Import Dialog Options
This section describes the configuration of the import dialog that appears when importing resources such as FBX files, images, shaders, fonts or scripts.
The specific options available in the dialog may vary depending on the type of asset being imported.
Import Dialog
1
Comparison:
The resources located at the import destination are compared against the resources included in the current import, and the resulting update status is displayed. Import status is shown using icons and tooltips in the Status column. The same status is also conveyed through the font color applied to each resource name in the After Import column.
Green: A new resource will be added.
Yellow: A resource with the same name exists, but its properties are different.
No highlight: A matching resource already exists with identical properties, or the resource is not included in the current import.
2
Save Report…:
Generates and saves a report file (CVS format) summarizing the comparison results for the imported files. The report name and save location can be specified in the dialog window that appears when this button is clicked.
3
Select Files…:
Opens a dialog that allows you to select the items to be imported into the solution.
4
Folder:
Select the destination folder for imported files. Use the drop-down menu or the Browse button to select any location in the Solution Explorer as root folder for the import destination. By default, the root folder /Resources is selected.
5
Create new folder for import:
Select this option to create a new subfolder under the destination specified in the Folder section. Enter the name of the new subfolder in the input field.
6
Delete existing items in destination folder:
Enables deletion of all existing content in the destination folder before the import operation is executed.
7
Preserve imported folder structure:
This option is available only when importing Image or 3D model file types, and it can be enabled only when Delete existing items in destination folder is active. When this option is selected, all existing files in the destination folder are deleted, but the folder structure itself is retained.
*This option is not displayed when importing Font or Shader file types.
8
Visible in imports panel:
Enables imported items to be displayed both in the Import panel and in the Solution Explorer.
9
Preserve library item attributes:
This option allows you to retain specific attributes of an item during a re-import operation. When enabled, the attributes previously assigned to the item remain unchanged even if the incoming data would normally overwrite them.
The attributes that can be preserved include:
- Bitmap-related properties: Converter, Target format, Origin
- Vertex buffer properties: buffer type, enable cache, position, normal, texture coordinate, tangent, bi normal etc.
When any of these properties is preserved, the re-import process will not modify it, even if the newly imported object contains different values for that property.
10
Set bitmap profile:
This option allows you to specify a default bitmap profile that is applied to all bitmaps that do not have an explicitly assigned profile. It is available when importing Images, FBX, and glTF files.
You can configure bitmap profiles in two ways:
- From the menu bar: Solution > Solution Options...
- From the Properties panel, which appears when you select the target resource in the Solution Explorer.
11
Import as wireframe:
This option is available only when importing FBX files. When enabled, a wireframe vertex buffer is generatedbased on the triangles and rectangles contained in the FBX file. Both the standardvertex buffer and the  wireframe vertex buffer are then registered under Associated Vertex Buffer in the Solution Options.
12
Set the "Is Indexed" property of the vertex buffer to enabled:
This option is displayed only when importing FBX files and is enabled by default.
When this option is selected, the buffer type is converted to an index array, allowing Scene Composer to automatically determine and apply the appropriate index size. If the option is disabled, the buffer type is set to a regular array instead.
13
OK button:
Imports the selected resources using the configured settings.
14
Cancel button:
Closes the dialog without performing the import.
15
Radiance HDR Format:
This option appears only when the import selection contains Radiance HDR (.hdr) files. Select the pixel format to apply during import. The default value follows the format configured in Solution Options > Import Images Config.
    RgbFloatingPoint9E5PixelFormat
    RgbFloatPixelFormat
    RgbHalfFloatPixelFormat
    RgbaFloatPixelFormat
    RgbaHalfFloatPixelFormat
    In an OpenGL ES 2.0 environment, none of the five Radiance HDR Format options (RgbFloatingPoint9E5PixelFormat / RgbFloatPixelFormat / RgbHalfFloatPixelFormat / RgbaFloatPixelFormat / RgbaHalfFloatPixelFormat) are supported. If your solution contains any of these formats, a warning is shown in the Problems panel.
    SVG Importer Dialog
    (1)
    Import Settings
    Import to folder:
    Specifies the folder in the Solution Explorer where the SVG file will be imported.
    Select this option to create a new subfolder under the destination specified in the Folder section. Enter the name of the new subfolder in the input field below.
    Importing List
    Displays the list of items  selected for import.
    - Items that cannot be imported will be displayed with an error icon.
    - Items that can only be partially imported will be displayed with a warning icon
    Even if no icon is shown, some elements may still fail to load depending on their content or structure.
    (2)
    Add/Delete:
    Add: Adds another SVG file to the list of items to be imported.
    Delete: Removes the selected SVG file from the import list.
    (3)
    Preview Display:
    Left-side: Shows the original of the SVG image that has been selected from the Importing List
    Right-side: Shows a preview of how the selected SVG image will appear after being imported into Scene Composer.
    In the current version of Scene Composer, the previewed size may not always match the size of the original SVG image.
    (4)
    Error Message:
    If the selected file contains any warnings or errors, the corresponding message will be displayed in this area.
    (5)
    Import/Cancel:
    Import: Imports all items listed in the Importing List.
    Cancel: Cancels the import operation
