Control Behaviors
Construction Kit Control Behaviors
Map Control Behaviors
Map
Common Properties
TouchableId
String
Touchable Id of the behavior.
Bearing Float Clockwise angle relative to North that the users currently faces.
Longitude Candera::Variant Longitude of current users location.
Latitude Candera::Variant Latitude of current users location.
SimulateDriving bool Simulate driving along computed route when in navigation mode.
NaviMessageNode AbstractNodePointer Node to which navigation instructions will be sent.
LocationMesh AbstractNodePointer Node containing mesh(es) used to render the location indicator.
RouteOverlayColor Candera::Color Color used by the route overlay.
AvoidTolls bool Avoid tolls during route computation.
AvoidMotorways bool Avoid motorways during route computation.
AvoidFerry bool Avoid ferrys during route computation.
Map Bridge
Common Properties
TouchableId
String
TargetNode AbstractNodePointer Node containing the target MapBehavior to which events will be forwarded.
Scroll Control Behaviors
List Behavior
Common Properties
TouchableId
String
ScrollDirection ScrollDirection::Enum
The direction in which the ListBehavior scrolls.
Position FeatStd::Float The pixel position of the visible content within the list content.
AnimationDuration FeatStd::UInt32 Duration of the scrolling animation.
DecelerationFactor FeatStd::Float Loss of flick animation speed over time.
MaxSpeedPerFlick FeatStd::Float Maximum amount of speed each flick motion adds to the flick animation.
MinSpeedPerFlick FeatStd::Float Minimum speed required to count a touch gesture as a flick and start or continue the flick animation.
MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start a scrolling animation.
MaxTouchSampleAge FeatStd::UInt32 Maximum age in milliseconds of touch movement speed counted towards generating flick animation speed.
Items ListPropertyType<DataContextItem::SharedPointer>
ListFragmentTriggerOffset FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This trigger offset value defines an area at the begin and end of the list fragment. Whenever the list shows a part of these areas a new fragment is requested from the model.
ListFragmentSize FeatStd::SizeType A dynamic list is requested in fragments to reduce memory consumption and overall performance overhead. This buffer size defines how large this fragment should be. By default it is set to 0 which results in an automatic calculation. The automatic calculation assumes the number of item nodes is configured to match the maximum number of visible nodes for one page. By multiplying this number by three and adding the trigger offset one time for the begin and one additional time for the end to calculate for the automatic buffer size the list has a spare page on each side before a new fragment has to be requested
HandleKeyboardEvents
bool
Makes the behavior handle KeyboardFocusNavigation events internally.
WrapAround
bool
Set this flag to true for static list to wrap around the list items on the top and bottom of the list
Scrollbar
- 1 child: marker
Common Properties
TouchableId
String
TouchListenerNode Candera::AbstractNodePointer This node defines the area on which the ScrollbarBehavior will listen for the touch events.
ScrollDirection FeatStd::Optional< ScrollDirection::Enum > The direction in which the ListBehavior scrolls. By default it is configured as a vertical scrollbar.
ScrollbarVisibility ScrollbarVisibility::Enum
Configure the visibility of the scrollbar. By default it is set to Automatic which will determine the visibility based on the actual content.
Possible values: Automatic, Collapsed, Visible
HandleMinimumSize FeatStd::UInt32 The minimum height (for vertical scrollbar) or minimum width (for horizontal scrollbar) of the handle in pixels.
MinMovementToScrolling FeatStd::UInt32 Minimum distance a touch gesture needs to move to start scrolling.
ScrollableNode
Candera::AbstractNodePointer Node of the scrollable behavior.
Scroll View
TouchableId
String
Example Usage
Common Properties
Snap List Item Configuration
Allows the user to define the snap position of a list or list item by setting its item alignment (for example, Center) and offset. This is then applied when navigating or scrolling to align the list item. Can be used with the List Control.
Common Properties
ItemAlignment SnapAlignmentOrientation::Enum
The location of the alignment base point within the list item.
