SCML Tags > 2D Scene Tags
2D Scene Tags
Tag name Property Property type Supported Values/Types
Anchor2D AnchorDef String
Full name of the anchor definition from the composite which is used by this anchor node.
Position Vector2
Position of the object in local coordinate space.
Rotation Float Null
Rotation of the object in local coordinate space.
Scale Vector2
Scale factor of the object in local coordinate space.
Pivot Vector2
Pivot offset is the distance between the pivot point - defined by the "Position" property - and the origin of the element's bounding rectangle (upper left corner). The pivot point is used as center point for rotation and scaling.
BoundingRectangle Rectangle
The axis-aligned bounding rectangle in local coordinate space.
RenderOrderRank SByte Null
By using the render order rank we can set the order of two or many nodes (with values on a range from -128 - the farthest render node - to 127 - the nearest node).
LayoutProperties LayoutProperties
Layout properties
AlphaValue Float Null
Defines the local alpha transparency value between 0 and 1 for the node. The effective alpha value is combined with the materials alpha value of the node.
IsRenderingEnabled Boolean Null, True, False
Defines if node is rendered or not at both, design-time and run-time. If disabled, also descendants are not rendered.
ScopeBits UInt32 Null
Assigns node to scope(s) specified. If specified recursively, this setting is applied to all descendants as well. A scope forms conceptual groups independent of the scene graph hierarchy used e.g. for visibility and light culling. Visibility Culling: Node is rendered only if in same scope of camera. Light culling: Node is illuminated only if in same scope as light.
ScriptComponentCollection ISCItem
IsTemplate Boolean Null, True, False
If set then the object can be a template for the creation of other objects.
Id UInt32 Null
SymbolicName String
Symbolic names are translated to Ids in Candera, so they must be valid C++ identifiers. C++ identifiers can contain letters, numbers, and underscores. They must start with either a letter or an underscore.
TemplateName String
The path to the imported artifacts that serve as source.
Name String
The name of the object.
KnownTemplateNodes Collection
Collection of templates nodes that are known to the instance. This property is used when comparing the insatnce with its template to decide which nodes are new and which were deleted explicitly.
dyn Collection
Description String
Description of this item.
PreserveSCMLDocumentFormattingScope PreserveSCMLDocumentFormattingScope Null, Global, Local
Indicated the scope for the Preserve SCML Document Formatting property
PreserveSCMLDocumentFormatting Boolean Null, True, False
The formatting of the SCML documents will be preserved only if it is set to true, otherwise the formatting will be reset when the solution is saved
IsLocked Boolean Null, True, False
Indicates if this item is locked.
AnchorDefinition Node String
When expanding the composite node the content of the anchor will be put in this node.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Camera2D RenderTargetName String
Name of the render target the camera renders to
Viewport Rectangle
The viewport describes an rectangular area that is updated within the associated render target. The viewport position and size are given in pixels.
IsColorClearEnabled Boolean Null, True, False
Defines if camera shall clear the color buffer with the clear color before it renders.
ClearColor Color
If color clear is enabled, the clear color is applied to color buffer before camera is rendered (background color). The area cleared is defined by the viewport.
IsScissoringEnabled Boolean Null, True, False
ScissorRectangle Rectangle
The scissor rectangle specifies a rectangular region within the Camera's RenderTarget. The scissor rectangles position and size are given in pixels. A scissor rectangle that intersects the RenderTarget is allowed. If scissoring is enabled (see IsScissoringIsEnabled) pixels outside of the intersection area of viewport and scissor rectangle are clipped.
SequenceNumber Int16 Null
Defines the position of the camera in the sequence of concurrently rendered cameras. A camera with lower sequence number is rendered before a camera with higher sequence number.
IsSwapEnabled Boolean Null, True, False
Enables or disables a swap of Camera's render target after rendering has been processed.
IsRenderingInDisplayDesignEnabled Boolean Null, True, False
Indicates if the rendering is enabled in the Display design
PreviewScissoringScope PropertyValueScope Null, None, Global, Local
PreviewScissoringColor Color
Position Vector2
Rotation Float Null
Scale Vector2
Pivot Vector2
Layout properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Composite IsCanvasComposite Boolean Null, True, False
Indicates is the Composit is of type Canvas.
RenderOrderBins Collection
Collection of the render order bins
EditorClearColorScope EditorClearColorScope Null, None, Global, Local
Scene editor clear color scope
EditorClearColor Color
Indicates the background color used with the scene editor camera.
Widgets Collection
Collection of widgets
EditorProfile String
The Editor Profile associated to the scene
Theme String
The theme.
Anchors Collection
Uniform setter.
CompositeProperties Collection
Collection of composite properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Composite2D HorizontalGuidelines FloatArray
The horizontal guidelines displayed in the render panel. Drag a new one from the ruler. Drag an existing one outside the panel to remove it.
VerticalGuidelines FloatArray
The vertical guidelines displayed in the render panel. Drag a new one from the ruler. Drag an existing one outside the panel to remove it.
DesignMasterScope PropertyValueScope Null, None, Global, Local
Configures the Design Master image for this scene. Either the global setting or another bitmap from the solution can be used.
