. Lighting is not considered. |
| Effects/RefTransCubeMapRefraction | Transformaion, Texturing refraction using one cubemap texture. |
Environment mapping refractions using a CubeMap texture. Lighting is not considered. Refraction ratio has to be passed as additional uniform float refractionRatio. |
| Effects/RefTransCubeMapReflectionRefraction | Transformation, Texturing reflection and refraction using one cubemap texture. |
Core/RefCubeMapTex2 | SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetCameraPositionEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Environment mapping refractions and reflections using a CubeMap texture. Lighting is not considered. Refraction ratio has to be passed as additional uniform float refractionRatio. |
| Core/RefTransCubeMap | Transformation, Texturing using one CubeMap texture, addressed directly by object space vertex coordinates. |
Core/RefCubeMapTex | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Direct addressing of CubeMap texture using object space vertex positions. Can be used for e.g. a SkyBox using a CubeMap texture. |
| Effects/RefTransDof | Transformation, Texturing with one texture, First render pass of depth-of-field rendering: Rendering the scene, Scaled depth value passed as varying. |
Effects/RefTexDof | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. Light, bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Additional uniform u_depthScale has to be passed to scale the depth values. |
| Effects/RefTransLight1Dof | Transformation, Texturing with one Texture Vertex Lighting with one light source, First render pass of depth-of-field rendering: Rendering the scene, Scaled depth value passed as varying. |
Effects/RefColorTexDof | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(Light::Object); |
First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Additional uniform u_depthScale has to be passed to scale the depth values. Supports per vertex lighting. |
| Effects/RefTransFragmentLightDof | Transformation, Texturing with one Texture, Normal and position for per fragment lighting, First render pass of depth-of-field rendering: Rendering the scene, Scaled depth value passed as varying. |
Effects/RefTexFragmentLightDof | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(Light::World); SetModelMatrix4Enabled(true); SetNormalModelMatrix3Enabled(true); |
First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Additional uniform u_depthScale has to be passed to scale the depth values. Supports per Fragment lighting. |
| Core/RefTransPos | Transformation, Texture, Vertex position to fragment shader |
Core/RefFlatLight1 | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightActivationEnabled(true) |
No light calculation, passing vertex position to fragment shader for FlatShading calculations. |
| Effects/RefTransLight1Gooch | Transformation, Assignment of ambient light component, Calculation of varyings needed for computation of specular component in world space. First pass of gooch-shading: Shading. | Effects/RefGoochShading | SetModelMatrix4Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetCameraPositionEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightActivationEnabled(true) SetLightsCoordinateSpace(Light::World) |
This vertex shader in conjunction with RefGoochShading.fragp realizes the first pass of an implementation of Gooch's rendering technique to simulate the appearance of technical illustrations, often occuring in e.g. manuals or schematic presentations etc. (SIGGRAPH'98 paper "A Non-Photorealistic Lighting Model For Automatic Technical Illustration"). The first pass renders the object using a transition from "cool" to "warm" colors according to the lighting model. While phong shading is normally used to simulate real lighting, this lighting model aims more on preserving details away from the light source. The second pass then draws the silhoutte of the object. For this the object is upscaled and rendered with a fixed color (e.g. black). On Candera side the first and the second pass have to be rendered with different Culling states, such that first pass renders the front of the object, and the second only the back side. |
| Effects/RefTransScale | Transformation, Upscaling in direction of normals, texture coordinates. | Core/RefTex, Core/RefUniColor, Core/RefUniColorTex, Core/RefUniDiffuseMat, Core/RefTex2LightMap |
Lighting has no influence. Used to upscale the vertices inside the vertex shader, using a float scale factor passed as uniform u_Scale. Is used for silhouette rendering in gooch-shading, but may be also used for other techniques. |
| Core/RefViewportSpace | Texture Adjusting the position of the screen aligned billboard by setting uniform u_offsetLeft and u_offsetTop. |
Effects/RefTexGaussianBlurX, Effects/RefTexGaussianBlurY, Effects/RefTexDofCombine, Effects/RefBloomThreshold, Effects/RefCombineBloom, Core/RefInterlaceMask |
SetModelViewProjectionMatrix4Enabled(false)SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) |
