RPi5 Target Setup Guide
Before you Begin
  • Explore CGI-Studio
    Read the Quick Start Guide.
Software Image Setup
  1. Download and install the Raspberry Pi Imager from this link (https://www.raspberrypi.com/software/)
  2. Open Raspberry Pi Imager and click on choose device.
  3. Click on Raspberry Pi 5.
  4. Next choose the OS and scroll to “Use custom.”
  5. Click Ok and browse for the downloaded .img file provided by Candera and open.
  6. Next choose storage and select the SD card 64gb which is inserted and click on next, this will take some time to flash OS on SD card.
  7. Now eject the SD card form Laptop/PC.
Flash OS on Raspberry Pi 5
  1. Insert the flashed SD card into Raspberry pi 5 board.
  2. Connect the Raspberry Pi board to a display, connect USB for touch, and insert SD card into Raspberry Pi board and switch on the power supply.
  3. OS will automatically start to install on Raspberry Pi.
  4. Once installed you can see OS UI on the display.
Connecting to the Raspberry Pi using SSH(WinSCP)
After booting, connect to the target device via a serial terminal (e.g. Tera Term) or SSH.
At Candera we have used WinSCP to transfer additional files to the target device as needed.
After this step, your target system will be prepared to run Python-based data binding examples or any assets using the CGI-Studio runtime environment.
The login credentials for the connection are -
Username: candera
Password: candera
NOTE : To get the IP address of the RPI5RPi5 once it is connected to LAN, connect RPI5RPi5 with a keyboard and press “Ctrl+Alt+F4”. This will open a window asking for username and password, put candera for both and enter the command “ip addr show”, this will show the ip address of the connected network. Once you connect to the network using WinSCP or tera-term, press “Ctrl+Alt+F1” to come back to main screen.
Blood Pressure Sample
  1. We have prepared several samples to demonstrate the capabilities of CGI-Studio on the target image. These samples are located at:
    /opt/candera/Samples/ on the target image and in <cgi-studio-installation-path>\bin\ProfessionalEdition\Python\Samples on the host computer.
  2. We will use the Blood Pressure Sample as an example to demonstrate how to run our samples. The Blood Pressure device sample is a Scene Composer sample that showcases a blood pressure measurement device with exemplary scenes and animations.
  3. For the Professional Edition, the sample was extended with a data binding sample programmed in Python. The Python part of the sample relies on the Python-based player data binding library to interact with the data bindings of the scene.
  4. In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Player Connector Library. For this chapter the completed “Image Setup” is required.
1. Navigate to the player directory.
cd /opt/candera/Player
2. Run the Asset
    Execute the below command in the terminal
./Player ../Samples/BloodPressureDevice/BloodPressureDevice.bin
3. The Asset will be visible on the target device.
Once the hardware is set up follow these steps to configure the Python environment and execute the sample.
  1. In Target open terminal and navigate to project directory
    Open the terminal on your Raspberry Pi and move to the specific sample directory:
    Command - cd /opt/candera/Samples/BloodPressureDevice
  2. Prepare the System Environment
    Before running the application, ensure the system package list is up to date and that the Python virtual environment module is installed:
    Commands -
    sudo apt update
    sudo apt install python3-venv
  3. Configure the Python Virtual Environment
    1. Create the environment:
    python3 -m venv .
    2. Activate the environment: source bin/activate
    source bin/activate
  4. Install Dependencies
    Install the required Python packages defined in the project's requirements file:
    Command -
  5. Configure Environment Variables
    For the application to locate the Candera libraries and GStreamer plugins, you must export the following paths.
    Important: These exports are session-specific. If you close the terminal, you will need to run them again.
    Commands -
    export PYTHONPATH=$PYTHONPATH:/opt/candera:/opt/candera/CanderaAppConnector:/opt/candera/Samples/BloodPressureDevice
    export GST_PLUGIN_PATH=/usr/lib/aarch64-linux-gnu/gstreamer-1.0
    export GSTREAMER_ROOT=/usr/lib/aarch64-linux-gnu/
  6. Run the Blood Pressure Sample
    Execute the main script by pointing it to the Player Connector library and the compiled asset file:
    Command  -
    python3 BloodPressureDevice.py -wsh -lbp /opt/candera/PlayerConnector/libPlayerConnectorLibrary.so -abp /opt/candera/Samples/BloodPressureDevice/BloodPressureDevice.bin
    Verification: Upon execution, the Blood Pressure Device UI should initialize and appear on your connected Raspberry Pi display.
    NOTE: If the display is portrait mode but if needs to be rotated to landscape mode.
    Command - sudo XDG_RUNTIME_DIR=/tmp wlr-randr --output DSI-1 --transform 90
Run Slider and Gauge Sample with Player Connector Library
           Command - cd /opt/candera/Samples/SliderAndGauge
    Commands -
    sudo apt update
    python3 -m venv .
    source bin/activate
  4. Configure Environment Variables
    Commands -
    export PYTHONPATH=$PYTHONPATH:/opt/candera:/opt/candera/CanderaAppConnector:/opt/candera/Samples/SliderAndGauge
  5. Run the Slider and gauge Sample
    Command  -
    python3 Sample.py  -lbp /opt/candera/PlayerConnector/libPlayerConnectorLibrary.so -abp /opt/candera/Samples/SliderAndGauge/SliderAndGauge.bin
    Verification: Upon execution, the Slider and gauge UI should initialize and appear on your connected Raspberry Pi display. The slider and gauge moves accordingly.
