Scene Tree UI
This section explains the User Interface of the Scene Tree panel.
No. Name Description
1 Navigation buttonbuttons
This button is enabled when multiple scenes are displayed.
The button has a back (left arrow)and right arrow buttons allow you to navigate backward and forward (rightthrough arrow)the function.
history of opened scenes and controls. Clicking the small triangle buttonlocated at the bottombottom-right rightcorner of eacheither arrowarrows button displaysopens the display history.history, enabling quick access to previously viewed scenes.
These buttons are disabled when no backward or forward navigation history is available
2 Lock button
ThisClicking this button islocks enabledthe when aselected node is selected in the scene tree.
Pressing the button locks the selected node. For additional details, please refer to here. When a locknode is set,locked, thea lock icon isappears displayed.next Theto it, and all child node icons will beare displayed in grey.grey to indicate their locked status.
3 Rendering button
This button is enabledused whento acontrol whether the selected node is selected in the scene tree.
This button is used to set whether or not the node will be rendered at design-design time and run-time.run Iftime. When rendering is disabled,disabled for a node, all of its child nodes willare also notexcluded befrom rendered.rendering. IfWhen rendering is disabled,disabled thefor a node, a rendering disabled icon willis bedisplayed displayed.next to it.
4 Transparency
This function isallows enabledyou whento a node is selected in the scene tree.
This setsset the local alpha transparency (Alpha Value) of the selected node.node and all of its child nodes. The effectiveresulting transparency is calculated by combining the node's local alpha value is combined with the material alpha value ofdefined in its material settings, producing the node.effective alpha used during rendering.
5 Search field Searches
The search field allows you to search for items in both the scene tree and the extra scene tree and extra scene tree.. Nodes containingthat match the inputentered keywords are highlighted.automatically highlighted, making them easier to locate.
6 Scene tree
The scene tree displays all nodes that make up the scene displayedshown in the Scene Editor panelpanel. The nodes are displayedorganized inhierarchically, areflecting tree.the structure of the scene.
7 Extra scene tree The behaviourextra setscene fortree displays the behaviors assigned to the currently selected node. isThis displayedallows here.you to inspect and manage behavior-related settings independently from the main scene hierarchy.
8 Rendering disabled icon
IfWhen rendering is disabled using the Rendering button,button, thea rendering disabled icon willis bedisplayed displayed.next to the corresponding node.
9 Lock icon IfWhen thea node is locked using Lock button,button, a lock icon willis bedisplayed displayed.next to that node. If the locked node has child nodes, thesethey willare also be displayed with a greyed-out lock icon (greyedto out).indicate that they belong to the locked hierarchy.
10 Annotation
The status of each node is displayedindicated using four-colour icons.icons, each representing a different type of annotation:.
  • Orange :- If aThe node has a behaviourbehavior setassigned.
  • Blue :- If aThe node has an animation property setset.
  • Yellow :- IfA a script is setassigned forto the nodenode.
  • Red :- IfAn anerror, error/warning/warning or message is displayedassociated forwith athe nodenode.
11 Fusion DisplaysClicking this button opens the Fusion panel displaying the Fusion paneldiagram for the node currently selected in the scene tree.
