Pollen Infoscreen
IMPORTANT: Please request a new API key to use in the associated script (see collapsible block below).
For more info on the deployment on HW please check our Target Setup Guide.
Overview scene:
Dynamic Elements:
  • Clock control
  • Air Quality –– text value
  • DayRisk control (4 week days)
  • Pollen_Brief control (level of preselected contaminant, with 4 levels, triggers list of contaminants)
  • City Button (triggers location list)
  • Insights Button (switches to contaminants list scene)
Insights scene
ContaminantListElement control –– List element, composed of other controls:
  • ContaminantName control
  • 4 x ContaminantLevel
Controls
DayRisk
PollenBrief
MultihourValue
ContaminantLevel
ContaminantName
ContaminantsListElement
Contaminant
Country
City
Contaminants_List
GroupBox_List
Scenes
The app has 2 main scenes, the “Overview”“Overview” and the “Insights”“Insights” scene, and can switch between them using the buttons on the bottom bar. The “TopBar”“TopBar” and “BottomBar”“BottomBar” scenes are always loaded and visible. For selecting items from lists, there are also two smaller scenes always loaded, and their visibility is controlled by triggering animations: “Location_Popup”“Location_Popup” and “ContaminantsList_Popup”“ContaminantsList_Popup”.
Overview Scene
Insights Scene
TopBar Scene
BottomBar Scene
ContaminantList_Popup Scene
Location_popup Scene
Other elements
Below you can find more information on the remaining elements not belonging in the controls and scenes chapter.
Associated script (WebAPI)
State Machine
Animations