Possible values: Begin, Center, End
ItemAlignmentOffset FeatStd::Float
The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin.
ItemAlignmentOffsetInPercent bool
The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset.
Snap List Item Extension
Information on how to use this behavior can be found in the chapter of the List Control.
Common Properties
ListBehavior ListBehavior*
The ListBehavior that shall be extended.
ListAlignment SnapAlignmentOrientation::Enum
ListAlignmentOffset FeatStd::Float The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin.
ListAlignmentOffsetInPercent bool The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset.
ItemAlignment SnapAlignmentOrientation::Enum The location of the alignment base point within the list item.
ItemAlignmentOffset FeatStd::Float The offset of the alignment point from the configured alignment base point. For End alignment a positive offset will move the alignment point from the list item end towards the list item begin.
ItemAlignmentOffsetInPercent bool The offset is either in percent (when set to true) or in pixel (when set to false). In case of percent the item size will be taken to calculate the pixel offset.
SubList Behavior
Common Properties
TouchableId
String
The direction in which the SubListBehavior scrolls.
Items ListPropertyType< ::Courier::DataContextItem::SharedPointer > The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required.
bool
ParentListNode
Candera::AbstractNodePointer The node with a ListBehavior that acts as a parent to this SubListBehavior.
Circular Slider Behavior
Common Properties
Receivers
Value FeatStd::Variant Value of the slider
MinimumValue FeatStd::Variant Minimum value of the slider
MaximumValue FeatStd::Variant Maximum value of the slider
StepSize FeatStd::Variant Step size for Value
MinimumAngle FeatStd::Float Angle of the slider, corresponding to minimum value.
MaximumAngle FeatStd::Float Angle of the slider, corresponding to maximum value.
ThumbNode Candera::AbstractNodePointer Thumb node which will be rotated.
ImageNode Candera::AbstractNodePointer Image node which will be masked.
Drawer Behavior
Common Properties
Receivers
Open bool Shows the Drawer in its opened appearance.
AppearDirection AppearDirection::Enum
The direction from which the Drawer will open.
Possible values: Top, Left, Right, Bottom
DragEnabled bool Set to true to allow the Drawer to be controlled by Touch Inputs.
Linear Slider Behavior
Common Properties
Receivers
KnobNode
Candera::AbstractNodePointer Knob node which will be shifted.
SliderBarNode Candera::AbstractNodePointer Image node which will be scaled according to value.
BackgroundNode Candera::AbstractNodePointer Image node which will provide background image and also control slider total size.
UseBitmapClipping bool If true, the slider bar image will be resized using bitmap clipping instead of the layouter.
Internal Control Behaviors
Caret
Common Properties
Receivers
CaretNode Candera::AbstractNodePointer Node which will be set as caret..
IntervalSwitchBehavior Candera::Behavior*
The Caret Behavior will change the state of the given IntervalSwitch Behavior.
Handle Control State
Manages how a control responds to user actions like clicks, touches, or hover. Sends state events when the control is pressed, selected, or highlighted. State conditions behaviors react to these events to update the control accordingly.
Example Usage
Common Properties
TouchableId
String
Highlighted bool If true, the controls state Highlighted is set to true.
Selected
bool
If true, the controls state Selected is set to true.
Identifier Candera::AbstractNodePointer Identifier which is used when emitting an Event (e.g. Click Event).
DataContext
Common Properties
Edit Text
Common Properties
Receivers
InputText FeatStd::String Text which will be set as default text.
TextNode Candera::AbstractNodePointer Text Node which will be edited.
Placeholder Candera::AbstractNodePointer Text which will be shown as placeholder.
SetValueOnEnter bool If true, the value will be set when the Enter key is pressed
SetValueOnEachChange bool If true, the value will be set on each input.
MaxTextLength FeatStd::UInt16 Maximum count of characters.
JustDigits bool If true, the Inputfield will receive just digits.
Selection Group
Common Properties
DefaultSelectedObject Candera::AbstractNodePointer Selection Object (e.g. RadioButton) which shall be selected by default.
