Import Raw Resources
To import any type of raw resource, select Import > Import Raw Resources... from the menu bar.
You can import raw resources in SceneComposer by dragging them onto the Solution Explorer panel.
In the Import Raw Resources dialog, click the Select Files... button. SceneComposer opens the Open File dialog. In this dialog, select one or more raw resources to import, then click OK.
Click Save Report... to save the content of the Comparison tab in CSV (Comma Separated Values) format. In the Save As dialog, enter a name and select the location for the CSV file.
For a description of the Import Raw Resources dialog's checkboxes, refer to Import Dialog Options.
To  compare new content with already imported resources, right-click a raw resource, to open the Compare Properties dialog.
Problems: Import Conflicts
SceneComposer's Problems panel lists potential import conflicts.
Dependency errors occur during import if you check the Delete existing items in destination folder checkbox and this destination folder contains items that are used in the solution.
