Value Processing Behaviors
Animation Value Processing Behaviors
Jump to Animation Keyframe
Common Properties
| Animation | SharedPointer<Candera::Animation::AnimationPlayer> | The animation controlled. AnimationProcessValueBehavior sets the animation to the frame corresponding to the value it receives. |
| SequenceStartTime | FeatStd::Optional<Candera::Animation::SequenceTimeType> | The start point of the animation. [ms] |
| SequenceDurationTime | FeatStd::Optional<Candera::Animation::SequenceTimeType> | The duration of the animation. [ms] |
| ControlNode |
Candera::AbstractNodePointer | Control Node containing a Control Animation. |
Diagnostics Value Processing Behaviors
Frame Measurement
Common Properties
| RenderTarget | Candera::GraphicDeviceUnit* | The render target which FPS should be monitored. |
| Output | OutputType::Enum | Specifies which information will be output. |
| DispatchThreshold | FeatStd::Optional< FeatStd::Variant > | Specifies how much the Output has to change to dispatch an event to its receivers. |
| Receivers |
Candera::ProcessValueBehaviorArrayProperty |
The process value behaviors that will receive the value as next in the value processing chain. This property can be set in the right side of the Scene Tree panel. |
Effects Value Processing Behaviors
Set Alpha Value
Common Properties
| Target Node | Candera::AbstractNodePointer | The Node which gets the resulting alpha value. If not set, then the node where the behavior is attached to, will be modified. |
Set Bitmap Clipping Area
Adjusts the clipping area of a render node. Takes a float value to control the bitmap effect along the X and Y axes. In Relative mode, the value scales the clipping area proportionally (0.0 to 1.0); in Absolute mode, it sets the size in pixel.
Switch Image
Supports
- Controls:
Example Usage
Common Properties
| Upload Strategy | Enum (OnInit, OnDemand) |
Specifies if images are uploaded on demand or when the behavior is instantiated. OnInit may cause an initial delay and keeps all images loaded. OnDemand avoids an initial delay and only keeps one image loaded. Possible values: OnInit, OnDemand |
| Target Node | RenderNode * | The Render Node SwitchImageProcessValueBehavior will switch images on. |
| Images |
SharedPointer<Candera::Image2D> |
A list of images which should be available for selection. This property is only available for 2D scenes. |
| Textures |
SharedPointer<Candera::TextureImage> |
A list of images which should be available for selection. This property is only available for 3D scenes. |
| OutOfBoundsHandlingMode |
OutOfBoundsHandlingMode::Enum |
Behavior when an index greater than the number of images is given. Possible values: Hold, Clamping |
Switch Text
Common Properties
| Target Node | Candera::AbstractNodePointer | The Render Node SwitchTextProcessValueBehavior will switch the text on. |
| Texts |
ArrayProperty<FeatStd::String> | Use list of texts (strings) and switch between them. |
Zoom Effect
Common Properties
| Target Node |
Candera::AbstractNodePointer | The node whose children are enabled or disabled by ZoomProcessValueBehavior. If not set, then the node where the behavior is attached to will be considered. |
| Alpha Factors | Vector2 | Min/Max transparency factors |
| Zoom Factors | Vector2 | Min/Max zoom factors |
| Zoom Distribution | Float | Distribution of Zoom/Alpha to each side of the selection. |
| ZoomByLayout | bool | Whether the zoom is accomplished by layout size. |
Transformation Value Processing Behaviors
Resize Group Node
Common Properties
| AffectXAxis | bool | Enables or disables scaling in horizontal direction. |
| AffectYAxis | bool | Enables or disables scaling in vertical direction. |
| Mode |
Mode::Enum | Determines how the received value will be interpreted. |
| ScaleVector |
Vector2 |
This vector is multiplied by the received value and specifies the magnitude by which the node is scaled. |
Set Node Size
Common Properties
| Target Node | Candera::AbstractNodePointer | The target node which is modified. if not set, then the node where the behavior is attached to, will be modified. |
| Size Axis | AxisType2D::Enum |
The axis along which the size is set. Possible values: AxisX, AxisY |
Set Position
Example Usage
Common Properties
| Target Node | Candera::AbstractNodePointer | The target node to which the events are routed from the source node. |
| Translation Axis 2D |
AxisType2D::Enum |
The axis along which the position is set. Possible values: AxisX, AxisY This property is only available for 2D scenes. |
| Translation Axis 3D |
AxisType3D::Enum |
