View Definition Editor
View Definition Editor lets you define “screen-level Views” by combining Scenes created in SceneComposer with existing Views, and make those definitions available to the View Tree, the State Machine, and the Action Chain Editor.
Only Views appear as nodes in the tree of the View Definition Editor panel. A Scene with IsView=true can be referenced as a View on its own, so when you want to compose a screen from a single Scene, you can place that Scene directly as a View. When you want to build a screen that bundles multiple display elements, create a Composite View and combine Scenes with IsView=true or other Views as its components. For details, see View composition later in this document. With this structure, the state machine can consistently treat “which screen (View) to activate” at the View level, while still incorporating Scene-based content into the screen composition.
View Definition Editor UI
Panel layout
Double-click any View in Solution Explorer to open the View Definition Editor panel.
UI item Description
View Composition pane (orange frame in the figure above)
Lists which Scenes/Views the selected View is composed of. Add or remove Scenes and existing Views by drag and drop.
Preview area (red frame in the figure above)
Displays preview images of the Scenes/Views associated with the View in the right pane, where you can also adjust their layout positions. Useful for improving visual identification when referencing this View from the State Machine or View Tree.
Basic operations
This section outlines common procedures for defining and editing Views with the View Definition Editor.
For instructions on creating a View, see the View feature overview page.
View composition
In the View Definition Editor panel, you can use the tree structure to edit or delete child Views under the currently opened View. You can also review the entire tree rooted at that View on the tree, including the hierarchical relationships of its child Views and their descendant Views.
The composition editing described here applies to Views created as Composite Views. A Scene with IsView=true is treated as a standalone single-screen View, so you cannot edit its tree structure or add child elements in the View Definition Editor (it is always treated as a leaf node).
  1. In the Solution Explorer, double-click the View (Composite View) whose composition you want to edit.
  2. In the View composition pane, edit the elements to include in the View.
    • You can drag and drop a Scene with IsView=true or an existing View from the Solution Explorer to add it.
    • To remove an unnecessary element, select it and then select Delete from the context menu.
Behavior When You Drag and Drop a Scene with IsView=true
Only Views appear as nodes in the tree of the View Definition Editor panel. However, because a Scene with IsView=true is treated as a View on its own, you can add it directly to the tree.
  • When you drag and drop a Scene with IsView=true from the Solution Explorer onto the composition pane of the Composite View open in the View Definition Editor, the Scene is added as a child element.
  • A Scene with IsView=false is not included as a View candidate, so you cannot drag and drop it onto the composition pane. You must first select IsView in the Properties panel.
With this mechanism, the View Definition Editor tree can consistently treat the unit of screen transitions and visibility control as Views, while still allowing you to build Scene-based content within those Views.
Grandchild View
In the View Definition Editor panel, a single operation can add only "a child View one level below the View you have opened." To build structures with three or more levels — such as parent View > child View > grandchild View — start from a Composite View (a View that bundles multiple Views).
  • Place Composite Views at the parent and intermediate levels (because they are not leaf nodes, they can hold child Views beneath them).
  • A Scene with IsView=true is always treated as a leaf node and cannot be used as an intermediate node in a grandchild hierarchy.
Using a View that meets these requirements as the starting point, create a three-level structure (Parent View > Child View > Grandchild View) as follows:
  1. Open the View you want to use as the parent level, and add a child View under it (Parent View > Child View).
  2. Double-click the View you added as the child View in step 1 to open it, and then add another View under it as its child (Child View > Grandchild View).
After performing these steps, reopen the original parent View. You can then confirm in the tree that a three-level hierarchy (Parent View > Child View > Grandchild View) is displayed.