DesignMasterImage String
Bitmap used as a background during scene editing.
DesignMasterPosition DesignMasterPosition Null, Background, Foreground
Display layer of the Design Master image (Foreground/Background).
DesignMasterOffset Vector2
Display position of the Design Master image (X/Y coordinates).
DesignMasterTransparency Float Null
Transparency of the Design Master image.
Widgets Collection
Theme String
The theme.
Anchors Collection
Uniform setter.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositeNode CompositeName String
The name of the composite
CompositeProperties CompositeProperties
The dinamic properties of the node
Transform Matrix4
Local generic transformation matrix multiplied with local position, scale and rotation. It can be used for transformations that can not be expressed using the component form.
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
The geometric center of the node. The center and the radius of an object describe a bounding sphere.
Radius Float Null
The radius of the bounding sphere, whereas the center defines the geometric center of the node.
BoxLowerLeftBackVertex Vector3
The minimum bounds vector of axis-aligned bounding box (lower left corner).
BoxUpperRightFrontVertex Vector3
The maximum bounds vector of axis-aligned bounding box (upper right corner).
IsIntersectionTestEnabled Boolean Null, True, False
Defines if intersection test is enabled in SceneComposer for picking and as well as at run-time. If disabled, the effective intersection test is disabled for all descendants as well.
RenderOrderBinName String
Name of the render order bin the node is assigned to. If no name is specified, the node is assigned automatically either to opaque or transparent render order bin, depending if node has blending enabled or not.
RenderOrderRank Int32 Null
Defines the render order rank. The node is sorted by rank if assigned to a dedicated render order bin with a RankOrderCriterion applied.
RenderBenchmark Float Null
Set the render measure value of this Node, which is a benchmark related to rendering time, typically calculated by external tool and utilized by a camera render strategy.
NodePreviewType NodePreviewType Null, Normal, Wireframe
Node preview type allows the user to change the representation of the solid objects in the SceneEditor. There are two modes available: normal (solid) and wireframe (line representation). Wireframe mode applies for meshes, morphing meshes, planar shadows and billboards.
AppearanceCollection ISCItem
The collection of appearances.
NodeObject_ScripComponentCollectionPropertyTooltip
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositeNode2D CompositeName String
The name of the composite with the path
Position Vector2
Rotation Float Null
Scale Vector2
Pivot Vector2
Layout properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositeProperties Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
CompositePropertyDefinition Widget String
Full name of the widget in the composite.
WidgetProperty String
The name of the widget property
SourceItem String
SourceProperty String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
DynamicProperty Name String
Name
Value String
The value of the dynamic property
Type String
The type of the dynamic property
CompositePropertyDefinition String
Name of the composite property definition.
Effect Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Gizmo IsTemplate Boolean Null, True, False
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Group Transform Matrix4
Position Vector3
Rotation Vector3
Scale Vector3
Center Vector3
Radius Float Null
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Group2D Layout ILayout
The layout.
Position Vector2
Rotation Float Null
Scale Vector2
Pivot Vector2
Layout properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderNode2D Effects Collection
Collection of effects
IsSnapToDevicePixelEnabled Boolean Null, True, False
Enable or disable snapping of translation to device pixels.
Position Vector2
Rotation Float Null
Scale Vector2
Pivot Vector2
Layout properties
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderOrderBin IsPredefined Boolean Null, True, False
Protected render order bin are maintained by Candera and cannot be deleted or removed.
IsSortingEnabled Boolean Null, True, False
Enables or disables the sorting of this bin according to the order criterion set.
Criterion RenderOrderCriterion Null, DistanceToCamera, ReverseDistanceToCamera, RenderOrderRank, ReverseRenderOrderRank, BatchOrder
The order criterion specifies according to which sorting criteria the nodes in a render order bin are sorted.
BatchOrder BatchOrderCriterion Null, SortByShaderAndRenderMode, SortByAppearance
The batch order criterion specifies according to which sorting criteria the nodes in a render order bin are sorted.
DistanceFunction RenderOrderDistanceFunction Null, CameraPositionToBoundingSphere, CameraPositionToBoundingBox, ViewPlaneToBoundingSphere, ViewPlaneToBoundingBox
Determines how the distance from camera to any node is calculated.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
RenderTarget Display String
The display of the render target
PreviewBorderScope PropertyValueScope Null, None, Global, Local
Configures the preview border for this object. It can be used from the global preferences.
PreviewBorderColor Color
Configures the preview border color for this object.It can be used from the global preferences.
Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Scene RenderOrderBins Collection
Widgets Collection
Theme String
The theme.
Anchors Collection
Collection of anchors
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Scene2D HorizontalGuidelines FloatArray
Widgets Collection
Theme String
The theme.
Anchors Collection
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Theme IsTemplate Boolean Null, True, False
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
ThemeEntry Interface String
Full name of the theme entry interface implemented by this this entry.
EntryItem String
The item in the solution which will be used by all clients of this entry. If entry item is null, the master theme will be used. The master theme can not contain any empty entries.
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
Widget WidgetNodeName String
The name of the node associated to the widget
Definition String
Id UInt32 Null
SymbolicName String
TemplateName String
Name String
dyn Collection
Description String
