Create Nodes
Create Nodes from Toolbox
DragYou ancan itemcreate new nodes by dragging items from the Toolbox and dropdropping itthem into the following locations:
eitherScene Tree - Inserts the node into theScenedesiredTreepositionto sort the node properly intowithin the scene graph hierarchy.or directly into the render view of theScene Editorto(RendercreateView) - Creates the nodeonatathe specific displaycoordinate.coordinates where it is dropped.
When adding a node to the scene tree, notekeep the following:following behaviors in mind:
- Default Placement
The new nodewill beis created as the last child of the nodeononto which the node is dropped. ToRepositioning
Youmodifycanthedragsceneandtreedropstructure,nodeshold the "Ctrl" key while moving the node alongwithin the scene tree to modify thedesiredhierarchy.position.WhileThedragging,draggeda blue selection line indicates whether the node will bepositionedplacedbelowasthechild of another nodeitorwasbetweendroppedtwoon.existing nodes.Moving a node along the scene tree without keeping the "Ctrl" key pressed will move the selected node inside the node it was dropped on.
- Default Placement
Create Nodes from Imports
DragYou ancan itemcreate nodes by dragging items from a user-defined importimports (a template scene node)nodes) and dropdropping itthem tointo Scene Editor or the Scene Tree.Tree.
Creating Nodes in Scene Editor:Editor
Drag Drop thea template scene node infrom the Imports panel and drop it into the Scene Editor to create an instance of thisthat node at the givendrop location. The new scene node will beis created at the top level of the scene graph.
Creating Nodes in the Scene Tree:Tree
Alternatively, Asyou ancan alternative,drag thea template scene node from Imports canand alsodrop beit droppeddirectly into the Scene Tree. This allows you to the Scene Tree. This way it is possible to hierarchically sortplace the new node intowithin the desired position of the scene graph.graph hierarchy.
When dropping Bitmaps from Imports
canintoonlyeitherbethedroppedSceneonTreean already existing RenderNodeorBitmapNode.theInScenethis case,Editor, aBitmapBrushAlphaBlendRenderNode2Deffect will beis createdonautomatically. This node is initialized with a BitmapBrushBlend effect thatnode referencingreferences thegivenselected bitmap.
When adding a node to the scene tree, note the following:
Properties of Nodes Created from Imports
All node properties of a selected node are displayed in "Properties" panel.
For nodes created from imports, additional properties are available:
