Automatic Imports
If necessary, ityou is possible tocan configure monitored folders for automaticAutomatic importsImports -of both images and fbxFilmbox (FBX) files. To use thisthe featureAutomatic itImports is mandatory tofeature, enable it.Automatic Imports. This operationcan isbe possibledone in two different ways:
  1. By checkingOpen the "Enable automatic import" box in the "Automatic Imports Configuration"Configuration paneldialog (seeby theselecting imageImport below).> ThisConfigure window can be opened through the menu "Import" - "Configure Automatic Imports..."
    in the menu. In this dialog, check the Enable automatic import box.
    Each item in "the Automatic Import Configuration"Configuration dialog allowslets you toconfigure setAutomatic theImport details of automatic import.
    settings.
    Monitored Folder SetSpecifies the folder forthat monitoringSceneComposer monitors.
    Import Destination SetSpecifies the destination folder for import.imported files.
    Include subfolders Enable this optionSpecifies if youSceneComposer want toshould monitor files underin the sub-folderssubfolders of the folderselected youMonitored set as the Monitoring Folder.Folder.
    Sync on startup
    EnableSpecifies if SceneComposer should automatically sync the selected Monitored Folder when this optionsolution allowsis youopened. that
    If AutoSync on startup is enabled, the Automatic Import ]prompt dialog box will appearappears when the solution is startedopened, andallowing when this configuration is performedyou to synchronizeconfirm the monitoredimport folders.before it proceeds.
    TheSceneComposer "configurationsynchronizes ismonitored performed"folders isin the following two timming.cases:
    - EnableYou [enable Sync on startstartup ]in onthe "Automatic Imports Configuration"Configuration dialogdialog, but ifSceneComposer anyhas synchronizationnot hasn'tsynchronized beenmonitored donefolders at aduring solution startup.
    - IfYou [change Sync on startup ] is changed from disabled to enabled.
  2. By checkingOpen the "EnableSolution automaticOptions import"dialog boxby selecting File > Solution Options... in the menu. In the General Configuration sectionsection, ofcheck the "SolutionEnable Options"automatic panelimport (see the image bellow):
    box.
When the content of a folder iscontents modified,change, SceneComposer notifies you that thereimports are pendingpending, imports andoffering the user can choose tofollowing import theoptions:
new/modified
filesImport with "preview changes"changes: orSceneComposer "withoutopens previewthe changes".Import "WithoutImages preview"dialog meansgranting thatyou full control over the import cannotprocess. beImport stopped.without Withpreview "Previewchanges: Changes"SceneComposer imports the usualfiles importwithout workflowany isfurther meant.user interaction necessary.
The Scene Composer saves the configured paths are specific for each solution and are saved in
	USER_DIR\ AppData\Roaming\SceneComposer\Solutions\
When you convert a solution is converted to another version or ismigrate migratedit to another platform, the configurationsAutomatic forImports automatic importsconfiguration will not be lost.preserved.
BestAs practicea forbest usingpractice, thisconsider feature is thatconfiguring the user should configure themonitored folders that will be monitored in such a matterso that they contain either
    only contain image files or fbxonly FBX files and the images neededrequired by thethese fbx.FBX Iffiles.
    The reason for this is, if the modified files in the folder on disk containinclude aan fbxFBX file, SceneComposer performs only aan FBX import willand bedoes done,not soimport anymodified imagesimage files modified that are not neededrequired by the fbxFBX will not be imported.file.
