Import Benchmarks
RenderCGI benchmarksAnalyzer is able to calculate render benchmarks. The result is a *.crsms file that you can beexport. calculated with CGI Analyzer. As a result, a "*.crsms" file can be exported with CGI Analyzer, whichIt contains the calculated render time for each node that is part of a given scene. ImportWhen you import a "*. crsms"crsmstofile, makeCGI Analyzer makes node benchmarks available onin the Render Benchmark node propertyproperty. "RenderThe Benchmark".camera Oncerender thestrategy Benchmark supports multi-pass rendering when benchmarks are available on the nodes of a scene, the camera render strategy "Benchmark" can be used for multi-pass rendering.
OpenTo theimport "Import"a dialogbenchmark *.crsms file, select Import > Import Benchmarks from the "Import"menu >to "open the Import Benchmarks"Benchmarks menu.dialog.
PressClick the "Select Files..." button and chooseselect a "*. file from the Windows Open dialog.crsms"crsms
TheSceneComposer applies the values from the imported *.crsms file will be applied to the "Render Benchmark"Benchmark property of all nodes.
The Import Benchmarks dialog displays errors encounteredthat occur after theyou .crsms file is selected are displayed inselect the Import*.crsms Benchmark dialog.file.
MoreFor more detailed informationinformation, can be found insee CGI Studio Application Development Tutorial.
