How to Import Resources
This section describes how to import resources by selecting Import Resources... from the Import menu on the menu bar.
Import File Formats
TheYou can import the following file formats available for import throughusing this menu are listed below:menu:
- Image files (
*.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.ktx, *.hdr, *.exr) - Font files (
*.ttf, *.ttc,*.otf, *.fnt, *.fbm, *.*) - Shader files (
*.vert, *.frag) - SVG files (
*.svg) - FBX files (
*.fbx) - glTF files (
*.gltf, *.glb) - Icon files (
*.bmp, *.ico, *.jpg, *.png) - Script files (
*.lua)
In addition toBeside the formats listed above, Scene Composer also supports importing Photoshop (*.psd), Adobe XD (*.xd), Axure RP (*.rp) and Sketch (*.sketch) files. For more details on importing these formats, refer tosee the Smart Importer chapter.
When importing font files, selecting them in the file selection dialog allows the application to recognizerecognizes and importimports them as fonts, regardless of their file extensions. For more information, please refer tosee the explanation here.
Beginning with CGI 3.14, Scene Composer can play back skinning animations canafter beyou played back by importingimport skinning-enabled FBX or glTF files.
About .glTF File Format
SceneComposer supports the following glTF file formats during import:
- glTF: References external binary data (geometry, animation keyframes, skinning data), and image files.
- glTF-Embedded: Contains base64-encoded binary data, and images embedded inline using data URIs.
- glTF-Binary: Packages the entire glTF asset (JSON description, .bin binary data, and images) into a single binary file.
For more detailed information on these file formats, refer tosee the Khronos website: GLB File Format Specification.
About .ktx File Format
TheScene Composer supports the following compressed image formats are supported:formats:
- Etc2CompressedRgbFormat
- Etc2CompressedSrgbFormat
- Etc2EacCompressedRgbaFormat
To use thisthese typeformats, ofyou format,have to convert the source image must first be converted from anothera supported image type (such as .tga, .gif, .psd, .bmp, .pgm, .png etc.) into a .ktx file. TheYou can use the following tools can be used to generatecreate KTX files:
- Texgenpack
- Mali Texture Compression
toolTool EriccsonEricsson Texture Compression Tool
ThisThese tooltools compressescompress texture images to theusing Ericsson Texture Compression (ETC/ETC2) and Adaptive Scalable Texture Compression (ASTC). ItThey supports the following output formats:
- .pkm - Contains compressed textures
- .ktx – Stores a 2D texture along with all associated mipmap levels.
After theconversion, conversionyou iscan complete,import the .ktx file can be imported into SceneComposerScene usingComposer following the same workflowprocess as for other image formats.
When importing a converted .ktx file into
SceneComposer,Scene Composer, you cannot use the DefaultBitmapConverter property-that is available for standard .bmpimages - cannotbe used.images.
About Bitmap Font
SceneComposerScene Composer supports the use of bitmap fonts. To enable the bitmap font functionality, you must compile the SCHost.dll must be compiled using the BitmapFont font engine. OnlyNote that only one font engine can be active at a time within an instance of SCHost.dll.
Users can import theThe following file types can be imported as bitmap fonts:
- .fnt - Scene Composer converts these Windows font files
that are convertedto bitmapfontsfonts. - .fbm - Pre-converted bitmap font files
When you import a fontfont, isScene imported,Composer sets the following property is set:property:
- Source file names - Indicates the name of the imported file, helping
usersyou identify a font
On OpenGL ES1.1 platforms, such as Traveo2, importing shader files, SVG files, FBX files, and glTF files is not supported.
Import Operation
You can openOpen the Import Dialog to proceed importing resources in one of the following three ways.
Menu Bar
Select [Import]Import > [Import Resources...] from the menu bar.
Context menu
Right-click on any folder in Solution Explorer and select [Import]Import > [Resource.Resources...] from the context menu that appears.menu.