The axis along which the position is set. Possible values: AxisX, AxisY,, AxisZ This property is only available for 3D scenes. |
Set Rotation
Example Usage
Common Properties
| Target Node | Candera::AbstractNodePointer | The node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| RotationAxis |
AxisType3D::Enum |
The axis to rotate the node around. Possible values: AxisX, AxisY,, AxisZ This property is only available for 3D scenes. |
Set Scale
Example Usage
Common Properties
| TargetNode | Candera::AbstractNodePointer | The Node which is modified. If not set, then the node where the behavior is attached to, will be modified. |
| ScaleAlongX | bool | Enables or disables scaling in horizontal direction. |
| ScaleAlongY | bool | Enables or disables scaling in vertical direction. |
| ScaleAlongZ | bool |
Enables or disables scaling in Z-direction. This property is only available for 3D scenes. |
| ScaleVector2D | Vector2 |
This vector is multiplied by the received value and specifies the magnitude by which the node is scaled. This property is only available for 2D scenes. |
| ScaleVector3D | Vector3 |
This vector is multiplied by the received value and specifies the magnitude by which the node is scaled. This property is only available for 3D scenes. |
Move Node
Example Usage
Common Properties
| Target Node | Candera::AbstractNodePointer | The node TranslateProcessBehavior moves. |
| Multiplied Vector | Vector3 | This vector is multiplied by the value TranslateProcessValueBehavior receives and specifies direction and magnitude by which TranslateProcessValueBehavior moves Translated Node. If not set, then the node where the behavior is attached to, will be modified. |
AnimationMeter
This behavior is a Behavior Block. It can be dragged&dropped on nodes just like any Behavior. Controls an animation according to the passed value.
| Animation | Candera::Animation::AnimationPlayer |
TThe animation controlled. AnimtionMeter sets the animation to the frame corresponding to a mapped value it receives. |
| Minimum | FeatStd::Variant |
Minimum of the Variant value which will be mapped between 0 and 1. |
| Maximum | FeatStd::Variant |
Maximum of the Variant value which will be mapped between 0 and 1. |
Arithmetic Operation
Common Properties
| Operation | ArithmeticOperationType::Enum |
Arithmetic operation to be performed. Possible values: Addition, Subtraction, Multiplication, Division, Modulo, Absolute |
| Operand | FeatStd::Variant | A number to be used as addend/subtrahend/multiplicant/divisor on provided value. |
| OutputType | VariantValueType::Enum |
Type of the Variant forwarded as result. Possible values: FloatValue, Int32Value, UInt32Value, BoolValue, DoubleValue, Int8Value, Int16Value, Int64Value, UInt8Value, UInt16Value, UInt64Value, StringValue |
| Receivers |
Clock
Common Properties
| SecondsProcessValueBehavior | Candera::ProcessValueBehavior* |
The behavior that receives the seconds. This property can be set in the right side of the Scene Tree panel. |
| MinutesProcessValueBehavior | Candera::ProcessValueBehavior* |
The behavior that receives the minutes. This property can be set in the right side of the Scene Tree panel. |
| HoursProcessValueBehavior | Candera::ProcessValueBehavior* |
The behavior that receives the hours. This property can be set in the right side of the Scene Tree panel. |
| OffsetInMinutes | FeatStd::Int32 | Offset in minutes to add to time (i.e. for different time zones). |
| ShowFull24Hours | bool | If true, hours will be shown from 0-23, otherwise in AM/PM format. |
| AMText | FeatStd::String | The string of the AM label. |
| PMText | FeatStd::String | The string of the PM label. |
| AMPMTextBehavior | Candera::Behavior* |
Sets text 'AM' or 'PM'. This property can be set in the right side of the Scene Tree panel. |
| ShowSeconds | bool | If true, seconds will be shown. |
| SecondsNode | Candera::AbstractNodePointer | The node that will be turned off if showing of seconds is disabled. |
Dial
Common Properties
| CurrentValue | FeatStd::Int32 | Current value for the dial. |
| MinimumRotation | FeatStd::Float | Minimum rotation of the dial. |
| MaximumRotation | FeatStd::Float | Maximum rotation of the dial. |
| StepSize | FeatStd::Float | Step size in degrees. |
| KnobNode | Candera::AbstractNodePointer | Knob node which will be rotated. |
| Receivers |
Filter
Common Properties
| Condition | Candera::ConditionBehavior* | ConditionBehavior for passing the value to the next process value behavior. |
| Receivers |
Forward Value
Note that the target Value - Behavior must have 'Accept Value Event' property enabled.
Example Usage
Common Properties
| Event Dispatch Strategy | EventDispatchStrategyType::Enum |
The way the event gets sent. Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior |
| Target Node | Candera::AbstractNodePointer | The target node to which the events are routed. If this property is not set, the event will be routed to the node of the behavior. |
| Dedicated Behavior |
The dedicated process value behavior that will receive the change value event. This property can be set in the right side of the Scene Tree panel. |
Interpolate Value
If the Animation Mode property is set to Instant, no interpolation will be taking place - the received value will be applied immediately.
Example Usage
Common Properties
| Animation Mode | InterpolationAnimationMode::Enum |
Animation mode sets a specific interpolation type. Possible values: SpeedBased, TimeBased, Instant |
| Units Per Second | Float |
Speed at which InterpolateProcessValueBehavior changes its internal value. This property can only be set when AnimationMode is set to "SpeedBased". |
| Interpolation Time |
UInt32 |
Time in ms the InterpolateProcessValueBehavior changes its internal value. This Property can only be set when AnimationMode is set to "TimeBased" |
| Filter Time Constant | Float |
The moment before InterpolateProcessValueBehavior’s internal value reaches the received value, the speed at which the former is changing slows down. This prevents a sudden end of movement that can be felt as artificial in some cases. This property can only be set when AnimationMode is set to either "SpeedBased" or "Timebased". |
| Receivers |
Map Value
Common Properties
| InputMin | FeatStd::Optional< FeatStd::Variant > | [Optional] Smallest value of the interval to check. If Minimum is given as greater than Maximum then the values are internally swapped. |
| InputMax | FeatStd::Optional< FeatStd::Variant > | [Optional] Largest value of the interval to check. If Maximum is given as smaller than Minimum then the values are internally swapped. |
| OutputMin | FeatStd::Float | Smallest value of the interval mapped to. |
| OutputMax | FeatStd::Float | Largest value of the interval mapped to. |
| Receivers |
Map Value Normalized
Common Properties
| Reverse | bool | Toggles the mapping direction. If this property is true, the received value is assumed to be within range from 0.0 to 1.0 and the emitted value is mapped accordingly. |
| ValueForRange | ValueBehaviorBase* |
The input value behavior for defining the mapped range. This property can be set in the right side of the Scene Tree panel. |
| Receivers |
Process Value Changed Event
Example Usage
Common Properties
| Sender | Candera::AbstractNodePointer | The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead. |
| Minimum | Optional<FeatStd::Variant> | Minimum threshold of the processed values. |
| Maximum |
Maximum threshold of the processed values. |
| ConsumeEvent |
bool |
Set this flag to false if the event should not be consumed by the trigger. By default it is set to true and if the trigger evaluates to true the event will not be routed to any other behavior. |
| Receivers |
ProcessValueBehavior ArrayProperty |
Render a Range
This behavior is a Behavior Block. It can be dragged&dropped on nodes just like any Behavior. Renders a range of nodes according to the passed value.