Public Property Control Behaviors
Provide Alignment
Common Properties
HorizontalAlignment Candera::HorizontalAlignment
Provides property to set the Horizontal Alignment (especially for Controls).
Possible values: HLeft, HCenter, HRight, Hstretch, HstrechRight, HstrechCenter
VerticalAlignment Candera::VerticalAlignment
Provides property to set the Vertical Alignment (especially for Controls).
Possible values: VTop, VCenter, VBottom, Vstretch, VstrechCenter, VstrechBottom
Copy Size
Common Properties
Provide Color
Sets the color of a 2D node with a Color effect (e.g. BitmapBrushColorBlend, SolidColorBrush, MVGRender) or the diffuse color of a material in 3D.
Common Properties
Possible values: Self, Other
The color to set.
Advanced Properties
PropertyProvider Behavior*
This property is only available if PropertyReference is set to "Other".
Provide Margin
Common Properties
Margin Candera::Margin Provides property to set the Margin (especially for Controls).
Property Provider
Common Properties
PropertyDataType CgiStudioControl::PropertyDataTypes::Enum
Choose the type which should be offered by this behavior.
Possible values: Color, Text, Style, Image, Appearance, Value, BlendType, Layout, VertexBuffer
Advanced Properties
The color which can be used from other Behaviors.
This property is only available if PropertyDataType is set to "Color".
The Text that will be set to the Text Node.
This property is only available if PropertyDataType is set to "Text".
Style
SharedPointer<Candera::TextRendering::SharedStyle>
This property is only available if PropertyDataType is set to "Style".
Image SharedPointer<Candera::Image2D>
This property is only available for 2D scenes if PropertyDataType is set to "Image".
The texture to set on the effect.
This property is only available for 3D scenes if PropertyDataType is set to "Image".
Appearance SharedPointer<Candera::Appearance>
The appearance to set on the node.
This property is only available for 3D scenes if PropertyDataType is set to "Appearance".
The value that will be set to the Send Value as Event action.
This property is only available if PropertyDataType is set to "Value".
BlendType
BlendType::Enum
The blend type that will be set.
Possible values: Default, DefaultPremultiplied, DefaultTransparentLayer, Add, Multiply, Screen, Darken, Lighten, SourceAtop, SourceIn, SourceOut, SourceOver, DestinationIn, DestinationOut, DestinationOver, Off.
This property is only available if PropertyDataType is set to "BlendType".
Layout CgiStudioControl::LayoutType::Enum
The layouter type for node. See Set Layout for more information.
Possible values: Horizontal, Vertical
This property is only available for 2D scenes if PropertyDataType is set to "Layout".
StackArrangement
StackLayouter::Arrangement
Selects arrangement for stack layouter.
This property is only available for 2D scenes if PropertyDataType is set to "Layout" and the property Layout is set to "Stack".
VertexBuffer SharedPointer<Candera::VertexBuffer>
You can set the VertexBuffer held by the mesh created when importing FBX. This property is only available for 3D scenes if PropertyDataType is set to "VertexBuffer".
Render Node
Common Properties
EnableRendering bool If true, rendering is enabled.
PostponeChange bool If set to true the render change will be handled during the next Update cyle, if false it will be handled immediately.
Provide Appearance
Common Properties
Appearance
This property is only available if "PropertyReference" is set to "Self".
This property is only available if "PropertyReference" is set to "Other".
Provide Image
Example Usage
Common Properties
Advanced Properties
This property is only available for 2D scenes if "PropertyReference" is set to "Self".
This property is only available for 3D scenes if "PropertyReference" is set to "Self".
Set Layout
Class Reference
Limitations
  • Only certain built-in layout mechanisms are supported
  • Scene Composer does not support displaying layout-related properties when layouter is assigned using SetLayout behavior.
Common Properties
Selects layout type for node.
Possible values: None, Overlay, Stack, Baseline.
Advanced Properties
StackArrangement Candera::StackLayouter::Arrangement
This property is only available if Layout is set to "Stack".
