Candera CGI Studio Editions
There two major editions ofCandera CGI Studio:Studio is currently available in three different editions:
  1. Enterprise Edition - provides the versionmaximum whichlevel providesof maximumfeatures and flexibility for embedded projects  (the only version up to 3.14)
  2. Professional Edition - thefocuses version which provideson ease of use for creating embedded projects (available
fromCommunity versionEdition 3.15)- a free edition for creating projects for non-commercial applications
There are several key differences between the individual editions. The mainprimary differencedistinction between the Enterprise Edition and the Professional/Community Editions is howthe range of available features, with the Enterprise Edition offering the complete feature set (see full list of feature differences here).
In addition, the Professional and Community Editions use a different approach to data binding isimplementation. down inWhile the two versions. The Enterprise Edition provides maximum flexibility, however requires some engineering knowledge, as the CGI Studio Player needshas to be buildbuilt specifically for theeach target platform. This overheadenables allowfull to fully customizecustomization and optimizeoptimization of the HMI application for the respective target.
TheIn contrast, the Professional Edition aims to reduce the engineering knowledge to a minimum, so compiling of the player is required and theCommunity HMIEditions development is focused on designing the HMI. Theimplement data binding is, in contrast to the Enterprise Edition, possible in a Python-Scriptpredefined way using Python scripts instead of C++. This approach simplifies and isaccelerates already predefined, which further reduces the engineering efforts. TheHMI creation ofwhile HMI is so faster and requiresrequiring less engineering knowledge,expertise, howeverthough reducesit itsoffers reduced flexibility offor targettarget-specific optimization capabilities a little bit.optimization. To overcomeaddress thisthese limitations, Candera is preparing optimized Player builds for the supported platforms of the Professional Edition.
When
Thecomparing the Professional Edition replacedwith the definition,Community compilingEdition, there are no functional differences. The main distinction is that the Community Edition is available free of charge but may not be used for commercial purposes. In addition, it includes built-in hardware limitations that restrict target deployments through the implementation of a Candera watermark and dataruntime bindinglimitations implementation in C++ with a fixed set of data bindings and a Python based script (for themore datainformation, bindingclick implementation.
here
Professional Edition Advantages and Disadvantages
The simplificationcreated for the developmentsolutions and the skipping of the compiling of the data bindings, comes with some advantages and disadvantages.
    Advantages
      Simplified development process Less specific embedded knowledge is required for Professional Edition projects Faster development Aims for less complex HMI projects Simple Python scripting interface instead of C++ implementation No need for compiling the player Disadvantages
        fixed set of data binding items, but will be sufficient for most projects (is planned in future version to be flexible) Custom player buildsassets are not possiblecompatible oramong oneach demandother. via Candera support
        Enterprise Edition Advantages
        The Enterprise Edition allows highly optimized adoptions of the CGI Studio Player, as it can be built during the development process. Also, the data binding, as it can be individually optimized, allows further optimizations. This engineering overhead pays off, especially in projects with high volumes to optimize production costs and for experiences engineering departments. Moreover,E.g. if you arecreate usinga lower-endsolution/asset platform,with our Community Edition, you will not be able to use them with the additional flexibility allows further performanceProfessional and memoryEnterprise optimizations.Editions (and vice versa). However, if you want to upgrade to a commercial Edition we can convert your solutions/assets for you.