| OperationMode | OperationModeType Enum | When set to MultipleNodes, EnableNodesProcessValueBehavior will enable the first N children of Group Node. When Operation Mode is set to SingleNode, only Nth node is enabled. N is a number from 0 to number of all children nodes of Group Node. It corresponds linearly to the value EnableNodesProcessValueBehavior receives. |
| Minimum | Optional< FeatStd::Variant > | Minimum of the Variant value which gets mapped between 0 and 1. |
| Maximum |
Optional< FeatStd::Variant > | Maximum of the Variant value which gets mapped between 0 and 1. |
Send ChangeValue on receiving ProcessValue event
Common Properties
| ChangeValue | ChangeValue::Enum | How the event value shall be handled by the receiving behavior |
| Target Node |
The target node to which the events are routed. If this property is not set, the event will be routed to the node of the behavior. This property is only visible if EventDispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel". |
| EventDispatchStrategy | CgiStudioControl::EventDispatchStrategyType::Enum |
The way the event gets sent Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior |
| DedicatedBehavior | Candera::ProcessValueBehavior* |
The dedicated process value behavior that will receive the change value event. This property can be set in the right side of the Scene Tree panel. This property only visible if EventDispatchStrategy is set to "DedicatedBehavior". |
| Receivers |
Set Selected State
Smooth Value
Common Properties
| SmoothingFactor | FeatStd::Float | The factor how fast the output value should adapt to the input value. Valid values are between 0.0 and 1.0 |
| Receivers |
Render Child Nodes
Common Properties
| OperationMode | OperationMode::Enum |
When set to MultipleNodes, EnableChildNodes will enable the first N children of Group Node. When Operation Mode is set to SingleNode, only the Nth node is enabled. Possible values: MultipleNodes, SingleNode |
| Levels | FeatStd::UInt8 | Number of levels to step down through groups. Default is zero. |
| NormalizeValue | bool | If set to true, the received value has to be between 0 and 1 and will be mapped to the number of children. Otherwise the value has to be the index of the child. |
Format String
Example Usage
Common Properties
| Text | String | Text that TextBehavior will change the Node to. Supports formatting for one variable that corresponds to the value TextProcessValueBehavior2D receivers. |
| Style | SharedPointer <Candera::TextRendering::SharedStyle> | The style that will be set to the Text Node. |
| Alignment | TextNode2DLayouter::TextAlignment |
The horizontal text alignment, using the culture text direction, is used to define how text will be horizontally aligned within its layout area. Possible values: Auto, Left, Center, Right |
| Multiline | bool | If multi line is disabled, then the new line control characters will be ignored and text will always be rendered in one line. |
| Line Spacing | PixelSize (UInt16) | Defines the distance between the baselines of successive lines of type. |
| Word Wrap | Bool | If word wrapping is enabled then the lines that exceed the client area will be split during arrangement into multiple lines. |
| Trimming | TextNode2DLayouter::Trimming |
Trimming defines the behavior to employ when content overflows the content area. Possible values: None, Ellipsis, CustomText |
| TrimmingText | FeatStd::String |
Trimming text defines the text which replaces content overflowing the content area. This property is only visible if Trimming is set to "CustomText". |
| TargetNode | Candera::AbstractNodePointer | The Node which gets the given text. If not set, then the node where the behavior is attached to, will be modified. |
Track Angle on Drag
Common Properties
| TouchNode | Candera::AbstractNodePointer | A node that is used to collect information about the touch. |
| Receivers |
Drag on Track to Value
Common Properties
| UseCenter | bool | If true, the center value defined for the knob bitmap is used to align the knob to the value position, otherwise the calculated center. |
| TrackDirection | TrackDirection::Enum |
Defines if the position will be tracked horizontally or vertically Possible values: Vertical, Horizontal |
| LeftTouchMargin | FeatStd::Float | Defines the size for extending or shrinking the touch-sensitive area at the left border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area. |
