Scene Tree UI
This section explains the User Interface of the Scene Tree panel.
| No. | Name | Description |
| 1 | Navigation buttons |
The left and right arrow buttons allow you to navigate backward and forward through the history of opened scenes and controls. Clicking the small triangle located at the bottom-right corner of either arrows opens the display history, enabling quick access to previously viewed scenes. These buttons are disabled when no backward or forward navigation history is available |
| 2 | Lock button |
Clicking this button locks the selected node in the scene tree. For additional details, refer to here. When a node is locked, a lock icon appears next to it, and all child node icons are displayed in grey to indicate their locked status. |
| 3 | Rendering button |
This button is used to control whether the selected node is rendered at design time and run time. When rendering is disabled for a node, all of its child nodes are also excluded from rendering. When rendering is disabled for a node, a rendering disabled icon is displayed next to it. |
| 4 | Transparency |
This function allows you to set the local alpha transparency (Alpha Value) of the selected node and all of its child nodes. The resulting transparency is calculated by combining the node's local alpha value with the alpha value defined in its material settings, producing the effective alpha used during rendering. |
| 5 | Search field |
The search field allows you to search for items in both the scene tree and the extra scene tree. Nodes that match the entered keywords are automatically highlighted, making them easier to locate. |
| 6 | Scene tree |
The scene tree displays all nodes that make up the scene shown in the Scene Editor panel. The nodes are organized hierarchically, reflecting the structure of the scene. |
| 7 | Extra scene tree | The extra scene tree displays the behaviors assigned to the currently selected node. This allows you to inspect and manage behavior-related settings independently from the main scene hierarchy. |
| 8 | Rendering disabled icon |
When rendering is disabled using the Rendering button, a rendering disabled icon is displayed next to the corresponding node. |
| 9 | Lock icon | When a node is locked using Lock button, a lock icon is displayed next to that node. If the locked node has child nodes, they are also be displayed with a greyed-out lock icon to indicate that they belong to the locked hierarchy. |
| 10 | Annotation |
The status of each node is indicated using four-colour icons, each representing a different type of annotation:.
| 11 | Fusion | Clicking this button opens the Fusion panel displaying the Fusion diagram for the node currently selected in the scene tree. |
