Pollen Infoscreen
IMPORTANT: Please request a new API key to use in the associated script (see collapsible block below).
For more info on the deployment on HW please check our Target Setup Guide.
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality – text value
  • DayRisk control (4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
  • City Button (triggers location list)
  • Insights Button (switches to contaminants list scene)
Insights scene
ContaminantListElement control – List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk
PollenBrief
MultihourValue
ContaminantLevel
ContaminantName
ContaminantsListElement
Contaminant
Country
City
Contaminants_List
GroupBox_List
Scenes
Overview Scene
Insights Scene
TopBar Scene
BottomBar Scene
ContaminantList_Popup Scene
Location_popup Scene
Other elements
Below you can find more information on the remaining elements not belonging in the controls and scenes chapter.
Associated script (WebAPI)
State Machine
Animations
