How to Import Resources
This section describes how to import resources by selecting Import Resources... from the Import menu on the menu bar.
Import File Formats
The file formats available for import through this menu are listed below:
  • Image files (*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr)
  • Font files (*.ttf, *.ttc,*.otf, *.fnt, *.fbm, *.*)
  • Shader files (*.vert, *.frag)
  • SVG files (*.svg)
  • FBX files (*.fbx)
  • glTF files (*.gltf, *.glb)
  • Icon files (*.bmp, *.ico, *.jpg, *.png)
  • Script files (*.lua)
In addition to the formats listed above, Scene Composer also supports importing Photoshop (*.psd), Adobe XD (*.xd), Axure RP (*.rp) and Sketch (*.sketch) files. For more details on importing these formats, refer to the Smart Importer chapter.
When importing font files, selecting them in the file selection dialog allows the application to recognize and import them as fonts, regardless of their file extensions. For more information, please refer to the explanation here.
Beginning with CGI 3.14, skinning animations can be played back by importing skinning-enabled FBX or glTF files.
About .glTF File Format
SceneComposer supports following glTF file formats during import:
  • glTF: References external binary data (geometry, animation keyframes, skinning data), and image files.
  • glTF-Embedded: Contains base64-encoded binary data, and images embedded inline using data URIs.
  • glTF-Binary: Packages the entire glTF asset (JSON description, .bin binary data, and images) into a single binary file.
For more detailed information on these file formats, refer to the Khronos website: GLB File Format Specification.
About .ktx File Format
  • Etc2CompressedRgbFormat
  • Etc2CompressedSrgbFormat
  • Etc2Alpha1CompressedRgbaFormat
  • Etc2Alpha1CompressedSrgbaFormat
  • Etc2EacCompressedRgbaFormat
  • Etc2EacCompressedSrgbaFormat
To use this type of format, the source image must first be converted from another supported image type (such as .tga, .gif, .psd, .bmp, .pgm, .png etc.) into a .ktx file. The following tools can be used to generate KTX files:
  • Texgenpack
  • Mali Texture Compression tool
  • Ericcson Texture Compression Tool
This tool compresses texture images to the Ericsson Texture Compression (ETC/ETC2) and Adaptive Scalable Texture Compression (ASTC). It supports the following output formats:
  • .pkm - Contains compressed textures
  • .ktx – Stores a 2D texture along with all associated mipmap levels.
After the conversion is complete, the .ktx file can be imported into SceneComposer using the same workflow as for other image formats.
When importing a converted .ktx file into SceneComposer, the DefaultBitmapConverter property - available for standard .bmp images - can not be used.
About Bitmap Font
SceneComposer supports the use of bitmap fonts. To enable bitmap font functionality, SCHost.dll must be compiled using the BitmapFont font engine. Only one font engine can be active at a time within an instance of SCHost.dll.
Users can import the following file types as bitmap fonts:
  • .fnt - Windows font files that are converted to bitmap fonts
  • .fbm - Pre-converted bitmap font files
When a font is imported, the following property is set:
  • Source file names - Indicates the name of the imported file, helping users identify a font
On OpenGL ES1.1 platforms, such as Traveo2, importing shader files, SVG files, FBX files, and glTF files is not supported.
Import Operation
Menu Bar
Context menu
Drag and Drop
    • glTF file can also be imported by drag-and-drop to any folder under Solution in Solution Explorer.
    • Note that under OpenGLES1.1 environment, shader files (*.vert, *.frag), SVG files (*.svg), FBX files, and glTF files cannot be imported by drag-and-drop operation.
    • When an image file format (*.bmp, *.jpg, *.png) that can be imported as an icon is dragged and dropped into any folder under Solution in Solution Explorer, the dialog box will appear as shown below, allowing you to select whether to import it as an image or icon resource. You can choose whether to import it as an image or an icon.
For importing FBX files contains skinning, see here.
When an image file is imported, the original image file is retained along with the bitmap information file (*.bin file) used on Scene Composer. See here for details.
  1. When the import process is executed, Scene Composer will display a message to save any unsaved changes in the solution. Press OK to proceed. If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
  2. After saving the solution, the Import Resources dialog is opened, where you can select one or more resource files to be imported. Select your files to import and press OK.
    • You can search for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog.
    • You can import multiple files at once as long as their file format belong to the same category, such as an Image file or a Font file.
    • By selecting Font files from the pull-down menu below, you can import any file as a font file, regardless of its extension.
  3. After choosing your files to import, an Import dialog will be displayed depending on the file types you are importing (Image, Font, FBX, Shader…).
    • See Import Dialog Options for a description of the settings on the dialog screen.