Used in subsequent post processing passes in conjuction with a screen-aligned billboard. The billboard should be of size 0.0 to 1.0 with 1.0 being a fullscreen billboard. The position of the billboard on the screen can be adjusted by setting the left and top offset in the range of 0.0 to 1.0. Passes the position and texture coordinate to the fragment shader without any matrix transformation. Therefore the incoming vertex buffer should already be in homogenous screen coordinates. Note: Overlapping Billboards (in screen space) would produce Z-fighting artifacts. Disabling depth test and using render order as well as using depth bias can be used to avoid them. |
| Effects/RefTransLight1Carbon | Transformation, Lighting with one light source, Texture, Line of Sight | Effects/RefCarbon | SetModelMatrix3Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(Light::Object) |
Seamless texture utilized as carbon image |
| Effects/RefTransLight1FlopCarPaint | Transformation, Lighting with one light source, Line of Sight, Mixes two color components diffuse and emissive based on camera position | Effects/RefFlopCarPaint | SetModelMatrix3Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(false) SetLightsCoordinateSpace(Light::Object) |
Mixes two color components (diffuse and emissive) based on the camera position |
| Effects/RefTransLight1MetalFlakesCarPaint | Transformation, Lighting with one light source, Line of Sight, Texture | Effects/RefMetalFlakesCarPaint | SetModelMatrix3Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(Light::Object) |
Metal flake effect with one noise texture |
| Effects/RefTransLight1FlopMetalFlakesCarPaint | Transformation, Lighting with one light source, Line of Sight, Texture, Mixes two color components diffuse and emissive based on camera position | Effects/RefFlopMetalFlakesCarPaint | SetModelMatrix3Enabled(true) SetNormalModelMatrix3Enabled(true) SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetLightsCoordinateSpace(Light::Object) |
Metal flake effect with one noise texture Mixes two color components (diffuse and emissive) based on the camera position |
| Core/RefCanvasTrans | Applying scale and offset to vertices before transformation, Transformation into world space, Texturing with one texture. |
Core/RefTex, Core/RefUniColor, Core/RefUniColorTex, Core/RefTex2LightMap, Core/RefUniDiffuseMatTex |
SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetCanvasActivationEnabled(true) |
Similar to RefTrans, but additionally applies canvas offset and size before multiplying the mvp matrix. |
| Core/RefCanvasTransLight1 | Applying scale and offset to vertices before transformation, Transformation, Texturing with one tetxture, One light source with lighting in model space. |
SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetCanvasActivationEnabled(true) SetLightsCoordinateSpace(Light::Object) |
Similar to RefTransLight1, but additionally applies canvas offset and size before multiplying the mvp matrix. |
| Core/RefCanvasTransUniDiffuseMat | Applying scale and offset to vertices before transformation, Transformation into world space, Texturing with one texture, Forwarding of material diffuse color to fragment shader. |
Core/RefCanvasUniDiffuseMat | SetModelViewProjectionMatrix4Enabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetCanvasActivationEnabled(true) |
Similar to RefTrans, but additionally applies canvas offset and size before multiplying the mvp matrix. Additionally it passes material diffuse color to fragment shader. This shader is used to achieve the same effect as a SolidColorBrush in 2D. |
| Effects/RefFxaa | Coordinates in normalized device space. | Effects/RefFxaa | SetModelViewProjectionMatrix4Enabled(false) SetLightActivationEnabled(false) SetMaterialActivationEnabled(false) |
Applies the "Fast approximate anti-aliasing" algorithm to its input, which should be a quad using normalized device coordinates. The uniform (u_Resolution) needs to be set to the width and height of the input texture measured in texels. |
| Effects/Ref | Texture | Effects/RefTexGaussianBlurX, Effects/RefTexGaussianBlurY, Effects/RefTexDofCombine, Effects/RefBloomThreshold, Effects/RefCombineBloom |
SetModelViewProjectionMatrix4Enabled(false) SetLightActivationEnabled(false) SetMaterialActivationEnabled(false) SetTextureActivationEnabled(true) |
Passes texture coordinates and vertex position to fragment shader without applying a transformation. This is useful for post processing effects when the vertex buffer is just a quad in normalized device coordinates (-1,1). |
| Effects/RefTransGradientLinear | Transformation into world space, Vertex based linear gradient computations. |
Effects/RefGradientLinear | SetModelViewProjectionMatrix4Enabled(true) | Vertex Shader for linear gradient computations. |
| Effects/RefTransGradientRadial | Transformation into world space, Passing vertex position to fragment shader. |
Effects/RefGradientRadial | SetModelViewProjectionMatrix4Enabled(true) | Vertex Shader for radial gradient computations.
