AI Service
On this panel, you configure the connection that the AI features in Scene Composer use.
The features concerned are the Docs Agent panel and Search Helper. These features send questions and instructions to the AI service and receive answers. On AI Service, you configure how Scene Composer connects to Candera Operator, which relays that communication.
Every setting has a default value, and the features normally work with these defaults. You do not need to change them. Change a setting only when a connection problem occurs, or when you must specify the connection target explicitly.
Prerequisites
Candera Operator requires .NET Runtime 10.0. The CGI Studio installer does not include it, so install it beforehand. If it is not installed, the requirements check dialog that appears when you start Scene Composer lists it as a missing item.
Settings
With Local, Scene Composer starts the Candera Operator process and connects to it. With Network, Scene Composer connects to a Candera Operator that already runs. Depending on your selection, the panel shows either Executable Path or Host URL. Executable Path
Appears when Mode is set to Local.
Specifies the path to the Candera Operator executable. You can also select the file with Browse....
Host URLAppears when Mode is set to Network.
Specifies the Candera Operator to connect to, as a wss:// URL. You can specify only localhost or 127.0.0.1.
Choosing a Mode
Local
Scene Composer starts the Candera Operator process from the executable that you specify in Executable Path, and connects to it on the port number that you specify in Port. Use this mode under normal circumstances.
Network
Scene Composer connects to a Candera Operator that already runs. It connects to the host that you specify in Host URL and the port number that you specify in Port. In this mode, you do not specify an executable path, and Scene Composer does not start the Candera Operator process.
You can specify only localhost or 127.0.0.1 as the connection target. You cannot connect to a Candera Operator that runs on another machine on the network.
The target Candera Operator does not require a HASP key. The Scene Composer that connects to it holds the HASP key that the authentication uses.
About Candera Operator
Candera Operator is a server that relays the communication between the AI features in Scene Composer and the AI service. It runs as an application separate from Scene Composer.
The AI features never connect to the AI service directly. They connect to Candera Operator first, and Candera Operator relays the communication with the AI service. Because all AI features share the same relay point, they use a single authentication method and a single communication method. The authentication relies solely on the HASP key, and the product embeds no API key. In addition, Scene Composer sends only the identifier of the HASP key for the authentication; it never sends the key itself.
Scene Composer starts Candera Operator automatically. It starts Candera Operator when you send the first question or instruction to an AI feature.
Do not start Candera Operator manually. A manually started process conflicts with the process and the port that Scene Composer starts, and the connection fails.
Troubleshooting
Client could not connect!
Scene Composer cannot connect to Candera Operator. Check the settings on Environment > AI Service, and then test the connection with Test Connection. Also check that .NET Runtime 10.0 is installed.
