Recommended Layers Structure for Smart Importer
This page explains how to set up items so that they and their internal group items are automatically detected as controls when importing Adobe Photoshop (.psd), Adobe XD (.xd), Figma (.fig) files using the Smart Importer.
Controls that can be automatically assigned are limited to those in the Touchable, Common  and Core categories.
Creating Design Files
To automatically apply controls to group items in a design file and import them into Scene Composer, the group items must be created according to the recommended layer structure.
The following sections describe the specific creation steps in detail.
For Adobe Photoshop(.psd)Files
Controls can be created from Photoshop layer data as follows:
  1. Create a group item for the control to be assigned and name it "SC_<ControlName>". In the example below, in order to make a TextButton control, the top layer has been named "SC_TextButton" (see blue box).
  2. Make property layers that the control contains underneath the group item created in step 1 (see red and green boxes).
    These properties include text-related properties (e.g., Text, FirstText) and image-related properties (e.g., NormalImage, PressedImage).
  3. Use the names of the control properties for the names of these Photoshop layers. Note that any spaces in photoshop layer names should be deleted (see green boxes for comparison)
By naming a group item in the design file as “SC_<ControlName>”, Scene Composer automatically recognizes and maps it as a control.
Therefore, it is not necessary to create layers for all text-related and image-related properties of the control. Even if only the required properties are created as layers, the control will still be applied correctly.
After observing the above method, select the finished photoshop file from the Scene Composer toolbar [Import] > [Smart Importer] > [From Local File...]. The Smart Importer panel will open, and the file will be loaded in line with the .psd file layers that were set. As seen in the image below, the TextButton control has already been confirmed and subsequently applied.
Each property on the Appearance and Basic Property tabs will also reflect the layers that were set in the .psd file.
This will also be reflected on the property panel after importing is complete.
The size of the imported control will conform to the width and height of the largest image layer applied.
When importing nodes with mismatching layers and properties, new group nodes are created, and additional properties are added as child elements.
For Adobe XD(.xd)Files
The preparation needed for .xd files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Adobe XD items to match the structure and property names of controls to be automatically applied.
For Figma(.fig)Files
The preparation needed for .fig files is for all intents and purposes the same as with 「For Adobe Photoshop(.psd)Files」. As seen below with the TextButton example, structure the Figma items to match the structure and property names of controls to be automatically applied.
Layer Structure and Naming Guideline for Controls
Touchable
  • Button
    SC_Button
    ├ NormalImage
    ├ PressedImage
    └ FocusedImage
  • CheckBox
    SC_CheckBox
    ├ Text
    ├ NormalImage
    ├ PressedImage
    ├ SelectedImage
    ├ SelectedPressedImage
    └ FocusedImage
  • MultiStateButton
    SC_MultiStateButton
    ├ Text
    ├ StateImages0
    ├ StateImages1
    ├ StateImages2
    └ StateImages3
  • ToggleButton
    SC_ToggelButton
    ├ FirstText
    ├ SecondText
    ├ FirstImage
    ├ FirstPressedImage
    ├ SecondImage
    └ SecondPressedImage
Common
  • AnalogClock
     SC_AnalogClock
      ├ SecondsNeedleImage
      ├ MinutesNeedleImage
      ├ HoursNeedleImage
      └ FaceImage
  • Gauge
    SC_Gauge
      ├ BackgroundImage
      └ NeedleImage
  • Menu Icon
    SC_MenuIcon
      ├ Image
      └ BackgroundImage
  • Mesh2D
    SC_Mesh2D
      └ Image
Core
  • CoreDial
    SC_CoreDial
      ├ KnobImage
      ├ BackgroundImages0
      ├ BackgroundImages1
      └ BackgroundImages2
  • CoreTextButton
    SC_CoreTextButton
      ├ NormalImage
      ├ PressedImage
      ├ DisabledImage
      └ Text
  • CoreRadioButton
    SC_CoreRadioButton
      ├ Text
      ├ NormalImage
      ├ SelectedImage
      ├ NormalDisabledImage
      └ SelectedDisabledImage
  • CoreSlider
    SC_CoreSlider
      ├ TrackImage
      ├ TrackDisabledImage
      ├ TrackFillImage
      ├ TrackDisabledFillImage
      ├ KnobNormalImage
      ├ KnobPressedImage
      └ KnobDisabledImage