| Core/RefTransLight1Skin | Skinning | Core/RefColor, Core/RefColorTex |
SetModelViewProjectionMatrix4Enabled(true) SetLightActivationEnabled(true) SetMaterialActivationEnabled(true) SetTextureActivationEnabled(true) SetSkinningMeshActivationEnabled(true) |
If Texture is used, depends on corresponding fragment shader only. And, use with SkinningMesh. |
Reference Fragment Shaders
| Fragment Shaders | Supports | Combine with Vertex Shaders | GenericShaderParamSetter Configuration | Note |
| Core/RefColor | Color from varying | Core/RefTransLight*, Core/RefTransWorldLight*, Core/RefTransLight1Morph |
See configuration of RefTransLight* or RefTransWorldLight1 | Normaly used for models that support lighting but no texture. varying color (v_Color) is typically either set by lit material or by vertex color. |
| Core/RefTex | Texture | Core/RefTrans, Effects/RefTransSphereMap, Effects/RefTransScale |
See configuration of RefTrans or RefTransSphereMap | Lighting has no influence. |
| Core/RefColorTex | Color from varying, Texture |
Core/RefTransLight*, Core/RefTransWorldLight*, Core/RefTransColor, Core/RefTransLight1Morph, Core/RefTransLight*SphereMap |
See configuration of RefTransLight* or RefTransWorldLight1 | Normaly used for models that support lighting and one texture. varying color (v_Color) is normaly either set by lit material or by vertex color. |
| Core/RefUniColor | Color from uniform | Core/RefTrans, Effects /RefTransScale |
See configuration of RefTrans | Useful if certain color is set via uniform (u_Color) directly. Lighting or vertex colors have no influence. |
| Core/RefUniColorTex | Color from uniform, Texture |
Core/RefTrans, Effects/RefTransSphereMap, Effects /RefTransScale |
See configuration of RefTrans or RefTransSphereMap | Useful if certain color is set via uniform (u_Color) directly and blended with one texture. Lighting or vertex colors have no influence. |
| Core/RefUniDiffuseMatTex | Material diffuse color, Texture |
Core/RefTrans, Effects/RefTransSphereMap |
See configuration of RefTrans or RefTransSphereMap | Final color = materials diffuse color * texel color. The uniform value of the materials diffuse color is set by Candera automatically if a Material is applied to a Node. Lighting or vertex colors have no influence. |
| Core/RefPointSprite | Pointsprite incl. Texturing | Core/RefTransPointSprite | See configuration of RefTransPointSprite | Used for point sprites only. |
| Core/RefTex2LightMap | Texture, LightMap |
See configuration of RefTrans | Lightmap Multitexturing: A Lightmap typically defines an illumination texture at unit 1 that is multiplied with texture at unit 0. |
| Effects/RefLight1BumpMap | Per pixel lighting using the normals supplied in u_Texture1 (normal map). Computed color is combined with the texture in u_Texture0. | Effects/RefTransLight1BumpMap | See configuration of RefTransLight1BumpMap | Used to display rough surfaces without adding polygon complexity to it. The shader accepts two textures. u_Texture0 defines the color map used. u_Texture1 defines a normal map, that stores normals in tangent space to be used for lighting calculations. |
| Effects/RefProceduralWood | Procedural calculation of interpolated rings, which appears like annual rings of wood if the right colors are chosen. | Effects/RefTransLight1ProceduralWood | See configuration of RefTransLight1ProceduralWood | For procedural calculations two color, the orgin of the annual rings and a multiplier that controls the densitiy of the rings can be passed. |
| Effects/RefAnisotropicLight1StrandTex | Per pixel anisotropic lighting, using a strand texture | Effects/RefTransAnisotropicLight1Strand | First texture for color, second for strand. | The strand texture must hold the diffuse and specular light intensity in the R and G channels, respectively. |
