CGI-Player Launcher
Requirements
This document mandates adherence to the Android Application Development Environment Setup Guide, as a prerequisite for system compliance.
The project requirements
  • CGI-Player Launcher Android application uses the Android Gradle Plugin version 7.2.18.9.1+ and Gradle version 7.3.38.11.1.
  • A customNDK NDK 2626.1.10909125 is required, as described in the Android Native Development Kit (NDK) chapter.
  • CMake 3.22.1 is required as described in the CMake chapter.
  • Eclipse Temurin JDK 1117 is required as described in Java Development Kit (JDK) chapter.
  • Supported API levels: 23–2831–36 (The application is compatible with later Android versions up to API 36 on Android 16).
  • Supported ABIs: arm64-v8a, x86_64, x86
  • The CGI-Player Launcher Android application integrates the NativeView library, which is provided externally from ../libs/nativeview-lib and already imported into the project.
1. Substitute the CGI Studio root as described in the windows-commands/subst article.
Open a Command Prompt in the CGI Studio root directory (e.g., “...\cgistudio”) and type:
subst x: .
Press enter. The CGI root is now available under the X: drive in Windows Explorer.
2. Open the Android Application:
    • Open local.properties.sample file from the root of the Android application.
    • Copy the content of the sample to the local.properties file in the root of the Android application.
    • Update the USERNAME in the SDK and NDK paths to match your system.
    • How the asset can be loaded is described in the Asset Configuration block.
    • Set the ABI to the target CPU architecture under the Target ABI block.
    • If you need Vulkan support, change angle_vulkan=off to angle_vulkan=on in local.properties.
    • Save local.properties and sync project with Gradle files (Ctrl+Shift+O).
Note: If the SDK or NDK paths do not exist, Android Studio may reset local.properties after syncing the project with Gradle files.
4. Create an Android asset
Run the following batch file:
    •  Choose an asset template (e.g., “3D Basic”) and save this as Test.bin
      • If from sdcard: to the /sdcard/ directory of the target or emulator. In Android Studio, this can be done in the "Device Explorer" of the target or emulator.
      • If from APK: to the following folder:
5. Build variant:
    • In Android Studio, open [View | Tool Window | Build Variants].
    • In the Build Variants tool window, select debug or release under Active Build Variant.
6. Run the application:
    • Select the target device or emulator in Android Studio.
    • Click Run (the play button)
    • The first time the Application starts, it will request permissions. Accept and restart the application.
    • The assets are loaded from the location that is set in the Asset Location option in the application.
    • The desired asset can be clicked on and the asset should be running.
The asset path can be found in the CGI-Player Launcher app. Replace the asset path and asset filename in the command. Use this method to start the CGI-Player Launcher and open a selected asset from cmd:
7. APK
After the application is running, the current built APK can be found in the build directory. This can located by opening [Build | Analyze APK]. The usual directory would be:
Troubleshooting
Platform Tests
  • Google Pixel C, ARM Cortex A57, Android 8.1.0, API 27
  • Huawei MediaPad M5, ARM Cortex A73, Android 9, EMUI 9.1.0, API28
  • Emulator Pixel 2, x86_64, Android 6, API 23 (Without Play/APIs)
  • Emulator Medium Phone, x86_64, Android 9, API 28 (Without Play/APIs)
  • Emulator Pixel 2, x86, Android 9, API 28 (Without Play/APIs)
  • Emulator Google Pixel Tablet, x86_64, Android 14.0, API 34
  • Emulator Google Pixel Tablet, x86_64, Android 16.0, API 36
  • Emulator Google Pixel 9 Pro XL, x86_64, Android 16.0, API 36