Property Behavior which contains the layout which has to be set on the effect. See Property Provider for more information.
This property is only available if "PropertyReference"" is set to "Other".
Provide Text
Example Usage
Common Properties
Text FeatStd::String The Text that will be set to the Text Node.
Style SharedPointer<Candera::TextRendering::SharedStyle>
Alignment Candera::TextNode2DLayouter::TextAlignment
Possible values: Auto, Left, Center, Right.
Multiline bool
If multi line is disabled then the new line control characters will be ignored and text will always be rendered in one line.
LineSpacing Candera::TextRendering::PixelSize
Defines the distance between the baselines of successive lines of text.
WordWrap bool
If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines.
Trimming Candera::TextNode2DLayouter::Trimming
Possible values: None, Ellipsis, CustomText.
Advanced Properties
TrimmingText FeatStd::String
This property is only available if "Trimming" is set to "CustomText".
Align Pivot
Example Usage
Common Properties
Android Event Bridge
Common Properties
TargetNode Candera::AbstractNodePointer The target node to which the events are sent. If the property is not set, the event will be routed to the node of the behavior.
Arc Align
Example Usage
Common Properties
Radius Float Radius of the digital needle indicators.
Orientation Offset Float Offset in the orientation of the needle indicators.
Angle Min Max Vector2 Min/Max angle values (e.g. indicators displayed from -25 to 210 degrees).
Blend Mode
Class Reference
  • Default
  • DefaultPremultiplied
  • DefaultTransparentLayer
  • Add
  • Multiply
  • Screen
  • Darken (3D only)
  • Lighten (3D only)
  • Source Atop
  • Source In
  • SourceOut
  • Source Over
  • Destination Atop
  • Destination In
  • Destination Out
  • Destination Over
  • Off
  • Lighten
  • Darken
Common Properties
PropertyProvider PropertyProviderBehavior*
Mode BlendType::Enum
Possible values: Default, DefaultPremultiplied, DefaultTransparentLayer, Add, Multiply, Screen, Darken (3D only), Lighten (3D only), Source Atop, Source In, SourceOut, Source Over, Destination Atop, Destination In, Destination Out, Destination Over, Off
Breadcrumb Behavior
Common Properties
StateMachineNode Candera::AbstractNodePointer The node of the State Machine
EllipsisText FeatStd::String When more elements are added than the breadcrumb can show, one element will be replaced with the text from this field (collapse effect).
PathDelimiter FeatStd::String Tag that separates the elements that a path contains.
Disable Control
A set of actions can be configured, which will be executed when the node gets disabled.
Enable Control
A set of actions can be configured, which will be executed when the node gets enabled.
Event Bridge
Common Properties
TargetNode Candera::AbstractNodePointer The target node to which the events are routed from the source node. If the property is not set, the event will be routed to the node of the behavior.
Focus
A set of actions can be configured, which will be executed when the node gets focused.
Focus Leave
A set of actions can be configured, which will be executed when the node's focus is left.
Hover
See also: HoverLeave
A set of actions can be configured, which will be executed when the node gets hovered.
Example Usage
HoverLeave
A set of actions can be configured, which will be executed when the node's hovering is left.
Example Usage
IntervalSwitch
Common Properties
State IntervalSwitchState::Enum
If set to On, sends only On value to Trigger Behaviors in the same node. If set to Off, sends only Off value to Trigger Behaviors in the same node. If set to Blinking, alternates between sending On or Off values. Use On Time Ms and Off Time Ms to specify the speed of blinking.
OnTimeMs FeatStd::UInt32 If State is set to Blinking, IntervalSwitchBehavior will be sending On value for On Time Ms milliseconds before switching to sending Off value.
OffTimeMs FeatStd::UInt32 If State is set to Blinking, IntervalSwitchBehavior will be sending Off value for Off Time Ms milliseconds before switching to sending On value.
AcceptValueEvent
bool
Set this flag to true to make the behavior changeable by events/actions.
