Import from Solution
AImport From Solution is a powerful option tofor importimporting different elementsitems from a specific solution previous created in SceneComposerSceneComposer.
is
Select "Import > Import from Solution".Solution Thisin optionthe can be accessed from Import menu.menubar.
The "Import fromFrom Solution"Solution paneldialog givesguides you through the possibility to follow a successionsteps of three logical steps in order to import specific elements from a chosen solution.
Using the "Import from Solution"
The first step consists in selecting a desired solution from which the user needs to import some elements.
Choose an existed folder were the desired elements from a selected solution will be imported or create a new folder for import
Select someimporting specific elements from a selected solution.
Using Import From Solution
    Click Select. In the Windows Open dialog, select the solution that contains the items you want to import. SceneComposer loads the selected solution and displays a hierarchical list of all items that can be imported in the Import From Solution dialog. Use the drop down menu next to Import to folder to select an existing folder for the imported items. Alternatively click Browse. In the Select Location dialog you can also create a new folder using the context menu Add > New Folder. In the list of items that can be imported, select the specific items that you would like to import using the checkboxes. Click OK to import the selected elements.
    If for a selected elementitem there arehas dependent items, athis special Options button will become available. This buttoninformation is placeddisplayed aboveon the right side ofwithin the screenitem wherelist. allNext to the items arewith shown.dependencies, SceneComposer provides an Options button.
    FourClicking differentthe optionsbutton arewill available:present the following options:
    • Copy all
    • Skip all
    • Replace all existing
    • Skip all existing
    For everyeach categoryimported-item ofcategory, importedyou items it is possible tocan see theirits relationship withto existing imported items: New,New, Existing and Conflict.Conflict.
    By selectingSelect one or manymore fromShow theseoptions "Show" options, the user canto see the new items, the existing items or the conflicts between newnewly imported items and previouspreviously imported items. If there are different existing (\=) items, another "Existing"Existing button will becomebecomes available. ByClick usingExisting itto aopen "CompareImportItemsView"the Compare Items dialog willand be opened to showview the existing items.
    TheClick "Show only differences"differences button allows the user to see justonly the differences between selected items. The comparisonYou can beuse usedthe comparison in different modes. For instance,example, if the imported items are shaders, theyyou can beview seenthem in three different modes: Objects,Objects, Visual and Text.Text.
    "Conflict"Conflict button
    If there are conflicts between itemsthe aitems, "Conflict"Conflict buttonbecomes willavailable. becomeClick availIConflict waable.to By pressing itopen the "Compare Items"Items dialog will be opened and show all the existing conflicts will be shown.conflicts.
    The status'status signs showindicate the nature of everyeach conflict. IfWhen theyou "click Show only differences" button is pressed,differences, the dialoguedialog willshows only show the conflicts. IfWhen you click the button isagain, released,the dialog shows all theitems. itemsWhen willyou be shown. Ifselect a conflictconflict, isthe selected,dialog shows all the properties and their differences will be shown.differences.
