Warping Sequence
- Distribute reference points over the bitmap according to the specifications in the parameter list. Parameterized through: Bitmap Area and the associated Bitmap Area Shift
- Bitmap predistortion (warping) Parameterized through: the active Parameter Set
- Rotate predistorted image data according to the parameter list. The rotation of the warped reference points must take place around the center point of the warped bitmap. Parameterized through: rotation of the warping area and warped bitmap area center point.
- Shift rotated and warped image data according to the parameter list. Parameterized through: shift of warped bitmap area center point.
- Display warped, rotated and shifted image data on the display
