Image Update
Image Update
This feature allows you to update an entire folder including all subfolders and images in a single operation rather tan updating individual image files separately. Using Image Update, SceneComposer preserves the folder hierarchy of the imported folder and applies it to the Solution Folder defined in the solution.
Select Import > Image Update... in the menu to open the Image Update dialog.
In the Image Update dialog's Solution Folder drop down menu, select the solution folder containing the images you want to update. Click Select Update Folder..., then select the folder that contains the replacement images and click OK. SceneComposer shows a warning if the folder is empty or does not contain any images.
Click Read Folder to scan the selected folder and its subfolders recursively for images to import. This may take several minutes for large amounts of images. The result of this scan is displayed in a table directly below.
You can filter the images displayed in the table. Select a search criterion from the Search by drop-down menu to specify the column to search. Then, enter a search string in the text field to the right. SceneComposer displays all matching results.
The following options are available in Search by:
  • Image to update: The image's relative path in the SceneComposer solution.
  • Status: The status of the image.
  • Update with: The image's relative path on the storage device.
Check Add new images to add newly found images to the solution. Clear Add new images to update only existing images.
Click Save Report... to save the image comparison results as a comma-separated values (CSV) file. In the Save Image Update Report dialog specify the file name and location for the report.
If the update folder contains fewer images than the solution, SceneComposer updates only the images found in the selected folder. Images that are not found are listed as Missing images in the report and are not modified by the update process.
Summary of the update process
After the images have been updated, SceneComposer displays a summary of the actions performed in the Image Update Summary dialog. Click Save Report... to save this summary as a comma-separated values (CSV) file. In the Save Image Update Summary Report dialog specify the file name and location for this report.