Drag and Drop
Drag and drop the target file that you want to be importedimport into any folder under Solution in Solution Explorer.
glTF fileYou can alsobeimportimporteda glTF file bydrag-and-drag and drop to any folder under Solution in Solution Explorer.- Note that
underin an OpenGLES1.1 environment, you cannot import shader files (*.vert, *.frag), SVG files (*.svg), FBX files, and glTF filescannotviabedragimportedandby drag-and-drop operation.drop. - When you drag an image file format (*.bmp, *.jpg, *.png) that Scene Composer can
be importedimport as an iconis dragged and droppedinto any folder under Solution in Solution Explorer,thea dialog boxwill appear as shown below,appears, allowing you toselectchoose whether to import it as an image or icon resource.You can choose whether to import it as an image or an icon.
Save Solution
When you start the import process, Scene Composer checks your solution for unsaved changes. If necessary, you are prompted to save your solution. Click OK to proceed. Once the solution is saved, Scene Composer opens the Import Resources dialog.
To hide this dialog from popping up at future imports, clear the Always show this dialog checkbox.
After selectingyou select a file, Scene Composer shows different import operations will vary depending on the file format. Please refer toSee the following linkstopics for detailed operationimport procedures.
For importing FBX files containsthat contain skinning, see here.
When you import an image filefile, isScene imported,Composer retains the original image file is retained along with the bitmap information file (*.bin file) used on Scene Composer. See here for details.
After saving the solution,In the Import Resources dialog is opened, where you candialog, select one or more resource files tothat beyou imported. Select your fileswant to import and pressclick OK.
You can searchSearch for supported file formats by selecting them in the drop-down menu at the bottom right of the Import Resources dialog.You can importImport multiple files at once as long as their file format belong to the same category, such asanImagefilefiles or a Fontfile.files.By selectingSelect Font files from the pull-down menu below,you canto import any file as a font file, regardless of its extension.
After choosingyou yourselected the files to import, Scene Composer displays an Import dialog will be displayed depending onfor the selected file types you are importingtype (Image, Font, FBX, Shader…).
- Select
[Import as wireframe]check box to import the wireframe vertex buffer when importing an FBX file. - When the import selection contains Radiance HDR (.hdr) files, a Radiance HDR Format option appears in the Import dialog.
The available choices and the default value follow the setting made in the Import Images Config panel of Solution Options. See Import Dialog Options for details.
Configure the import settingssettings, to your needs andthen click "OK" button.OK.
TheScene Composer imports the filewill be importedas a resource intheSolutionExplorer in the location corresponding to the settings on the dialog screen.
Explorer.
FBX files with multiple animations
Scene Composer supports the import of FBX files that contain multiple animation tracks. TheScene Composer automatically creates the names of the imported animation tracks arebased automaticallyon created from eachthe animation tracktracks contained in the FBX file.
The animations thatYou can beimport importedthe following types of animations from FBX files are as follows.files:
- Translation
- Rotation
- Scaling
Icon files
WhenIn theimportImportprocessResourcesisdialog,executed, Scene Composer will display a message to save any unsaved changes inselect thesolution.targetPressfile,OKthentoclickproceed.OK.If you do not want this dialog to appear during the import process, uncheck the "Always show this dialog" checkbox.
After saving the solution, the Import Resources dialog will open. Select the target file and press OK.If the selected file format is "*.ico", Scene Composer displays the[Import Icons]dialogwillthatappearprovidesastheshownfollowingbelow.options:- The Selected files field displays the path
ofto the selectedfile is displayed in the [ Selected files ] field.file. To re-select a file,pressclickthe [Select File...] button.. - In
[Destination folder], specify the location where Scene Composer imports the filewill be importedas a resource. - As explained in the Drag and Drop section,
ifwhen you drag and drop an image fileformat(*.bmp, *jpg, *.png) that can be imported as aniconicon,(*.bmp,Scene*jpg,Composer*.png),displaystheaabovepromptdialog will appear andallowing youcanto select whether to import it asanimage or icon.
