Import Dialog Options
This section describes the configuration of the importImport dialog that appears when importing resources such as FBX files, images, shaders, fontsfonts, or scripts.
The specificavailable options available inwithin the dialog may vary depending on the type of asset being imported.
Import Dialog
| 1 |
Comparison:
Green: A new resource will be added. |
| 2 |
Save Report…: Generates and saves a report file (CVS format) summarizing the comparison results for the imported files. The report name and save location can be specified in the dialog |
| 3 |
Select Files…: Opens a dialog that allows you to |
| 4 |
Folder: Select the destination folder for imported files. Use the drop-down menu or the Browse button to select any location in the Solution Explorer as root folder for the import destination. By default, the root folder /Resources is selected. |
| 5 |
Create new folder for import:
| 6 |
Delete existing items in destination folder:
| 7 |
Preserve imported folder structure: This option is available only when importing Image or 3D model file types, and it can be enabled only *Note: This option is not |
| 8 |
Visible in imports panel:
| 9 |
Preserve library item attributes: This option allows you to retain specific item attributes
- - Vertex buffer properties:
When |
| 10 |
Set bitmap profile:
Bitmap profiles can - From the menu bar: Solution > Solution Options... - From the Properties panel, which appears when |
| 11 |
Import as wireframe: This option is available only when importing FBX files. When enabled, a wireframe vertex buffer is |
| 12 |
Set the "Is Indexed" property of the vertex buffer to enabled: This option is |
| 13 |
OK button: Imports the selected resources using the configured settings. |
| 14 |
Cancel button: Closes the dialog without performing the |
| 15 |
Radiance HDR Format: Available formats include:
In an OpenGL ES 2.0 environment, none of the fiveavailable Radiance HDR Format options (RgbFloatingPoint9E5PixelFormat / RgbFloatPixelFormat / RgbHalfFloatPixelFormat / RgbaFloatPixelFormat / RgbaHalfFloatPixelFormat) are supported. If your solution contains any of these formats,formats are present in the solution, a warning is showndisplayed in the Problems panel.
SVG Importer Dialog
| (1) |
Import Settings Import to folder: Specifies the destination folder in the Solution Explorer where the SVG file will be imported. Create new folder for import
Importing List Displays the - Items that cannot be imported - Items that can only be partially imported Even if no icon is |
| (2) |
Add/Delete: Add: Adds |
| (3) |
Preview Display: Left-side: In the current version of Scene Composer, the previewed size may not always match the |
| (4) |
Error Message:
| (5) |
Import/Cancel: Import: Imports all items listed in the Importing List. |
