Configuration and System Requirements
Android application on Windows 10/11. Remember to restart your system after making changes related to CMake
Operating System
Ensure that your development machine is running Windows 10/11. This guide has been refined to work on Windows 10/11. Other Operating Systems might work, but are not supported.
Android Studio
For this guide, Android Studio Narwhal 4 Feature Drop | 2025.1.4 have been tested and confirmed to work. Android Studio can be downloaded from the official Android Studio archive: https://developer.android.com/studio/archive.
Android Studio Emulator
When using the Android Studio Emulator for testing, ensure that the Android version and ABI match those of the Android application. Additionally, make sure that, for the emulator, the OpenGL ES API level (requires a restart) is set to "Renderer maximum (up to OpenGL ES 3.1)." This OpenGL ES API level can be configured in the Android Studio Emulator's Extended Controls.
Android Software Development Kit (SDK)
After installing and setting up Android Studio, the SDK path has to be added to the System Environment Variables under the User Variables. After saving make sure to restart the system to apply the changes correctly.
- Variable Name: ANDROID_HOME
- Variable Value: %LOCALAPPDATA%\Android\Sdk
Android Native Development Kit (NDK)
- In Android Studio, open [Tools | SDK Manager | SDK Tools | enable NDK (Side by side) | then click Show Package Details and select version
26.1.10909125]28.0.13004108]. - Click Apply / OK to install.
NDK will be automatically installed at:
C:\Users\<your-username>\AppData\Local\Android\Sdk\ndk\
26.1.1090912528.0.13004108
Java Development Kit (JDK)
The JDK can be downloaded and used within Android Studio directly. For Android Applications we make use of the Eclipse Temurin 17. When the Android Demo Application has been opened with Android Studio, the Android JDK should be set. On the specific Android Application wiki page the used JDK version is written down.
- In Android Studio, open [File | Settings | Build, Execution, Deployment | Build Tools | Gradle].
- Choose Gradle JDK: Temurin-17 Eclipse Temurin Version 17.0.18.
If this version is not available in the dropdown, download it by clicking on “Download JDK…” in the dropdown of Gradle JDK.
Ninja
The "ninja" version used is 1.10.2 and can be downloaded from https://github.com/ninja-build/ninja/releases/download/v1.10.2/ninja-win.zip. Copy "ninja.exe" to "C:\Programs\" and add this path "C:\Programs\" to the Environment Variables -> System Variables -> Path.
CMake
For the current Android demo applications that use the NativeView approach (e.g., NativeViewLibrary and AndroidCgiPlayerLauncher), we rely on specific CMake versions.
- Up to CGI 3.14 -> CMake 3.10.2 is used
- From CGI 3.15 -> CMake 3.22.1 is used
- The supported CMake version can be also found in the Android application module (app) build.gradle.
These CMake versions can be installed directly through the Android Studio SDK Manager.
- In Android Studio, open [File | Settings | Languages & Frameworks | Android SDK] and navigate to the SDK Tools tab.
- Click on Show Package Details on the bottom right of the page.
- In the list, make sure only CMake 3.10.2 is selected and installed.
- After installing and closing the settings page, make sure to restart the system to apply the changes correctly.
Alternative CMake Approach
For applications other than the NativeView Library approach, (e.g. SampleApp) the '.so' library must be configured and generated with CMake outside of Android Studio. It should be built using 'ninja' with Windows CMD. We recommend using CMake 3.24.2, which can be installed through the CMake installer executable available for download on the official CMake website: https://cmake.org/download/. Once the build is complete, manually copy the '.so' library to the corresponding ABI directory in the project. Detailed configuration and build steps will be provided in the respective Android Application Wiki page.
Other Dependencies
Troubleshooting
- If encountering any issues during the setup, refer to the official documentation for Android Studio,
Environment tested with Android Applications
- NativeViewLibrary
- AndroidCgiPlayerLauncher
- SampleApp (Previously known as CourierSampleApp)
