Easy Mode
Easy Mode isprovides a featureconfigurable thatinterface for managing the properties of individual elements. It allows you to customize the properties of each element. For example,hide unused properties can be hidden in the properties panelpanel, tohelping organizestreamline workflows when working with a large numberset of properties.attributes. YouIn canaddition, alsoEasy export/importMode customizedsupports propertyexporting and importing custom property-configuration files.files, This allowsenabling each user (designer,such programmer,as etc.)designers or developers) to useapply the most appropriate property configuration file.that best fits their role or workflow.
This feature was implemented in CGI Studio 3.12 and earlier as a function to generate Easy Mode configuration files using the "SceneComposerConfigurator.exe" file. From CGI Studio 3.13 onward, this has been updated to make it easier than ever to set Easy Mode from "Preferences" in Scene Composer.
Target Elements
The following elementselement cantypes havesupport theirproperty properties customizedcustomization in Easy Mode.Mode:
  • Behavior
  • Effect
  • Node(Node 2D、2D, Node 3D)
Customizable Items
The following propertiesproperty aspects can be customized.configured in Easy Mode:.
  • Visibility (show/hide- Specify whether a property is shown or hidden in the properties panel)
    panel.
  • Read-only
    - Define whether a property can be edited by the user.
  • Initial Value - Set the default value (initialapplied valueto ofthe aproperty property)when an element is created.
ItemsThe set of customizable propertiesproperty differoptions forvaries eachdepending on the specific property.
Customizing properties
  1. Open the Preferences dialog fromby [selecting  File > Preferences...] onfrom the menu bar.
  2. In Preferences dialog, selectnavigate [to Environment > Easy Mode ].
  3. Select the properties ofChoose any element and setcustomize its properties by adjusting any of the visibility/read-only/defaultfollowing valuesoptions: for
    the
  4. Visibility
properties.
Read-only Initial Value
ExampleThe ofimage settingabove shows how to set the initial value of TextNode2D's Text property to "Default text".
Export/Export and Import
    Export
    The configuration of each property itemconfigurations setdefined in the Preferences dialog can be exported as an XML file. ExportTo is performed by clickingexport the [current Easy Mode settings, click the Export ]button buttonlocated in the upper right corner of the Preferences dialog.
    Import
    You can import a previously exported XML file by clicking the [ Import ] button in the upper right corner of the Preferences dialog.
    Restore defaults
    The [ Restore defaults ] button in the lower upper-right corner of the Preferences dialog restores(see eachimage propertybelow). that
    Import
    To hasimport alreadya beenpreviously setexported XML configuration file click the Import  button in the upper-right corner of the Preferences dialog.
    Restore defaults
    Clicking the Restore defaults button in the lower-right corner of the Preferences dialog resets all previously customized properties to thetheir original default settings.
    Clicking [ Restore defaults ] button will return to the default settingsrevert all property entriessettings for all elements.elements Pleaseback to their default values.
    Use this function with caution, as all customized configurations will be careful when executing this function.lost.