Keyboard
Common Properties
ConfigurationScript FeatStd::String String that specifies symbols and layout of the Control
KeyContent
AbstractNodePointer Node containing Keyboard Keys.
StateMachineNode AbstractNodePointer State machine that reacts on events sent by a special key to change keyboard layout
KeyBackContentType CgiStudioControl::KeyContent::Enum
Switch for Content of KEY_BACK special key.
Possible values: Text, Icon
KeyBackText FeatStd::String
KEY_BACK is labeled with the text.
This property is only visible if KeyBackContentType is set to "Text".
KeyBackImage SharedPointer<Candera::Image2D>
KEY_BACK is labeled with the image.
This property is only visible if KeyBackContentType is set to "Icon".
KeyEnterContentType CgiStudioControl::KeyContent::Enum
Switch for Content of KEY_ENTER special key.
KeyEnterText FeatStd::String
KEY_ENTER is labeled with the text.
KeyEnterImage SharedPointer<Candera::Image2D>
KEY_ENTER is labeled with the image.
KeySpaceContentType CgiStudioControl::KeyContent::Enum
Switch for Content of KEY_SPACE special key.
KeySpaceText FeatStd::String
KEY_SPACE is labeled with the text.
KeySpaceImage SharedPointer<Candera::Image2D>
KEY_SPACE is labeled with the image.
KeySwitchContentType CgiStudioControl::KeyContent::Enum Switch for Content of SWITCH special key
KeySwitchText FeatStd::String
SWITCH is labeled with the text.
This property is only visible if KeySwitchContentType is set to "Text".
KeySwitchImage SharedPointer<Candera::Image2D>
SWITCH is labeled with the image.
This property is only visible if KeySwitchContentType is set to "Icon".
KeyShiftContentType CgiStudioControl::KeyContent::Enum Switch for Content of SHIFT special key
KeyShiftText FeatStd::String
SHIFT is labeled with the text.
This property is only visible if KeyShiftContentType is set to "Text".
KeyShiftImage SharedPointer<Candera::Image2D>
SHIFT is labeled with the image.
This property is only visible if KeyShiftContentType is set to "Icon".
KeyShiftOnceContentType CgiStudioControl::KeyContent::Enum Switch for Content of SHIFT ONCE special key
KeyShiftOnceText FeatStd::String
SHIFT ONCE is labeled with the text:
This property is only visible if KeyShiftOnceContentType is set to "Text".
KeyShiftOnceImage SharedPointer<Candera::Image2D>
SHIFT ONCE is labeled with the image.
This property is only visible if KeyShiftOnceContentType is set to "icon".
KeyShiftLockContentType CgiStudioControl::KeyContent::Enum Switch for Content of SHIFT LOCK special key
KeyShiftLockText FeatStd::String
SHIFT LOCK is labeled with the text.
This property is only visible if KeyShiftLockContentType is set to "Text".
KeyShiftLockImage SharedPointer<Candera::Image2D>
LEFT is labeled with the image.
This property is only visible if KeyShiftLockContentType is set to "Icon".
KeyCloseContentType CgiStudioControl::KeyContent::Enum Switch for Content of SHIFT LOCK special key
KeyCloseText FeatStd::String
CLOSE is labeled with the text.
This property is only visible if KeyCloseContentType is set to "Text".
KeyCloseImage SharedPointer<Candera::Image2D>
CLOSE is labeled with the image.
This property is only visible if KeyCloseContentType is set to "Icon".
KeyLeftContentType CgiStudioControl::KeyContent::Enum Switch for Content of LEFT special key
KeyLeftText
FeatStd::String
LEFT is labeled with the text.
This property is only visible if KeyLeftContentType is set to "Text".
KeyLeftImage
This property is only visible if KeyLeftContentType is set to "Icon".
KeyRightContentType
CgiStudioControl::KeyContent::Enum Switch for Content of RIGHT special key
KeyRightText
FeatStd::String
RIGHT is labeled with the text.
This property is only visible if KeyRightContentType is set to "Text".
