Target Setup and First Steps
Before you Begin
- Explore CGI-Studio
Software Image Setup
The CGI Studio Community Edition supports both Raspberry Pi 4 and Raspberry Pi 5. The following section describes how you can install the Community Edition on your Raspberry Pi device. Additional information about the proper setup and configuration of a Raspberry Pi device can be found in the official Raspberry Pi documentation. It also contains information on how to get started with your Raspberry Pi device. Complete the following steps to prepare your Raspberry Pi for the installation of the CGI Studio Community Edition.
- Download and install the Raspberry Pi Imager from this
linklink:(https://www.raspberrypi.com/software/)Raspberry Pi software – Raspberry Pi. - Insert a compatible SD card into your computer for flashing the image.
Click
time.
FlashRaspberry OSPi Startup
This section outlines the initial hardware setup, booting, and first-time configuration process for setting up the operating system on a Raspberry Pi 54
or a Raspberry Pi 5.
- Insert the SD Card: Insert the flashed
SDmicroSD card securely intoRaspberrythepidedicated5cardboard.
Connect display,Hardware: connectConnect USB for touch, and insert SD card intoyour Raspberry Pi boardto an external display (using a micro-HDMI to HDMI cable), plug in your USB touch interface/peripherals or connect to DSI cable, and switch onconnect the official USB-C power supply.supply to power it on.
region, skip the Wi-Fi and connect LAN, and establish your core username and password. Boot to Desktop: Once you complete the wizard, the system will finalize its settings and boot directly into the desktop user interface. Once
Connecting to the Raspberry Pi using SSH(SSH (WinSCP)
After booting, connect to the target device via SSH or a serial terminal (e.g., Tera Term). orThis SSH.connection is required to transfer files and execute commands. Additional information on how to connect can be found here.
At Candera we haveuse used WinSCP to transfer additional files to the target device as needed.After this step, your target system will be prepared to run Python-based data binding examples or any assets using the CGI-Studio runtime environment.The login credentials for the connection are -Username: candera Password: candera
NOTE : To get the IP address of the RPi5 once it is connected to LAN, connect RPi5 with a keyboard and press “Ctrl+Alt+F4”. This will open a window asking for username and password, put candera for both and enter the command “ip addr show”, this will show the ip address of the connected network. Once you connect to the network using WinSCP or tera-term, press “Ctrl+Alt+F1” to come back to main screen.
device.
Blood Pressure Sample
Run Blood Pressure Sample aswith anTarget examplePlayer
The Blood Pressure deviceDevice sample is a Scene Composer sample that showcasesdemonstrates a blood pressure measurement device with exemplary scenes and animations.
Execute the following command on the Raspberry Pi device to run the sample wasusing our target player.
The Blood Pressure Sample sample is extended with a data binding sample programmed in Python. The Python part of the sample relies on the Python-basedBased playerPlayer dataData bindingBinding libraryLibrary to interact with the data bindings of the scene.
2. Run the Asset Execute the below command in the terminal
3. The Asset will be visible on the target device.
Once the hardware is set up follow these steps to configure the Python environment and execute the sample.
Follow
the Blood Pressure Sample with player connector library.
python -m venv .
Install
Install the required Python packages defined in the project's requirements
Run the applicationSample:
Execute the Blood Pressure SampleExecuteDevice python script using the mainfollowing scriptflags.
python BloodPressureDevice.py -wsh -lbp /opt/candera/PlayerConnector/lib/libPlayerConnectorLibrary.so \
-abp /opt/candera/Python/Samples/BloodPressureDevice/BloodPressureDevice.bin
-wsh
Verification: Upon execution, the Blood Pressure Device UI should initialize and appear on your connected Raspberry Pi display.
NOTE: If the display is portrait mode butthen ifit needs to be rotated to landscape mode.
Command - sudo XDG_RUNTIME_DIR=/tmp wlr-randr --output DSI-12 --transform 90
Run
Before proceeding with the example, it is recommended to explore CGI-Studio by reading the Quick Start Guide, both of which are available in the CGI-Studio Documentation.
In the Render Targets panel (on the right side of the SceneComposer), set the resolution of Display (0) to X Resolution (width) of 800 and Y Resolution (height) of 480.Drag and drop a Slider Control and a Gauge Control from the Control section of the Toolbox (on the right side of the Scene Composer) into the Scene Editor.
You can move the controls in the Scene Editor by selecting the translation icon (the red square in the screenshot below) in the top left corner of the Scene Editor and then selecting the control which you want to move. Just select the item you want to move and drag it to a new location.
Select the Gauge Control in either the Scene Editor or the Scene Tree, navigate to the properties, and adjust the scale to ensure it fits comfortably within the display.
To set up a data binding for the Gauge value, first select the Gauge either in the Scene Editor or the Scene Tree. In the properties panel locate the Value property under the Control section and click the chain icon next to it to establish the binding.
To set a data binding for the Slider property, select the Slider control in either the Scene Editor or the Scene Tree. Then, click the chain icon next to the Value property in the Control section of the Properties panel. Next, choose Item2 (under PredefinedBindingSource1) from the available options.
Next, generate an asset library for the target environment to run the solution in the player.
A popup window will appear, allowing you to generate the asset library. Choose your desired asset location, set the environment to “Target”, then click “Generate” to create each asset library.
Next, create a Python script. You can use the provided Sample.py file located in
<cgi-installation-path>\bin\CommunityEdition\Pythony\Samples\SliderAndGauge\Sample.py in your local CGI-Studio installation folder and in /opt/cgistudio/Python/Samples/SliderAndGauge/Sample.py on the target. Run the asset on the target device:
Run it analogous to the steps from chapter Run Blood Pressure Sample with Player Connector Library
