Target Setup and First Steps
Before you Begin
  • Explore CGI-Studio
    Read the Quick Start Guide.
Software Image Setup
The CGI Studio Community Edition supports both Raspberry Pi 4 and Raspberry Pi 5. The following section describes how you can install the Community Edition on your Raspberry Pi device. Additional information about the proper setup and configuration of a Raspberry Pi device can be found in the official Raspberry Pi documentation. It also contains information on how to get started with your Raspberry Pi device. Complete the following steps to prepare your Raspberry Pi for the installation of the CGI Studio Community Edition.
  1. Download and install the Raspberry Pi Imager from this link: Raspberry Pi software – Raspberry Pi.
  3. Open Raspberry Pi Imager and in the Device section select Raspberry Pi 4 or Raspberry Pi 5, depending on your model. Afterwards click "Next".
  4. In the menu Choose operating system select "Raspberry Pi OS (64-bit)". Then click "Next".
  5. In the storage section, select the inserted SD card, and click "Next".
  6. In the Customization step click "Next" till the "Customisation: SSH authentication" configuration occurs. Make sure that SSH is enabled.
  7. Click "Next" and write the image to the SD card. This may take some time.
Raspberry Pi Startup
  1. Insert the SD Card: Insert the flashed microSD card securely into the dedicated card slot on your Raspberry Pi board.
  2. Connect Hardware: Connect your Raspberry Pi to an external display (using a micro-HDMI to HDMI cable), plug in your USB touch interface/peripherals or connect to DSI cable, and connect the official USB-C power supply to power it on.
  3. Initial Boot & Setup: The OS will automatically begin its initial boot diagnostics. Follow the on-screen configuration wizard to set up your region, skip the Wi-Fi and connect LAN, and establish your core username and password.
  4. Boot to Desktop: Once you complete the wizard, the system will finalize its settings and boot directly into the desktop user interface.
After booting, connect to the target device via SSH or a serial terminal (e.g., Tera Term). This connection is required to transfer files and execute commands. Additional information on how to connect can be found here.
At Candera we use WinSCP to transfer additional files to the device.
Install Debian package on the Raspberry Pi
Installing the Professional Edition Debian (.deb) package, which is delivered with the installer, configures the native CGI Studio Player application and the CGI Studio Player Connector on your Raspberry Pi. This chapter outlines the process of transferring and installing the CGI Studio Professional package onto a Raspberry Pi 4 or Raspberry Pi 5 using WinSCP and a terminal connection.
    Transfer the File: Use WinSCP or SSH to transfer the downloaded .deb file to your Raspberry Pi (e.g., /home/username/). Navigate to the Directory: Use cd and verify with ls.
    Install the Package:
    sudo apt update
    sudo apt install ./cgi-studio-PE-RaspberryPi_1.0.0-arm64.deb
    The Player can now be executed using:
    /opt/candera/bin/Player
    The Blood Pressure Device sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations. General information on this sample can be found in the Blood Pressure Solution documentation.
    The Blood Pressure Sample sample is extended with a data binding programmed in Python. The Python part of the sample relies on the Python-Based Player Data Binding Library to interact with the data bindings of the scene. Once the hardware is set up follow these steps to configure the Python environment and execute the sample.
    <cgi-studio-installation-path>\bin\CommunityEdition\Python\Samples\BloodPressureDevice on the host computer and in /opt/candera/Python/Samples/BloodPressureDevice on the target, after successful installation of the debian package.
    • Move to the directory: Open the terminal on your Raspberry Pi and move to the sample directory.
    • Configure and activate the Python Virtual Environment:
      python -m venv .
      source bin/activate
    • Install Dependencies:
    • Run the Sample:
      • -wsh : Disable SoundHound integration
      • -lbp : Library binary path
      • -abp : Asset binary path
        python BloodPressureDevice.py -lbp /opt/candera/lib/libPlayerConnectorLibrary.so \
        -abp /opt/candera/Python/Samples/BloodPressureDevice/BloodPressureDevice.bin -wsh
          Verification: Upon execution, the Blood Pressure Device UI should initialize and appear on your connected Raspberry Pi display.
          NOTE: If the display is portrait mode then it needs to be rotated to landscape mode.
          Command -  wlr-randr --output DSI-2 --transform 90
    Before proceeding with the example, it is recommended to explore CGI-Studio by reading the Quick Start Guide, both of which are available in the CGI-Studio Documentation.
    • Start Scene Composer in <cgi-studio-installation-path>\bin\SceneComposer\Scenecomposer.exe
    • Next, generate an asset library for the target environment to run the solution in the player.
      • A popup window will appear, allowing you to generate the asset library. Choose your desired asset location, set the environment to “Target”, then click “Generate” to create each asset library.
      <cgi-installation-path>\bin\CommunityEdition\Pythony\Samples\SliderAndGauge\Sample.py in your local CGI-Studio installation folder and in /opt/cgistudio/Python/Samples/SliderAndGauge/Sample.py on the target.
      Ensure the device is set up correctly according to the chapter Software Image Setup. Use WinSCP or a similar tool to copy the generated target asset from the host computer to the target device.
      Run it analogous to the steps from chapter Run Blood Pressure Sample with Player Connector Library.
