Manage Nodes
Copying and Moving Scene Nodes
A scene is composed of individual scene nodes. They may originate from the Toolbox panel or the Imports panel.
During solution development, you may need to divide a single scene into multiple smaller scenes or merge elements from several scenes to maintain a structured and manageable solution. Instead of recreating nodes manually, you can copy and paste existing nodes into any other scene as needed.
To copy and paste a node, follow the steps below:
  1. In the Scene Tree or Scene Editor, select the desired item(s).node.
  2. Right-click on your selection.
    • The context menu is opened.
  3. Choose Copy from the context menu.
  4. Switch to the target scene.
  5. In Scene Tree or Scene Editor, right-click where you want the copied itemnode to be placed.
    In
    Within the Scene Tree,Tree, you can also navigate to e.g. a specific node - such as a GroupNode where- youand cantright-click it to paste the copied element directly into that node.
    Choose Paste from the context menu
      The copied item tois bepasted. placed..
      Second,You switchcan also use the following keyboard shortcuts to theperform desiredcopy, scenecut and right-clickpaste on the main node in the Scene Tree. Then select the Paste option. The desired element will be copied into the selected scene.operations:
      Another
      similar possibility is to get the desired nodes by using Cut option and to paste them into the new scene. The usual combos are available: Ctrl + cC for... Copy,Copy Ctrl + xX for... Cut and Ctrl + vV for... Paste.Paste
      UponDuring copy/cut/copy, cut or paste operations, the SceneComposerScene willComposer allowexecutes the requested action and reports any operationresulting anderrors displayor awarnings. setThese ofmessages errors/warningsmay dependinginclude onissues thesuch raised violations (e.g.as missing references, badinvalid pathspaths, andor soother forth).dependency violations.
      It is possible to select and tocopy, cut/copy/paste twocut or morepaste Nodesmultiple onlynodes ifsimultaneously, theyprovided arethat all selected nodes reside at the same level inwithin the scene hierarchy. By using Ctrl + C shortcut it is possible to copy the path of any selected object together with all the properties to the clipboard. The path can be copied directly in the Properties panel.
      Clone, Delete,Delete and Rename Scene Nodes
      Clone
      CloneYou can clone a scene node viausing the "Clone"Clone option from the context menu.menu Thefollowing clonethe ofsteps below:
        Right-Click on the item willyou havewant to clone.
          The context menu opens. Select Clone from the samecontext menu
            The Clone Item dialog appears, as shown below. Enter a name asfor your clone (or accept the item,provided suffixedname) and confirm by aclicking number,OK. and
            willThe becloned placeditem is created in the same group or scene.scene as the original.
            If there is necessary to realize manymultiple clones of the same item,item are required, use the "Multiple Clone"Clone option shouldas described here:
              Right-Click on the item you want to clone.
                The context menu opens. Select Clone from the context menu
                  The Clone Item dialog appears, as shown below. Switch to the Multiple Clone tab.
                    The Clone Item dialog is displayed as shown below. Enter a base name for your clone (or accept the provided name) and the number of clones to be used.created. AsConfirm canby beclicking seenOK.
                      The cloned items are created in the imagesame below,group or scene as the useroriginal.
                      has just to specify
                      the
                      "Base Name" of all the clones and how many copies are needed.
                      When cloningcreating multiple clones (or pasting a copied node), the system automatically checks whether the node's name ofends with a numeric suffix. If a number is present, it is incremented for the new nodenode.
                      will automatically check if there is already a number at the end of the name. If there is a number this should be increased automatically.
                      For instance,example:
                      if
                      anCloning existingNode_1 "Node_1"results (orin "Node1")Node_2, isNode_3.... clonedCloning theNode1 nameresults ofin theNode2, cloneNode3.....
                      will be "Node_2" (or "Node2") and not "Node_1_1" (or "Node1_1").
                      The duplication of the item names is incremented based on the numeric suffix with our without an _ separator.
                      To duplicate an item intoin the selected locationlocation, hold left shiftLeftShift while dragdragging and dropping anthe item.  UponWhen droppingyou release the mouse button, a copy of the item will beis created inat the target location.
                      Currently
                      Note that duplicating an item as a child of itself is currently not supported.
                      Delete
                      Delete aA scene node viacan be deleted using the "Delete"Delete option in the context menu.
                      menu
                      or
                      by
                        Ifpressing the itemDelete iskey noton usedyour anywhere,keyboard. a
                        Special simplecare prompt to confirm the deletion will appear.
                        If the item is used in an animation, the "Delete Item" dialog willmust be opentaken andwhen list the paths of thedeleting items fromthat thehave animationdependencies. whereAdditional thedetails sceneon nodehandling isdependent used.items The "OK" button is disabled so the scene node cannotcan be deleted.found
                        here
                        Rename
                        Rename aA scene node viacan be renamed using the "Rename"Rename contextoption menu.
                          Item is not used anywhere; the renaming will take place as the user presses Enter key after editing. Item with same name already exists (in the samecontext location);menu warningor messageby popspressing up.F2.
                          Revert
                          Properties
                          to
                          Default
                          Value
                          Properties of the instance items can also be modified in the user defined scene. Properties thatpanel. haveIf beennecessary, changedany modified property can be resetrestored to theirits default value inusing the templateRevert item by clicking the "revert" button on(see theimage left of the property to be restored.below).
                          The first change of a property from the value from the template will cause the name of the property and its value to appear in bold in the "Properties" panel of the main view.
                          Reset Node Structure
                          Groups which have been created from a template item (an imported scene graph) can be resetrestored to thetheir original template structure withby using the Reset Structure option in the context menu "Reset Structure" onof the group:group.
                          DeletedWhen this action is performed, any delete or modified elements within the group elements will beare restored to thetheir default structure.template configuration.
                          Multi-Selection and Comparison of Nodes
                          1. For multi-selection of nodes, press the Ctrl key while left clicking all the desired elements to select. When the last desired element is selected the Ctrl key can be released.
                          2. To select a set of consecutive items, click the first item, press the Shift key while clicking the last item.
                          3. Another way is to use one of select options from the Scene Tree context menu for multi-selection:
                            • Select > Leaf Nodes
                            • Select > Children
                            • Select > All Descendants
                          Examples:
                          After the multi-selection operation it is possible to copy, move or delete all selected items as desired.