| Effects/RefAnisotropicLight1SpecularTex | Per pixel anisotropic lighting | Effects/RefTransAnisotropicLight1 | See configuration of RefTransAnisotropicLight1 | Using alternative anisotropic specular highlights, according to Ward's SIGGRAPH 92 paper "Measuring and Modeling Anisotropic Reflection". Additional calculated specular component is combined with u_Texture0. Used to display the reflection behavior of multiple surfaces. Uniforms u_AlphaX and u_AlphaY model the distribution of the specular highlight. Combined with a texture it can for example be used to simulate metallic surfaces like brushed steel. In the cited paper alphaX and alphaY for several materials can be found. |
| Effects/RefUniColorTexFur | Assignment of product of alpha mask, texture and fixed color. | Effects/RefTransFur | See configuration of RefTransFur | Simulates the appearance of fur if applied with MulitPassRendering. Is also intended to demonstrate multi pass rendering. |
| Core/RefCubeMapTex | Addressing one cube map texture using a single varying vec3. | Effects/RefTransCubeMapReflection, Effects/RefTransCubeMapRefraction, Core/RefTransCubeMap |
See configuration of RefTransCubeMapReflection, RefTransCubeMapRefraction, RefTransCubeMap |
Cube Map addressing, material colors or lighting are not considered. |
| Core/RefCubeMapTex2 | Mixing two different addressed fragments of a CubeMap using a varying ratio. Addressing is done using two varying vec3. | Effects/RefTransCubeMapReflectionRefraction | See configuration of RefTransCubeMapReflectionRefraction | Cube Map addressing, material colors or lighting are not considered. |
| Core/RefUniDiffuseMat | Material diffuse color | Core/RefTrans | See configuration of RefTrans | Final color = materials diffuse color The uniform value of the materials diffuse color is set by Candera automatically if a Material is applied to a Node. Lighting or vertex colors have no influence. |
| Effects/RefTexDof | Assignment of Texture, First render pass of depth-of-field rendering: Rendering the scene, Depth encoded into alpha channel. | Effects/RefTransDof | See configuration of RefTransDof | First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. Light, bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. |
| Effects/RefColorTexDof | Color from varying, Assignment of Texture, First render pass of depth-of-field rendering: Rendering the scene, Depth encoded into alpha channel. |
Effects/RefTransLight1Dof | See configuration of RefTransLight1Dof | First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Support per vertex lighting. |
| Effects/RefTexFragmentLightDof | Per fragment lighting with one light source, Assignment of Texture, First render pass of depth-of-field rendering: Rendering the scene, Depth encoded into alpha channel. |
Effects/RefTransFragmentLightDof | See configuration of RefTransFragmentLightDof | First pass of depth-of-field rendering has to be applied to every node that is rendered. The resulting image then contains the scene's depth values as alpha value, which is used for further processing. If other effects (e.g. bump mapping etc.) have to be applied on the nodes, then also the corresponding shaders have to be adapted to meet the depth-of-field requirements. Supports per fragment lighting. |
| Effects/RefTexDofBlur | Assignment of texture, second render pass of depth-of-field: blurring the texture, simulating an optical circle of confusion, caused by lens refraction out of focus. | Core/RefTrans | See configuration of RefTrans | Second pass of depth-of-field rendering: blurring the incoming image. Result is a blurred image of the passed texture. u_CocScale controls the size of the circle of confusion, and therefore the blur strength. |
