Sauna Screen
Please note that due to the display size the solution - when opened with the player - may exceed your computer screen. To adjust the size of the solution please use the "Zoom" options of the player CGI Panel.
Feature Description
| (3) | OptionScene2D | This scene acts as the main control interface of the sauna automation solution, providing access to different sauna modes such as Sauna, Steam, Infrared, and My Sauna. Each mode is represented through an interactive tile-based layout for simplified navigation between functionalities. In addition, the scene provides real-time environmental monitoring, where temperature and humidity values are displayed through circular indicators. |
| (4) | SaunaScene2D |
This scene handles sauna temperature control through a circular slider–based interface, allowing dynamic adjustment of the sauna environment. It also includes predefined session timing options. In the lower mid section controls for lights (including brightness and RGB settings), ventilation and music can be found. The individual menus can be cycled through via the available navigation arrow controls or swiped through by touch control. |
| (5) | InfraredScene2D | In addition to the features described for (4) SaunaScene2D this scene also includes panel selection options to enable the users to tailor their infrared experience to their needs. |
| (6) | SteamScene2D | In addition to the features described for (4) SaunaScene2D this scene also includes a separate circular slider for adjusting the steam level according to the users' needs. |
| (7) | MySaunaScene2D | This scene provides personalized sauna configuration management through preset-based controls. It allows selection between multiple preset profiles, enabling quick access to predefined sauna, steam and infrared settings and preferences. The interface enables quick transition between customized sauna profiles while maintaining a clean and interactive layout. |
| (8) | Preset1Scene2D | This scene manages a predefined sauna configuration profile through dedicated controls for temperature, humidity, session timing, and ventilation management. The parameters can be modified dynamically to customize the sauna environment based on the selected preset configuration. Ventilation control and preheating functionality are also integrated to prepare the infrared environment before the session begins. |
| (9) | Preset2Scene2D | This scene is similar to Preset1Scene2D but features settings tailored more for a steam experience. |
| (11) | RunningScene2D | This scene provides real-time monitoring and management of the active sauna session by displaying essential operational parameters such as temperature, humidity, selected sauna mode, door status, and configured session duration. The interface presents all session-related information in a centralized layout for continuous tracking of the sauna environment during operation. A session countdown indicator is provided to display the remaining session duration before completion. Additionally, a dedicated stop control allows immediate termination of the active sauna session whenever required. |
| (12) | PreheatingScene2D | This scene manages the sauna preheating process by monitoring and displaying the progress of the heating cycle. It provides target temperature tracking functionality, allowing the system to indicate the current progress toward the configured sauna temperature before the session begins. A real-time countdown display is provided to show the remaining preheating duration, helping monitor the estimated time required for the sauna environment to reach the desired condition. A dedicated stop control is integrated into the interface to allow interruption or cancellation of the preheating operation whenever required. |
Controls
- An own control was created for the circular sliders in the SaunaScene2D/SteamScene2D/InfraredScene2D, that extends the existing CircularSlider control with the background image and the slider value text and unit.
- As the same lists for the settings are displayed in SaunaScene2D/SteamScene2D/InfraredScene2D, it is also provided as control.
Transitions
Transition rules were used with Fade-shade animations are applied to the scene transitions to create smooth and continuous visual movement between Scenes.
Animations
The following two animations are used:
- TimeRemaining: decreases the remaining time displayed in the PreheatingScene2D
- PreheatPulsatingAnimation: takes care of the pulsating of the red background in the BackgroundScene2D.
Both animations are started in the Statemachine when the "Start Preheat" button in the SaunaScene2D is pressed.
State Machine
Operational Control Elements
