Recommended Layers Structure for Smart Importer
This page will explainexplains how best to set up items so that they and their internal group items are automatically detected as controls when importing Adobe Photoshop (.psd)/, Adobe XD (.xd)/, Figma (.fig) files withusing the Smart Importer.
Controls that can be automatically assigned are limited to those found in the TouchableTouchable, Common and CommonCore categories.
Creating Design Files
To automatically apply controls to group items in a design file and import them into Scene Composer, the group items must be created according to the recommended layer structure.
The recommended layer structure mainly targets the text-related and image-related properties of a control. In the design file, by creating layers corresponding to these properties and assigning them the same names as the property names, the layers can be automatically mapped by the Smart Importer.
The following sections describe the specific creation steps in detail.
For Adobe Photoshop(.psd)Files
- Create a group item for the control to be assigned and name it "SC_<
name of controlControlName>". In the example below, in order to make a TextButton control, the top layer has been named "SC_TextButton" (see blue box). - Make property layers that the
desiredcontrol contains underneath the group itemmadecreated in step 1 (see red and green boxes).
These properties include text-related properties (e.g., Text, FirstText) and image-related properties (e.g., NormalImage, PressedImage). - Use the names of the control properties for the names of these
photoshopPhotoshop layers. Note that any spaces in photoshop layer names should be deleted (see green boxes for comparison)
By naming a group item in the design file as “SC_<ControlName>”, Scene Composer automatically recognizes and maps it as a control.
Therefore, it is not necessary to create layers for all text-related and image-related properties of the control. Even if only the required properties are created as layers, the control will still be applied correctly.
After observing the above method, select the finished photoshop file from the Scene Composer toolbar [Import] > [Smart Importer] > [From Local File...]. The Smart Importer panel will open, and the file will be loaded in line with the .psd file layers that were set. As seen in the image below, the TextButton control has already been confirmed and subsequently applied.
This will also be reflected on the property panel after importing is complete.
The size of the imported control will conform to the width and height of the largest image layer applied.
When importing nodes with mismatching layers and properties, new group nodes are created, and additional properties are added as child elements.
For Adobe XD(.xd)Files
The preparation needed for .xd files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Adobe XD items to match the structure and property names of controls to be automatically applied.
For Figma(.fig)Files
The preparation needed for .fig files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Figma items to match the structure and property names of controls to be automatically applied.
Layer Structure and Naming Guideline for Controls
Touchable
ButtonSC_Button
├ NormalImage
├ PressedImage
└ FocusImage
CheckBox
SC_CheckBox
├ Text
├ NormalImage
├ PressedImage
├ SelectedImage
├ SelectedPressedImage
└ FocusedImage
MultiStateButton
SC_MultiStateButton
├ Text
├ StateImages0
├ StateImages1
├ StateImages2
└ StateImages3
ToggleButton
SC_ToggelButton
├ FirstText
├ SecondText
├ FirstImage
├ FirstPressedImage
├ SecondImage
└ SecondPressedImage
Common
- AnalogClock
- ├ SecondsNeedleImage
- ├ MinutesNeedleImage
- ├ HoursNeedleImage
- └ FaceImage
Gauge
SC_Gauge
- ├ BackgroundImage
└ NeedleImage
Menu Icon
SC_MenuIcon
- ├ Image
- └ BackgroundImage
Mesh2D
SC_Mesh2D
└ Image
Core
ImageCoreDial
SC_CoreDial
├ KnobImage
├ BackgroundImages0
├ BackgroundImages1
└ BackgroundImages2
SC_CoreTextButton
├ NormalImage
├ PressedImage
├ DisabledImage
└ Text
CoreRadioButton
SC_CoreRadioButton
├ Text
├ NormalImage
├ SelectedImage
├ NormalDisabledImage
└ SelectedDisabledImage
CoreSlider
SC_CoreSlider
├ TrackImage
├ TrackDisabledImage
├ TrackFillImage
├ TrackDisabledFillImage
├ KnobNormalImage
├ KnobPressedImage
└ KnobDisabledImage