KeyRightImage
RIGHT is labeled with the image.
This property is only visible if KeyRightContentType is set to "Icon".
NavigateUpKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key above the current focused
NavigateDownKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key below the current focused
NavigateNextKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key on the right from the current focused
NavigatePreviousKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that moves focus to a key on the left from the current focused
NavigateStartOnDown bool Enables starting navigation with the same key as NavigateDownKeyCode
NavigateEndOnUp bool Enables finishing navigation with the same key as NavigateUpKeyCode
NavigateStartKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that starts navigation within the Control
NavigateEndKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that finishes navigation within the Control
NavigateCloseKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that hides the Control
NavigateInvokeKeyCode Candera::KeyboardKeyCode::Enum Key from a physical keyboard that emulates clicking the current focused Key from the Control
Configuration String
Key String Meaning
enum from Candera::KeyboardKeyCode::Enum:
KEY_BACK, KEY_SPACE, KEY_ENTER
For most keys KEY_* has the same meaning as * (e.g. „KEY_A“ is the same as simply „A“); it enables keys with non-printable characters like backspace etc.
CLOSE() Represents a key that sends Close KeyboardAction to a state machine; it is designed to enable hiding (setting EnableRendering to false) an instance of the Control
SWITCH(layoutName) Represents a key that sends ¬¬to a state machine an event with its argument; it is designed to enable permanent changing layout e.g. to uppercase letters, symbols or digits
SHIFT(layoutName) Mostly the same as SWITCH() but is separated to enable changing layout only for a single input, it means after entering a single letter (e.g. first capital letter in a sentence) the layout will be reset to the previous one
NULL() Represents a key that will NOT be rendered; it is designed for a layouting/padding purpose
Menu Item
Class Reference
Common Properties
DeleteButtonNode Candera::AbstractNodePointer Delete button node needed to control visibility (render on/off).
Focusable bool If true then focus node will be visible.
FocusNode Candera::AbstractNodePointer Focus node needed to control visibility (render on/off) and change focus image.
Enabled bool If true then item is visible.
FocusImageOnSelection SharedPointer<Candera::Image2D> The image to set on the effect.
FocusImageOnDragging SharedPointer<Candera::Image2D> The image to set on the effect.
MenuScreen
Class Reference
Common Properties
ActiveScreenIndex
UInt32
Currently active index.
NumberOfScreens
UInt32 Number of active screens.
LimitOfScreens
UInt32 Limit of active screens.
Rows
UInt32 Number of rows.
Columns
UInt32 Number of columns.
ScreenChangeTime
Float
Time of dragging a Menu Item outside boundaries of the Menu Screen to change its screen to a neighbour.
SwapItemAnimationEasingFunction
EasingFunctions::Enum
Swap item animation easing function.
Possible values: CircularInOut, Linear, SineIn, SineOut, SineInOut
SwapItemAnimationLength
Float
Swap item animation length
ChangeScreenAnimationEasingFunction
Change screen animation easing function.
ChangeScreenAnimationLength
Float
Change screen animation length.
KeyCodeToMoveSelectionLeft
Key code to move selection left.
KeyCodeToMoveSelectionRight KeyboardKeyCode::Enum
Key code to move selection right.
KeyCodeToMoveSelectionUp KeyboardKeyCode::Enum
Key code to move selection up.
KeyCodeToMoveSelectionDown KeyboardKeyCode::Enum
Key code to move selection down.
PageIndicatorNode Candera::AbstractNodePointer Page indicator node.
Items ListPropertyType<::Courier::DataContextItem::SharedPointer> The items property is used for binding of dynamic items. It can only be set via databinding. Only one visible list control should be bound to a fragment list in the model. Otherwise the list fragments in the model are not able to provide data for both list controls. Use a separate list model that is filled with the same data if such a use case is required.
ContentNode Candera::AbstractNodePointer Content node.
Navigation Instruction View
Common Properties
SignDisplayNode Candera::AbstractNodePointer Node used to display the graphical sign.