Click
"OK" buttonOK to complete the import operation.
SVG files
After saving the solution,In the Import Resources dialog is opened, where you candialog, select one or more SVG files tothat beyou imported. Select your fileswant to import and pressclick OK.
AfterScene choosingComposer yourdisplays files to import, anthe SVG Importer dialog will be displayed.
dialog:
See SVG Importer Dialog for a description of the settings on the dialog screen.
Configure the import settingssettings, to your needs andthen click "Import" button.Import..
"ImportedScenes"Scene Composer creates the ImportedScenes and"Scenes"Scenes foldershave been createdat the destination folderchosenselected in"SolutionExplorer"Explorer. The former holds data imported as template scenes, while the latter holds data imported as actual scenes. -
If you import multiple SVG
files have been imported,files, the Scene Editorwill displaydisplays the actual sceneforthatwhatcorrespondswasto the topmost SVG file in the SVG Importer.-
Transform > Position > X = 0, Y = 0
will beis the item's initial position.
CopyYou can copy group nodeswithinfrom imported scenes and paste them intotheyour desired sceneandto use them.
glTF files
- MorpingMorphing
- Vertex Buffer Streams
- Sparse Accessors
For additional details on handling glTF files—files — e.g., supported extensions, multiple UV sets, and limitations—pleaselimitations — see the glTF file page.
For importing glTF files containsthat contain skinning, see here.
After saving the solution,In the Import Resources dialog is opened, where you candialog, select one or more resource files tothat beyou imported. Select your fileswant to importimport, andthen pressclick OK.
AfterScene choosingComposer yourdisplays filesthe to import, an Import dialogGLTF will be displayed.
dialog:
- Use the import dialog to configure Image-Based Lighting (IBL). You cannot change these settings after the import.
- If you do not want to use IBL, clear the Use Image Based Lighting (IBL) checkbox.
- During glTF import, the Engine automatically generates the IBL from a single HDR panorama (latlong) image, so you do not
needhave to set the radiance, irradiance, or BRDF integration textures manually. - Configure HDR Panorama (Latitude/Longitude) Image, IBL Cubemap Texture Size, and IBL Lookup Texture Size in the import dialog as necessary.
- IBL cubemap textures size: Specifies the size of the cubemap texture used for IBL generation. The default value is 256. On ES2.0 platforms, the minimum value is 64 and the size must be a power of two. On ES3.0 platforms, the minimum value is 64.
- IBL lookup textures size: Specifies the size of the lookup texture used for IBL generation. The default value is 256. On ES2.0 platforms, the minimum value is 64 and the size must be a power of two. On ES3.0 platforms, the minimum value is 64.
- You can also set IBL in Solution Options. For details about these settings, see IBL HDR.
- You can’t change IBL settings in the import dialog (red box below).
- When you specify an HDR panorama image and run the import, the Engine automatically assigns the generated shared IBL textures to each mesh (orange box below).
- The Engine generates the following textures: LambertianTexture (Diffuse/Irradiance), GGXTexture (Specular/Radiance), GGXLutTexture (BRDF 2D LUT), and SkyBoxTexture (Skybox).
- For other settings on the dialog,
please refer tosee Import Dialog Options.
OK.
TheScene Composer imports the filewill be importedas a resource intheSolution Explorerin,the location corresponding to the settingsbased on the selected dialogscreen.
settings.
Shared IBL textures
When you import a glTF and generate IBL from an HDR panorama (lat/long), the importer automatically assigns the shared IBL textures (LambertianTexture/GGXTexture/GGXLutTexture/SkyBoxTexture) to each mesh. When you change a shared IBL texture, the importer propagates the change to all meshes that reference it.the shared IBL texture.
In the example below, select LambertianTexture (Diffuse/Irradiance) in Solution Explorer and set Magnification Filter to Nearest in the Properties panel;panel. theThe importer applies the same setting to every mesh/material that references LambertianTexture (irradiance/diffuse slot).LambertianTexture.
