Figma
Smart Importer can import Figma data. This page explains how to import Figma data with Smart Importer and how to work with the results.
You cannot import Figma data for which you do not have editing privileges.
Preparations for Importing Figma Data
Preparing the URL and Access Token
Before you import Figma data with Smart Importer, acquire the URL and access token for the Figma data.
Obtain the URL and access token in the Figma Desktop App as follows.
Ensure that you have access to the Figma REST API (https://api.figma.com). In case of a connectivity issue, contact your IT department because a firewall might block the API.
Acquiring the URL
In the top bar of the Figma Desktop App, right-click the relevant project tab, and then select Copy Link from the context menu.
Acquiring the Access Token
  1. In the Figma Desktop App, select Figma Icon > Help and Account > Account Settings to open the dialog.
  2. In the Security tab of the dialog, click Generate new token under Personal access tokens.
  3. In the Generate new token dialog, set the Token name, Expiration, and Scopes, and then click Generate token.
  4. Figma displays the created access token under Personal access tokens on the Security tab of the dialog.
The instructions on how to obtain the URL and access token apply to Figma Desktop App version 125.10.8.
How to Import Figma Data
  1. From the Scene Composer toolbar, select Import > Smart Importer > From Cloud Resource...
    • Scene Composer displays a new dialog titled Import from cloud resource.
  2.  Enter the URL and access token in the respective fields and click OK. For information about acquiring the URL and access token, see Preparing the URL and Access Token.
  3. The Smart Importer dialog opens. The procedure for using Smart Importer is the same as for other file types.
  4. Adjust the necessary settings, and then click OK.
    • Smart Importer imports the data into the folder that you specified in Import to folder.
      If you entered an incorrect or invalid URL or access token in the Import from cloud resource dialog, Smart Importer stops the import and displays the following error dialog.
API access limits vary depending on your subscription plan. If your API requests exceed that limit, Smart Importer stops the import and displays the following error dialog. For details on each plan, see Figma’s official website.
Importing Figma Data - Advanced
Importing as a scene
Smart Importer imports the topmost item of each page in the Figma data as a scene.
Use the following naming : <Page name>_<Parent item name>
Relationship between Figma items and Scene Composer Nodes
When you import Figma items with Smart Importer, Smart Importer imports each item as a specific type of node, as shown in the following table.
Scene Composer node type
Group Bitmap Text
Figma item type
Component ✓
ComponentSet ✓
Ellipse
Frame ✓
Group ✓
Instance ✓
Line
Polygon
Rectangle
Section ✓
Slice
Star
Text
Vector
Smart Importer imports bitmap and text items only when Figma provides their render data. For example, if you set a Figma item to hidden, Smart Importer cannot import it.
Importing as Controls or Bitmaps
Smart Importer can import any Figma item as a control or bitmap. The imported item can contain the following child items:
  • Component
  • ComponentSet
  • Frame
  • Group
  • Instance
  • Section
Importing as a control
Smart Importer imports an item as a control when the name is SC_<control name>. You can also specify control property values by naming child items after the corresponding control properties. If a child item name matches a control property name in Scene Composer, Smart Importer can automatically map the bitmap from the Figma file to that property.
For example, Scene Composer's CheckBox control provides multiple image properties. When a Figma file contains an item named SC_CheckBox with child items whose names match these properties, Smart Importer automatically assigns the corresponding bitmaps to the correct control properties (see the image below). This way, no manual assignment of image properties is necessary in Smart Importer.
Smart Importer supports this functionality only for Touchable and Common controls.
Importing as bitmaps
Smart Importer can import group items that contain child items as bitmaps when you prefix the group item name with SC_Bmp.
Import as a State Machine
When you define flows (screen transitions) in Figma, Smart Importer imports the structure of screen transitions into Scene Composer as a state machine.
You can review the imported state machine in the State Machine Editor in Scene Composer.
Figma Settings: Scenes and Flows
In Figma, define multiple scenes and the flows that connect them. Create screen transitions beginning with the scene designated as the flow start point.
The Import Result in Scene Composer
Smart Importer imports the flow structure defined in Figma into CGI Studio as a state machine.
The state machine starts from the state that corresponds to the scene that you set as the flow start point in Figma. After importing, for each generated state, Smart Importer automatically creates a screenshot of the corresponding Figma scene. Scene Composer's State Machine Editor displays this screenshot as a Scene Image.