PrimaryTextNode Candera::AbstractNodePointer Node used to display the primary message.
SecondaryTextNode Candera::AbstractNodePointer Node used to display the secondary message.
ManeuverTypeTextNode Candera::AbstractNodePointer Node used to display the maneuver type (as text).
OnClick
A set of actions can be configured, which will be executed when the node is clicked.
Note:
Click is a synthetic event composed by combining two basic events: Press and Release.
Example Usage
OnPressed
A set of actions can be configured, which will be executed when the node is pressed.
Example Usage
OnTimer
A timer node and a set of actions can be configured. These actions will be executed when the timer expires.
Example Usage
Orbit Camera Transform
When attached to a Node, the specified camera will orbit around that Node. PLAYER USE ONLY.
And the options to limit the movement of the camera to specific parts of the spherical orbit. Setting the flag IsOrbitLimited allows the user to set minimum and maximum angles between the camera and the axes of the coordinate system, preventing the camera from moving too close to an axis. In this way, the user can define unwanted areas that the camera cannot move to, e.g., below the ground.
Common Properties
TouchableId
String
Touchable Id
Camera CameraType The camera that looks at the associated node.
Advanced Properties
IsOrbitLimited
bool
Enables setting of boundaries for the camera within the orbit.
AngleMinX FeatStd::Float Min angle between camera and X-axis (from 0 to 180 degrees). Must be less than AngleMaxX.
AngleMaxX FeatStd::Float Max angle between camera and X-axis (from 0 to 180 degrees). Must be greater than AngleMinX.
AngleMinY FeatStd::Float Min angle between camera and Y-axis (from 0 to 180 degrees). Must be less than AngleMaxY.
AngleMaxY FeatStd::Float Max angle between camera and Y-axis (from 0 to 180 degrees). Must be greater than AngleMinY.
AngleMinZ FeatStd::Float Min angle between camera and Z-axis (from 0 to 180 degrees). Must be less than AngleMaxZ.
AngleMaxZ FeatStd::Float Max angle between camera and Z-axis (from 0 to 180 degrees). Must be greater than AngleMinZ.
Page Indicator
Class Reference
Send events to a PageIndicator behavior to update its state. Can change the number of pages, set the active page, or activate a specific dot via external controls or PageIndicatorElement. This behavior is available for 2D scenes only.
Common Properties
TargetNode Candera::AbstractNodePointer Target node that will receive a ChangeValueEvent when ActivePageIndex changes
ActivePageIndex FeatStd::Int32 Index of active page (range from 0 to NumberOfPages - 1)
NumberOfPages FeatStd::Int32 Total number of pages (you have to ensure that PageIndicator has at least this number of child elements)
DecrementKeyCode Candera::KeyboardKeyCode::Enum
Key used for decrementing value (if value is actually decremented, focus handling is suspended)
IncrementKeyCode Candera::KeyboardKeyCode::Enum
Key used for incrementing value (if value is actually incremented, focus handling is suspended)
Rectangle Clipping Behavior
Common Properties
Width Float Width of the clipping rectangle.
Height Float Height of the clipping rectangle.
ClipPositionEnabled bool Enable Clipping Position.
ClipPosition
Candera::Vector2
Position of the clipping rectangle.
This property is only available if ClipPositionEnabled is set to true.
Roll
Class Reference
Displays a list of float values within a specified range, and lets the user select a value by rolling with touch or scrolling via configured arrow keys. This behavior is available for 2D scenes only.
Common Properties
ValueGroup Candera::AbstractNodePointer Node containing a range of displayed values
LensGroup Candera::AbstractNodePointer
Node containing current value.
This property is only available if 'LensVisible' is set to 'true'.
DecorationGroup Candera::AbstractNodePointer
Node containing lens decoration.
Value FeatStd::Float Current value
Min FeatStd::Float Minimum value
Max FeatStd::Float Maximum value
LensVisible bool Is lens group visible?
UseCyclicRoll bool Is roll cyclic?