| Effects/RefTexDofCombine | Third pass of depth of field: Assignment and blending of two textures, representing the sharp and blurred image. Blend weights result from focus and focus range of the simulated camera lens. | Core/RefViewportSpace, Effects/Ref | See configuration of RefTrans | Third pass of depth rendering: Combines the sharp and the blurred image according to the set focus of the simulated camera lens. u_Focus controls the distance of the focus plane (where a sharp image would be formed). u_Range controls the size of the area around the focus plane, where a sharp image would be drawn. |
| Effects/RefTexGaussianBlurX | Assignment of texture, Subsequent pass of post-processing effect: blurring the texture with a Gaussian blur, Gaussian blur step width from unifrom |
Core/RefViewportSpace, Effects/Ref | See configuration of RefViewportSpace plus SetUniform("u_blurFactor",Shader::Float, &blurFactor) |
Subsequent pass of post-processing effect: blurring the incoming image horizontally. Result is a blurred image of the passed texture. u_blurFactor controls the step width of the Gaussian function. u_blurFactor should always be 1.0/TextureWidth so that every step will correlate with one pixel. |
| Effects/RefTexGaussianBlurY | Assignment of texture, Subsequent pass of post-processing effect: blurring the texture with a Gaussian blur, Gaussian blur step width from unifrom |
Subsequent pass of post-processing effect: blurring the incoming image vertically. Result is a blurred image of the passed texture. u_blurFactor controls the step width of the Gaussian function. u_blurFactor should always be 1.0/TextureHeight so that every step will correlate with one pixel. |
| Core/RefFlatLight1 | Per fragment lighting with one light source for Flat Shading. | Core/RefTransPos | See configuration of RefTransPos | In order to use derivative functions dFdx and dFdy the extension GL_OES_standard_derivatives has to be enabled and supported by driver. |
| Effects/RefGoochShading | Per Fragment calculation of specular component, Mixing cool and warm color using the dot product of light direction and vertex normal as weight, Output: Mixed color + specular and ambient lightcomponent. | Effects/RefTransLight1Gooch | See configuration of RefTransLight1Gooch | This fragment shader in conjunction with RefTransLight1Gooch.vertp realizes the first pass of an implementation of Gooch's rendering technique to simulate the appearance of technical illustrations, often occuring in e.g. manuals or schematic presentations etc. (SIGGRAPH'98 paper "A Non-Photorealistic Lighting Model For Automatic Technical Illustration"). For details please refer to the description of the vertex shader, and to the cited paper. The following unifiorms are needed: u_CoolColor and u_CoolColor are 4-component vectors that describe the colors for the cool to warm transition. u_CoolDiffuseWeight and u_WarmDiffuseWeight are float values that describe, how the original diffuse color is combined with the warm and cool colors. |
| Effects/RefBloomThreshold | Assignment of texture, Subsequent pass of bloom effect: extracting only the bright parts of the image that should be blurred, brightness threshold from unifrom |
Core/RefViewportSpace, Effects/Ref | See configuration of Core/RefViewportSpace | Subsequent pass of post-processing bloom effect: extracting only the bright parts of the incoming texture. Those bright parts are blurred in the next step to generate a bloom effect. |
| Effects/RefCombineBloom | Subsequent pass of bloom effect: Assignment and djustable combination of the original and the bloomed texture | Core/RefViewportSpace, Effects/Ref | See configuration of RefViewportSpace | Subsequent pass of post-processing bloom effect: The incoming texture of the original scene and the incoming texture of the bright, bloomed parts are combined. The blending of the two textures is adjustable by uniforms representing the intensity and saturation of the images. |