If a Figma file contains multiple flows, Smart Importer imports each flow as an independent state machine.
If you include a transition from one flow in a separate flow (that is, when a transition is duplicated), Smart Importer does not import the separate flow.
Names and Behavior After Importing as a State Machine
  • Names After Import
    • The name of the state machine after import is StateMachine<Flow Name>.
    • After import, each state has the same name as the Figma item that Smart Importer imports as a scene.
  • In Figma, you can select the interaction that triggers screen transitions, such as click, drag, or mouse over.
    Regardless of the interaction that you defined in Figma, Smart Importer sets Scene Composer's Transition properties as follows:
    • Event: `Clicked`
    • Condition: `Check Click`
Importing a Layout
Auto layout
If you set Auto layout on a Figma Frame, Smart Importer imports the frame as a Stack Layout in Scene Composer and applies each Auto layout setting as a Stack Layout property.
Smart Importer applies Figma Auto layout settings as properties of Scene Composer's Stack Layout:
Auto layout
(Figma)
Stack Layout Properties
(Scene Composer)
1
Direction
Stack Layout
Layouter > Arrangement
Direction Arrangement
Vertical layout Vertical
Horizontal layout Horizontal
Wrap
2
Gap
Each node after the first node in the Stack Layout
Layout > Margin > Left or Top
Direction Margin
Vertical layout Top
Horizontal layout Left
Wrap
3 Alignment
Nodes included in a Stack Layout
Layout > VerticalAlignment and HorizontalAlignment
4 Padding (Horizontal)
The node to be placed at the leftmost position of the Stack Layout
5 Padding (Vertical)
The topmost node in the Stack Layout
Layout > Margin > Top
The following example shows how Scene Composer's Stack Layout inherits Figma's horizontal Auto layout settings.
Text Layout
When Smart Importer imports a Figma text layer into Scene Composer, it creates a Group node with LayoutType Overlay, and additionally a TextNode under that group.
In addition, Scene Composer's TextNode layout property inherits the Typography Alignment settings from the Figma text layer.
Importing Fonts
When importing Figma data with Smart Importer, you can import any fonts that are used in the Figma design but are not available in the current Scene Composer solution.
During import, Smart Importer compares the fonts used in the Figma design with the fonts available in the solution. If it detects a missing font, Smart Importer opens the Smart Importer dialog and displays font-selection options.
In the Smart Importer dialog, select one of the following options for each missing font:
  • Replace it with an existing font (select an existing font from the dropdown menu)
  • Import the font as a new resource (select Import from the dropdown menu)
If you select Import, Smart Importer adds the corresponding font to the solution and stores it in the Resources\Fonts folder.
If you select an existing font, Smart Importer applies that font to the imported data.
In the Smart Importer dialog, Smart Importer displays the Import option for each font in the dropdown menu only when it can import the corresponding font.
If the Resources\Fonts folder does not exist in the solution, Smart Importer automatically creates it.
Automatic Text Mapping
During the import of Figma data, Smart Importer can compare the TextNode content with the Language Table and automatically assign matching Text IDs. Previously, you had to manually assign a Text ID to each TextNode after import. This feature enables automation of the mapping process.
Smart Importer compares the displayed text Strings in the Figma data with the Master Language Strings in the Language Table. If it finds a matching String, it automatically assigns the corresponding Text ID for that String.
Configuration
Enable or disable this feature in the Smart Importer dialog under the Import Settings tab using the Map language table to texts option. Smart Importer enables this setting by default.
Behavior
The feature workflow includes the following three steps: Smart Importer retrieves the text, compares it with the Language Table and assigns the Text ID.
  1. Smart Importer retrieves the text String from the TextNode
    In the following example, it retrieves the String "TEST".
  2. Smart Importer compares the retrieved String with the master language in the Language Table
    In the following example, it compares the String retrieved in step 1 with the master language [00] in the Language Table.
  3. If Smart Importer finds a match, it assigns the Text ID
    In the example below, it assigns the Text ID of the matching Language Table entry to the TextNode
If multiple Text IDs exist for the same text String, Smart Importer uses the first matching Text ID.
If there is no matching text String, Smart Importer does not assign a Text ID.