AllowDraggingPastLimit bool
Allow temporary over-dragging (dragging to blank values before first and after last entry)
This property is only available if 'UseCyclicRoll' is set to 'false'.
TextEditNode Candera::AbstractNodePointer Node containing text edit field
Step FeatStd::Float Value step (positive float value).
Advanced Properties
Format FeatStd::String
Value display format (use '%f' for value)
This property is only available if 'LensVisible' is set to 'false'.
EditKeyCode Candera::KeyboardKeyCode::Key_Enter
Key used for entering text edit mode
This property is only available if 'LensVisible' is set to 'true' and a 'TextEditNode' is configured.
Touch Indication
Common Properties
TouchableId
String
Touchable Id
IndicationNode Candera::AbstractNodePointer The node moved by the Touch Indication Behavior. It is moved to the touch location to point it out.
TouchAreaNode Candera::AbstractNodePointer The node whose area the Touch Indication Behavior should indicate touch events on.
Camera Candera::AbstractNodePointer The camera used to render the touch indicator. Will be used to correctly match touch position with object position in case the camera has a position offset.
DistanceFromCamera FeatStd::Float
How far from the camera should the touch indication node be rendered.
OnAnimation Candera::MemoryManagement::SharedPointer<Candera::Animation::AnimationPlayer> Optional animation played when the indicator is shown.
OffAnimation Candera::MemoryManagement::SharedPointer<Candera::Animation::AnimationPlayer> Optional animation played when the indicator is hidden.
HideIndicatorOnMove bool Hide the touch indicator when a move is detected, otherwise the indicator will stay visible during movement until the finger is lifted from the screen.
Transform Mesh2D
Class Reference
Common Properties
Rotation FeatStd::Float Defines the rotation angle in degree around configured rotation axis at the configured origin
CameraDistance FeatStd::Float Defines a normalized camera distance (the projection is based on a normalized geometry of widht and height 1) with a default value of 1.
FitToMaximumSizeRotation FeatStd::Float Defines the rotation angle in degree that will be uses as maximum for the FitToMaximumSize fit strategy. Default is an angle of 90 degree.
RotationAxis Candera::Vector3 Defines the axis (default is the y axis) for the rotation as a 3D direction vector (the vector will be internally normalized).
FieldOfView FeatStd::Float The area on the Y axis view field in degrees. It influences the perspective distortion of the projection. Higher angles will result in more distorted projection. Lower angles will result in less perspective distorted projections. The angle has to be higher than 0 and less than 180.
FitStrategy TransformMesh2DFitStrategy::Enum Defines how the perspective projected mesh should fit into the original boundaries.
HorizontalOrigin CgiStudioControl::HorizontalOrigin::Enum The origin influences where the rotation is performed and how the perspective projection looks. It is defined as a normalized (bitmap resolution independent) origin on the y axis as Left (0), Center (0.5), Right (1.0) or Custom (see CustomHorizontalOrigin).
VerticalOrigin CgiStudioControl::VerticalOrigin::Enum The origin influences where the rotation is performed and how the perspective projection looks. It is defined as a normalized (bitmap resolution independent) origin on the y axis as Top (0), Center (0.5), Bottom (1.0) or Custom (see CustomVerticalOrigin).
CustomHorizontalOrigin FeatStd::Float Defines a normalized (bitmap resolution independent) custom origin that can not be defined with Left, Center or Right.
CustomVerticalOrigin FeatStd::Float Defines a normalized (bitmap resolution independent) custom origin that can not be defined with Top, Center or Bottom.
OriginOffset Candera::Vector2 In addition to the configured normalized origin this pixel based origin offset is added.
Event Handler
Example Usage
Common Properties
Actions ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
ConsumeEvent
bool
Virtual Key
Common Properties
KeyType
CgiStudioControl::KeyType::Enum
Choose the type of key. With KeyCode you can select any key.
Possible values: Modifier, KeyCode
Modifier Candera::KeyModifierEnum::Enum
Modifier Key (e.g. Shift)