    • Select [ Import as wireframe ] check box to import the wireframe vertex buffer when importing an FBX file.
    • When the import selection contains Radiance HDR (.hdr) files, a Radiance HDR Format option appears in the Import dialog.
    • The available choices and the default value follow the setting made in the Import Images Config panel of Solution Options. See Import Dialog Options for details.
  4. Configure import settings to your needs and click "OK" button.
    • The file will be imported as a resource in the Solution Explorer in the location corresponding to the settings on the dialog screen.
FBX files with multiple animations
Scene Composer supports the import of FBX files that contain multiple animation tracks. The names of the imported animation tracks are automatically created from each animation track contained in the FBX file.
The animations that can be imported from FBX files are as follows.
  • Translation
  • Rotation
  • Scaling
Icon files
  2. After saving the solution, the Import Resources dialog will open. Select the target file and press OK. If the selected file format is "*.ico", the [ Import Icons ] dialog will appear as shown below.
    • The path of the selected file is displayed in the [ Selected files ] field. To re-select a file, press the [ Select File... ] button.
    • In [ Destination folder ], specify the location where the file will be imported as a resource.
    • As explained in the Drag and Drop section, if you drag and drop an image file format that can be imported as an icon (*.bmp, *jpg, *.png), the above dialog will appear and you can import it as an icon.
  3. Click "OK" button to complete the import operation.
SVG files
  2. After saving the solution, the Import Resources dialog is opened, where you can select one or more SVG files to be imported. Select your files to import and press OK.
    • You can import multiple files at once.
  3. After choosing your files to import, an SVG Importer dialog will be displayed.
  4. Configure import settings to your needs and click "Import" button.
    • "ImportedScenes" and "Scenes" folders have been created at the destination folder chosen in "Solution Explorer". The former holds data imported as template scenes, while the latter holds data imported as actual scenes.
    • If multiple SVG files have been imported, the Scene Editor will display the actual scene for what was the topmost SVG file in the SVG Importer.
      • Transform > Position > X = 0, Y = 0 will be the item's initial position.
    • Copy group nodes within imported scenes into the desired scene and use them.
glTF files
  - Morping
  - Vertex Buffer Streams
  - Sparse Accessors
For additional details on handling glTF files—e.g., supported extensions, multiple UV sets, and limitations—please see the glTF file page.
For importing glTF files contains skinning, see here.
    • You can import multiple files at once.inn
  3. After choosing your files to import, an Import dialog will be displayed.
    • Use the import dialog to configure Image-Based Lighting (IBL). You cannot change these settings after the import.
    • If you do not want to use IBL, clear the Use Image Based Lighting (IBL) checkbox.
    • During glTF import, the Engine automatically generates the IBL from a single HDR panorama (latlong) image, so you do not need to set the radiance, irradiance, or BRDF integration textures manually.
    • When necessary, set theConfigure HDR panoramaPanorama (latlong)Latitude/Longitude) imageImage, IBL Cubemap Texture Size, and IBL textureLookup sizeTexture Size in the import dialog.
    dialog as necessary.
    • IBL cubemap texture size: Specifies the size of the cubemap texture used for IBL generation. The default IBL texture sizevalue is 256.256. On ES2.0, setplatforms, atthe leastminimum value is 64 and usethe size must be a power-of-twopower value.of two. On ES3.0, platforms, the minimum sizevalue is 64.
  4. IBL lookup texture size: Specifies the size of the lookup texture used for IBL generation. The default value is 256. On ES2.0 platforms, the minimum value is 64. and the size must be a power of two. On ES3.0 platforms, the minimum value is 64.
You can also set IBL in Solution Options. For details about these settings, see IBL HDR.
Then, "Import GLTF" dialog will be displayed.
  • You can’t change IBL settings in the import dialog (red box below).
  • When you specify an HDR panorama image and run the import, the Engine automatically assigns the generated shared IBL textures to each mesh (orange box below).
  • The Engine generates the following textures: LambertianTexture (Diffuse/Irradiance), GGXTexture (Specular/Radiance), GGXLutTexture (BRDF 2D LUT), and SkyBoxTexture (Skybox).
  • For other settings on the dialog, please refer to Import Dialog Options.
Shared IBL textures
When you import a glTF and generate IBL from an HDR panorama (lat/long), the importer automatically assigns the shared IBL textures (LambertianTexture/GGXTexture/GGXLutTexture/SkyBoxTexture) to each mesh. When you change a shared IBL texture, the importer propagates the change to all meshes that reference it.
In the example below, select LambertianTexture (Diffuse/Irradiance) in Solution Explorer and set Magnification Filter to Nearest in the Properties panel; the importer applies the same setting to every mesh/material that references LambertianTexture (irradiance/diffuse slot).