| Core/RefInterlaceMask | Uses a texture's color to create a mask through discarding pixels with low transparency. No value is written to the discarded fragments, so also no depth or stencil values. | Core/RefViewportSpace | See configuration of RefViewportSpace | Is especially useful for e.g. Creating stencil masks for stereoscopic 3D. |
| Effects/RefCarbon | Wraps a seamless texture multible times around the object to achieve carbon look. | Effects/RefTransLight1Carbon | See configuration RefTransLight1Carbon | Creates a car paint with typical carbon look. |
| Effects/RefFlopCarPaint | Mixes the two color components together based on the camera position and a user defined bias | Effects/RefTransLight1FlopCarPaint | See configuration RefTransLight1FlopCarPaint | Creates a car paint with shiny, anisotropic two color look. |
| Effects/RefMetalFlakesCarPaint | Adding a noise to the spectral part of the light. Noise can be wrapped around the object multible times. Create the illusion of metal flakes in the car paint. | Effects/RefTransLight1MetalFlakesCarPaint | See configuration RefTransLight1MetalFlakesCarPaint | Creates a car paint with shiny, sparkling look produced by metal flakes within specular highlight |
| Effects/RefFlopMetalFlakesCarPaint | Mixes the two color components together based on the camera position and a user defined bias. Adding a noise to the spectral part of the light. Noise can be wrapped around the object multible times. Create the illusion of metal flakes in the car paint. |
Effects/RefTransLight1FlopMetalFlakesCarPaint | See configuration RefTransLight1FlopMetalFlakesCarPaint | Creates a car paint with shiny, sparkling look produced by metal flakes within specular highlight combined with anisotropic two color look. |
| Core/RefCanvasUniDiffuseMat | Assignment of material's diffuse color to fragment color | Core/RefCanvasTransUniDiffuseMat | See configuration RefCanvasTransUniDiffuseMat |
| Effects/RefFxaa | Coordinates in normalized device space. | Effects/RefFxaa | See configuration of Effects/RefFxaa | Applies the "Fast approximate anti-aliasing" algorithm to its input, which should be a quad using normalized device coordinates. The uniform (u_Resolution) needs to be set to the width and height of the input texture measured in texels. |
| Effects/RefGradientLinear | Mixing fragment color according to gradient computations. | Effects/RefTransGradientLinear | See configuration RefTransGradientLinear |
Fragment Shader for linear gradient computations. |
| Effects/RefGradientRadial | Assignment of radial gradient color to fragment color. | Effects/RefTransGradientRadial | See configuration RefTransGradientRadial |
Fragment Shader for radial gradient computations. |
| Core/RefColorTexAlpha, | Assignment of product of varying color and texture color to fragment color. | Core/RefTransColor | See configuration RefTransColor | This fragment shader shall be used for text or alpha mask rendering. |
| Effects/RefColorTexAlphaOutline | This fragment shader renders an outline of color "u_outlineColor" and width specified by "u_outlineWidth" around the contents in the texture "u_Texture". The input texture is also multiplied by the vertex color. If the "u_outlineWidth" value is bigger than 10, the contents of the texture need be bigger than 10 too, otherwise artefacts will start to appear with increasing outline width. There is no instancing version of this shader, because it will usually be applied to text rendering which is batched by Canvas rather than the Renderer. |
Core/RefTransColor | See configuration RefTransColor Additionally: SetTexelSizeActivationEnabled(true) Custom uniforms: uniform vec4 u_outlineColor; // Color of outline. uniform float u_outlineWidth; //Width of outline. |
This fragment shader shall be used if a text or an alpha mask shall receive an outline. |