| RightTouchMargin | FeatStd::Float | Defines the size for extending or shrinking the touch-sensitive area at the right border of the knob. The size is given in percentage of the knob width. Positive values extend, negative values shrink the area. |
| TopTouchMargin | FeatStd::Float | Defines the size for extending or shrinking the touch-sensitive area at the top border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area. |
| BottomTouchMargin | FeatStd::Float | Defines the size for extending or shrinking the touch-sensitive area at the bottom border of the knob. The size is given in percentage of the knob height. Positive values extend, negative values shrink the area. |
| OnKnobDragOnly | bool | The position will only be updated when the Knob gets dragged, otherwise clicking on the control will move the knob to the position. |
| UseExcclusiveMode |
bool |
Enabling the option prevents some controls (e.g. Slider) from loosing the touch when leaving the node area. |
| DraggedNode |
Defines the node to move along the track, to determine the hit area and to determine the position change relative to its center. |
| Receivers |
Action on Value
Example Usage
Common Properties
| Condition | ConditionBehavior* | The ConditionBehavior that TriggerBehavior passes a value to and expect a response from to see if Action needs to be invoked. |
| Actions | ActionBehaviorArrayProperty | The set of ActionBehaviors that TriggerBehavior invokes in the event that it receives a positive response form Condition. |
| Consume Event | bool | Set this flag to false if the event should not be consumed by the trigger. By default it is set to true and if the trigger evaluates to true the event will not be routed to any other behavior. |
Value
Example Usage
Common Properties
| Minimum | FeatStd::Optional< FeatStd::Variant > |
Minimum of the Variant value. If Minimum is given as greater than Maximum then the values are internally swapped. |
| Maximum | FeatStd::Optional< FeatStd::Variant > | Maximum of the Variant value. If Maximum is given as smaller than Minimum then the values are internally swapped. |
| IntervalHandling | IntervalHandling::Enum |
Select how the behavior should react when the minimum or maximum limit is exceeded. Possible values: Limit, Cycle, Ignore |
| AcceptValueEvent | bool | Set this flag to true to make the value changeable by events/actions. |
| BroadcastProcessValueEvent | bool | Set this flag to true to broadcast ProcessValue event even if value did not change. |
| DispatchStrategy |
By default the event that indicates that this value behavior has been changed (ValueChangedEvent) is dispatched only on the node to which the value behavior is attached (CgiStudioControl::EventDispatchStrategyType::Direct). To change this you have to select a different dispatch strategy. Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior |
| DedicatedBehavior |
The dedicated behavior that will receive ValueChangedEvent when DedicatedBehavior dispatch strategy is selected. This property is only visible if DispatchStrategy is set to "DedicatedBehavior". This property can be set in the right side of the Scene Tree panel. |
| TargetNode |
The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead. This property is only visible if DispatchStrategy is set to "Direct", "Broadcast", "Bubble" or "Tunnel". |
| Variant |
Candera::Variant | Specifies the type and the value to pass onto Process Value Behavior. |
| Receivers |
Value Generator
The Value Generator is a demo behavior. It allows you to configure minimum and maximum values, period, and update interval, and is used for UI verification and simulation purposes. It appears in the tool when CONTROLS_DEMO_BEHAVIORS_ENABLED is enabled via CMake.
Common Properties
| GeneratorFunction | Enum | The type of function used to generate values (linear, sin, etc.) |
| Minimum | Float | The minimum for the generated values. |
| Maximum | Float | The maximum for the generated values. |
| OffsetMs | Int | The time offset where the function is evaluated. |
| PeriodMs | Int | The time period after which the generated values repeat. |
| SamplerateMs | Int | The update rate of the generated value. |
| GenerateValues | bool |
Set this flag to true to generates values at sample rate. If set to false, no values are generated. |
| Dedicated Behavior | Candera::ProcessValueBehavior* |
